[petsc-dev] Possible bugs when using TS with ViennaCL (continued)
Karl Rupp rupp at mcs.anl.gov
Tue Jan 28 10:12:59 CST 2014
Hi Mani,
 > Thanks for the explanation. Do you think it will help if I use a GPU
> which is capable of doing double precision arithmetic?
Your GPU must be supporting double precision, otherwise the jit-compiler
will fail. However, your GPU might emulate double precision arithmetics
poorly.
> I am using NVIDIA Quadra FX 1800 M. It has 1GB of global memory.
For production runs you definitely want to use a discrete GPU to get the
benefits of higher bandwidth (through higher heat dissipation...)
> Unfortunately NVIDIAs' visual profiler does not seem to work with its
> OpenCL implementation. The code does not crash when I run it on the CPU
> using Intels OpenCL.
Let me put it this way: This ridiculous move of taking OpenCL debugging
capabilities out when releasing CUDA 5.0 is not based on scientific
reasoning...
> I mean't to say that the code does not crash either with
> ComputeResidualViennaCL or ComputeResidual with the normal Petsc
> Vec/Mats but does indeed crash when either of them are used with the
> ViennaCL vecs.
I'm wondering how ComputeResidualViennaCL will work if the vector type
is not AIJVIENNACL?
> Do you think there is memory allocation at every time
> step? I thought all the memory would be allocated during initialization.
 From your description a memory allocation seems to be the case, yes,
but I still need to verify this. Did you see a similar increase in
memory consumption (use e.g. top) with Intel's OpenCL SDK?
Best regards,
Karli
