[petsc-dev] Question converning integration of Pardiso in PETSc ...
pascal.tremblay at fr.michelin.com pascal.tremblay at fr.michelin.com
Fri Feb 28 03:14:20 CST 2014
Dear PETSc developper,
I am interested in testing / using (contributing to improve) the Intel MKL
Pardiso interface developped by Jose Bermeo.
I have seen the two pull request in the petsc-dev repository (the pull
requests #105 and #103 in https://bitbucket.org/petsc/petsc/pull-requests)
and
would like to know if it will be included in the next PETSc release and
approximately when (or at least integrated in the dev version).
I have also followed the discussion concerning the plugin approach to the
integration of external packages in PETSc and would also be interested in
that (I could
work on if you guide me through this new plugin approach. It would be very
convenient to us to be able to compile external plugins without
recompiling
the core of PETSc, especially when corrections to these plugins are
needed.)
Thank you for your input,
Pascal Tremblay
Mécanique Numérique
Michelin, Centre de technologie de Ladoux -CTE/DTO/SIM/ER
63040 Clermont-Ferrand Cedex 09 - FRANCE
Tél. (ext.): 04 73 10 91 63
Tél. (int.): 69 163
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140228/5492f849/attachment.html>
