[petsc-dev] configuring on Titan
Mark Adams mfadams at lbl.gov
Tue Jan 14 07:06:45 CST 2014
I'm trying to configure on Titan.  It tells me to run the compute node job
but when I run the resulting reconfigure script it tells me to
run conftest-arch-titan-opt again (infinite loop).  So I do:
mv ./conftest-arch-titan-opt $MEMBERWORK/env003/
adams/env003> aprun -n 1 ./conftest-arch-titan-opt
mv $MEMBERWORK/env003/reconfigure-arch-titan-opt.py .
./reconfigure-arch-titan-opt.py
vi ./reconfigure-arch-titan-opt.py
I need to edit reconfigure:
                ERROR in COMMAND LINE ARGUMENT to ./configure
The option --known-mpi-int64_t should probably be --known-mpi-int64-t
I just delete this line.  The correct one seems to be there also.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140114/ed41d56d/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140114/ed41d56d/attachment.obj>
