[petsc-dev] Sean is going to love this
Geoff Oxberry goxberry at gmail.com
Mon Dec 29 21:56:17 CST 2014
> Date: Sun, 28 Dec 2014 21:27:21 -0600
> From: Barry Smith <bsmith at mcs.anl.gov>
> To: Sean Farley <sean.michael.farley at gmail.com>
> Cc: petsc-dev <petsc-dev at mcs.anl.gov>
> Subject: Re: [petsc-dev] Sean is going to love this
> Message-ID: <BA03ABA6-C693-4404-9FA5-2211BC371836 at mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
>   Sean,
>     brew install /homebrew/science/petsc
>     brew install /homebrew/science/petsc --HEAD --with-x11
>   Is there any reason not to use home-brew for everything now? Should we
be working with the homebrew/science guys to work out the rough edges?
(Like their hypre build is sequential and they don't pass the MPI compiler
wrappers properly to build packages and ... and ...)
I contributed most of the hypre recipe; brew install hypre --with-mpi
should get you a parallel build, and it should also run some parallel
exampled as smoke tests. If there's anything missing that should be added,
let me know and I can get to it when I return from vacation.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141229/12607920/attachment.html>
