[petsc-dev] Fwd: [Bitbucket] Issue #84: pastix compilation error when custom compiler flags are set (petsc/petsc)
Fri Dec 19 12:38:06 CST 2014
Added to branch 'balay/update-pastix_5.2.2.20' off 'maint' - and merged
to next for now.
https://bitbucket.org/petsc/petsc/commits/c7c61743d300979d95f7cd246d0504c36be35be5
Satish
On Thu, 18 Dec 2014, Barry Smith wrote:
>   Satish,
>    Can you update maint and master to use this new version (after testing in next of course :-)
>   Barry
> > Begin forwarded message:
> > Subject: Re: [Bitbucket] Issue #84: pastix compilation error when custom compiler flags are set (petsc/petsc)
> > From: XL <issues-reply at bitbucket.org>
> > To: <bsmith at mcs.anl.gov>
> > Date: December 18, 2014 at 8:57:38 AM CST
> > XL commented on issue #84:
> > pastix compilation error when custom compiler flags are set <https://bitbucket.org/petsc/petsc/issue/84/pastix-compilation-error-when-custom>
> > I just released a new version that should fix the issue: https://gforge.inria.fr/frs/download.php/file/34392/pastix_5.2.2.20.tar.bz2 <https://gforge.inria.fr/frs/download.php/file/34392/pastix_5.2.2.20.tar.bz2>.
> > View this issue <https://bitbucket.org/petsc/petsc/issue/84/pastix-compilation-error-when-custom> or add a comment by replying to this email.
> > Unsubscribe from issue emails <https://bitbucket.org/api/1.0/petsc/petsc/issue/84/unsubscribe/BarryFSmith/f343cf249e6eedb3a0515582b9c690454c49d619/> for this repository.		             <https://bitbucket.org/>
