[petsc-dev] [mpich-discuss] turning off MPI abort messages
Munson, Todd S. tmunson at mcs.anl.gov
Fri Feb 21 13:54:28 CST 2014
Sounds like someone needs to look up the definition of "customer support".
On Feb 21, 2014, at 1:20 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
> Aron told me that I should have said "we look forward to your patch"
> earlier instead of causing you guys to go apoplectic over my different
> definition of the word crash.
> Jeff
> On Fri, Feb 21, 2014 at 1:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Understood. But I would like to eliminate both sets of error messages and still provide a useful “return code”. Perhaps compile time options to the library?
>>   Barry
>> On Feb 21, 2014, at 12:40 PM, Jim Dinan <james.dinan at gmail.com> wrote:
>>> A little more detail -- you're actually getting messages from two sources: (1) the MPICH library ("application called MPI_Abort...") and (2) the job launcher ("BAD TERMINATION...").  You can eliminate the messages from the job launcher by providing an error code of 0 in MPI_Abort.
>>> ~Jim.
>>> On Fri, Feb 21, 2014 at 1:19 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
>>>>> Just configure MPICH such that snprintf isn't discovered by configure
>>>>> and you won't see these messages.
>>>>> The other solution is to fix PETSc so that people can't crash it so easily ;-)
>>>>   Here we go again. It is not CRASHING; it has detected an error conditioning and trying to appropriately and cleanly terminate. The reason it needs to use MPI_Abort() is that often detecting error conditions is not a uniformly collective thing.
>>>>    Printing a suitable error message and ending is not crashing. But with all the badly formatted “error messages” printed by MPICH I can not control at the end it looks like it is crashing.
>>> You're returning a non-zero exit code, which I consider crashing.  I
>>> apologize if this definition disagrees with yours.  If this is just
>>> gentle cleanup, why not exit with code=0 as Jim suggested already?
>>> Jeff
>>>>> On Thu, Feb 20, 2014 at 3:19 PM, Jim Dinan <james.dinan at gmail.com> wrote:
>>>>>> If you can find a way to call MPI_Finalize instead, you will portably
>>>>>> eliminate these messages.
>>>>>> A lesser solution would be to provide an error code of 0 (or MPI_SUCCESS) to
>>>>>> MPI_Abort, e.g. MPI_Comm_abort(MPI_COMM_WORLD, MPI_SUCCESS).  This would
>>>>>> eliminate the error message that you are getting from the job launcher.
>>>>>> MPICH could be modified to be quiet about the abort when the application
>>>>>> aborts with an error code of MPI_SUCCESS.
>>>>>> ~Jim.
>>>>>> On Thu, Feb 20, 2014 at 12:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>>  Is there any way to turn off MPICH (and others) printing messages about
>>>>>>> MPI_Abort?  We have already prepared and presented useful error messages to
>>>>>>> the user about the situation and would like to avoid having these additional
>>>>>>> messages printed (that often make the situation look worse than it is)
>>>>>>>   Thanks
>>>>>>>  Barry
>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>>>>>> [cli_0]: aborting job:
>>>>>>> ==================================================================mailto:discuss at mpich.org=================
>>>>>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>>>> =   EXIT CODE: 56
>>>>>>> =   CLEANING UP REMAINING PROCESSES
>>>>>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>>>> _______________________________________________
>>>>>>> discuss mailing list     discuss at mpich.org
>>>>>>> To manage subscription options or unsubscribe:
>>>>>>> https://lists.mpich.org/mailman/listinfo/discuss
>>>>> Jeff Hammond
>>> Jeff Hammond
> Jeff Hammond
