[petsc-dev] Possible bugs when using TS with ViennaCL
Karl Rupp rupp at mcs.anl.gov
Mon Jan 27 15:48:47 CST 2014
Hey,
>> For the sake of completeness of this thread:
>> Mani's build included
>> --with-threadcomm --with-pthreadclasses --with-openmp
>> which seems the be the cause of the problem. Without these flags,  the
>> problem disappears and results are correct. If I remember correctly,
>> this is a more fundamental problem in threadcomm rather than specific to
>> the ViennaCL bindings, yet we clearly need to fix it.
> [repost from petsc-maint]
> Evidently threads are a liability right now.  Do you know what caused
> this behavior so we can avoid it in the future?
Unfortunately I don't know what exactly is causing the problem. My best
guess is that one of the sys-calls inside threadcomm is in conflict with
the internals of the OpenCL runtime. I'll see whether I can reproduce
this on my machine, then I can incrementally disable parts of threadcomm
until I found the cause.
Best regards,
Karli
