[petsc-dev] Fwd: [ideas-xsdk] common configure/cmake arguments for XSDK packages ready for testing
Wed Dec 24 15:41:10 CST 2014
> On Dec 24, 2014, at 12:26 PM, Jed Brown <jed at jedbrown.org> wrote:
> In this case, it might be more reliable to compare "cc --version".
  Presumably this is trivial with the gnumake stuff?
  And  the mythical petsc-config could do any number of sanity checks each time it is run.
   Barry
> Modules was never intended as a robust solution.  It was a disgusting
> hack that probably seemed okay at the time, but ended up as an
> established methodology and now we have to live with its many points of
> failure, horrible debugability, and lack of an API.
