[petsc-dev] configure failed after update of OSX
Mon Jan 27 12:57:25 CST 2014
On Jan 27, 2014, at 11:44 AM, Sean Farley <sean.michael.farley at gmail.com> wrote:
> bsmith at mcs.anl.gov writes:
>>  I think resolved it by getting rid of some stuff that macports put in maybe
> I just *completely* revamped the mpi ports in macports and would like to
> know if these types of problems still exist.
  Sean,
    It wasn’t the MPI ports in macports. It was MPICH’s regular configure/make making mistakes because of some libraries in those directories that did not have corresponding .la files.
   Barry
>>  MPICH or libtool assumes certain files are there if other files are there (without checking for them)
>>   Barry
>> On Jan 27, 2014, at 10:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Mon, 27 Jan 2014, Jed Brown wrote:
>>>> Mark Adams <mfadams at lbl.gov> writes:
>>>>> It seems to want /opt/local/lib/liblzma.la
>>>>> I do have /opt/local/lib/liblzma.a
>>>> There is no explicit reference to liblzma in either PETSc or MPICH.  Can
>>>> you send PETSC_ARCH/externalpackages/mpich*/config.log?
>>> Ah - perhaps its a buggy libtool. Presumably its picked up from
>>> /opt/local/bin/libtool - aka macports - and you have a broken macports
>>> install.
>>> Satish
