[petsc-dev] resurrecting the finite element energy functions thread
Jed Brown jed at jedbrown.org
Tue Jan 21 12:04:58 CST 2014
Geoffrey Irving <irving at naml.us> writes:
>>> It isn't, the only difference is that the function I'm imagining needs
>>> an extra quadrature rule argument.  Nothing here is complicated, so if
>>> there are no particular opinions I'll write the function and send a
>>> patch.  Can I write it hard coded to MPI_SUM first, and we can discuss
>>> how to generalize it after that?  I am less clear on how to best write
>>> the generalized version.
>> That's fine with me.
> Should the result be an array of PetscScalar or PetscReal?  My
> application is for objectives, so PetscReal, but PetscScalar is more
> generic.
I would use PetscScalar.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140121/d3c4bff5/attachment.sig>
