[petsc-dev] DMplex reader / viewers
Jed Brown jed at jedbrown.org
Wed Jan 22 16:07:58 CST 2014
Brad Aagaard <baagaard at usgs.gov> writes:
> I agree that one would probably not visualize "checkpoint" files nor
> restart from "visualization" files. I wasn't able to follow where the
> discussion separated these issues. Is the DMPlex I/O targeting
> checkpointing and ExodusII/HDF5/etc targeting viz?
All the existing formats are targeting viz.  I think it's cleaner to
have only one IO mechanism that needs to be optimized, but viz plugins
are inconvenient at present and support for mock-in-situ (viz
application uses application to load and compute derived quantities) is
sorely lacking.  There is a relevant DOE call out now with preproposals
due next week.  If this is important and we can organize a plan of
action, it may be worth submitting a preproposal.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140122/efc90a40/attachment.sig>
