[petsc-dev] Broken example ?
Patrick Sanan patrick.sanan at gmail.com
Wed Dec 17 10:55:56 CST 2014
I can reproduce (on a laptop, OS X 10.9)
Running in the debugger (and looking at a related error when running the
second suggested command line option in ex55.c), a possible source of
the problem is with the way the IS's are being set up. The direct cause
of the segfault on my machine is that, in PCFieldSplitSetDefaults,
jac->head is a null pointer.
It seems to be unrelated to hypre (based on the fact that the same
behavior is observed changing to -fieldsplit_0_pc_type lu).
Pasted below:
1) LLDB running the first recommended settings
2) Error from these settings
3) Error from the second set of recommended options
1)
$ lldb ./ex55
(lldb) target create "./ex55"
Current executable set to './ex55' (x86_64).
(lldb) r -ksp_type fgmres -pc_type fieldsplit
-pc_fieldsplit_detect_saddle_point -pc_fieldsplit_type schur
-pc_fieldsplit_schur_precondition self -fieldsplit_1_ksp_type fgmres
-fieldsplit_1_pc_type lsc -snes_vi_monitor -ksp_monitor_true_residual
-fieldsplit_ksp_monitor -fieldsplit_0_pc_type hypre -da_grid_x 65
-da_grid_y 65 -snes_atol 1.e-11  -ksp_rtol 1.e-8
Process 84592 launched: './ex55' (x86_64)
   0 SNES VI Function norm 6.221605446769e-05 Active lower constraints
1928/2241 upper constraints 302/397 Percent of total 0.131953 Percent of
bounded 0.175937
Process 84592 stopped
* thread #1: tid = 0x8c484, 0x0000000101196734
libpetsc.3.05.dylib`PCFieldSplitSetDefaults(pc=0x0000000104351a60) +
6868 at fieldsplit.c:411, queue = 'com.apple.main-thread', stop reason =
EXC_BAD_ACCESS (code=1, address=0x48)
     frame #0: 0x0000000101196734
    408             ierr =
MatFindZeroDiagonals(pc->mat,&zerodiags);CHKERRQ(ierr);
    409             ierr =
ISComplement(zerodiags,nmin,nmax,&rest);CHKERRQ(ierr);
    410             if (jac->reset) {
-> 411               jac->head->is       = rest;
    412               jac->head->next->is = zerodiags;
    413             } else {
    414               ierr = PCFieldSplitSetIS(pc,"0",rest);CHKERRQ(ierr);
(lldb)
2)
$ ./ex55 -ksp_type fgmres -pc_type fieldsplit
bounded 0.175937
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PCFieldSplitSetDefaults line 321
/Users/patrick/program/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: [0] PCSetUp_FieldSplit line 484
[0]PETSC ERROR: [0] KSPSetUp line 220
/Users/patrick/program/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: [0] SNESSolve_VINEWTONRSLS line 346
/Users/patrick/program/petsc/src/snes/impls/vi/rs/virs.c
[0]PETSC ERROR: [0] SNESSolve line 3696
/Users/patrick/program/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-1118-g64daeef
GIT Date: 2014-12-11 04:32:01 -0600
[0]PETSC ERROR: ./ex55 on a arch-darwin-double-debug named
Patricks-MacBook-Pro-3.local by patrick Tue Dec 16 11:19:48 2014
[0]PETSC ERROR: Configure options PETSC_DIR=/Users/patrick/program/petsc
PETSC_ARCH=arch-darwin-double-debug --download-mpich
--download-fblaslapack --with-cc=clang --with-cxx=clang++
--with-fc=gfortran-mp-4.9 --with-debugging=1 --with-precision=double
--download-mumps --download-scalapack --download-metis
--download-parmetis --download-spai --download-hypre --download-viennacl
--with-opencl
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
3)
$ ./ex55 -ksp_type fgmres -pc_type mg -mg_levels_ksp_type fgmres
-mg_levels_pc_type fieldsplit
-mg_levels_pc_fieldsplit_detect_saddle_point
-mg_levels_pc_fieldsplit_type schur
-mg_levels_pc_fieldsplit_factorization_type full
-mg_levels_pc_fieldsplit_schur_precondition user
-mg_levels_fieldsplit_1_ksp_type gmres -mg_levels_fieldsplit_1_pc_type
none -mg_levels_fieldsplit_0_ksp_type preonly
-mg_levels_fieldsplit_0_pc_type sor
-mg_levels_fieldsplit_0_pc_sor_forward -snes_vi_monitor
-ksp_monitor_true_residual -pc_mg_levels 5 -pc_mg_galerkin
-mg_levels_ksp_monitor -mg_levels_fieldsplit_ksp_monitor
-mg_levels_ksp_max_it 2 -mg_levels_fieldsplit_ksp_max_it 5 -snes_atol
1.e-11 -mg_coarse_ksp_type preonly -mg_coarse_pc_type svd -da_grid_x 65
-da_grid_y 65 -ksp_rtol 1.e-8
SNESVI solver converged at t = 0.0000 in 8 iterations
   0 SNES VI Function norm 6.499999997699e+01 Active lower constraints
12663/12663 upper constraints 0/0 Percent of total 0.74929 Percent of
bounded 0.999053
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 2
Patricks-MacBook-Pro-3.local by patrick Tue Dec 16 11:21:47 2014
--with-opencl
[0]PETSC ERROR: #1 MatGetSubMatrix() line 7482 in
/Users/patrick/program/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 552 in
[0]PETSC ERROR: #3 PCSetUp() line 902 in
/Users/patrick/program/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #4 KSPSetUp() line 306 in
[0]PETSC ERROR: #5 PCSetUp_MG() line 758 in
/Users/patrick/program/petsc/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #6 PCSetUp() line 902 in
[0]PETSC ERROR: #7 KSPSetUp() line 306 in
[0]PETSC ERROR: #8 SNESSolve_VINEWTONRSLS() line 506 in
[0]PETSC ERROR: #9 SNESSolve() line 3743 in
[0]PETSC ERROR: #10 main() line 108 in
/Users/patrick/program/petsc/src/snes/examples/tutorials/ex55.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
On 16/12/14 05:22 AM, Pierre Jolivet wrote:
> When trying to run snes/examples/tutorials/ex55 with the command line given in the source code, i.e.
> $ ./ex55 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_detect_saddle_point -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition self -fieldsplit_1_ksp_type fgmres -fieldsplit_1_pc_type lsc -snes_vi_monitor -ksp_monitor_true_residual -fieldsplit_ksp_monitor -fieldsplit_0_pc_type hypre -da_grid_x 65 -da_grid_y 65 -snes_atol 1.e-11  -ksp_rtol 1.e-8
> I end up with a crash with these lines in the log:
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: [0] PCFieldSplitSetDefaults line 321petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: [0] PCSetUp_FieldSplit line 484 petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: [0] KSPSetUp line 220 petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] SNESSolve_VINEWTONRSLS line 346 petsc/src/snes/impls/vi/rs/virs.c
> [0]PETSC ERROR: [0] SNESSolve line 3696 petsc/src/snes/interface/snes.c
> This is happening on two computers (a MBP and a Linux, on the master branch), both have —download-hypre, am I the only one having this error ? Please let me know if so, I’ll send you both configure.log if need be.
> Thank you,
> Pierre
make[1]: Entering directory `/Users/patrick/program/petsc'
See documentation/faq.html and documentation/bugreporting.html
for help with installation problems.  Please send EVERYTHING
printed out below when reporting problems.  Please check the
mailing list archives and consider subscribing.
  http://www.mcs.anl.gov/petsc/miscellaneous/mailing-lists.html
Starting on Patricks-MacBook-Pro.local at Tue Dec 16 10:52:58 PST 2014
Machine characteristics: Darwin Patricks-MacBook-Pro.local 13.4.0 Darwin Kernel Version 13.4.0: Sun Aug 17 19:50:11 PDT 2014; root:xnu-2422.115.4~1/RELEASE_X86_64 x86_64
Using PETSc directory: /Users/patrick/program/petsc
Using PETSc arch: arch-darwin-double-debug
PETSC_VERSION_RELEASE    0
PETSC_VERSION_MAJOR      3
PETSC_VERSION_MINOR      5
PETSC_VERSION_SUBMINOR   2
PETSC_VERSION_PATCH      0
PETSC_VERSION_DATE       "unknown"
PETSC_VERSION_GIT        "unknown"
PETSC_VERSION_DATE_GIT   "unknown"
PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
Using configure Options: PETSC_DIR=/Users/patrick/program/petsc PETSC_ARCH=arch-darwin-double-debug --download-mpich --download-fblaslapack --with-cc=clang --with-cxx=clang++ --with-fc=gfortran-mp-4.9 --with-debugging=1 --with-precision=double --download-mumps --download-scalapack --download-metis --download-parmetis --download-spai --download-hypre --download-viennacl --with-opencl
Using configuration flags:
#define INCLUDED_PETSCCONF_H
#define IS_COLORING_MAX 65535
#define STDC_HEADERS 1
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_RTLD_DEFAULT 1
#define PETSC_UINTPTR_T uintptr_t
#define PETSC_HAVE_PTHREAD 1
#define PETSC_HAVE_SSL 1
#define PETSC_DEPRECATED(why) __attribute((deprecated))
#define PETSC_HAVE_OPENCL 1
#define PETSC_REPLACE_DIR_SEPARATOR '\\'
#define PETSC_HAVE_SO_REUSEADDR 1
#define PETSC_HAVE_MPI 1
#define PETSC_PREFETCH_HINT_T2 _MM_HINT_T2
#define PETSC_PREFETCH_HINT_T0 _MM_HINT_T0
#define PETSC_PREFETCH_HINT_T1 _MM_HINT_T1
#define PETSC_HAVE_FORTRAN 1
#define PETSC_DIR "/Users/patrick/program/petsc"
#define PETSC_HAVE_X 1
#define PETSC_HAVE_HYPRE 1
#define PETSC_LIB_DIR "/Users/patrick/program/petsc/arch-darwin-double-debug/lib"
#define PETSC_HAVE_SPAI 1
#define PETSC_HAVE_PARMETIS 1
#define PETSC_USE_SOCKET_VIEWER 1
#define PETSC_USE_ISATTY 1
#define PETSC_HAVE_SOWING 1
#define PETSC_SLSUFFIX "dylib"
#define PETSC_FUNCTION_NAME_CXX __func__
#define PETSC_HAVE_VIENNACL 1
#define PETSC_HAVE_MUMPS 1
#define PETSC_HAVE_FBLASLAPACK 1
#define PETSC_HAVE_ATOLL 1
#define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
#define PETSC_UNUSED __attribute((unused))
#define PETSC_FUNCTION_NAME_C __func__
#define PETSC_HAVE_MPICH 1
#define PETSC_HAVE_VALGRIND 1
#define PETSC_USE_SINGLE_LIBRARY 1
#define PETSC_HAVE_BUILTIN_EXPECT 1
#define PETSC_HAVE_METIS 1
#define PETSC_DIR_SEPARATOR '/'
#define PETSC_PATH_SEPARATOR ':'
#define PETSC_HAVE_XMMINTRIN_H 1
#define PETSC_PREFETCH_HINT_NTA _MM_HINT_NTA
#define PETSC_Prefetch(a,b,c) _mm_prefetch((const char*)(a),(c))
#define PETSC_HAVE_BLASLAPACK 1
#define PETSC_HAVE_HWLOC 1
#define PETSC_HAVE_GZIP 1
#define PETSC_HAVE_STRING_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_MACHINE_ENDIAN_H 1
#define PETSC_HAVE_SCHED_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_MATH_H 1
#define PETSC_HAVE_STDLIB_H 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_PTHREAD_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_CXXABI_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_LIMITS_H 1
#define PETSC_HAVE_SEARCH_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_TIME_WITH_SYS_TIME 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_USING_F90 1
#define PETSC_USING_F2003 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_C_STATIC_INLINE static inline
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_CXX_NAMESPACE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_C_RESTRICT restrict
#define PETSC_CXX_RESTRICT  __restrict__
#define PETSC_CXX_STATIC_INLINE static inline
#define PETSC_HAVE_LIBZ 1
#define PETSC_HAVE_LIBDL 1
#define PETSC_HAVE_LIBGFORTRAN 1
#define PETSC_HAVE_LIBSCALAPACK 1
#define PETSC_HAVE_LIBGCC_EXT_10_5 1
#define PETSC_HAVE_LIBMETIS 1
#define PETSC_HAVE_LIBCRYPTO 1
#define PETSC_HAVE_LIBCMUMPS 1
#define PETSC_HAVE_LIBM 1
#define PETSC_HAVE_LIBCLANG_RT_OSX 1
#define PETSC_HAVE_LIBDMUMPS 1
#define PETSC_HAVE_LIBMUMPS_COMMON 1
#define PETSC_HAVE_LIBPTHREAD 1
#define PETSC_HAVE_LIBPARMETIS 1
#define PETSC_HAVE_LIBFBLAS 1
#define PETSC_HAVE_LIBMPICXX 1
#define PETSC_HAVE_LIBCLANG_RT 1
#define PETSC_HAVE_LIBHWLOC 1
#define PETSC_HAVE_LIBZMUMPS 1
#define PETSC_HAVE_LIBSSL 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_LIBHYPRE 1
#define PETSC_HAVE_LIBC__ 1
#define PETSC_HAVE_LIBPORD 1
#define PETSC_HAVE_LIBSMUMPS 1
#define PETSC_HAVE_LIBMPIFORT 1
#define PETSC_HAVE_LIBSPAI 1
#define PETSC_HAVE_LIBFLAPACK 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_LIBX11 1
#define PETSC_HAVE_LIBQUADMATH 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_ARCH "arch-darwin-double-debug"
#define PETSC_CLANGUAGE_C 1
#define PETSC_USE_ERRORCHECKING 1
#define PETSC_SIZEOF_MPI_COMM 4
#define PETSC_BITS_PER_BYTE 8
#define PETSC_SIZEOF_MPI_FINT 4
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_RETSIGTYPE void
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_SIZEOF_LONG 8
#define PETSC_USE_FORTRANKIND 1
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_HAVE_SIGINFO_T 1
#define PETSC_SIZEOF_CHAR 1
#define PETSC_SIZEOF_DOUBLE 8
#define PETSC_SIZEOF_FLOAT 4
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_SIGSET 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_HAVE_TIMES 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_GETTIMEOFDAY 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_MKSTEMP 1
#define PETSC_HAVE_SIGACTION 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_SYSCTLBYNAME 1
#define PETSC_HAVE_SIGNAL 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_VFPRINTF 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE__GFORTRAN_IARGC 1
#define PETSC_SIGNAL_CAST
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_VPRINTF 1
#define PETSC_HAVE_BZERO 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_WRITE_MEMORY_BARRIER() asm volatile("sfence":::"memory")
#define PETSC_MEMORY_BARRIER() asm volatile("mfence":::"memory")
#define PETSC_READ_MEMORY_BARRIER() asm volatile("lfence":::"memory")
#define PETSC_CPU_RELAX() asm volatile("rep; nop" ::: "memory")
#define PETSC_BLASLAPACK_UNDERSCORE 1
#define PETSC_HAVE_MPI_F90MODULE 1
#define PETSC_HAVE_MPI_IALLREDUCE 1
#define PETSC_HAVE_MPI_IN_PLACE 1
#define PETSC_HAVE_MPI_COMM_C2F 1
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#define PETSC_HAVE_MPI_INT64_T 1
#define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
#define PETSC_HAVE_MPI_WIN_CREATE 1
#define PETSC_HAVE_MPI_TYPE_DUP 1
#define PETSC_HAVE_MPI_INIT_THREAD 1
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#define PETSC_HAVE_MPI_COMM_F2C 1
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#define PETSC_HAVE_MPICH_CH3_SOCK 1
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#define PETSC_HAVE_MPICH_NUMVERSION 30103300
#define PETSC_HAVE_MPIIO 1
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#define PETSC_HAVE_MPICH_CH3_SOCK_FIXED_NBC_PROGRESS 1
#define PETSC_HAVE_MPI_FINT 1
#define PETSC_HAVE_MPI_IBARRIER 1
#define PETSC_HAVE_MPI_ALLTOALLW 1
#define PETSC_HAVE_MPI_REPLACE 1
#define PETSC_HAVE_MPI_EXSCAN 1
#define PETSC_HAVE_MPI_C_DOUBLE_COMPLEX 1
#define PETSC_HAVE_MPI_FINALIZED 1
#define PETSC_USE_INFO 1
#define PETSC_Alignx(a,b)
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_DEBUG 1
#define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
#define PETSC_USE_LOG 1
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_USE_CTABLE 1
#define PETSC_USE_SCALAR_REAL 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_HAVE_ISNORMAL 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_MEMALIGN 16
#define PETSC_VERSION_DATE_GIT "2014-12-11 04:32:01 -0600"
#define PETSC_VERSION_BRANCH_GIT "master"
#define PETSC_VERSION_GIT "v3.5.2-1118-g64daeef"
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_HAVE_SHARED_LIBRARIES 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_LEVEL1_DCACHE_LINESIZE 32
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#define PETSC_LEVEL1_DCACHE_ASSOC 2
#define PETSC_HAVE_CLOSURE 1
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_HAVE_GFORTRAN_IARGC 1
#define PETSC_USE_BYTES_FOR_SIZE 1
#define PETSC_HAVE_SYS_SYSCTL_H 1
Using C/C++ compile: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0   -I/Users/patrick/program/petsc/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/opt/X11/include -I/opt/local/include
mpicc -show: clang -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpi -lpmpi
Using Fortran compile: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   -I/Users/patrick/program/petsc/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/opt/X11/include -I/opt/local/include
mpif90 -show: gfortran-mp-4.9 -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpifort -lmpi -lpmpi
Using C/C++ linker: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc
Using C/C++ flags: -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0
Using Fortran linker: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90
Using Fortran flags: -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
Using libraries: -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib  -lpetsc -lHYPRE -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lspai -lflapack -lfblas -lparmetis -lmetis -L/opt/X11/lib -lX11 -lhwloc -lpthread -framework opencl -lssl -lcrypto -lmpifort -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpicxx -lc++ -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Using mpiexec: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpiexec
Building PETSc using GNU Make with 7 build threads
make[2]: Entering directory `/Users/patrick/program/petsc'
/usr/bin/python conf/gmakegen.py --petsc-arch=arch-darwin-double-debug
make[2]: Leaving directory `/Users/patrick/program/petsc'
Use "/usr/bin/make V=1" to see the verbose compile lines.
