[petsc-dev] [GPU] Crash on ex19 with mpirun -np 2 (optimized build)
Projet_TRIOU triou at cea.fr
Tue Jan 14 10:15:06 CST 2014
On 01/14/14 16:41, Karl Rupp wrote:
> Hi Pierre,
> > I try running in parallel the ex19 test case on CPU and GPU:
>> OPT="_opt"
>> dir=/ccc/cont002/home/den/triou/Version_test_airain-hybrid/Trio_U/lib/src/LIBPETSC/petsc/linux$OPT/src/snes/examples/tutorials
>> option="-pc_type none -ksp_type fgmres -snes_monitor_short -snes_rtol
>> 1.e-5 -log_summary -ksp_view -cuda_show_devices"
>> mpirun -np 2 $dir/ex19 $option 1>cpu$OPT.log 2>&1
>> mpirun -np 2 $dir/ex19 -dm_vec_type cusp -dm_mat_type aijcusp $option
>> 1>gpu$OPT.log 2>&1
>> With OPT="", PETSc optimized library is used, parallel calculation runs
>> well on CPU and GPU.
>> With OPT="_opt", PETSc non optimized library is used, parallel
>> calculation crashes on GPU (it is OK on CPU).
>> I join the log files. The only difference seems that PETSc-dev is built
>> with -O3 intead of -g...
>> I could try to rebuild PETSc with -O2 but do you have any idea of the
>> problem ?
> I could reproduce the problem and also get some uninitialized variable
> warnings in Valgrind. The debug version detects these errors, hence
> you only see the errors in the debug build. For the optimized build,
> chances are good that the computed values are either wrong or may
> become wrong in other environments. I'll see what I can do when I'm
> again at GPU machine tomorrow (parallel GPU debugging via SSH is not
> great...)
Sorry, I mean:
Parallel calculation on CPU or GPU run well with PETSc non optimized library
Parallel calculation on GPU crashes with PETSc optimized library (on CPU
it is OK)
I could add that the "mpirun -np 1 ex19" runs well for all builds on CPU
and GPU.
Pierre
> Best regards,
> Karli
*Trio_U support team*
Marthe ROUX (Saclay)
Pierre LEDAC (Grenoble)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140114/3a2fc14e/attachment.html>
