[petsc-dev] Single configure script for SuiteSparse package
Wed Feb 12 21:11:21 CST 2014
On Wed, 12 Feb 2014, Satish Balay wrote:
> And then configure should print an error message if --with-umpfack
> option is specified [via check_for_option_changed() in
> config/configure.py]
Shri,
I pushed this change [to 'shri/update-SuiteSparse'] along with another
change for nightlybuilds] - so you should pull these chagnes.
Satish
