[petsc-dev] Changing Mat block size?
Jed Brown jed at jedbrown.org
Fri Feb 14 20:37:32 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Ok, then don’t add bs to MatCreateShell and AIJ just go through the
>   several steps to create and set up the matrices
I made a PR that lets the user use convenience wrappers and change the
block size later.
https://bitbucket.org/petsc/petsc/pull-request/144/lazy-block-sizes/diff
The most common change is to use the accessor interface instead of
reaching into map->bs directly, which I think is generally positive.
When used in initialization statements are too cumbersome to pull out by
that interface, I added PetscAbs.  That's mildly ugly, but I think it's
better than having more weird constraints in the public interface.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140214/fc59fc0d/attachment.sig>
