[petsc-dev] PCASM+KSPGMRES
Karl Rupp rupp at mcs.anl.gov
Tue Jan 21 15:38:19 CST 2014
Hi Andrea,
 > sorry to bother you with this again, but can you please give me a final
> word on whether KSPGMRES in combination with PCASM is currently supposed
> or not to work with MATMPIAIJCUSP on multiple-GPUs as it does (that I
> can clearly see) on 1 GPU? Do you have a test for that?
There are certainly examples around which allow this functionality, but
multi-GPU algorithms are not routinely tested yet.
> Again, for what I can see, residuals are inconsistent with 1 or more
> GPUs and you don't get the same discrepancy with, for instance, PCJACOBI
> (same exact residuals on single and multi-GPU). This makes me think
> (maybe wrongly) that my part of the interfacing with PETSc is right.
Do you happen to have a simple example to reproduce? Which runtime
options do you use/set? I'll try to reproduce this tomorrow.
Best regards,
Karli
