[petsc-dev] [mpich-discuss] turning off MPI abort messages
Jim Dinan james.dinan at gmail.com
Fri Feb 21 12:40:01 CST 2014
A little more detail -- you're actually getting messages from two sources:
(1) the MPICH library ("application called MPI_Abort...") and (2) the job
launcher ("BAD TERMINATION...").  You can eliminate the messages from the
job launcher by providing an error code of 0 in MPI_Abort.
 ~Jim.
On Fri, Feb 21, 2014 at 1:19 PM, Jeff Hammond <jeff.science at gmail.com>wrote:
> >> Just configure MPICH such that snprintf isn't discovered by configure
> >> and you won't see these messages.
> >> The other solution is to fix PETSc so that people can't crash it so
> easily ;-)
> >    Here we go again. It is not CRASHING; it has detected an error
> conditioning and trying to appropriately and cleanly terminate. The reason
> it needs to use MPI_Abort() is that often detecting error conditions is not
> a uniformly collective thing.
> >     Printing a suitable error message and ending is not crashing. But
> with all the badly formatted "error messages" printed by MPICH I can not
> control at the end it looks like it is crashing.
> You're returning a non-zero exit code, which I consider crashing.  I
> apologize if this definition disagrees with yours.  If this is just
> gentle cleanup, why not exit with code=0 as Jim suggested already?
> Jeff
> >> On Thu, Feb 20, 2014 at 3:19 PM, Jim Dinan <james.dinan at gmail.com>
> wrote:
> >>> If you can find a way to call MPI_Finalize instead, you will portably
> >>> eliminate these messages.
> >>> A lesser solution would be to provide an error code of 0 (or
> MPI_SUCCESS) to
> >>> MPI_Abort, e.g. MPI_Comm_abort(MPI_COMM_WORLD, MPI_SUCCESS).  This
> would
> >>> eliminate the error message that you are getting from the job launcher.
> >>> MPICH could be modified to be quiet about the abort when the
> application
> >>> aborts with an error code of MPI_SUCCESS.
> >>> ~Jim.
> >>> On Thu, Feb 20, 2014 at 12:33 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >>>>   Is there any way to turn off MPICH (and others) printing messages
> about
> >>>> MPI_Abort?  We have already prepared and presented useful error
> messages to
> >>>> the user about the situation and would like to avoid having these
> additional
> >>>> messages printed (that often make the situation look worse than it is)
> >>>>    Thanks
> >>>>   Barry
> >>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> >>>> [cli_0]: aborting job:
> ==================================================================mailto:
> discuss at mpich.org=================
> >>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> >>>> =   EXIT CODE: 56
> >>>> =   CLEANING UP REMAINING PROCESSES
> >>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> >>>> _______________________________________________
> >>>> discuss mailing list     discuss at mpich.org
> >>>> To manage subscription options or unsubscribe:
> >>>> https://lists.mpich.org/mailman/listinfo/discuss
> >> Jeff Hammond
> Jeff Hammond
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140221/56c4758a/attachment.html>
