[petsc-dev] TaoTerminationReason -> TaoConvergedReason
Jason Sarich jason.sarich at gmail.com
Tue Feb 18 15:31:14 CST 2014
This has been updated now in barry/tao-fixes-for-petsc4py
Jason
On Tue, Feb 18, 2014 at 11:32 AM, Smith, Barry F. <bsmith at anl.gov> wrote:
> On Feb 18, 2014, at 10:12 AM, Jason Sarich <jason.sarich at gmail.com> wrote:
> > Yes, I'll rename them under Tao and make them PETSC_INTERNAL.
>    Thanks, move the declarations to taoimpl.h also and do it in the
> barry/tao-fixes-for-petsc4py branch. Just put Tao in front of them.
>    We should eventually clean this stuff up and merge into
> VecGetSubVector() and MatGetSubMatrix() and unify usage in all of PETSc but
> will require some thought and care so I have added an issue
> https://bitbucket.org/petsc/petsc/issue/58/cleanup-taovecmatgetsubvec-and-unify-intoinstead of doing it rapidly and poorly now.
>    It is generally useful stuff and after cleanup should be used by SNESVI
> also.
>    Barry
> > I don't think using the VI routines is a good idea at the moment, those
> are attached to SNES objects.
> > Jason
> > On Tue, Feb 18, 2014 at 10:06 AM, Jed Brown <jed at jedbrown.org> wrote:
> > Jason Sarich <jason.sarich at gmail.com> writes:
> > > These functions are for eliminating the variables corresponding to
> active
> > > sets when performing matrix, vector operations. I don't think they were
> > > meant to be in the public interface, only for utilities in active set
> > > algorithms.
> > Okay, can you either make them PETSC_INTERNAL and namespace them or
> > replace them?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140218/4e2ab049/attachment.html>
