[petsc-dev] aij and baij data access
Jose David Bermeol jbermeol at purdue.edu
Tue Feb 4 10:01:54 CST 2014
Looking the code for MatGetRowIJ_SeqAIJ_Inode_Nonsymmetric, it is copying the data and I want to avoid that. So, is there other way to do this??
----- Original Message -----
To: "Jed Brown" <jed at jedbrown.org>
Cc: "Jose David Bermeol" <jbermeol at purdue.edu>, "petsc-dev" <petsc-dev at mcs.anl.gov>
Sent: Tuesday, February 4, 2014 9:21:34 AM
Subject: Re: [petsc-dev] aij and baij data access
On Tue, Feb 4, 2014 at 7:41 AM, Jed Brown < jed at jedbrown.org > wrote:
Matthew Knepley < knepley at gmail.com > writes:
> On Mon, Feb 3, 2014 at 10:22 AM, Jose David Bermeol < jbermeol at purdue.edu >wrote:
>> Hi, Is it possible to access to the raw data of aij matrices(row indices,
>> column indices and data). I need to used for and optimize algorithm, this
>> data will keep constant all the time. So is it cossible with the public
>> interface you have or not??
> This is a question for petsc-maint.
I disagree; there is no reason to keep such questions private.
Let me rephrase: This is a question for petsc-maint (my default suggestion so as not to force
people into the public) or petsc-users, not petsc-dev which is for development discussion.
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatGetColumnIJ.html
You actually want MatGetRowIJ because MatGetColumnIJ is expensive with a
row-based format like AIJ.
Yes, bad click.
Matt
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatSeqAIJGetArray.html
-- Norbert Wiener