          CC arch-darwin-double-debug/obj/src/sys/utils/arch.o
          CC arch-darwin-double-debug/obj/src/sys/utils/fhost.o
          CC arch-darwin-double-debug/obj/src/sys/utils/fuser.o
          CC arch-darwin-double-debug/obj/src/sys/utils/memc.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mpiu.o
          CC arch-darwin-double-debug/obj/src/sys/utils/psleep.o
          CC arch-darwin-double-debug/obj/src/sys/utils/sortd.o
          CC arch-darwin-double-debug/obj/src/sys/utils/str.o
          CC arch-darwin-double-debug/obj/src/sys/utils/sorti.o
          CC arch-darwin-double-debug/obj/src/sys/utils/sortip.o
          CC arch-darwin-double-debug/obj/src/sys/utils/pbarrier.o
          CC arch-darwin-double-debug/obj/src/sys/utils/pdisplay.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ctable.o
          CC arch-darwin-double-debug/obj/src/sys/utils/psplit.o
          CC arch-darwin-double-debug/obj/src/sys/utils/select.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mpimesg.o
          CC arch-darwin-double-debug/obj/src/sys/utils/sseenabled.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mpitr.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mpilong.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mathinf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/mpits.o
          CC arch-darwin-double-debug/obj/src/sys/utils/segbuffer.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/memcf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/mpitsf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/mpiuf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/psplitf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/psleepf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/sortdf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/sortipf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-auto/sortif.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-custom/zarchf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-custom/zstrf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-custom/zpbarrierf.o
          CC arch-darwin-double-debug/obj/src/sys/utils/ftn-custom/zfhostf.o
          CC arch-darwin-double-debug/obj/src/sys/dll/dlimpl.o
          CC arch-darwin-double-debug/obj/src/sys/dll/dl.o
          CC arch-darwin-double-debug/obj/src/sys/dll/reg.o
          CC arch-darwin-double-debug/obj/src/sys/dll/ftn-auto/regf.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ffpath.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftest.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ghome.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/mpiuopen.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/rpath.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/fpath.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/fwd.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/grpath.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/mprint.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/sysio.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/fretrieve.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/smatlab.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-auto/mpiuopenf.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-auto/sysiof.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-custom/zghomef.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-custom/zmpiuopenf.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-custom/zmprintf.o
          CC arch-darwin-double-debug/obj/src/sys/fileio/ftn-custom/zsysiof.o
          CC arch-darwin-double-debug/obj/src/sys/memory/mal.o
          CC arch-darwin-double-debug/obj/src/sys/memory/mem.o
          CC arch-darwin-double-debug/obj/src/sys/memory/mtr.o
          CC arch-darwin-double-debug/obj/src/sys/memory/ftn-auto/memf.o
          CC arch-darwin-double-debug/obj/src/sys/memory/ftn-custom/zmtrf.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/impls/nothread/nothread.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/interface/dlregisthreadcomm.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/interface/threadcomm.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/interface/threadcommregi.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/interface/threadcommred.o
          CC arch-darwin-double-debug/obj/src/sys/threadcomm/interface/ftn-auto/threadcommf.o
          CC arch-darwin-double-debug/obj/src/sys/ftn-custom/zsys.o
          CC arch-darwin-double-debug/obj/src/sys/ftn-custom/zutils.o
          CC arch-darwin-double-debug/obj/src/sys/python/pythonsys.o
          CC arch-darwin-double-debug/obj/src/sys/python/ftn-custom/zpythonf.o
          CC arch-darwin-double-debug/obj/src/sys/error/adebug.o
          CC arch-darwin-double-debug/obj/src/sys/error/err.o
          CC arch-darwin-double-debug/obj/src/sys/error/errtrace.o
          CC arch-darwin-double-debug/obj/src/sys/error/errabort.o
          CC arch-darwin-double-debug/obj/src/sys/error/errstop.o
          CC arch-darwin-double-debug/obj/src/sys/error/fp.o
          CC arch-darwin-double-debug/obj/src/sys/error/signal.o
          CC arch-darwin-double-debug/obj/src/sys/error/pstack.o
          CC arch-darwin-double-debug/obj/src/sys/error/checkptr.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-auto/adebugf.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-auto/checkptrf.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-auto/errf.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-auto/fpf.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-auto/signalf.o
          CC arch-darwin-double-debug/obj/src/sys/error/ftn-custom/zerrf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/version.o
          CC arch-darwin-double-debug/obj/src/sys/objects/gcomm.o
          CC arch-darwin-double-debug/obj/src/sys/objects/gtype.o
          CC arch-darwin-double-debug/obj/src/sys/objects/olist.o
          CC arch-darwin-double-debug/obj/src/sys/objects/pname.o
          CC arch-darwin-double-debug/obj/src/sys/objects/tagm.o
          CC arch-darwin-double-debug/obj/src/sys/objects/destroy.o
          CC arch-darwin-double-debug/obj/src/sys/objects/gcookie.o
          CC arch-darwin-double-debug/obj/src/sys/objects/inherit.o
          CC arch-darwin-double-debug/obj/src/sys/objects/options.o
          CC arch-darwin-double-debug/obj/src/sys/objects/pgname.o
          CC arch-darwin-double-debug/obj/src/sys/objects/prefix.o
          CC arch-darwin-double-debug/obj/src/sys/objects/init.o
          CC arch-darwin-double-debug/obj/src/sys/objects/pinit.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ptype.o
          CC arch-darwin-double-debug/obj/src/sys/objects/state.o
          CC arch-darwin-double-debug/obj/src/sys/objects/aoptions.o
          CC arch-darwin-double-debug/obj/src/sys/objects/subcomm.o
          CC arch-darwin-double-debug/obj/src/sys/objects/fcallback.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/destroyf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/gcommf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/inheritf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/optionsf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/pinitf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/ptypef.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/statef.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-auto/tagmf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zgcommf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zoptionsf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zpgnamef.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zpnamef.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zprefixf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zdestroyf.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zstart.o
          CC arch-darwin-double-debug/obj/src/sys/objects/ftn-custom/zstartf.o
          CC arch-darwin-double-debug/obj/src/sys/totalview/tv_data_display.o
          CC arch-darwin-double-debug/obj/src/sys/info/verboseinfo.o
          CC arch-darwin-double-debug/obj/src/sys/info/ftn-auto/verboseinfof.o
          CC arch-darwin-double-debug/obj/src/sys/info/ftn-custom/zverboseinfof.o
          CC arch-darwin-double-debug/obj/src/sys/logging/plog.o
          CC arch-darwin-double-debug/obj/src/sys/logging/ftn-auto/plogf.o
          CC arch-darwin-double-debug/obj/src/sys/logging/ftn-custom/zplogf.o
          CC arch-darwin-double-debug/obj/src/sys/logging/utils/classlog.o
          CC arch-darwin-double-debug/obj/src/sys/logging/utils/stagelog.o
          CC arch-darwin-double-debug/obj/src/sys/logging/utils/eventlog.o
          CC arch-darwin-double-debug/obj/src/sys/logging/utils/stack.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/binary/binv.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/binary/ftn-auto/binvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/binary/f90-custom/zbinvf90.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/binary/ftn-custom/zbinvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/draw/drawv.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/draw/ftn-auto/drawvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/draw/ftn-custom/zdrawvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/socket/send.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/socket/ftn-custom/zsendf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/vu/petscvu.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/vtk/vtkv.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/vtk/ftn-custom/zvtkvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/ascii/filev.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/ascii/vcreatea.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/ascii/ftn-auto/filevf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zfilevf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/ascii/ftn-custom/zvcreatef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/string/stringv.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/impls/string/ftn-custom/zstringvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/view.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/flush.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/viewregall.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/viewreg.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/viewa.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/dlregispetsc.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/viewers.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/dupl.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/ftn-auto/duplf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/ftn-auto/flushf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/ftn-auto/viewf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/ftn-auto/viewregf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/viewer/interface/ftn-custom/zviewaf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/bag/bag.o
          CC arch-darwin-double-debug/obj/src/sys/classes/bag/ftn-auto/bagf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/bag/f90-custom/zbagf90.o
          CC arch-darwin-double-debug/obj/src/sys/classes/bag/ftn-custom/zbagf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/xinit.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/wmap.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/xcolor.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/xops.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/text.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/tone.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/drawopenx.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/x/ftn-custom/zdrawopenxf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/impls/tikz/tikz.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/draw.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dline.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dlinew.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dlinegw.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dtext.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dtextv.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dtexts.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dtextgs.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dpoint.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dpoints.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dviewp.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dcoor.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dpause.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dgpause.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dgcoor.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dbuff.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dsetpause.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dflush.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dsflush.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dclear.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dsclear.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/drect.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dtri.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dmouse.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/drawreg.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/drawregall.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/dellipse.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dbufff.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dclearf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dcoorf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dellipsef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dflushf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dgcoorf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dgpausef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dlinef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dlinegwf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dlinewf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dmousef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dpausef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dpointsf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dpointf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/drawf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/drawregf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/drectf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dsclearf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dsetpausef.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dsflushf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dtextgsf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dtextsf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dtrif.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-auto/dviewpf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-custom/zdrawf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-custom/zdrawregf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-custom/zdtextf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-custom/zdtextvf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/interface/ftn-custom/zdtrif.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/axis.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/lg.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/dscatter.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/hists.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/zoom.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/hue.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/lgc.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/axisc.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/axiscf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/axisf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/dscatterf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/histsf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/lgcf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-auto/lgf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-custom/zaxisf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/draw/utils/ftn-custom/zzoomf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/impls/rand/rand.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/impls/rand48/rand48.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/random.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/randreg.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/dlregisrand.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/randomc.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/ftn-auto/randomcf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/ftn-auto/randomf.o
          CC arch-darwin-double-debug/obj/src/sys/classes/random/interface/ftn-custom/zrandomf.o
          CC arch-darwin-double-debug/obj/src/sys/time/cputime.o
          CC arch-darwin-double-debug/obj/src/sys/time/fdate.o
          CC arch-darwin-double-debug/obj/src/sys/time/ftn-auto/cputimef.o
          CC arch-darwin-double-debug/obj/src/sys/time/ftn-custom/zptimef.o
          CC arch-darwin-double-debug/obj/src/sys/webclient/client.o
          CC arch-darwin-double-debug/obj/src/sys/webclient/google.o
          CC arch-darwin-double-debug/obj/src/sys/webclient/box.o
          CC arch-darwin-double-debug/obj/src/sys/webclient/textbelt.o
          CC arch-darwin-double-debug/obj/src/sys/webclient/globus.o
          CC arch-darwin-double-debug/obj/src/sys/f90-src/f90_cwrap.o
          FC arch-darwin-double-debug/obj/src/sys/objects/f2003-src/fsrc/optionenum.o
          FC arch-darwin-double-debug/obj/src/sys/classes/bag/f2003-src/fsrc/bagenum.o
          FC arch-darwin-double-debug/obj/src/sys/fsrc/somefort.o
          FC arch-darwin-double-debug/obj/src/sys/f90-mod/petscsysmod.o
          FC arch-darwin-double-debug/obj/src/sys/f90-src/fsrc/f90_fwrap.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/isltog.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/isio.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/pmap.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/vsectionis.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/ftn-auto/isltogf.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/ftn-auto/vsectionisf.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/f90-custom/zisltogf90.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/f90-custom/zvsectionisf90.o
          CC arch-darwin-double-debug/obj/src/vec/is/utils/ftn-custom/zisltogf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/f90-custom/zblockf90.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/stride/stride.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/stride/ftn-auto/stridef.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/block/block.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/block/ftn-auto/blockf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/block/ftn-custom/zblockf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/general/general.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/impls/general/ftn-auto/generalf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/isregall.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/index.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/isreg.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/ftn-auto/indexf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/ftn-auto/isregf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/f90-custom/zindexf90.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/interface/ftn-custom/zindexf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/iscomp.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/iscoloring.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/isdiff.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/isblock.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/ftn-auto/isblockf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/ftn-auto/iscoloringf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/ftn-auto/iscompf.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/ftn-auto/isdifff.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/f90-custom/ziscoloringf90.o
          CC arch-darwin-double-debug/obj/src/vec/is/is/utils/ftn-custom/ziscoloringf.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/memscalable/aomemscalable.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/mapping/aomapping.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/mapping/ftn-auto/aomappingf.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/mapping/ftn-custom/zaomappingf.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/basic/aobasic.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/impls/basic/ftn-custom/zaobasicf.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/ao.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/dlregisdm.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/aoreg.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/aoregall.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/ftn-auto/aof.o
          CC arch-darwin-double-debug/obj/src/vec/is/ao/interface/ftn-custom/zaof.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/impls/window/sfwindow.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/impls/basic/sfbasic.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/interface/dlregissf.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/interface/sfregi.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/interface/sf.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/interface/sftype.o
          CC arch-darwin-double-debug/obj/src/vec/is/sf/interface/ftn-auto/sff.o
          CC arch-darwin-double-debug/obj/src/vec/pf/impls/constant/const.o
          CC arch-darwin-double-debug/obj/src/vec/pf/impls/string/cstring.o
          CC arch-darwin-double-debug/obj/src/vec/pf/interface/pf.o
          CC arch-darwin-double-debug/obj/src/vec/pf/interface/pfall.o
          CC arch-darwin-double-debug/obj/src/vec/pf/interface/ftn-auto/pff.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/shared/shvec.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/shared/ftn-auto/shvecf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/nest/vecnest.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/nest/ftn-auto/vecnestf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/nest/ftn-custom/zvecnestf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/bvec2.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/bvec1.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/dvec2.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/vseqcr.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/bvec3.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/ftn-auto/vseqcrf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/ftn-custom/zvsectionf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/seq/ftn-custom/zbvec2f.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/pbvec.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/pdvec.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/pvec2.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/vmpicr.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/commonmpvec.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/ftn-auto/commonmpvecf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/ftn-auto/pbvecf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/ftn-auto/vmpicrf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/ftn-custom/zpbvecf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/vector.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/veccreate.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/vecreg.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/vecregall.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/dlregisvec.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/rvector.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/ftn-auto/rvectorf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/ftn-auto/veccreatef.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/ftn-auto/vectorf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/f90-custom/zvectorf90.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/ftn-custom/zvecregf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/interface/ftn-custom/zvectorf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vinv.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vpscat.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vscat.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/cmesh.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vecio.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/comb.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vecstash.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vecmpitoseq.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vecs.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/vsection.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/projection.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/cmeshf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/combf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/projectionf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/veciof.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/vecmpitoseqf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/vinvf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/vpscatf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-auto/vscatf.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/f90-custom/zvsectionf90.o
          CC arch-darwin-double-debug/obj/src/vec/vec/utils/ftn-custom/zvscatf.o
         CXX arch-darwin-double-debug/obj/src/vec/vec/impls/seq/seqviennacl/vecviennacl.o
         CXX arch-darwin-double-debug/obj/src/vec/vec/impls/mpi/mpiviennacl/mpiviennacl.o
          FC arch-darwin-double-debug/obj/src/vec/f90-mod/petscvecmod.o
          CC arch-darwin-double-debug/obj/src/mat/ftn-custom/zmat.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/color.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/degr.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/dsm.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/ido.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/numsrt.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/seq.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/slo.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/minpack/setr.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/natural/natural.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/jp/jp.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/power/power.o
          CC arch-darwin-double-debug/obj/src/mat/color/impls/greedy/greedy.o
          CC arch-darwin-double-debug/obj/src/mat/color/interface/matcoloring.o
          CC arch-darwin-double-debug/obj/src/mat/color/interface/matcoloringregi.o
          CC arch-darwin-double-debug/obj/src/mat/color/interface/ftn-auto/matcoloringf.o
          CC arch-darwin-double-debug/obj/src/mat/color/interface/ftn-custom/zmatcoloringf.o
          CC arch-darwin-double-debug/obj/src/mat/color/utils/bipartite.o
          CC arch-darwin-double-debug/obj/src/mat/color/utils/valid.o
          CC arch-darwin-double-debug/obj/src/mat/color/utils/weights.o
