[petsc-dev] [mpich-discuss] turning off MPI abort messages
Thu Feb 20 17:43:48 CST 2014
On Feb 20, 2014, at 4:40 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
> Just configure MPICH such that snprintf isn't discovered by configure
> and you won't see these messages.
> The other solution is to fix PETSc so that people can't crash it so easily ;-)
   Here we go again. It is not CRASHING; it has detected an error conditioning and trying to appropriately and cleanly terminate. The reason it needs to use MPI_Abort() is that often detecting error conditions is not a uniformly collective thing.
    Printing a suitable error message and ending is not crashing. But with all the badly formatted “error messages” printed by MPICH I can not control at the end it looks like it is crashing.
   Barry
> Jeff
> On Thu, Feb 20, 2014 at 3:19 PM, Jim Dinan <james.dinan at gmail.com> wrote:
>> If you can find a way to call MPI_Finalize instead, you will portably
>> eliminate these messages.
>> A lesser solution would be to provide an error code of 0 (or MPI_SUCCESS) to
>> MPI_Abort, e.g. MPI_Comm_abort(MPI_COMM_WORLD, MPI_SUCCESS).  This would
>> eliminate the error message that you are getting from the job launcher.
>> MPICH could be modified to be quiet about the abort when the application
>> aborts with an error code of MPI_SUCCESS.
>> ~Jim.
>> On Thu, Feb 20, 2014 at 12:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>   Is there any way to turn off MPICH (and others) printing messages about
>>> MPI_Abort?  We have already prepared and presented useful error messages to
>>> the user about the situation and would like to avoid having these additional
>>> messages printed (that often make the situation look worse than it is)
>>>    Thanks
>>>   Barry
>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>> [cli_0]: aborting job:
>>> ==================================================================mailto:discuss at mpich.org=================
>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>> =   EXIT CODE: 56
>>> =   CLEANING UP REMAINING PROCESSES
>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>> _______________________________________________
>>> discuss mailing list     discuss at mpich.org
>>> To manage subscription options or unsubscribe:
>>> https://lists.mpich.org/mailman/listinfo/discuss
> Jeff Hammond
