[petsc-dev] Single configure script for SuiteSparse package
Jed Brown jed at jedbrown.org
Wed Feb 12 12:21:17 CST 2014
Satish Balay <balay at mcs.anl.gov> writes:
> On Wed, 12 Feb 2014, Abhyankar, Shrirang G. wrote:
>> Barry,
>>    Satish and I have attempted to create a single configure script for SuiteSparse installation. It is currently in the branch shri/update-SuiteSparse https://bitbucket.org/petsc/petsc/branch/shri%2Fupdate-SuiteSparse. This change downloads the entire SuiteSparse package and installs all the sub-packages that PETSc currently supports (UMFPACK, CHOLMOD, and KLU). We can of course have selective installation of sub-packages if need be, currently it does not. I know you prefer a 'separate' configure script for each sub-package, but we think a single configure is a better approach. This change also updates PETSc to use the latest SuiteSparse. I've tested it with both debugging and optimized modes (with complex and 64-bit ints) and there was no change needed for UMFPACK or CHOLMOD solver interfaces. Let us know what you think? petsc-devs?
> Note: Apart from--download-suitsparse=1 - --with-suitsparse=1 or
> --with-suitsparse works on ubuntu/linux with preisntalled suitsparse
> [and presumably will work with other suitsparse installs]
> And it avoids all the issues with spliting and maintaining our own
> taballs for UMFPACK, CHOLMOD, and KLU [and managing duplicate copies
> of dependencies like AMD, COLAMD libsuitsparse etc.] - and will avoid
> corner-cases like --download-umfpack --with-cholmod-dir= etc..
Those packages were never packaged for sane independent-install anyway.
However, some distributions have done the work of allowing separate
install of each component.  Could we have the one suitesparse configure
script detect which components are available?
> One caveat: we build only part of suitsparse [required by petsc] - not
> the whole thing.
> BTW: should we change PETSC_HAVE_UMFPACK PETSC_HAVE_CHOLMOD etc to
> PETSC_HAVE_SUITSPARSE?  [I don't think its necessary - but checking..]
> And then configure should print an error message if --with-umpfack
> option is specified [via check_for_option_changed() in
> config/configure.py]
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140212/841263e0/attachment.sig>