          CC arch-darwin-double-debug/obj/src/mat/partition/partition.o
          CC arch-darwin-double-debug/obj/src/mat/partition/spartition.o
          CC arch-darwin-double-debug/obj/src/mat/partition/ftn-auto/partitionf.o
          CC arch-darwin-double-debug/obj/src/mat/partition/impls/pmetis/pmetis.o
          CC arch-darwin-double-debug/obj/src/mat/partition/impls/pmetis/ftn-auto/pmetisf.o
          CC arch-darwin-double-debug/obj/src/mat/partition/ftn-custom/zpartitionf.o
          CC arch-darwin-double-debug/obj/src/mat/matfd/fdmatrix.o
          CC arch-darwin-double-debug/obj/src/mat/matfd/ftn-auto/fdmatrixf.o
          CC arch-darwin-double-debug/obj/src/mat/matfd/ftn-custom/zfdmatrixf.o
          CC arch-darwin-double-debug/obj/src/mat/coarsen/coarsen.o
          CC arch-darwin-double-debug/obj/src/mat/coarsen/scoarsen.o
          CC arch-darwin-double-debug/obj/src/mat/coarsen/ftn-auto/coarsenf.o
          CC arch-darwin-double-debug/obj/src/mat/coarsen/impls/hem/hem.o
          CC arch-darwin-double-debug/obj/src/mat/coarsen/impls/mis/mis.o
          CC arch-darwin-double-debug/obj/src/mat/interface/matrix.o
          CC arch-darwin-double-debug/obj/src/mat/interface/mhas.o
          CC arch-darwin-double-debug/obj/src/mat/interface/matreg.o
          CC arch-darwin-double-debug/obj/src/mat/interface/matregis.o
          CC arch-darwin-double-debug/obj/src/mat/interface/matnull.o
          CC arch-darwin-double-debug/obj/src/mat/interface/dlregismat.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-auto/matnullf.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-auto/matrixf.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-auto/mhasf.o
          CC arch-darwin-double-debug/obj/src/mat/interface/f90-custom/zmatrixf90.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-custom/zmatregf.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-custom/zmatrixf.o
          CC arch-darwin-double-debug/obj/src/mat/interface/ftn-custom/zmatnullf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/submat/submat.o
          CC arch-darwin-double-debug/obj/src/mat/impls/submat/ftn-auto/submatf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/is/matis.o
          CC arch-darwin-double-debug/obj/src/mat/impls/is/ftn-auto/matisf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/fft/fft.o
          CC arch-darwin-double-debug/obj/src/mat/impls/fft/ftn-custom/zfftf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baij2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa3.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgedi.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa4.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa5.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa6.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/dgefa7.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/aijbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact3.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact4.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact5.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact7.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact9.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact11.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijfact13.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijsolvtrannat.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijsolvtran.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijsolv.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/baijsolvnat.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/ftn-auto/baijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/ftn-custom/zbaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/bstream/bstream.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/seq/bstream/bstrmfact.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/mpibaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/mmbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/baijov.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/mpb_baij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/ftn-auto/mpibaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/ftn-custom/zmpibaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/baij/mpi/bstream/mpibstream.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/seq/dense.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/seq/ftn-custom/zdensef.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/mpi/mpidense.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/mpi/mmdense.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/mpi/ftn-auto/mpidensef.o
          CC arch-darwin-double-debug/obj/src/mat/impls/dense/mpi/ftn-custom/zmpidensef.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/mffd.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/mffddef.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/mfregis.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/ftn-custom/zmffdf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/wp.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/ftn-auto/wpf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/ftn-auto/mffddeff.o
          CC arch-darwin-double-debug/obj/src/mat/impls/mffd/ftn-auto/mffdf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/python/pythonmat.o
          CC arch-darwin-double-debug/obj/src/mat/impls/python/ftn-custom/zpythonmf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/adj/mpi/mpiadj.o
          CC arch-darwin-double-debug/obj/src/mat/impls/adj/mpi/ftn-auto/mpiadjf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/adj/mpi/ftn-custom/zmpiadjf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/maij/maij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/maij/ftn-auto/maijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/lrc/lrc.o
          CC arch-darwin-double-debug/obj/src/mat/impls/lrc/ftn-auto/lrcf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/shell/shell.o
          CC arch-darwin-double-debug/obj/src/mat/impls/shell/shellcnv.o
          CC arch-darwin-double-debug/obj/src/mat/impls/shell/ftn-auto/shellf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/shell/ftn-custom/zshellf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/normal/normm.o
          CC arch-darwin-double-debug/obj/src/mat/impls/normal/ftn-auto/normmf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/composite/mcomposite.o
          CC arch-darwin-double-debug/obj/src/mat/impls/composite/ftn-auto/mcompositef.o
          CC arch-darwin-double-debug/obj/src/mat/impls/nest/matnest.o
          CC arch-darwin-double-debug/obj/src/mat/impls/nest/ftn-auto/matnestf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/nest/ftn-custom/zmatnestf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/transpose/transm.o
          CC arch-darwin-double-debug/obj/src/mat/impls/transpose/ftn-auto/transmf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/localref/mlocalref.o
          CC arch-darwin-double-debug/obj/src/mat/impls/localref/ftn-auto/mlocalreff.o
          CC arch-darwin-double-debug/obj/src/mat/impls/blockmat/seq/blockmat.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaij2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sro.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact3.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact4.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact5.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact6.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact7.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact8.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact9.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact10.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact11.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbaijfact12.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/aijsbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/ftn-auto/sbaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/ftn-custom/zsbaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbstream/sbstream.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/seq/sbstream/sbstrmfact.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/mpisbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/mmsbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/sbaijov.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/mpiaijsbaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/ftn-auto/mpisbaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/ftn-custom/zmpisbaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/sbaij/mpi/sbstream/mpisbstream.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/aij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/aijfact.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/ij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/fdaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/matmatmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/symtranspose.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/matptap.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/matrart.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/inode.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/inode2.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/matmatmatmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/mattransposematmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/ftn-custom/zaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/bas/basfactor.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/bas/spbas.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/csrperm/csrperm.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/ftn-auto/aijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/crl/crl.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mmaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiaijpc.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiov.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/fdmpiaij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiptap.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpimatmatmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpb_aij.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpimatmatmatmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpimattransposematmult.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/ftn-custom/zmpiaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/csrperm/mpicsrperm.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mumps/mumps.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mumps/ftn-auto/mumpsf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/ftn-auto/mpiaijf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/crl/mcrl.o
          CC arch-darwin-double-debug/obj/src/mat/impls/scatter/mscatter.o
          CC arch-darwin-double-debug/obj/src/mat/impls/scatter/ftn-auto/mscatterf.o
          CC arch-darwin-double-debug/obj/src/mat/order/sp1wd.o
          CC arch-darwin-double-debug/obj/src/mat/order/spnd.o
          CC arch-darwin-double-debug/obj/src/mat/order/spqmd.o
          CC arch-darwin-double-debug/obj/src/mat/order/sprcm.o
          CC arch-darwin-double-debug/obj/src/mat/order/sorder.o
          CC arch-darwin-double-debug/obj/src/mat/order/spectral.o
          CC arch-darwin-double-debug/obj/src/mat/order/sregis.o
          CC arch-darwin-double-debug/obj/src/mat/order/degree.o
          CC arch-darwin-double-debug/obj/src/mat/order/fnroot.o
          CC arch-darwin-double-debug/obj/src/mat/order/genqmd.o
          CC arch-darwin-double-debug/obj/src/mat/order/qmdqt.o
          CC arch-darwin-double-debug/obj/src/mat/order/rcm.o
          CC arch-darwin-double-debug/obj/src/mat/order/fn1wd.o
          CC arch-darwin-double-debug/obj/src/mat/order/gen1wd.o
          CC arch-darwin-double-debug/obj/src/mat/order/genrcm.o
          CC arch-darwin-double-debug/obj/src/mat/order/qmdrch.o
          CC arch-darwin-double-debug/obj/src/mat/order/rootls.o
          CC arch-darwin-double-debug/obj/src/mat/order/fndsep.o
          CC arch-darwin-double-debug/obj/src/mat/order/gennd.o
          CC arch-darwin-double-debug/obj/src/mat/order/qmdmrg.o
          CC arch-darwin-double-debug/obj/src/mat/order/qmdupd.o
          CC arch-darwin-double-debug/obj/src/mat/order/wbm.o
          CC arch-darwin-double-debug/obj/src/mat/order/ftn-auto/spectralf.o
          CC arch-darwin-double-debug/obj/src/mat/order/ftn-custom/zsorderf.o
          CC arch-darwin-double-debug/obj/src/mat/utils/convert.o
          CC arch-darwin-double-debug/obj/src/mat/utils/matstash.o
          CC arch-darwin-double-debug/obj/src/mat/utils/axpy.o
          CC arch-darwin-double-debug/obj/src/mat/utils/zerodiag.o
          CC arch-darwin-double-debug/obj/src/mat/utils/getcolv.o
          CC arch-darwin-double-debug/obj/src/mat/utils/gcreate.o
          CC arch-darwin-double-debug/obj/src/mat/utils/freespace.o
          CC arch-darwin-double-debug/obj/src/mat/utils/compressedrow.o
          CC arch-darwin-double-debug/obj/src/mat/utils/multequal.o
          CC arch-darwin-double-debug/obj/src/mat/utils/matstashspace.o
          CC arch-darwin-double-debug/obj/src/mat/utils/pheap.o
          CC arch-darwin-double-debug/obj/src/mat/utils/bandwidth.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/axpyf.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/bandwidthf.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/gcreatef.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/getcolvf.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/multequalf.o
          CC arch-darwin-double-debug/obj/src/mat/utils/ftn-auto/zerodiagf.o
         CXX arch-darwin-double-debug/obj/src/mat/impls/aij/seq/seqviennacl/aijviennacl.o
         CXX arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiviennacl/mpiaijviennacl.o
          FC arch-darwin-double-debug/obj/src/mat/f90-mod/petscmatmod.o
          CC arch-darwin-double-debug/obj/src/dm/impls/shell/dmshell.o
          CC arch-darwin-double-debug/obj/src/dm/impls/shell/ftn-auto/dmshellf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/shell/ftn-custom/zdmshellf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/network/networkcreate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/network/network.o
          CC arch-darwin-double-debug/obj/src/dm/impls/network/ftn-auto/networkcreatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/network/ftn-auto/networkf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/composite/pack.o
          CC arch-darwin-double-debug/obj/src/dm/impls/composite/packm.o
          CC arch-darwin-double-debug/obj/src/dm/impls/composite/ftn-auto/packf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/composite/f90-custom/zfddaf90.o
          CC arch-darwin-double-debug/obj/src/dm/impls/composite/ftn-custom/zfddaf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/da2.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/da1.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/da3.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/daghost.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dacorn.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dagtol.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/daltol.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/daindex.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dascatter.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dacreate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dadestroy.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dalocal.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dadist.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/daview.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dasub.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/gr1.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/gr2.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dagtona.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dainterp.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dapf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dagetarray.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dagetelem.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/da.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dareg.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/fdda.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/grvtk.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dageometry.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dadd.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/dapreallocate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dacornf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dacreatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/daddf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dadistf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/daf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dageometryf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dagetarrayf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/daghostf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dagtolf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dagtonaf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/daindexf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dainterpf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dalocalf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/dapreallocatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/fddaf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-auto/gr1f.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/f90-custom/zda1f90.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zdaf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zda1f.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zda2f.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zda3f.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zdacornf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zdagetscatterf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/ftn-custom/zdaviewf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/redundant/dmredundant.o
          CC arch-darwin-double-debug/obj/src/dm/impls/redundant/ftn-auto/dmredundantf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/patch/patchcreate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/patch/patch.o
          CC arch-darwin-double-debug/obj/src/dm/impls/patch/ftn-auto/patchcreatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/sliced/sliced.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexcreate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plex.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexpartition.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexdistribute.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexrefine.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexinterpolate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexpreallocate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexreorder.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexgeometry.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexlabel.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexsubmesh.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexhdf5.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexexodusii.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexgmsh.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexcgns.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexvtk.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexpoint.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexvtu.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexfem.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexindices.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexbc.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plextree.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexgenerate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/plexorient.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexcgnsf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexcreatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexdistributef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexexodusiif.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexfemf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexgeneratef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexgeometryf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexgmshf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexindicesf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexinterpolatef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexlabelf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexorientf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexpartitionf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexpointf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexrefinef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexreorderf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plextreef.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-auto/plexsubmeshf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/f90-custom/zplexf90.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/f90-custom/zplexgeometryf90.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-custom/zplex.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-custom/zplexinterpolate.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-custom/zplexsubmesh.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-custom/zplexlabel.o
          CC arch-darwin-double-debug/obj/src/dm/impls/plex/ftn-custom/zplexexodusii.o
          CC arch-darwin-double-debug/obj/src/dm/interface/dm.o
          CC arch-darwin-double-debug/obj/src/dm/interface/dmregall.o
          CC arch-darwin-double-debug/obj/src/dm/interface/dmget.o
          CC arch-darwin-double-debug/obj/src/dm/interface/dmi.o
          CC arch-darwin-double-debug/obj/src/dm/interface/dlregisdmdm.o
          CC arch-darwin-double-debug/obj/src/dm/interface/ftn-auto/dmf.o
          CC arch-darwin-double-debug/obj/src/dm/interface/ftn-auto/dmgetf.o
          CC arch-darwin-double-debug/obj/src/dm/interface/ftn-custom/zdmf.o
          CC arch-darwin-double-debug/obj/src/dm/interface/ftn-custom/zdmgetf.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/dt.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/dtfe.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/dtfv.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/dtds.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/ftn-auto/dtdsf.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/ftn-auto/dtf.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/ftn-auto/dtfef.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/ftn-auto/dtfvf.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/f90-custom/zdtf90.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/f90-custom/zdtdsf90.o
          CC arch-darwin-double-debug/obj/src/dm/dt/interface/ftn-custom/zdtf.o
          FC arch-darwin-double-debug/obj/src/dm/f90-mod/petscdmmod.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/lsc/lsc.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/bjacobi/bjacobi.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/bjacobi/ftn-auto/bjacobif.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/bjacobi/ftn-custom/zbjacobif.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/is/pcis.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/is/ftn-auto/pcisf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/is/nn/nn.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/sor/sor.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/sor/ftn-auto/sorf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/pbjacobi/pbjacobi.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/cp/cp.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/eisens/eisen.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/eisens/ftn-auto/eisenf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/wb/wb.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/wb/ftn-auto/wbf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/ksp/pcksp.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/ksp/ftn-auto/pckspf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/python/pythonpc.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/python/ftn-custom/zpythonpcf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/bitmask.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/comm.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/gs.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/ivec.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/xxt.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/xyt.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/tfs/tfs.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/factor.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/factimpl.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/ftn-custom/zluf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/cholesky/cholesky.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/cholesky/ftn-auto/choleskyf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/icc/icc.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/lu/lu.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/ilu/ilu.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/factor/ftn-auto/factorf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/jacobi/ftn-auto/jacobif.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/jacobi/jacobi.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/kaczmarz/kaczmarz.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/galerkin/galerkin.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/galerkin/ftn-auto/galerkinf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/shell/shellpc.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/shell/ftn-auto/shellpcf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/shell/ftn-custom/zshellpcf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gasm/gasm.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gasm/ftn-auto/gasmf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mat/pcmat.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/composite/composite.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/composite/ftn-auto/compositef.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/composite/ftn-custom/zcompositef.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/none/none.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/redistribute/redistribute.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/redistribute/ftn-auto/redistributef.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/gamg.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/agg.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/geo.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/tools.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/classical.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/ftn-auto/aggf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/gamg/ftn-auto/gamgf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/spai/ispai.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/spai/dspai.