[petsc-dev] aij and baij data access
Jose David Bermeol jbermeol at purdue.edu
Mon Feb 3 10:22:22 CST 2014
Hi, Is it possible to access to the raw data of aij matrices(row indices, column indices and data). I need to used for and optimize algorithm, this data will keep constant all the time. So is it cossible with the public interface you have or not??
Thanks
