[petsc-dev] Sean is going to love this
Sun Dec 28 21:27:21 CST 2014
  Sean,
    brew install /homebrew/science/petsc
    brew install /homebrew/science/petsc --HEAD --with-x11
  Is there any reason not to use home-brew for everything now? Should we be working with the homebrew/science guys to work out the rough edges? (Like their hypre build is sequential and they don't pass the MPI compiler wrappers properly to build packages and ... and ...)
  Barry
> On Dec 24, 2014, at 12:22 PM, Sean Farley <sean.michael.farley at gmail.com> wrote:
> Jose E. Roman writes:
>> El 23/12/2014, a las 20:38, Sean Farley escribió:
>>> 4) Better coordination with dependent packages
>>> This item is hard to implement because it's out of the PETSc team's
>>> control. For example, packages like SLEPc depend on PETSc but don't have
>>> as good of a build system. SLEPc can't be built with a version of SLEPc
>>> already installed in the prefix. This is unnecessarily cumbersome for
>>> end-users.
>> SLEPc issues a warning in this case, but does not prevent building. I have removed the warning, since it is no longer necessary. Please report any problems.
> Ah, great! Thanks!