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/spai/ftn-auto/ispaif.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/fieldsplit/fieldsplit.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/fieldsplit/ftn-auto/fieldsplitf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/asm/asm.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/asm/ftn-auto/asmf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/asm/ftn-custom/zasmf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/mg.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/fmg.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/smg.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/mgfunc.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/ftn-auto/mgf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/ftn-auto/mgfuncf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/ftn-custom/zmgf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/svd/svd.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/redundant/redundant.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/redundant/ftn-auto/redundantf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/precon.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/pcset.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/pcregis.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/ftn-auto/pcsetf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/ftn-auto/preconf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/ftn-custom/zpcsetf.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/interface/ftn-custom/zpreconf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/minres/minres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bicg/bicg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/fcg/fcg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/fcg/ftn-auto/fcgf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/cg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/cgeig.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/cgtype.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/gltr/gltr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/gltr/ftn-auto/gltrf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/cgne/cgne.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/stcg/stcg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/stcg/ftn-auto/stcgf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/groppcg/groppcg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/ftn-auto/cgtypef.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/nash/nash.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/nash/ftn-auto/nashf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cg/pipecg/pipecg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cr/cr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cr/pipecr/pipecr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/ibcgs/ibcgs.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/python/pythonksp.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/python/ftn-custom/zpythonkspf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gcr/gcr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/qcg/qcg.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/qcg/ftn-auto/qcgf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/rich/rich.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/rich/richscale.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/rich/ftn-auto/richscalef.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/specest/specest.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bcgsl/bcgsl.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bcgsl/ftn-auto/bcgslf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/lsqr/lsqr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/lsqr/lsqr_monitor.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/lsqr/lsqr_converged.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cheby/cheby.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cheby/ftn-auto/chebyf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bcgs/bcgs.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bcgs/fbcgs/fbcgs.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/bcgs/fbcgsr/fbcgsr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/lcd/lcd.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/preonly/preonly.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/gmres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/borthog.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/borthog2.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/gmres2.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/gmreig.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/gmpre.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/dgmres/dgmres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/ftn-auto/gmpref.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/ftn-auto/gmresf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/pgmres/pgmres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/fgmres/fgmres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/fgmres/modpcf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/fgmres/ftn-auto/modpcff.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/gmres/lgmres/lgmres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/cgs/cgs.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/symmlq/symmlq.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/tfqmr/tfqmr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/impls/tcqmr/tcqmr.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/itcl.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/itfunc.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/iguess.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/itcreate.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/iterativ.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/itres.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/itregis.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/xmon.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/eige.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/dlregisksp.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/dmksp.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/eigef.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/itclf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/itcreatef.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/iterativf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/itfuncf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/itresf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-auto/xmonf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/f90-custom/zitfuncf90.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-custom/zitclf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-custom/zitcreatef.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-custom/zitfuncf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-custom/zxonf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/interface/ftn-custom/zdmkspf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/utils/schurm.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/utils/dmproject.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/utils/ftn-auto/dmprojectf.o
          CC arch-darwin-double-debug/obj/src/ksp/ksp/utils/ftn-auto/schurmf.o
          FC arch-darwin-double-debug/obj/src/ksp/f90-mod/petsckspmod.o
          CC arch-darwin-double-debug/obj/src/snes/mf/snesmfj.o
          CC arch-darwin-double-debug/obj/src/snes/mf/ftn-auto/snesmfjf.o
          CC arch-darwin-double-debug/obj/src/snes/utils/dmsnes.o
          CC arch-darwin-double-debug/obj/src/snes/utils/dmdasnes.o
          CC arch-darwin-double-debug/obj/src/snes/utils/dmlocalsnes.o
          CC arch-darwin-double-debug/obj/src/snes/utils/dmplexsnes.o
          CC arch-darwin-double-debug/obj/src/snes/utils/ftn-auto/dmplexsnesf.o
          CC arch-darwin-double-debug/obj/src/snes/utils/ftn-custom/zdmdasnesf.o
          CC arch-darwin-double-debug/obj/src/snes/utils/ftn-custom/zdmlocalsnesf.o
          CC arch-darwin-double-debug/obj/src/snes/utils/ftn-custom/zdmsnesf.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snes.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snesj.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snesregi.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snesut.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snesj2.o
          CC arch-darwin-double-debug/obj/src/snes/interface/dlregissnes.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snesob.o
          CC arch-darwin-double-debug/obj/src/snes/interface/snespc.o
          CC arch-darwin-double-debug/obj/src/snes/interface/ftn-auto/snesf.o
          CC arch-darwin-double-debug/obj/src/snes/interface/ftn-auto/snespcf.o
          CC arch-darwin-double-debug/obj/src/snes/interface/ftn-auto/snesutf.o
          CC arch-darwin-double-debug/obj/src/snes/interface/f90-custom/zsnesf90.o
          CC arch-darwin-double-debug/obj/src/snes/interface/ftn-custom/zsnesf.o
          CC arch-darwin-double-debug/obj/src/snes/interface/noise/snesmfj2.o
          CC arch-darwin-double-debug/obj/src/snes/interface/noise/snesnoise.o
          CC arch-darwin-double-debug/obj/src/snes/interface/noise/snesdnest.o
          CC arch-darwin-double-debug/obj/src/snes/impls/vi/vi.o
          CC arch-darwin-double-debug/obj/src/snes/impls/vi/ftn-auto/vif.o
          CC arch-darwin-double-debug/obj/src/snes/impls/vi/ss/viss.o
          CC arch-darwin-double-debug/obj/src/snes/impls/vi/rs/virs.o
          CC arch-darwin-double-debug/obj/src/snes/impls/shell/snesshell.o
          CC arch-darwin-double-debug/obj/src/snes/impls/shell/ftn-auto/snesshellf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/shell/ftn-custom/zsnesshellf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/gs/snesgs.o
          CC arch-darwin-double-debug/obj/src/snes/impls/gs/gssecant.o
          CC arch-darwin-double-debug/obj/src/snes/impls/gs/ftn-auto/snesgsf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ngmres/snesngmres.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ngmres/ngmresfunc.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ngmres/anderson.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ngmres/ftn-auto/snesngmresf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/composite/snescomposite.o
          CC arch-darwin-double-debug/obj/src/snes/impls/composite/ftn-auto/snescompositef.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/fas.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/fasgalerkin.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/fasfunc.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/ftn-auto/fasf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/ftn-auto/fasfuncf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/fas/ftn-auto/fasgalerkinf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ksponly/ksponly.o
          CC arch-darwin-double-debug/obj/src/snes/impls/tr/tr.o
          CC arch-darwin-double-debug/obj/src/snes/impls/python/pythonsnes.o
          CC arch-darwin-double-debug/obj/src/snes/impls/python/ftn-custom/zpythonsf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ls/ls.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ms/ms.o
          CC arch-darwin-double-debug/obj/src/snes/impls/qn/qn.o
          CC arch-darwin-double-debug/obj/src/snes/impls/qn/ftn-auto/qnf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/test/snestest.o
          CC arch-darwin-double-debug/obj/src/snes/impls/richardson/snesrichardson.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ncg/snesncg.o
          CC arch-darwin-double-debug/obj/src/snes/impls/ncg/ftn-auto/snesncgf.o
          CC arch-darwin-double-debug/obj/src/snes/impls/nasm/nasm.o
          CC arch-darwin-double-debug/obj/src/snes/impls/nasm/aspin.o
          CC arch-darwin-double-debug/obj/src/snes/impls/nasm/ftn-auto/nasmf.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/bt/linesearchbt.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/bt/ftn-auto/linesearchbtf.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/shell/linesearchshell.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/cp/linesearchcp.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/l2/linesearchl2.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/impls/basic/linesearchbasic.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/interface/linesearch.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/interface/linesearchregi.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/interface/ftn-auto/linesearchf.o
          CC arch-darwin-double-debug/obj/src/snes/linesearch/interface/ftn-custom/zlinesearchf.o
          FC arch-darwin-double-debug/obj/src/snes/f90-mod/petscsnesmod.o
          CC arch-darwin-double-debug/obj/src/ts/characteristic/impls/da/slda.o
          CC arch-darwin-double-debug/obj/src/ts/characteristic/interface/characteristic.o
          CC arch-darwin-double-debug/obj/src/ts/characteristic/interface/mocregis.o
          CC arch-darwin-double-debug/obj/src/ts/characteristic/interface/slregis.o
          CC arch-darwin-double-debug/obj/src/ts/characteristic/interface/ftn-auto/characteristicf.o
          CC arch-darwin-double-debug/obj/src/ts/utils/dmts.o
          CC arch-darwin-double-debug/obj/src/ts/utils/dmlocalts.o
          CC arch-darwin-double-debug/obj/src/ts/utils/dmdats.o
          CC arch-darwin-double-debug/obj/src/ts/utils/dmplexts.o
          CC arch-darwin-double-debug/obj/src/ts/utils/ftn-auto/dmplextsf.o
          CC arch-darwin-double-debug/obj/src/ts/event/tsevent.o
          CC arch-darwin-double-debug/obj/src/ts/interface/ts.o
          CC arch-darwin-double-debug/obj/src/ts/interface/tscreate.o
          CC arch-darwin-double-debug/obj/src/ts/interface/tsreg.o
          CC arch-darwin-double-debug/obj/src/ts/interface/tsregall.o
          CC arch-darwin-double-debug/obj/src/ts/interface/dlregists.o
          CC arch-darwin-double-debug/obj/src/ts/interface/tseig.o
          CC arch-darwin-double-debug/obj/src/ts/interface/ftn-auto/tsf.o
          CC arch-darwin-double-debug/obj/src/ts/interface/ftn-custom/ztscreatef.o
          CC arch-darwin-double-debug/obj/src/ts/interface/ftn-custom/ztsf.o
          CC arch-darwin-double-debug/obj/src/ts/interface/ftn-custom/ztsregf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/python/pythonts.o
          CC arch-darwin-double-debug/obj/src/ts/impls/python/ftn-custom/zpythontf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/explicit/ssp/ssp.o
          CC arch-darwin-double-debug/obj/src/ts/impls/explicit/ssp/ftn-auto/sspf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/explicit/ssp/ftn-custom/zsspf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/explicit/euler/euler.o
          CC arch-darwin-double-debug/obj/src/ts/impls/explicit/rk/rk.o
          CC arch-darwin-double-debug/obj/src/ts/impls/pseudo/posindep.o
          CC arch-darwin-double-debug/obj/src/ts/impls/pseudo/ftn-auto/posindepf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/arkimex/arkimex.o
          CC arch-darwin-double-debug/obj/src/ts/impls/arkimex/ftn-custom/zarkimexf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/eimex/eimex.o
          CC arch-darwin-double-debug/obj/src/ts/impls/rosw/rosw.o
          CC arch-darwin-double-debug/obj/src/ts/impls/rosw/ftn-custom/zroswf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/alpha/alpha.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/alpha/ftn-auto/alphaf.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/gl/gl.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/gl/gladapt.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/theta/theta.o
          CC arch-darwin-double-debug/obj/src/ts/impls/implicit/theta/ftn-auto/thetaf.o
          CC arch-darwin-double-debug/obj/src/ts/adapt/impls/cfl/adaptcfl.o
          CC arch-darwin-double-debug/obj/src/ts/adapt/impls/none/adaptnone.o
          CC arch-darwin-double-debug/obj/src/ts/adapt/impls/basic/adaptbasic.o
          CC arch-darwin-double-debug/obj/src/ts/adapt/interface/tsadapt.o
          CC arch-darwin-double-debug/obj/src/ts/adapt/interface/ftn-auto/tsadaptf.o
          FC arch-darwin-double-debug/obj/src/ts/f90-mod/petsctsmod.o
          CC arch-darwin-double-debug/obj/src/tao/matrix/lmvmmat.o
          CC arch-darwin-double-debug/obj/src/tao/matrix/adamat.o
          CC arch-darwin-double-debug/obj/src/tao/matrix/submatfree.o
          CC arch-darwin-double-debug/obj/src/tao/bound/impls/gpcg/gpcg.o
          CC arch-darwin-double-debug/obj/src/tao/bound/impls/tron/tron.o
          CC arch-darwin-double-debug/obj/src/tao/bound/impls/blmvm/blmvm.o
          CC arch-darwin-double-debug/obj/src/tao/bound/impls/bqpip/bqpip.o
          CC arch-darwin-double-debug/obj/src/tao/bound/utils/isutil.o
          CC arch-darwin-double-debug/obj/src/tao/util/tao_util.o
          CC arch-darwin-double-debug/obj/src/tao/util/ftn-auto/tao_utilf.o
          CC arch-darwin-double-debug/obj/src/tao/interface/taosolver.o
          CC arch-darwin-double-debug/obj/src/tao/interface/taosolver_fg.o
          CC arch-darwin-double-debug/obj/src/tao/interface/taosolverregi.o
          CC arch-darwin-double-debug/obj/src/tao/interface/taosolver_hj.o
          CC arch-darwin-double-debug/obj/src/tao/interface/taosolver_bounds.o
          CC arch-darwin-double-debug/obj/src/tao/interface/dlregistao.o
          CC arch-darwin-double-debug/obj/src/tao/interface/fdiff.o
          CC arch-darwin-double-debug/obj/src/tao/interface/fdtest.o
          CC arch-darwin-double-debug/obj/src/tao/interface/ftn-auto/taosolver_boundsf.o
          CC arch-darwin-double-debug/obj/src/tao/interface/ftn-auto/taosolver_hjf.o
          CC arch-darwin-double-debug/obj/src/tao/interface/ftn-auto/taosolver_fgf.o
          CC arch-darwin-double-debug/obj/src/tao/interface/ftn-auto/taosolverf.o
          CC arch-darwin-double-debug/obj/src/tao/interface/ftn-custom/ztaosolverf.o
          CC arch-darwin-double-debug/obj/src/tao/pde_constrained/impls/lcl/lcl.o
          CC arch-darwin-double-debug/obj/src/tao/complementarity/impls/ssls/ssls.o
          CC arch-darwin-double-debug/obj/src/tao/complementarity/impls/ssls/ssils.o
          CC arch-darwin-double-debug/obj/src/tao/complementarity/impls/ssls/ssfls.o
          CC arch-darwin-double-debug/obj/src/tao/complementarity/impls/asls/asils.o
          CC arch-darwin-double-debug/obj/src/tao/complementarity/impls/asls/asfls.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/nls/nls.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/neldermead/neldermead.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/ntr/ntr.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/cg/taocg.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/lmvm/lmvm.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/bmrm/bmrm.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/ntl/ntl.o
          CC arch-darwin-double-debug/obj/src/tao/unconstrained/impls/owlqn/owlqn.o
          CC arch-darwin-double-debug/obj/src/tao/constrained/impls/ipm/ipm.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/impls/armijo/armijo.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/impls/morethuente/morethuente.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/impls/owarmijo/owarmijo.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/impls/unit/unit.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/impls/gpcglinesearch/gpcglinesearch.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/interface/taolinesearch.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/interface/dlregis_taolinesearch.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/interface/ftn-auto/taolinesearchf.o
          CC arch-darwin-double-debug/obj/src/tao/linesearch/interface/ftn-custom/ztaolinesearchf.o
          CC arch-darwin-double-debug/obj/src/tao/leastsquares/impls/pounders/pounders.o
          CC arch-darwin-double-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
          CC arch-darwin-double-debug/obj/src/vec/vec/impls/hypre/vhyp.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/seq/seqviennacl/ftn-custom/zaijviennaclf.o
          CC arch-darwin-double-debug/obj/src/mat/impls/aij/mpi/mpiviennacl/ftn-custom/zmpiaijviennaclf.o
          CC arch-darwin-double-debug/obj/src/dm/impls/da/hypre/mhyp.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/hypre/hypre.o
          CC arch-darwin-double-debug/obj/src/ksp/pc/impls/hypre/ftn-custom/zhypref.o
     CLINKER /Users/patrick/program/petsc/arch-darwin-double-debug/lib/libpetsc.3.05.2.dylib
    DSYMUTIL /Users/patrick/program/petsc/arch-darwin-double-debug/lib/libpetsc.3.05.2.dylib
make[2]: Leaving directory `/Users/patrick/program/petsc'
make[1]: Leaving directory `/Users/patrick/program/petsc'
Now to check if the libraries are working do:
make PETSC_DIR=/Users/patrick/program/petsc PETSC_ARCH=arch-darwin-double-debug test
Finishing at: Tue Dec 16 10:54:44 PST 2014
                              Pushing language C
                              Popping language C
                              Pushing language CUDA
                              Popping language CUDA
                              Pushing language Cxx
                              Popping language Cxx
                              Pushing language FC
                              Popping language FC
Starting Configure Run at Tue Dec 16 10:46:35 2014
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_DIR=/Users/patrick/program/petsc PETSC_ARCH=arch-darwin-double-debug --download-mpich --download-fblaslapack --with-cc=clang --with-cxx=clang++ --with-fc=gfortran-mp-4.9 --with-debugging=1 --with-precision=double --download-mumps --download-scalapack --download-metis --download-parmetis --download-spai --download-hypre --download-viennacl --with-opencl
Working directory: /Users/patrick/program/petsc
Machine platform:
('Darwin', 'Patricks-MacBook-Pro.local', '13.4.0', 'Darwin Kernel Version 13.4.0: Sun Aug 17 19:50:11 PDT 2014; root:xnu-2422.115.4~1/RELEASE_X86_64', 'x86_64', 'i386')
Python version:
2.7.5 (default, Mar  9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
          Pushing language C
          Popping language C
          Pushing language FC
          Popping language FC
TEST configureExternalPackagesDir from config.framework(/Users/patrick/program/petsc/config/BuildSystem/config/framework.py:829)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:829)
TEST configureDebuggers from config.utilities.debuggers(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /opt/local/bin/gdb...not found
Checking for program /opt/local/sbin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /usr/sbin/gdb...not found
Checking for program /sbin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /opt/X11/bin/gdb...not found
Checking for program /Users/patrick/gdb...not found
Checking for program /opt/local/bin/dbx...not found
Checking for program /opt/local/sbin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/sbin/dbx...not found
Checking for program /sbin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /opt/X11/bin/dbx...not found
Checking for program /Users/patrick/dbx...not found
Checking for program /opt/local/bin/xdb...not found
Checking for program /opt/local/sbin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/sbin/xdb...not found
Checking for program /sbin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /opt/X11/bin/xdb...not found
Checking for program /Users/patrick/xdb...not found
Checking for program /opt/local/bin/dsymutil...not found
Checking for program /opt/local/sbin/dsymutil...not found
Checking for program /usr/bin/dsymutil...found
            Defined make macro "DSYMUTIL" to "/usr/bin/dsymutil"
TEST configureGit from config.sourceControl(/Users/patrick/program/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /opt/local/bin/git...found
            Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.1.2
TEST configureCLanguage from PETSc.options.languages(/Users/patrick/program/petsc/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
        C language is C
          Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/Users/patrick/program/petsc/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
        Version Information:
        #define PETSC_VERSION_RELEASE    0
        #define PETSC_VERSION_MAJOR      3
        #define PETSC_VERSION_MINOR      5
        #define PETSC_VERSION_SUBMINOR   2
        #define PETSC_VERSION_PATCH      0
        #define PETSC_VERSION_DATE       "unknown"
        #define PETSC_VERSION_GIT        "unknown"
        #define PETSC_VERSION_DATE_GIT   "unknown"
        #define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
        #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
        #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
          Defined make macro "DIR" to "/Users/patrick/program/petsc"
TEST configureInstallationMethod from PETSc.options.petscclone(/Users/patrick/program/petsc/config/PETSc/options/petscclone.py:15)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:15)
        bin/maint exists. This appears to be a repository clone
        .git directory exists
          Defined "VERSION_GIT" to ""v3.5.2-1118-g64daeef""
          Defined "VERSION_DATE_GIT" to ""2014-12-11 04:32:01 -0600""
          Defined "VERSION_BRANCH_GIT" to ""master""
TEST getDatafilespath from PETSc.options.dataFilesPath(/Users/patrick/program/petsc/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureArchitecture from PETSc.options.arch(/Users/patrick/program/petsc/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
  Checks PETSC_ARCH and sets if not set
          Defined "ARCH" to ""arch-darwin-double-debug""
TEST setInstallDir from PETSc.options.installDir(/Users/patrick/program/petsc/config/PETSc/options/installDir.py:34)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:34)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/Users/patrick/program/petsc/config/PETSc/options/installDir.py:73)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:73)
TEST cleanInstallDir from PETSc.options.installDir(/Users/patrick/program/petsc/config/PETSc/options/installDir.py:66)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:66)
TEST configureInstallDir from PETSc.options.installDir(/Users/patrick/program/petsc/config/PETSc/options/installDir.py:50)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:50)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
        Changed persistence directory to /Users/patrick/program/petsc/arch-darwin-double-debug/conf
TEST restoreReconfigure from PETSc.options.installDir(/Users/patrick/program/petsc/config/PETSc/options/installDir.py:86)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:86)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/Users/patrick/program/petsc/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/Users/patrick/program/petsc/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1534)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1534)
        **** printenv ****
VERSIONER_PYTHON_PREFER_32_BIT=no
LC_CTYPE=UTF-8
LOGNAME=patrick
USER=patrick
PATH=/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/opt/X11/bin
HOME=/Users/patrick
