[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown jed at jedbrown.org
Sun Jan 19 21:29:41 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>      Where should we put the files that end up in conf? Should we
>      simply not install those?
I don't think we should install logs.  If it were up to me, I would put
the makefiles in $prefix/share/petsc/, but I would install a script
petsc-config that can be used to dump the configuration as well as
provide configuration (a la pkg-config).  I think we should recommend
that users use this petsc-config script instead of including makefiles.
What do you think?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/1f77cffe/attachment.sig>
