[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown jed at jedbrown.org
Sun Jan 19 14:15:16 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
>> I'm inclined to do this because it's less code and simpler logic, thus
>> the easiest to explain.  If they don't set CFLAGS, of course we have to
>> automatically choose reasonable defaults based on --with-debugging.
> I think changing to this is worse than what we currently have.
Why?
I just talked to Brad and he mentioned that he tried to use CFLAGS and
the optimization flags were masked.  If COPTFLAGS is not clear to an
expert like him, something is wrong with what we have.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/61d0690f/attachment.sig>
