[petsc-dev] broken stuff in next please fix
Sat Jan 4 20:41:51 CST 2014
Matthew Knepley <knepley at gmail.com> writes:
> On Sat, Jan 4, 2014 at 6:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2014/01/04/filtered-make_next_arch-linux-pkgs-dbg-ftn-interfaces_crank.log
>> /sandbox/petsc/petsc.clone/src/sys/objects/pinit.c:224:37: warning:
>> argument type 'struct <anonymous struct at
>> /sandbox/petsc/petsc.clone/src/sys/objects/pinit.c:217:3> *' doesn't match
>> specified 'MPI' type tag that requires 'struct mpich_struct_mpi_2int *'
>> [-Wtype-safety]
>> 1 warning generated.
>> /sandbox/petsc/petsc.clone/src/vec/is/sf/interface/sf.c:459:49: warning:
>> argument type 'PetscSFNode *' doesn't match specified 'MPI' type tag that
>> requires 'struct mpich_struct_mpi_2int *' [-Wtype-safety]
> Can we shut off this warning?
What version of MPICH and Clang are you using?  Current MPICH 'master'
is broken, but earlier versions with clang-3.3 are not producing this
warning.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140104/6a1c4f7c/attachment.sig>
