[petsc-dev] [petsc-users] PETSc/VC12 compilation
Tue Jan 14 13:16:17 CST 2014
    Hmm, if the user provides --with-cc='win32fe cl’  shouldn’t we automatically add --with-cxx='win32fe cl’ as well?
It does not harm (right?) and will prevent this from hitting other people in the future.
   Barry
Request-assigned: balay automatically add --with-cxx='win32fe cl’  if --with-cc='win32fe cl’ is provided?
On Jan 14, 2014, at 10:37 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Try adding configure option: --with-cxx='win32fe cl'
> Satish
> On Tue, 14 Jan 2014, Abilash Nair wrote:
>> Hello all,
>> I am trying to build petsc to use as a library on a visual C++ project.
>> I configured the petsc (v3.4.3) with VC++ 2012 under the shell provided by
>> VC2012 with the following command (in cygwin):
>> ./config/configure.py --with-mpi=0 --download-f2cblaslapack=1 --with-fc=0
>> --with-cc='win32fe cl' --with-debugging=1
>> then I did a make all; make test while still in cygwin. I have sent the log
>> file outputs from these commands. As the files show, I am able to make with
>> no errors at all, however I am unable to execute any of the tests (error
>> being that a libstcc++.lib not found).
>> I hope you would be able to suggest a path forward.
>> Thanks!
>> Abilash.
