[petsc-dev] candidate branches for master
Thu Feb 27 13:16:30 CST 2014
All these commits appear to be arround petsc-3.4 release timeframe
[almost a year back]. I'm not sure if that has something to do with
it.
[we were supporsed to rebase them to latest 'master' after release.
So - perhaps some got rebased - others didn't - and got lost?
0663011c7c207a5fa055b14c8d07abb792066d70 : Looks like this change is not in master
2a4c4990d51857b2e976754013cc7d755ade2a93 : I can't make this one out - the code appears
to have changed.
89a07f43a9e1dc00590d8e1b396cfde42a147e02 : this is in master - perhaps via rebase as 94b4b8a88246c8b3db6048a97d51fe6e24a661cb
120d0d30176ca78dcbd89ba7a8610c920f0555d4 : this is also in master perhaps via rebase as f5d698276d9eaf7faf6b5f5d493d10f9fdd50558
Satish
On Thu, 27 Feb 2014, Matthew Knepley wrote:
> On Thu, Feb 27, 2014 at 10:43 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Matthew Knepley <knepley at gmail.com> writes:
> > >> Candidate for master: refs/remotes/origin/knepley/fix-dm-clone Wed May
> > 22
> > >> 13:48:39 2013 -0400
> > > The branch above should be in master
> If this email is to indicate that this is not the case, then something has
> gone horribly wrong. I most
> definitely merged this branch with master, and then deleted my local
> checkout. If its not in master,
> something has happened to master.
>    Matt
> > $ git log master..bb/knepley/fix-dm-clone
> > commit 0663011c7c207a5fa055b14c8d07abb792066d70
> > Author: Matthew G. Knepley <knepley at gmail.com>
> > Date:   Wed May 22 13:48:39 2013 -0400
> >     DMPlex: clones are already setup
> > >> Candidate for master: refs/remotes/origin/knepley/fix-plex-cgns Wed Feb
> > 26
> > >> 16:59:26 2014 -0600
> > >> Candidate for master: refs/remotes/origin/knepley/fix-plex-subdm Tue Jun
> > >> 25 07:18:49 2013 -0600
> > $ git log master..bb/knepley/fix-plex-subdm
> > commit 2a4c4990d51857b2e976754013cc7d755ade2a93
> > Date:   Tue Jun 25 07:18:49 2013 -0600
> >     DMPlex: DMGetSubDM_Plex() had a memory leak
> >     - It was also doing extra work
> > >> Candidate for master: refs/remotes/origin/knepley/submesh-declarations
> > Tue
> > >> May 14 23:55:12 2013 -0500
> > $ git log master..bb/knepley/submesh-declarations
> > commit 89a07f43a9e1dc00590d8e1b396cfde42a147e02
> > Date:   Tue May 14 23:55:12 2013 -0500
> >     DMInterpolation: Fixed declarations
> > commit 120d0d30176ca78dcbd89ba7a8610c920f0555d4
> > Date:   Tue May 14 22:41:04 2013 -0500
> >     DMPlex: Added declaration