DISPLAY=/tmp/launch-FrMKw2/org.macosforge.xquartz:0
TERM_PROGRAM=iTerm.app
TERM=xterm-256color
SHELL=/bin/bash
COLORFGBG=12;8
VERSIONER_PYTHON_VERSION=2.7
SHLVL=1
ITERM_SESSION_ID=w4t0p0
_=./configure
SSH_AUTH_SOCK=/tmp/launch-OY9ieD/Listeners
Apple_PubSub_Socket_Render=/tmp/launch-hHYAUR/Render
ITERM_PROFILE=Default
TMPDIR=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/
HISTIGNORE=&:ls:pwd
OLDPWD=/Users/patrick/program/petsc/src/ksp/ksp/examples/tutorials
CLICOLOR=1
__CF_USER_TEXT_ENCODING=0x1F5:0:4
PMPI=/Users/patrick/program/petsc/bin/petscmpiexec
__CHECKFIX1436934=1
TEST resetEnvCompilers from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1541)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1541)
TEST checkMPICompilerOverride from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1506)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1506)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1525)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1525)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:398)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:398)
  Determine the compiler vendor
        Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:408)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:408)
  Initialize the compiler and linker flags
          Pushing language C
        Initialized CFLAGS to
        Initialized LDFLAGS to
          Popping language C
        Initialized CUDAFLAGS to
        Initialized CXXFLAGS to
        Initialized CXX_CXXFLAGS to
          Pushing language FC
        Initialized FFLAGS to
          Popping language FC
        Initialized CPPFLAGS to
        Initialized CUDAPPFLAGS to
        Initialized CXXCPPFLAGS to
        Initialized CC_LINKER_FLAGS to []
        Initialized CXX_LINKER_FLAGS to []
        Initialized FC_LINKER_FLAGS to []
        Initialized CUDAC_LINKER_FLAGS to []
        Initialized sharedLibraryFlags to []
        Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:534)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:534)
  Locate a functional C compiler
Checking for program /opt/local/bin/clang...not found
Checking for program /opt/local/sbin/clang...not found
Checking for program /usr/bin/clang...found
            Defined make macro "CC" to "clang"
            Pushing language C
                        All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34
                      All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest
            Popping language C
TEST checkCPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:567)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:567)
  Locate a functional C preprocessor
            Defined make macro "CPP" to "clang -E"
          Pushing language C
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 82 "/usr/include/sys/signal.h" 2 3 4
# 145 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 148 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 153 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 154 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 266 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 328 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 345 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 364 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 387 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait") ;
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid") ;
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid") ;
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (*)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *, const void *, size_t,
     size_t, int (*)(const void *, const void *));
void *calloc(size_t, size_t);
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t);
int mblen(const char *, size_t);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **, size_t, size_t) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *, size_t, size_t,
int rand(void);
void *realloc(void *, size_t);
void srand(unsigned);
double strtod(const char *, char **) __asm("_" "strtod") ;
float strtof(const char *, char **) __asm("_" "strtof") ;
long strtol(const char *, char **, int);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *, char **, int);
unsigned long
  strtoul(const char *, char **, int);
unsigned long long
  strtoull(const char *, char **, int);
int system(const char *) __asm("_" "system") ;
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]);
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void);
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void);
long nrand48(unsigned short[3]);
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv") ;
long random(void);
int rand_r(unsigned *);
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char *, const char *, int) __asm("_" "setenv") ;
void setkey(const char *) __asm("_" "setkey") ;
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv") ;
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 239 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 241 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 242 "/usr/include/stdlib.h" 2 3 4
u_int32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int );
void arc4random_buf(void * , size_t ) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
u_int32_t
  arc4random_uniform(u_int32_t ) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *, const void *, size_t,
     size_t, int (^)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *, size_t, size_t,
int heapsort_b(void *, size_t, size_t,
int mergesort(void *, size_t, size_t,
int mergesort_b(void *, size_t, size_t,
void psort(void *, size_t, size_t,
     int (*)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *, size_t, size_t,
void psort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *, size_t, size_t,
void qsort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
  strtoq(const char *, char **, int);
unsigned long long
  strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
          Popping language C
TEST checkCUDACompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:608)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:608)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:648)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:648)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:760)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:760)
  Locate a functional Cxx compiler
Checking for program /opt/local/bin/clang++...not found
Checking for program /opt/local/sbin/clang++...not found
Checking for program /usr/bin/clang++...found
            Defined make macro "CXX" to "clang++"
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers     /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language CXX
                    Popping language CXX
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:798)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:798)
  Locate a functional Cxx preprocessor
            Defined make macro "CXXCPP" to "clang++ -E"
Executing: clang++ -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 175 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 1 3
# 85 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 1 3
# 16 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
# 226 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
typedef __char16_t char16_t;
typedef __char32_t char32_t;
# 349 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
namespace std {
  inline namespace __1 {
# 494 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
template <bool> struct __static_assert_test;
template <> struct __static_assert_test<true> {};
template <unsigned> struct __static_assert_check {};
# 86 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 2 3
typedef union {
} __mbstate_t;
 void *__arg;
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
 char __xmm_reg[16];
 __uint16_t __cpu;
 __uint32_t __err;
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
    __uint16_t __cpu;
    __uint32_t __err;
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
 void *ss_sp;
 int ss_flags;
 int uc_onstack;
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 long si_band;
} siginfo_t;
         void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
struct sigvec {
 int sv_mask;
 int sv_flags;
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 386 "/usr/include/sys/signal.h" 3 4
extern "C" {
struct timeval
struct rusage {
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
 uint32_t wm_flags;
 int32_t wm_rate;
# 346 "/usr/include/sys/resource.h" 3 4
extern "C" {
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
union wait {
 int w_status;
 struct {
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 247 "/usr/include/sys/wait.h" 3 4
extern "C" {
# 31 "/usr/include/alloca.h" 3 4
extern "C" {
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 127 "/usr/include/stdlib.h" 3 4
extern "C" {
long long
void free(void *);
long long
  llabs(long long);
size_t mbstowcs(wchar_t * , const char * , size_t);
int mbtowc(wchar_t * , const char * , size_t);
int rand(void);
long double
long long
unsigned long
unsigned long long
size_t wcstombs(char * , const wchar_t * , size_t);
char *ecvt(double, int, int *, int *);
char *fcvt(double, int, int *, int *);
int grantpt(int);
char *l64a(long);
long lrand48(void);
long mrand48(void);
char *ptsname(int);
long random(void);
char *realpath(const char * , char * ) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
void srand48(long);
int unlockpt(int);
u_int32_t
const char
 *getprogname(void);
     unsigned);
     unsigned);
long long
unsigned long long
# 87 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 2 3
# 93 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
namespace std {inline namespace __1 {
using ::size_t;
using ::div_t;
using ::ldiv_t;
using ::lldiv_t;
using ::atof;
using ::atoi;
using ::atol;
using ::atoll;
using ::strtod;
using ::strtof;
using ::strtold;
using ::strtol;
using ::strtoll;
using ::strtoul;
using ::strtoull;
using ::rand;
using ::srand;
using ::calloc;
using ::free;
using ::malloc;
using ::realloc;
using ::abort;
using ::atexit;
using ::exit;
using ::_Exit;
using ::getenv;
using ::system;
using ::bsearch;
using ::qsort;
using ::abs;
using ::labs;
using ::llabs;
using ::div;
using ::ldiv;
using ::lldiv;
using ::mblen;
using ::mbtowc;
using ::wctomb;
using ::mbstowcs;
using ::wcstombs;
# 159 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long abs( long __x) throw() {return labs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long long abs(long long __x) throw() {return llabs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) ldiv_t div( long __x, long __y) throw() {return ldiv(__x, __y);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) lldiv_t div(long long __x, long long __y) throw() {return lldiv(__x, __y);}
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
TEST checkFortranCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:915)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:915)
  Locate a functional Fortran compiler
Checking for program /opt/local/bin/gfortran-mp-4.9...found
            Defined make macro "FC" to "gfortran-mp-4.9"
            Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                            Pushing language C
                                            Popping language C
                                            Pushing language FC
                                            Popping language FC
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
            Popping language FC
TEST checkFortranComments from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:936)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:936)
  Make sure fortran comment "!" works
          Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
        Fortran comments can use ! in column 1
          Popping language FC
TEST checkPIC from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:999)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:999)
  Determine the PIC option for each compiler
       - There needs to be a test that checks that the functionality is actually working
          Pushing language C
Executing: clang --help
stdout:
OVERVIEW: clang LLVM compiler
USAGE: clang [options] <inputs>
OPTIONS:
  -###                    Print (but do not run) the commands to run for this compilation
  --analyze               Run the static analyzer
  -arcmt-migrate-emit-errors
                          Emit ARC errors even if the migrator can fix them
  -arcmt-migrate-report-output <value>
                          Output path for the plist report
  -cxx-isystem <directory>
                          Add directory to the C++ SYSTEM include search path
  -c                      Only run preprocess, compile, and assemble steps
  -dD                     Print macro definitions in -E mode in addition to normal output
  -dependency-dot <value> Filename to write DOT-formatted header dependencies to
  -dependency-file <value>
                          Filename (or -) to write dependency output to
  -dM                     Print macro definitions in -E mode instead of normal output
  -emit-ast               Emit Clang AST files for source inputs
  -emit-llvm              Use the LLVM representation for assembler and object files
  -E                      Only run the preprocessor
  -faltivec               Enable AltiVec vector initializer syntax
  -fansi-escape-codes     Use ANSI escape codes for diagnostics
  -fapple-kext            Use Apple's kernel extensions ABI
  -fapple-pragma-pack     Enable Apple gcc-compatible #pragma pack handling
  -fapplication-extension Restrict code to those available for App Extensions
  -fblocks                Enable the 'blocks' language feature
  -fborland-extensions    Accept non-standard constructs supported by the Borland compiler
  -fbounds-checking       Enable run-time bounds checks
  -fbuild-session-timestamp=<time since Epoch in seconds>
                          Time when the current build session started
  -fcolor-diagnostics     Use colors in diagnostics
  -fcomment-block-commands=<arg>
                          Treat each comma separated argument in <arg> as a documentation comment block command
  -fcxx-exceptions        Enable C++ exceptions
  -fdata-sections         Place each data in its own section (ELF Only)
  -fdebug-types-section   Place debug types in their own section (ELF Only)
  -fdelayed-template-parsing
                          Parse templated function definitions at the end of the translation unit
  -fdiagnostics-parseable-fixits
                          Print fix-its in machine parseable form
  -fdiagnostics-print-source-range-info
                          Print source range spans in numeric form
  -fdiagnostics-show-note-include-stack
                          Display include stacks for diagnostic notes
  -fdiagnostics-show-option
                          Print option name with mappable diagnostics
  -fdiagnostics-show-template-tree
                          Print a template comparison tree for differing templates
  -fdollars-in-identifiers
                          Allow '$' in identifiers
  -femit-all-decls        Emit all declarations, even if unused
  -fexceptions            Enable support for exception handling
  -ffast-math             Enable the *frontend*'s 'fast-math' mode. This has no effect on optimizations, but provides a preprocessor macro __FAST_MATH__ the same as GCC's -ffast-math flag
  -ffixed-r9              Reserve the r9 register (ARM only)
  -ffp-contract=<value>   Form fused FP ops (e.g. FMAs): fast (everywhere) | on (according to FP_CONTRACT pragma, default) | off (never fuse)
  -ffreestanding          Assert that the compilation takes place in a freestanding environment
  -ffunction-sections     Place each function in its own section (ELF Only)
  -fgnu-keywords          Allow GNU-extension keywords regardless of language standard
  -fgnu-runtime           Generate output compatible with the standard GNU Objective-C runtime
  -fgnu89-inline          Use the gnu89 inline semantics
  -finstrument-functions  Generate calls to instrument function entry and exit
  -fmath-errno            Require math functions to indicate errors by setting errno
  -fmodule-implementation-of <name>
                          Specify the name of the module whose implementation file this is
  -fmodule-map-file= <file>
                          Load this module map file
  -fmodule-maps           Read module maps to understand the structure of library headers
  -fmodule-name= <name>   Specify the name of the module to build
  -fmodules-cache-path=<directory>
                          Specify the module cache path
  -fmodules-decluse       Require declaration of modules used within a module
  -fmodules-ignore-macro=<value>
                          Ignore the definition of the given macro when building and loading modules
  -fmodules-prune-after=<seconds>
                          Specify the interval (in seconds) after which a module file will be considered unused
  -fmodules-prune-interval=<seconds>
                          Specify the interval (in seconds) between attempts to prune the module cache
  -fmodules-user-build-path <directory>
                          Specify the module user build path
  -fmodules-validate-once-per-build-session
                          Don't verify input files for the modules if the module has been successfully validate or loaded during this build session
  -fmodules-validate-system-headers
                          Validate the system headers that a module depends on when loading the module
  -fmodules               Enable the 'modules' language feature
  -fms-compatibility      Enable full Microsoft Visual C++ compatibility
  -fms-extensions         Accept some non-standard constructs supported by the Microsoft compiler
  -fmsc-version=<value>   Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fno-access-control     Disable C++ access control
  -fno-assume-sane-operator-new
                          Don't assume that C++'s global operator new can't alias any pointer
  -fno-autolink           Disable generation of linker directives for automatic library linking
  -fno-builtin-<value>    Disable implicit builtin knowledge of a specific function
  -fno-builtin            Disable implicit builtin knowledge of functions
  -fno-common             Compile common globals like normal definitions
  -fno-constant-cfstrings Disable creation of CodeFoundation-type constant strings
  -fno-diagnostics-fixit-info
                          Do not include fixit information in diagnostics
  -fno-dollars-in-identifiers
                          Disallow '$' in identifiers
  -fno-elide-constructors Disable C++ copy constructor elision
  -fno-elide-type         Do not elide types when printing diagnostics
  -fno-lax-vector-conversions
                          Disallow implicit conversions between vectors with a different number of elements or different element types
  -fno-math-builtin       Disable implicit builtin knowledge of math functions
  -fno-merge-all-constants
                          Disallow merging of constants
  -fno-objc-infer-related-result-type
                          do not infer Objective-C related result type based on method family
  -fno-operator-names     Do not treat C++ operator name keywords as synonyms for operators
  -fno-reroll-loops       Turn off loop reroller
  -fno-rtti               Disable generation of rtti information
  -fno-sanitize-blacklist Don't use blacklist file for sanitizers
  -fno-sanitize-recover   Disable sanitizer check recovery
  -fno-show-column        Do not include column number on diagnostics
  -fno-show-source-location
                          Do not include source location information with diagnostics
  -fno-signed-char        Char is unsigned
  -fno-spell-checking     Disable spell-checking
  -fno-standalone-debug   Limit debug information produced to reduce size of debug binary
  -fno-threadsafe-statics Do not emit code to make initialization of local statics thread safe
  -fno-unroll-loops       Turn off loop unroller
  -fno-use-cxa-atexit     Don't use __cxa_atexit for calling destructors
  -fno-use-init-array     Don't use .init_array instead of .ctors
  -fobjc-arc-exceptions   Use EH-safe code when synthesizing retains and releases in -fobjc-arc
  -fobjc-arc              Synthesize retain and release calls for Objective-C pointers
  -fobjc-exceptions       Enable Objective-C exceptions
  -fobjc-gc-only          Use GC exclusively for Objective-C related memory management
  -fobjc-gc               Enable Objective-C garbage collection
  -fobjc-runtime=<value>  Specify the target Objective-C runtime kind and version
  -fpack-struct=<value>   Specify the default maximum struct packing alignment
  -fpascal-strings        Recognize and construct Pascal-style string literals
  -fpcc-struct-return     Override the default ABI to return all structs on the stack
  -fprofile-instr-generate
                          Generate instrumented code to collect execution counts
  -fprofile-instr-use=<value>
                          Use instrumentation data for profile-guided optimization
  -fprofile-sample-use=<value>
                          Enable sample-based profile guided optimizations
  -freg-struct-return     Override the default ABI to return small structs in registers
  -freroll-loops          Turn on loop reroller
  -fsanitize-blacklist=<value>
                          Path to blacklist file for sanitizers
  -fsanitize-memory-track-origins
                          Enable origins tracking in MemorySanitizer
  -fsanitize=<check>      Enable runtime instrumentation for bug detection: undefined (miscellaneous undefined behavior)
  -fshort-enums           Allocate to an enum type only as many bytes as it needs for the declared range of possible values
  -fshort-wchar           Force wchar_t to be a short unsigned int
  -fshow-overloads=<value>
                          Which overload candidates to show when overload resolution fails: best|all; defaults to all
  -fslp-vectorize-aggressive
                          Enable the BB vectorization passes
  -fslp-vectorize         Enable the superword-level parallelism vectorization passes
  -fstandalone-debug      Emit full debug info for all types used by the program
  -fstrict-enums          Enable optimizations based on the strict definition of an enum's value range
  -ftrap-function=<value> Issue call to specified function rather than a trap instruction
  -ftrapv-handler=<function name>
                          Specify the function to be called on overflow
  -ftrapv                 Trap on integer overflow
  -funroll-loops          Turn on loop unroller
  -fuse-init-array        Use .init_array instead of .ctors
  -fvectorize             Enable the loop vectorization passes
  -fvisibility-inlines-hidden
                          Give inline C++ member functions default visibility by default
  -fvisibility-ms-compat  Give global types 'default' visibility and global functions and variables 'hidden' visibility by default
  -fvisibility=<value>    Set the default symbol visibility for all global declarations
  -fwrapv                 Treat signed integer overflow as two's complement
  -fwritable-strings      Store string literals as writable data
  -F <value>              Add directory to framework include search path
  --gcc-toolchain=<value> Use the gcc toolchain at the given directory
  -gdwarf-2               Generate source level debug information with dwarf version 2
  -gdwarf-3               Generate source level debug information with dwarf version 3
  -gdwarf-4               Generate source level debug information with dwarf version 4
  -gline-tables-only      Emit debug line number tables only
  -g                      Generate source level debug information
  -help                   Display available options
  -H                      Show header includes and nesting depth
  -idirafter <value>      Add directory to AFTER include search path
  -iframework <value>     Add directory to SYSTEM framework search path
  -imacros <file>         Include macros from file before parsing
  -include-pch <file>     Include precompiled header file
  -include <file>         Include file before parsing
  -index-header-map       Make the next included directory (-I or -F) an indexer header map
  -iprefix <dir>          Set the -iwithprefix/-iwithprefixbefore prefix
  -iquote <directory>     Add directory to QUOTE include search path
  -isysroot <dir>         Set the system root directory (usually /)
  -isystem <directory>    Add directory to SYSTEM include search path
  -ivfsoverlay <value>    Overlay the virtual filesystem described by file over the real file system
  -iwithprefixbefore <dir>
                          Set directory to include search path with prefix
  -iwithprefix <dir>      Set directory to SYSTEM include search path with prefix
  -iwithsysroot <directory>
                          Add directory to SYSTEM include search path, absolute paths are relative to -isysroot
  -I <value>              Add directory to include search path
  -mcrc                   Allow use of CRC instructions (ARM only)
  -MD                     Write a depfile containing user and system headers
  -mfp32                  Use 32-bit floating point registers (MIPS only)
  -mfp64                  Use 64-bit floating point registers (MIPS only)
  -MF <file>              Write depfile output from -MMD, -MD, -MM, or -M to <file>
  -MG                     Add missing headers to depfile
  --migrate-xct           Apply modifications and produces temporary files to migrate to XCTest framework
  --migrate               Run the migrator
  -mllvm <value>          Additional arguments to forward to LLVM's option processing
  -MMD                    Write a depfile containing user headers
  -mms-bitfields          Set the default structure layout to be compatible with the Microsoft compiler standard
  -mmsa                   Enable MSA ASE (MIPS only)
  -MM                     Like -MMD, but also implies -E and writes to stdout by default
  -mno-global-merge       Disable merging of globals
  -mno-implicit-float     Don't generate implicit floating point instructions
  -mno-msa                Disable MSA ASE (MIPS only)
  -mno-restrict-it        Allow generation of deprecated IT blocks for ARMv8. It is off by default for ARMv8 Thumb mode
  -mno-unaligned-access   Force all memory accesses to be aligned (AArch32/AArch64 only)
  -mnocrc                 Disallow use of CRC instructions (ARM only)
  -module-dependency-dir <value>
                          Directory to dump module dependencies to
  -momit-leaf-frame-pointer
                          Omit frame pointer setup for leaf functions
  -MP                     Create phony target for each dependency (other than main file)
  -mqdsp6-compat          Enable hexagon-qdsp6 backward compatibility
  -MQ <value>             Specify name of main file output to quote in depfile
  -mrelax-all             (integrated-as) Relax all machine instructions
  -mrestrict-it           Disallow generation of deprecated IT blocks for ARMv8. It is on by default for ARMv8 Thumb mode.
