[petsc-dev] error on MatCreateTranspose with MatSchur
Jed Brown jed at jedbrown.org
Fri Feb 28 11:18:22 CST 2014
Stephan Kramer <s.kramer at imperial.ac.uk> writes:
> Dear petsc devs,
> Building our code against today's 'master', I came across the following error that worked fine with petsc 3.4.
I believe this is fixed in 'next'.  If you check there, I'll merge it to
'master'.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140228/4f498773/attachment.sig>
