[petsc-dev] Sean is going to love this
Jed Brown jed at jedbrown.org
Tue Dec 23 18:53:34 CST 2014
Sean Farley <sean.michael.farley at gmail.com> writes:
> That's entirely up to you of where to put it. Jed, I'm sure, can advise
> on which files in 'conf' to put into etc, var, or share.
I would actually prefer to create a bin/petsc-config that can be used to
query everything about the configuration.  The location of its data
files would not be part of the public interface.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141223/34b15426/attachment.sig>