  -mrtd                   Make StdCall calling convention the default
  -msoft-float            Use software floating point
  -mstack-alignment=<value>
                          Set the stack alignment
  -mstackrealign          Force realign the stack at entry to every function
  -MT <value>             Specify name of main file output in depfile
  -munaligned-access      Allow memory accesses to be unaligned (AArch32/AArch64 only)
  -M                      Like -MD, but also implies -E and writes to stdout by default
  -nobuiltininc           Disable builtin #include directories
  -nostdinc++             Disable standard #include directories for the C++ standard library
  -ObjC++                 Treat source input files as Objective-C++ inputs
  -objcmt-atomic-property Make migration to 'atomic' properties
  -objcmt-migrate-all     Enable migration to modern ObjC
  -objcmt-migrate-annotation
                          Enable migration to property and method annotations
  -objcmt-migrate-designated-init
                          Enable migration to infer NS_DESIGNATED_INITIALIZER for initializer methods
  -objcmt-migrate-instancetype
                          Enable migration to infer instancetype for method result type
  -objcmt-migrate-literals
                          Enable migration to modern ObjC literals
  -objcmt-migrate-ns-macros
                          Enable migration to NS_ENUM/NS_OPTIONS macros
  -objcmt-migrate-property
                          Enable migration to modern ObjC property
  -objcmt-migrate-protocol-conformance
                          Enable migration to add protocol conformance on classes
  -objcmt-migrate-readonly-property
                          Enable migration to modern ObjC readonly property
  -objcmt-migrate-readwrite-property
                          Enable migration to modern ObjC readwrite property
  -objcmt-migrate-subscripting
                          Enable migration to modern ObjC subscripting
  -objcmt-ns-nonatomic-iosonly
                          Enable migration to use NS_NONATOMIC_IOSONLY macro for setting property's 'atomic' attribute
  -objcmt-returns-innerpointer-property
                          Enable migration to annotate property with NS_RETURNS_INNER_POINTER
  -objcmt-whitelist-dir-path=<value>
                          Only modify files with a filename contained in the provided directory path
  -ObjC                   Treat source input files as Objective-C inputs
  -o <file>               Write output to <file>
  -pg                     Enable mcount instrumentation
  -pipe                   Use pipes between commands, when possible
  -print-file-name=<file> Print the full library path of <file>
  -print-ivar-layout      Enable Objective-C Ivar layout bitmap print trace
  -print-libgcc-file-name Print the library path for "libgcc.a"
  -print-prog-name=<name> Print the full program path of <name>
  -print-search-dirs      Print the paths used for finding libraries and programs
  -pthread                Support POSIX threads in generated code
  -P                      Disable linemarker output in -E mode
  -Qunused-arguments      Don't emit warning for unused driver arguments
  -relocatable-pch        Whether to build a relocatable precompiled header
  -rewrite-legacy-objc    Rewrite Legacy Objective-C source to C++
  -rewrite-objc           Rewrite Objective-C source to C++
  -save-temps             Save intermediate compilation results
  -serialize-diagnostics <value>
                          Serialize compiler diagnostics to a file
  -std=<value>            Language standard to compile for
  -stdlib=<value>         C++ standard library to use
  -S                      Only run preprocess and compilation steps
  --target=<value>        Generate code for the given target
  -time                   Time individual commands
  -traditional-cpp        Enable some traditional CPP emulation
  -trigraphs              Process trigraph sequences
  -undef                  undef all system defines
  --verify-debug-info     Verify the binary representation of debug output
  -verify-pch             Load and verify that a pre-compiled header file is not stale
  -v                      Show commands to run and use verbose output
  -Wa,<arg>               Pass the comma separated arguments in <arg> to the assembler
  -Wl,<arg>               Pass the comma separated arguments in <arg> to the linker
  -working-directory <value>
                          Resolve file paths relative to the specified directory
  -Wp,<arg>               Pass the comma separated arguments in <arg> to the preprocessor
  -W<warning>             Enable the specified warning
  -w                      Suppress all warnings
  -Xanalyzer <arg>        Pass <arg> to the static analyzer
  -Xassembler <arg>       Pass <arg> to the assembler
  -Xclang <arg>           Pass <arg> to the clang compiler
  -Xlinker <arg>          Pass <arg> to the linker
  -Xpreprocessor <arg>    Pass <arg> to the preprocessor
  -x <language>           Treat subsequent input files as having type <language>
        Trying C compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -fPIC
        Adding C compiler flag -fPIC
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fPIC
          Popping language C
          Pushing language Cxx
Executing: clang++ --help
stdout:
OPTIONS:
        Trying Cxx compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid Cxx linker flag -fPIC
        Adding Cxx compiler flag -fPIC
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   -fPIC    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fPIC
          Popping language Cxx
          Pushing language FC
Executing: gfortran-mp-4.9 --help
stdout:
Usage: gfortran-mp-4.9 [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -pie                     Create a position independent executable
  -shared                  Create a shared library
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gfortran-mp-4.9.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://trac.macports.org/newticket>.
        Trying FC compiler flag -fPIC
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid FC linker flag -fPIC
        Adding FC compiler flag -fPIC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -fPIC
          Popping language FC
TEST checkLargeFileIO from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1032)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1032)
TEST checkArchiver from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1131)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1131)
  Check that the archiver exists and can make a library usable by the compiler
          Pushing language C
Executing: ar -V
Executing: ar -V
              Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int foo(int a) {
  return a+1;
Checking for program /opt/local/bin/ar...found
            Defined make macro "AR" to "/opt/local/bin/ar"
Checking for program /opt/local/bin/ranlib...found
            Defined make macro "RANLIB" to "/opt/local/bin/ranlib -c"
Executing: /opt/local/bin/ar cr /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconf1.a /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conf1.o
Executing: /opt/local/bin/ranlib -c /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconf1.a
Possible ERROR while running compiler:
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:6:26: warning: if statement has empty body [-Wempty-body]
  int b = foo(1);  if (b);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:6:26: note: put the semicolon on a separate line to silence this warning
1 warning generated.
Source:
extern int foo(int);
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -lconf1
          Defined make macro "AR_FLAGS" to "cr"
          Defined make macro "AR_LIB_SUFFIX" to "a"
          Popping language C
TEST checkSharedLinker from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1242)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1242)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Darwin
        Checking shared linker clang using flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress']
Checking for program /opt/local/bin/clang...not found
Checking for program /opt/local/sbin/clang...not found
Checking for program /usr/bin/clang...found
            Defined make macro "LD_SHARED" to "clang"
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -dynamiclib -single_module   -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -dynamiclib -single_module
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -undefined dynamic_lookup   -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -undefined dynamic_lookup
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -multiply_defined suppress   -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -multiply_defined suppress
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
                                          Pushing language C
                                          Popping language C
                                          Pushing language CUDA
                                          Popping language CUDA
                                          Pushing language FC
                                          Popping language FC
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:7:8: warning: if statement has empty body [-Wempty-body]
if(ret);;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:7:8: note: put the semicolon on a separate line to silence this warning
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest    -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -L/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -lconftest
        Using shared linker clang with flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress'] and library extension dylib
Executing: uname -s
stdout: Darwin
TEST checkLinkerMac from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1300)
TESTING: checkLinkerMac from config.setCompilers(config/BuildSystem/config/setCompilers.py:1300)
  Tests some Apple Mac specific linker flags
          Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress   -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid C linker flag -Wl,-search_paths_first
          Popping language C
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid Cxx linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid Cxx linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid Cxx linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid Cxx linker flag -Wl,-search_paths_first
          Pushing language FC
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress   -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid FC linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid FC linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid FC linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
      program main
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
          Valid FC linker flag -Wl,-search_paths_first
          Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1320)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1320)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
          Pushing language C
Executing: uname -s
stdout: Darwin
Executing: clang -V
          Popping language C
Executing: uname -s
stdout: Darwin
Executing: clang -V
          Pushing language FC
Executing: uname -s
stdout: Darwin
Executing: clang -V
          Popping language FC
TEST checkLibC from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1355)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1355)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                  Pushing language C
                  Popping language C
        Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1404)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1404)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                      All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 37 "/usr/include/dlfcn.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 38 "/usr/include/dlfcn.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdbool.h" 1 3 4
# 41 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 42 "/usr/include/dlfcn.h" 2 3 4
typedef struct dl_info {
        const char *dli_fname;
        void *dli_fbase;
        const char *dli_sname;
        void *dli_saddr;
} Dl_info;
extern int dladdr(const void *, Dl_info *);
extern int dlclose(void * __handle);
extern char * dlerror(void);
extern void * dlopen(const char * __path, int __mode);
extern void * dlsym(void * __handle, const char * __symbol);
extern _Bool dlopen_preflight(const char* __path) __attribute__((availability(macosx,introduced=10.5)));
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
            Defined "HAVE_DLFCN_H" to "1"
            Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
              Pushing language C
                          All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                      Pushing language C
                      Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -ldl
              Defined "HAVE_LIBDL" to "1"
              Popping language C
          Adding ['dl'] to LIBS
Executing: uname -s
stdout: Darwin
        Checking dynamic linker clang using flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress']
            Defined make macro "DYNAMICLINKER" to "clang"
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -dynamiclib -single_module -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -undefined dynamic_lookup -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -multiply_defined suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                          Pushing language C
                                          Popping language C
                                          Pushing language FC
                                          Popping language FC
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:11:3: warning: implicitly declaring library function 'printf' with type 'int (const char *, ...)'
  printf("Could not load symbol\n");
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:11:3: note: please include the header <stdio.h> or explicitly provide a declaration for 'printf'
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  return -1;
if ((*foo)()) {
  printf("Invalid return from foo()\n");
  return -1;
if (dlclose(handle)) {
  printf("Could not close library\n");
  return -1;
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
        Using dynamic linker clang with flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress'] and library extension dylib
TEST output from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1450)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1450)
  Output module data as defines and substitutions
          Substituting "CC" with "clang"
          Substituting "CFLAGS" with " -fPIC"
          Defined make macro "CC_LINKER_SLFLAG" to "-L"
          Substituting "CPP" with "clang -E"
          Substituting "CPPFLAGS" with ""
          Substituting "CXX" with "clang++"
          Substituting "CXX_CXXFLAGS" with " -fPIC"
          Substituting "CXXFLAGS" with ""
          Substituting "CXX_LINKER_SLFLAG" with "-L"
          Substituting "CXXCPP" with "clang++ -E"
          Substituting "CXXCPPFLAGS" with ""
          Substituting "FC" with "gfortran-mp-4.9"
          Substituting "FFLAGS" with " -fPIC"
          Defined make macro "FC_LINKER_SLFLAG" to "-L"
          Substituting "LDFLAGS" with ""
          Substituting "LIBS" with "-ldl "
          Substituting "SHARED_LIBRARY_FLAG" with "-dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress"
Executing: uname -s
stdout: Darwin
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/Users/patrick/program/petsc/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/Users/patrick/program/petsc/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
          Defined make rule "shared_arch" with dependencies "shared_darwin" and code []
          Defined make macro "SONAME_FUNCTION" to "$(1).$(2).dylib"
          Defined make macro "SL_LINKER_FUNCTION" to "-dynamiclib -install_name $(call SONAME_FUNCTION,$(1),$(2)) -compatibility_version $(2) -current_version $(3) -single_module -multiply_defined suppress -undefined dynamic_lookup"
          Defined make macro "BUILDSHAREDLIB" to "yes"
          Defined "HAVE_SHARED_LIBRARIES" to "1"
          Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/Users/patrick/program/petsc/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:96)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
          Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/Users/patrick/program/petsc/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:102)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureCompilerFlags from config.compilerFlags(/Users/patrick/program/petsc/config/BuildSystem/config/compilerFlags.py:71)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:71)
  Get the default compiler flags
          Pushing language C
Executing: clang --version
stdout:
Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
Target: x86_64-apple-darwin13.4.0
Thread model: posix
getCompilerVersion: clang Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
        Trying C compiler flag -Wall
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
        Trying C compiler flag -Wwrite-strings
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
        Trying C compiler flag -Wno-strict-aliasing
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
        Trying C compiler flag -Wno-unknown-pragmas
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
        Trying C compiler flag -g3
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g3
        Trying C compiler flag -O0
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -O0
          Popping language C
Executing: clang++ --version
stdout:
Thread model: posix
getCompilerVersion: clang++ Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
        Trying Cxx compiler flag -Wall
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
        Trying Cxx compiler flag -Wwrite-strings
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
        Trying Cxx compiler flag -Wno-strict-aliasing
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
        Trying Cxx compiler flag -Wno-unknown-pragmas
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
        Trying Cxx compiler flag -g
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
        Trying Cxx compiler flag -O0
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O0
          Pushing language FC
Executing: gfortran-mp-4.9 --version
stdout:
GNU Fortran (MacPorts gcc49 4.9.1_1) 4.9.1
Copyright (C) 2014 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: gfortran-mp-4.9 GNU Fortran (MacPorts gcc49 4.9.1_1) 4.9.1
stdout:
stdout:
        Trying FC compiler flag -Wall
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
        Trying FC compiler flag -Wno-unused-variable
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-variable
        Trying FC compiler flag -ffree-line-length-0
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
        Trying FC compiler flag -Wno-unused-dummy-argument
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
        Trying FC compiler flag -g
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
        Trying FC compiler flag -O0
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -O0
          Popping language FC
TEST configureDebugging from PETSc.options.debugging(/Users/patrick/program/petsc/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
          Defined "USE_ERRORCHECKING" to "1"
TEST checkRestrict from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:136)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:136)
  Check for the C/CXX restrict keyword
          Pushing language C
                    All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.c:5:18: warning: unused variable 'x' [-Wunused-variable]
float * restrict x;;
Source:
int main() {
  return 0;
        compilers: Set C restrict keyword to restrict
          Defined "C_RESTRICT" to "restrict"
          Popping language C
TEST checkCFormatting from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:309)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:309)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:107)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:107)
  Check for C keyword: static inline
          Pushing language C
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.c
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
        compilers: Set C StaticInline keyword to static inline
          Popping language C
          Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:320)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:320)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl
          Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:163)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:163)
  Determines the libraries needed to link with C
          Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                Pushing language C
                Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl
Possible ERROR while running linker:
stderr:
Thread model: posix
 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -dynamic -arch x86_64 -macosx_version_min 10.9.0 -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
          Popping language C
        compilers: Checking arg Apple
        compilers: Unknown arg Apple
        compilers: Checking arg LLVM
        compilers: Unknown arg LLVM
        compilers: Checking arg version
        compilers: Unknown arg version
        compilers: Checking arg 6.0
        compilers: Unknown arg 6.0
        compilers: Checking arg (clang-600.0.54)
        compilers: Unknown arg (clang-600.0.54)
        compilers: Checking arg (based
        compilers: Unknown arg (based
        compilers: Checking arg on
        compilers: Unknown arg on
        compilers: Checking arg 3.5svn)
        compilers: Unknown arg 3.5svn)
        compilers: Checking arg Target:
        compilers: Unknown arg Target:
        compilers: Checking arg x86_64-apple-darwin13.4.0
        compilers: Unknown arg x86_64-apple-darwin13.4.0
        compilers: Checking arg Thread
        compilers: Unknown arg Thread
        compilers: Checking arg model:
        compilers: Unknown arg model:
        compilers: Checking arg posix
        compilers: Unknown arg posix
        compilers: Checking arg "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld"
        compilers: Unknown arg /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld
        compilers: Checking arg -demangle
        compilers: Unknown arg -demangle
        compilers: Checking arg -dynamic
        compilers: Unknown arg -dynamic
        compilers: Checking arg -arch
        compilers: Unknown arg -arch
        compilers: Checking arg -macosx_version_min
        compilers: Unknown arg -macosx_version_min
        compilers: Checking arg 10.9.0
        compilers: Unknown arg 10.9.0
        compilers: Checking arg -o
        compilers: Unknown arg -o
        compilers: Checking arg /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest
        compilers: Unknown arg /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest
        compilers: Checking arg -multiply_defined
        compilers: Unknown arg -multiply_defined
        compilers: Checking arg suppress
        compilers: Unknown arg suppress
        compilers: Checking arg -commons
        compilers: Unknown arg -commons
        compilers: Checking arg use_dylibs
        compilers: Unknown arg use_dylibs
        compilers: Checking arg -search_paths_first
        compilers: Unknown arg -search_paths_first
        compilers: Checking arg /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o
        compilers: Unknown arg /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o
        compilers: Checking arg -ldl
        compilers: Found library : -ldl
        compilers: Checking arg -lSystem
        compilers: Found library : -lSystem
        compilers: Checking arg /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
        compilers: Found full library spec: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
        compilers: Libraries needed to link C code with another linker: ['-ldl', '-lSystem', '/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a']
        compilers: Check that C libraries can be used from Fortran
            Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest
            Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1327)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1327)
  Check if -MMD works for dependency generation, and add it if it does
          Pushing language C
        Trying C compiler flag -MMD -MP
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -MMD -MP  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
          Defined make macro "C_DEPFLAGS" to "-MMD -MP"
          Popping language C
        Trying Cxx compiler flag -MMD -MP
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC -MMD -MP   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
          Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
          Pushing language FC
        Trying FC compiler flag -MMD -MP
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -MMD -MP  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
          Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
          Popping language FC
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc
Possible ERROR while running compiler: exit code 256
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc:5:17: error: expected ';' at end of declaration
1 error generated.
