[petsc-dev] Matt, please don't put buggy code into PETSc
Jed Brown jed at jedbrown.org
Sun Jan 19 18:16:08 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
> On Sun, Jan 19, 2014 at 4:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> src/mat/examples/tests/ex18.c
>> passes a PetscScalar to VecNorm.
> I missed it when I went over the example, and C does not check
> typedefs, only the underlying type.
You have to do a build with complex.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/f96d3708/attachment.sig>
