[petsc-dev] [petsc-maint] SNESMF
Jed Brown jed at jedbrown.org
Thu Feb 13 22:34:09 CST 2014
panourg at mech.upatras.gr writes:
> Also, Yes, I want to find the solution of n+1 time using the steady state
> solution of non-linear system. That is to reply to the other guy.
Going directly to steady-state is not a pseudo-time algorithm.  I
suggest trying TSPSEUDO.  I would be interested in finding a case where
the algorithm you describe is preferable.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140213/5e6f1289/attachment.sig>
