[petsc-dev] Cell overlap in DMPlexDistribute
Michael Lange michael.lange at imperial.ac.uk
Tue Jan 28 08:57:43 CST 2014
I noticed that the cell overlap created during DMPlexDistribute does not
include cells that only share a vertex but no edge with an owned cell.
This causes problems when performing local assembly
(MAT_IGNORE_OFF_PROC_ENTRIES) based on information from the plex,
because one contribution to the shared vertex is missing.
As an example consider the 2x2 square with 8 cells (attached). When
partitioned across two ranks with overlap=1 each rank owns 4 cells and
in the current version knows about 2 halo cells, giving a total of 6
cells. The central vertex, however, touches 3 owned and 3 non-owned
cells, one of which doesn't share an edge with any owned cells. So, in
order to correctly assemble the central vertex locally, the rank owning
it needs to know about 7 cells in total.
I have attached a patch that fixes this problem by going over the
inverse closure of all vertices associated with a given cell instead of
using the provided edge graph. Please tell me what you think and whether
there might be an easier way to fix this.
Kind regards
Michael Lange
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140128/735c9383/attachment.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140128/735c9383/attachment-0001.bin>