Source:
int main() {
  return 0;
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc:5:23: warning: unused variable 'x' [-Wunused-variable]
float *  __restrict__ x;;
Source:
int main() {
  return 0;
        compilers: Set Cxx restrict keyword to  __restrict__
          Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:358)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:358)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
        compilers: C++ has namespaces
          Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:333)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:333)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0    -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
stderr:
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:5:22: warning: private field 'i' is not used [-Wunused-private-field]
class somename { int i; };;
Source:
int main() {
  return 0;
TEST checkCxxStaticInline from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:121)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:121)
  Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
        compilers: Set Cxx StaticInline keyword to static inline
          Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:412)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:412)
  Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
  return 0;
                Pushing language CXX
                Popping language CXX
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stderr:
Thread model: posix
 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -dynamic -arch x86_64 -macosx_version_min 10.9.0 -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem -lclang_rt.osx -ldl -lc++ -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
        compilers: Checking arg -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin
        compilers: Found library directory: -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin
        compilers: Found library: -ldl
        Library already in C list so skipping in C++
        compilers: Found library: -lSystem
        compilers: Checking arg -lclang_rt.osx
        compilers: Found library: -lclang_rt.osx
        compilers: Checking arg -lc++
        compilers: Found library: -lc++
        compilers: Libraries needed to link Cxx code with another linker: ['-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin', '-lclang_rt.osx', '-lc++', '/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a']
        compilers: Check that Cxx libraries can be used from C
            Pushing language C
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
        compilers: Check that Cxx libraries can be used from Fortran
            Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
      program main
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
            Popping language FC
TEST checkCxx11 from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:373)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:373)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
          Pushing language Cxx
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0    -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:32: error: unknown type name 'constexpr'
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:42: warning: variable templates are a C++1y extension [-Wc++1y-extensions]
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:43: error: expected ';' at end of declaration
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:51: error: unknown type name 'T'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:44: error: C++ requires a type specifier for all declarations
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:13:24: warning: unused variable 'x' [-Wunused-variable]
          const double x = dist(mt);
2 warnings and 4 errors generated.
Source:
          #include <random>
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
  return 0;
          Rejecting compiler flag  due to nonzero status from link
PETSc Error: No output file produced
          Popping language Cxx
TEST checkFortranTypeSizes from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:571)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:571)
  Check whether real*8 is supported and suggest flags which will allow support
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      program main
      real*8 variable
      end
          Popping language FC
TEST checkFortranNameMangling from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:630)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:630)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
            Pushing language C
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
            Popping language C
            Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      program main
       call d1chk()
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confc.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Popping language FC
        compilers: Fortran name mangling is underscore
          Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:667)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:667)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
            Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
            Popping language C
            Pushing language FC
Successful compile:
Source:
      program main
       call d1_chk()
      end
                    Pushing language FC
                    Popping language FC
stderr:
Undefined symbols for architecture x86_64:
  "_d1_chk_", referenced from:
      _MAIN__ in conftest.o
     (maybe you meant: _d1_chk__)
ld: symbol(s) not found for architecture x86_64
            Popping language FC
TEST checkFortranPreprocessor from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:677)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:677)
  Determine if Fortran handles preprocessing properly
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
          Popping language FC
        compilers: Fortran uses CPP preprocessor
TEST checkFortranDefineCompilerOption from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:698)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:698)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  -DTesting  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
          Defined make macro "FC_DEFINE_FLAG" to "-D"
          Popping language FC
        compilers: Fortran uses -D for defining macro
TEST checkFortranLibraries from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:715)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:715)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
          Pushing language FC
Executing: gfortran-mp-4.9 -V
Successful compile:
Source:
      program main
      end
                Pushing language FC
                Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stderr:
Driving: gfortran-mp-4.9 -mmacosx-version-min=10.9.4 -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -l gfortran -shared-libgcc
Using built-in specs.
COLLECT_GCC=gfortran-mp-4.9
COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/lto-wrapper
Configured with: /opt/local/var/macports/build/_opt_mports_dports_lang_gcc49/gcc49/work/gcc-4.9.1/configure --prefix=/opt/local --build=x86_64-apple-darwin13 --enable-languages=c,c++,objc,obj-c++,lto,fortran,java --libdir=/opt/local/lib/gcc49 --includedir=/opt/local/include/gcc49 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-4.9 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-4.9 --with-gxx-include-dir=/opt/local/include/gcc49/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-cloog=/opt/local --enable-cloog-backend=isl --disable-cloog-version-check --enable-stage1-checking --disable-multilib --enable-lto --enable-libstdcxx-time --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --with-pkgversion='MacPorts gcc49 4.9.1_1'
Thread model: posix
gcc version 4.9.1 (MacPorts gcc49 4.9.1_1)
Reading specs from /opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-mmacosx-version-min=10.9.4' '-o' '/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-Wno-unused-variable' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-O0' '-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin' '-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin' '-shared-libgcc' '-mtune=core2'
COMPILER_PATH=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/
LIBRARY_PATH=/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../:/usr/lib/
 /opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/collect2 -dynamic -arch x86_64 -macosx_version_min 10.9.4 -weak_reference_mismatches non-weak -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../.. -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -lSystem -lclang_rt.osx -lgfortran -no_compact_unwind -lSystem -lgcc_ext.10.5 -lgcc -lquadmath -lm -lgcc_ext.10.5 -lgcc -lSystem -v -idsym
collect2 version 4.9.1
/opt/local/bin/ld -dynamic -arch x86_64 -macosx_version_min 10.9.4 -weak_reference_mismatches non-weak -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../.. -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -lSystem -lclang_rt.osx -lgfortran -no_compact_unwind -lSystem -lgcc_ext.10.5 -lgcc -lquadmath -lm -lgcc_ext.10.5 -lgcc -lSystem -v
@(#)PROGRAM:ld  PROJECT:ld64-236.3
configured to support archs: i386 x86_64 x86_64h armv6 armv7 armv7s armv7m arm64
Library search paths:
	/usr/lib
	/usr/local/lib
Framework search paths:
	/Library/Frameworks/
	/System/Library/Frameworks/
 /opt/local/bin/nm -n /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o
          Popping language FC
        compilers: Checking arg Driving:
        compilers: Unknown arg Driving:
        compilers: Checking arg gfortran-mp-4.9
        compilers: Unknown arg gfortran-mp-4.9
        compilers: Checking arg -mmacosx-version-min=10.9.4
        compilers: Unknown arg -mmacosx-version-min=10.9.4
        compilers: Checking arg -v
        compilers: Unknown arg -v
        compilers: Checking arg -Wl,-multiply_defined,suppress
        compilers: Unknown arg -Wl,-multiply_defined,suppress
        compilers: Checking arg -Wl,suppress
        compilers: Unknown arg -Wl,suppress
        compilers: Checking arg -Wl,-commons,use_dylibs
        compilers: Unknown arg -Wl,-commons,use_dylibs
        compilers: Checking arg -Wl,-search_paths_first
        compilers: Unknown arg -Wl,-search_paths_first
        compilers: Checking arg -fPIC
        compilers: Unknown arg -fPIC
        compilers: Checking arg -Wall
        compilers: Unknown arg -Wall
        compilers: Checking arg -Wno-unused-variable
        compilers: Unknown arg -Wno-unused-variable
        compilers: Checking arg -ffree-line-length-0
        compilers: Unknown arg -ffree-line-length-0
        compilers: Checking arg -Wno-unused-dummy-argument
        compilers: Unknown arg -Wno-unused-dummy-argument
        compilers: Checking arg -g
        compilers: Unknown arg -g
        compilers: Checking arg -O0
        compilers: Unknown arg -O0
        Library already in C list so skipping in Fortran
        compilers: Already in lflags so skipping: -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin
        Library already in Cxx list so skipping in Fortran
        compilers: Already in lflags: -ldl
        compilers: Found canonical library: -lgfortran
        compilers: Checking arg -shared-libgcc
        compilers: Unknown arg -shared-libgcc
        compilers: Checking arg Using
        compilers: Unknown arg Using
        compilers: Checking arg built-in
        compilers: Unknown arg built-in
        compilers: Checking arg specs.
        compilers: Unknown arg specs.
        compilers: Checking arg COLLECT_GCC=gfortran-mp-4.9
        compilers: Unknown arg COLLECT_GCC=gfortran-mp-4.9
        compilers: Checking arg COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/lto-wrapper
        compilers: Unknown arg COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/lto-wrapper
        compilers: Checking arg Configured
        compilers: Unknown arg Configured
        compilers: Checking arg with:
        compilers: Unknown arg with:
        compilers: Checking arg /opt/local/var/macports/build/_opt_mports_dports_lang_gcc49/gcc49/work/gcc-4.9.1/configure
        compilers: Unknown arg /opt/local/var/macports/build/_opt_mports_dports_lang_gcc49/gcc49/work/gcc-4.9.1/configure
        compilers: Checking arg --prefix=/opt/local
        compilers: Unknown arg --prefix=/opt/local
        compilers: Checking arg --build=x86_64-apple-darwin13
        compilers: Unknown arg --build=x86_64-apple-darwin13
        compilers: Checking arg --enable-languages=c,c++,objc,obj-c++,lto,fortran,java
        compilers: Unknown arg --enable-languages=c,c++,objc,obj-c++,lto,fortran,java
        compilers: Checking arg --libdir=/opt/local/lib/gcc49
        compilers: Unknown arg --libdir=/opt/local/lib/gcc49
        compilers: Checking arg --includedir=/opt/local/include/gcc49
        compilers: Unknown arg --includedir=/opt/local/include/gcc49
        compilers: Checking arg --infodir=/opt/local/share/info
        compilers: Unknown arg --infodir=/opt/local/share/info
        compilers: Checking arg --mandir=/opt/local/share/man
        compilers: Unknown arg --mandir=/opt/local/share/man
        compilers: Checking arg --datarootdir=/opt/local/share/gcc-4.9
        compilers: Unknown arg --datarootdir=/opt/local/share/gcc-4.9
        compilers: Checking arg --with-local-prefix=/opt/local
        compilers: Unknown arg --with-local-prefix=/opt/local
        compilers: Checking arg --with-system-zlib
        compilers: Unknown arg --with-system-zlib
        compilers: Checking arg --disable-nls
        compilers: Unknown arg --disable-nls
        compilers: Checking arg --program-suffix=-mp-4.9
        compilers: Unknown arg --program-suffix=-mp-4.9
        compilers: Checking arg --with-gxx-include-dir=/opt/local/include/gcc49/c++/
        compilers: Unknown arg --with-gxx-include-dir=/opt/local/include/gcc49/c++/
        compilers: Checking arg --with-gmp=/opt/local
        compilers: Unknown arg --with-gmp=/opt/local
        compilers: Checking arg --with-mpfr=/opt/local
        compilers: Unknown arg --with-mpfr=/opt/local
        compilers: Checking arg --with-mpc=/opt/local
        compilers: Unknown arg --with-mpc=/opt/local
        compilers: Checking arg --with-cloog=/opt/local
        compilers: Unknown arg --with-cloog=/opt/local
        compilers: Checking arg --enable-cloog-backend=isl
        compilers: Unknown arg --enable-cloog-backend=isl
        compilers: Checking arg --disable-cloog-version-check
        compilers: Unknown arg --disable-cloog-version-check
        compilers: Checking arg --enable-stage1-checking
        compilers: Unknown arg --enable-stage1-checking
        compilers: Checking arg --disable-multilib
        compilers: Unknown arg --disable-multilib
        compilers: Checking arg --enable-lto
        compilers: Unknown arg --enable-lto
        compilers: Checking arg --enable-libstdcxx-time
        compilers: Unknown arg --enable-libstdcxx-time
        compilers: Checking arg --with-as=/opt/local/bin/as
        compilers: Unknown arg --with-as=/opt/local/bin/as
        compilers: Checking arg --with-ld=/opt/local/bin/ld
        compilers: Unknown arg --with-ld=/opt/local/bin/ld
        compilers: Checking arg --with-ar=/opt/local/bin/ar
        compilers: Unknown arg --with-ar=/opt/local/bin/ar
        compilers: Checking arg --with-bugurl=https://trac.macports.org/newticket
        compilers: Unknown arg --with-bugurl=https://trac.macports.org/newticket
        compilers: Checking arg --with-pkgversion=
        compilers: Unknown arg --with-pkgversion=
        compilers: Checking arg gcc
        compilers: Unknown arg gcc
        compilers: Checking arg 4.9.1
        compilers: Unknown arg 4.9.1
        compilers: Checking arg (MacPorts
        compilers: Unknown arg (MacPorts
        compilers: Checking arg gcc49
        compilers: Unknown arg gcc49
        compilers: Checking arg 4.9.1_1)
        compilers: Unknown arg 4.9.1_1)
        compilers: Checking arg Reading
        compilers: Unknown arg Reading
        compilers: Checking arg from
        compilers: Unknown arg from
        compilers: Checking arg /opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../libgfortran.spec
        compilers: Unknown arg /opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../libgfortran.spec
        compilers: Checking arg rename
        compilers: Unknown arg rename
        compilers: Checking arg lib
        compilers: Unknown arg lib
        compilers: Checking arg to
        compilers: Unknown arg to
        compilers: Checking arg liborig
        compilers: Unknown arg liborig
        compilers: Checking arg COLLECT_GCC_OPTIONS=
        compilers: Unknown arg COLLECT_GCC_OPTIONS=
        compilers: Checking arg COMPILER_PATH=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/
        compilers: Skipping arg COMPILER_PATH=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/
        compilers: Checking arg LIBRARY_PATH=/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../:/usr/lib/
        compilers: Skipping arg LIBRARY_PATH=/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../:/usr/lib/
        compilers: Checking arg /opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/collect2
        compilers: Unknown arg /opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/collect2
        compilers: Checking arg 10.9.4
        compilers: Unknown arg 10.9.4
        compilers: Checking arg -weak_reference_mismatches
        compilers: Unknown arg -weak_reference_mismatches
        compilers: Checking arg non-weak
        compilers: Unknown arg non-weak
        compilers: Checking arg -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1
        compilers: Found library directory: -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1
        compilers: Checking arg -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../..
        compilers: Already in lflags: -lSystem
        compilers: Already in lflags: -lclang_rt.osx
        compilers: Checking arg -lgfortran
        compilers: Found library: -lgfortran
        compilers: Checking arg -no_compact_unwind
        compilers: Unknown arg -no_compact_unwind
        compilers: Checking arg -lgcc_ext.10.5
        compilers: Found library: -lgcc_ext.10.5
        compilers: Found system library therefor skipping: -lgcc
        compilers: Checking arg -lquadmath
        compilers: Found library: -lquadmath
        compilers: Checking arg -lm
        compilers: Found library: -lm
        compilers: Already in lflags: -lgcc_ext.10.5
        compilers: Checking arg -idsym
        compilers: Unknown arg -idsym
        compilers: Checking arg collect2
        compilers: Unknown arg collect2
        compilers: Checking arg /opt/local/bin/ld
        compilers: Unknown arg /opt/local/bin/ld
        compilers: Already in lflags so skipping: -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1
        compilers: Already in lflags: -lgfortran
        compilers: Already in lflags: -lquadmath
        compilers: Checking arg @(#)PROGRAM:ld
        compilers: Unknown arg @(#)PROGRAM:ld
        compilers: Checking arg PROJECT:ld64-236.3
        compilers: Unknown arg PROJECT:ld64-236.3
        compilers: Checking arg configured
        compilers: Unknown arg configured
        compilers: Checking arg support
        compilers: Unknown arg support
        compilers: Checking arg archs:
        compilers: Unknown arg archs:
        compilers: Checking arg i386
        compilers: Unknown arg i386
        compilers: Checking arg x86_64h
        compilers: Unknown arg x86_64h
        compilers: Checking arg armv6
        compilers: Unknown arg armv6
        compilers: Checking arg armv7
        compilers: Unknown arg armv7
        compilers: Checking arg armv7s
        compilers: Unknown arg armv7s
        compilers: Checking arg armv7m
        compilers: Unknown arg armv7m
        compilers: Checking arg arm64
        compilers: Unknown arg arm64
        compilers: Checking arg Library
        compilers: Unknown arg Library
        compilers: Checking arg search
        compilers: Unknown arg search
        compilers: Checking arg paths:
        compilers: Unknown arg paths:
        compilers: Checking arg /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin
        compilers: Unknown arg /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin
        compilers: Checking arg /usr/lib
        compilers: Unknown arg /usr/lib
        compilers: Checking arg /usr/local/lib
        compilers: Unknown arg /usr/local/lib
        compilers: Checking arg Framework
        compilers: Unknown arg Framework
        compilers: Checking arg /Library/Frameworks/
        compilers: Unknown arg /Library/Frameworks/
        compilers: Checking arg /System/Library/Frameworks/
        compilers: Unknown arg /System/Library/Frameworks/
        compilers: Checking arg /opt/local/bin/nm
        compilers: Unknown arg /opt/local/bin/nm
        compilers: Libraries needed to link Fortran code with the C linker: ['-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin', '-lgfortran', '-L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1', '-L/opt/local/lib/gcc49', '-lgfortran', '-lgcc_ext.10.5', '-lquadmath', '-lm', '-lm']
        compilers: Libraries needed to link Fortran main with the C linker: []
        compilers: Check that Fortran libraries can be used from C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
        compilers: Check that Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
        compilers: Fortran libraries can be used from C++
TEST checkFortranLinkingCxx from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1061)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1061)
  Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
            Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/cxxobj.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confc.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Popping language FC
        compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1096)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1096)
  Determine whether the Fortran compiler handles F90
          Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Defined "USING_F90" to "1"
        Fortran compiler supports F90
          Popping language FC
TEST checkFortran2003 from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1109)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1109)
  Determine whether the Fortran compiler handles F2003
          Pushing language FC
Successful compile:
Source:
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
                  Pushing language FC
                  Popping language FC
          Defined "USING_F2003" to "1"
        Fortran compiler supports F2003
          Popping language FC
TEST checkFortran90Array from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1129)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1129)
  Check for F90 array interfaces
Executing: uname -s
stdout: Darwin
          Pushing language C
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    abort();
  return;
          Popping language C
          Pushing language FC
Successful compile:
Source:
      program main
      Interface
         Subroutine f90ptrtest(p1,p2,p3,i)
         integer, pointer :: p1(:,:)
         integer, pointer :: p2(:,:)
         integer, pointer :: p3(:,:)
         integer i
         End Subroutine
      End Interface
      integer, pointer :: ptr1(:,:),ptr2(:,:)
      integer, target  :: array(6:8,9:21)
      integer  in
      in   = 25
      ptr1 => array
      ptr2 => array
      call f90arraytest(ptr1,ptr2,ptr1,in)
      call f90ptrtest(ptr1,ptr2,ptr1,in)
      end
                      Pushing language FC
                      Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/fooobj.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest
stdout:
arrays [0x7fff5bd89950 0x7fff5bd89950 0x7fff5bd89950]
arrays [0x7fff5bd89900 0x7fff5bd898b0 0x7fff5bd89900]
pointers do not match! [0x40 0x7fff5bd89950] [0x7fff5bd89800]
ERROR while running executable: Could not execute "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest":
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
#0  0x103e7e3fc
#1  0x103e7e91f
#2  0x7fff935d75a9
          Popping language FC
        compilers: F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1216)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1216)
  Figures out what flag is used to specify the include path for Fortran modules
          Pushing language FC
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                  Pushing language FC
                  Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/configtest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
        compilers: Fortran module include flag -I found
          Popping language FC
TEST checkFortranModuleOutput from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1282)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1282)
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -module /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-module'
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -module  compile failed
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -module:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-module:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir'
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -module: compile failed
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -fmod=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-fmod=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir'
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -fmod= compile failed
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -J/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      module configtest
      integer testint
        compilers: Fortran module output flag -J found
          Popping language FC
TEST setupFrameworkCompilers from config.compilers(/Users/patrick/program/petsc/config/BuildSystem/config/compilers.py:1413)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1413)
TEST configureClosure from config.utilities.closure(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
  Determine if Apple ^close syntax is supported in C
          Pushing language C
                      All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure/conftest.c:6:7: warning: unused variable 'closure' [-Wunused-variable]
int (^closure)(int);;
1 warning generated.
Source:
#include <stdio.h>
int main() {
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Defined "HAVE_CLOSURE" to "1"
TEST configureFortranCPP from PETSc.options.fortranCPP(/Users/patrick/program/petsc/config/PETSc/options/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:27)
  Handle case where Fortran cannot preprocess properly
          Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} -o $@ $<']
          Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
          Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} -o $@ $<']
          Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FFLAGS} ${FC_FLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Source:
#include <string.h>
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/string.h" 1 3 4
# 61 "/usr/include/string.h" 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 62 "/usr/include/string.h" 2 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 64 "/usr/include/string.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 65 "/usr/include/string.h" 2 3 4
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 66 "/usr/include/string.h" 2 3 4
void *memchr(const void *, int, size_t);
int memcmp(const void *, const void *, size_t);
void *memcpy(void *, const void *, size_t);
void *memmove(void *, const void *, size_t);
void *memset(void *, int, size_t);
char *strcat(char *, const char *);
char *strchr(const char *, int);
int strcmp(const char *, const char *);
int strcoll(const char *, const char *);
char *strcpy(char *, const char *);
size_t strcspn(const char *, const char *);
char *strerror(int) __asm("_" "strerror") ;
size_t strlen(const char *);
char *strncat(char *, const char *, size_t);
int strncmp(const char *, const char *, size_t);
char *strncpy(char *, const char *, size_t);
char *strpbrk(const char *, const char *);
char *strrchr(const char *, int);
size_t strspn(const char *, const char *);
char *strstr(const char *, const char *);
char *strtok(char *, const char *);
size_t strxfrm(char *, const char *, size_t);
# 104 "/usr/include/string.h" 3 4
char *strtok_r(char *, const char *, char **);
# 116 "/usr/include/string.h" 3 4
int strerror_r(int, char *, size_t);
char *strdup(const char *);
void *memccpy(void *, const void *, int, size_t);
# 130 "/usr/include/string.h" 3 4
char *stpcpy(char *, const char *);
char *stpncpy(char *, const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strndup(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
size_t strnlen(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strsignal(int sig);
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rsize_t.h" 3 4
typedef __darwin_size_t rsize_t;
# 142 "/usr/include/string.h" 2 3 4
# 1 "/usr/include/sys/_types/_errno_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_errno_t.h" 3 4
typedef int errno_t;
# 143 "/usr/include/string.h" 2 3 4
errno_t memset_s(void *, rsize_t, int, rsize_t) __attribute__((availability(macosx,introduced=10.9)));
# 1 "/usr/include/sys/_types/_ssize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ssize_t.h" 3 4
typedef __darwin_ssize_t ssize_t;
# 153 "/usr/include/string.h" 2 3 4
void *memmem(const void *, size_t, const void *, size_t) __attribute__((availability(macosx,introduced=10.7)));
void memset_pattern4(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern8(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern16(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
char *strcasestr(const char *, const char *);
char *strnstr(const char *, const char *, size_t);
size_t strlcat(char *, const char *, size_t);
size_t strlcpy(char *, const char *, size_t);
void strmode(int, char *);
char *strsep(char **, const char *);
void swab(const void * restrict, void * restrict, ssize_t);
# 1 "/usr/include/strings.h" 1 3 4
# 70 "/usr/include/strings.h" 3 4
int bcmp(const void *, const void *, size_t) ;
void bcopy(const void *, void *, size_t) ;
void bzero(void *, size_t) ;
char *index(const char *, int) ;
char *rindex(const char *, int) ;
int ffs(int);
int strcasecmp(const char *, const char *);
int strncasecmp(const char *, const char *, size_t);
int ffsl(long) __attribute__((availability(macosx,introduced=10.5)));
int ffsll(long long) __attribute__((availability(macosx,introduced=10.9)));
int fls(int) __attribute__((availability(macosx,introduced=10.5)));
int flsl(long) __attribute__((availability(macosx,introduced=10.5)));
int flsll(long long) __attribute__((availability(macosx,introduced=10.9)));
# 93 "/usr/include/strings.h" 2 3 4
# 177 "/usr/include/string.h" 2 3 4
# 186 "/usr/include/string.h" 3 4
# 1 "/usr/include/secure/_string.h" 1 3 4
# 33 "/usr/include/secure/_string.h" 3 4
# 1 "/usr/include/secure/_common.h" 1 3 4
# 34 "/usr/include/secure/_string.h" 2 3 4
# 187 "/usr/include/string.h" 2 3 4
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
Source:
#include <stdlib.h>
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 82 "/usr/include/sys/signal.h" 2 3 4
# 145 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 148 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 153 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 154 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 266 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 328 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 345 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 364 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 387 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait") ;
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid") ;
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid") ;
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (*)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *, const void *, size_t,
     size_t, int (*)(const void *, const void *));
void *calloc(size_t, size_t);
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t);
int mblen(const char *, size_t);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **, size_t, size_t) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *, size_t, size_t,
int rand(void);
void *realloc(void *, size_t);
void srand(unsigned);
double strtod(const char *, char **) __asm("_" "strtod") ;
float strtof(const char *, char **) __asm("_" "strtof") ;
long strtol(const char *, char **, int);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *, char **, int);
unsigned long
  strtoul(const char *, char **, int);
unsigned long long
  strtoull(const char *, char **, int);
int system(const char *) __asm("_" "system") ;
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]);
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void);
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void);
long nrand48(unsigned short[3]);
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv") ;
long random(void);
int rand_r(unsigned *);
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char *, const char *, int) __asm("_" "setenv") ;
void setkey(const char *) __asm("_" "setkey") ;
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv") ;
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 239 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 241 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 242 "/usr/include/stdlib.h" 2 3 4
u_int32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int );
void arc4random_buf(void * , size_t ) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
u_int32_t
  arc4random_uniform(u_int32_t ) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *, const void *, size_t,
     size_t, int (^)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *, size_t, size_t,
int heapsort_b(void *, size_t, size_t,
int mergesort(void *, size_t, size_t,
int mergesort_b(void *, size_t, size_t,
void psort(void *, size_t, size_t,
     int (*)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *, size_t, size_t,
void psort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *, size_t, size_t,
void qsort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
  strtoq(const char *, char **, int);
unsigned long long
  strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
                      Pushing language C
                      Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest
          Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/types.h" 1 3 4
# 72 "/usr/include/sys/types.h" 3 4
# 73 "/usr/include/sys/types.h" 2 3 4
# 76 "/usr/include/sys/types.h" 2 3 4
# 70 "/usr/include/i386/types.h" 3 4
typedef union {
} __mbstate_t;
# 71 "/usr/include/i386/types.h" 2 3 4
# 77 "/usr/include/i386/types.h" 2 3 4
# 78 "/usr/include/i386/types.h" 2 3 4
# 79 "/usr/include/i386/types.h" 2 3 4
# 80 "/usr/include/i386/types.h" 2 3 4
# 93 "/usr/include/i386/types.h" 2 3 4
# 94 "/usr/include/i386/types.h" 2 3 4
# 79 "/usr/include/sys/types.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 3 4
 void *__arg;
# 80 "/usr/include/sys/types.h" 2 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
# 82 "/usr/include/sys/types.h" 2 3 4
typedef unsigned char u_char;
typedef unsigned short u_short;
typedef unsigned int u_int;
typedef unsigned long u_long;
typedef unsigned short ushort;
typedef unsigned int uint;
typedef u_int64_t u_quad_t;
typedef int64_t quad_t;
typedef quad_t * qaddr_t;
typedef char * caddr_t;
typedef int32_t daddr_t;
# 103 "/usr/include/sys/types.h" 2 3 4
typedef u_int32_t fixpt_t;
# 1 "/usr/include/sys/_types/_blkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blkcnt_t.h" 3 4
typedef __darwin_blkcnt_t blkcnt_t;
# 107 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_blksize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blksize_t.h" 3 4
typedef __darwin_blksize_t blksize_t;
# 108 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_gid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_gid_t.h" 3 4
typedef __darwin_gid_t gid_t;
# 109 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_addr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_addr_t.h" 3 4
typedef __uint32_t in_addr_t;
# 110 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_port_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_port_t.h" 3 4
typedef __uint16_t in_port_t;
# 111 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino_t.h" 3 4
typedef __darwin_ino_t ino_t;
# 112 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino64_t.h" 3 4
typedef __darwin_ino64_t ino64_t;
# 115 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_key_t.h" 3 4
typedef __int32_t key_t;
# 118 "/usr/include/sys/types.h" 2 3 4
# 119 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_nlink_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_nlink_t.h" 3 4
typedef __uint16_t nlink_t;
# 120 "/usr/include/sys/types.h" 2 3 4
# 121 "/usr/include/sys/types.h" 2 3 4
# 122 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_off_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_off_t.h" 3 4
typedef __darwin_off_t off_t;
# 123 "/usr/include/sys/types.h" 2 3 4
typedef int32_t segsz_t;
typedef int32_t swblk_t;
# 128 "/usr/include/sys/types.h" 2 3 4
# 161 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/_types/_clock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_clock_t.h" 3 4
typedef __darwin_clock_t clock_t;
# 162 "/usr/include/sys/types.h" 2 3 4
# 163 "/usr/include/sys/types.h" 2 3 4
# 164 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_time_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_time_t.h" 3 4
typedef __darwin_time_t time_t;
# 165 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_useconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_useconds_t.h" 3 4
typedef __darwin_useconds_t useconds_t;
# 167 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_suseconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_suseconds_t.h" 3 4
typedef __darwin_suseconds_t suseconds_t;
# 168 "/usr/include/sys/types.h" 2 3 4
# 171 "/usr/include/sys/types.h" 2 3 4
# 172 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_def.h" 1 3 4
# 46 "/usr/include/sys/_types/_fd_def.h" 3 4
typedef struct fd_set {
 __int32_t fds_bits[((((1024) % ((sizeof(__int32_t) * 8))) == 0) ? ((1024) / ((sizeof(__int32_t) * 8))) : (((1024) / ((sizeof(__int32_t) * 8))) + 1))];
} fd_set;
static __inline int
__darwin_fd_isset(int _n, const struct fd_set *_p)
 return (_p->fds_bits[(unsigned long)_n/(sizeof(__int32_t) * 8)] & ((__int32_t)(1<<((unsigned long)_n % (sizeof(__int32_t) * 8)))));
# 181 "/usr/include/sys/types.h" 2 3 4
typedef __int32_t fd_mask;
# 1 "/usr/include/sys/_types/_fd_setsize.h" 1 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_set.h" 1 3 4
# 195 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_clr.h" 1 3 4
# 196 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_zero.h" 1 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_isset.h" 1 3 4
# 198 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_copy.h" 1 3 4
# 201 "/usr/include/sys/types.h" 2 3 4
# 210 "/usr/include/sys/types.h" 3 4
# 211 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_cond_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_cond_t.h" 3 4
typedef __darwin_pthread_cond_t pthread_cond_t;
# 212 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_condattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_condattr_t.h" 3 4
typedef __darwin_pthread_condattr_t pthread_condattr_t;
# 213 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutex_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutex_t.h" 3 4
typedef __darwin_pthread_mutex_t pthread_mutex_t;
# 214 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 3 4
typedef __darwin_pthread_mutexattr_t pthread_mutexattr_t;
# 215 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_once_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_once_t.h" 3 4
typedef __darwin_pthread_once_t pthread_once_t;
# 216 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlock_t.h" 3 4
typedef __darwin_pthread_rwlock_t pthread_rwlock_t;
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 3 4
typedef __darwin_pthread_rwlockattr_t pthread_rwlockattr_t;
# 218 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_t.h" 3 4
typedef __darwin_pthread_t pthread_t;
# 219 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_key_t.h" 3 4
typedef __darwin_pthread_key_t pthread_key_t;
# 223 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsblkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsblkcnt_t.h" 3 4
typedef __darwin_fsblkcnt_t fsblkcnt_t;
# 227 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsfilcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsfilcnt_t.h" 3 4
typedef __darwin_fsfilcnt_t fsfilcnt_t;
# 228 "/usr/include/sys/types.h" 2 3 4
# 5 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/sys/stat.h" 1 3 4
# 75 "/usr/include/sys/stat.h" 3 4
# 76 "/usr/include/sys/stat.h" 2 3 4
# 1 "/usr/include/sys/_types/_timespec.h" 1 3 4
# 30 "/usr/include/sys/_types/_timespec.h" 3 4
struct timespec
 long tv_nsec;
# 79 "/usr/include/sys/stat.h" 2 3 4
# 110 "/usr/include/sys/stat.h" 3 4
struct ostat {
 __uint16_t st_dev;
 ino_t st_ino;
 mode_t st_mode;
 nlink_t st_nlink;
 __uint16_t st_uid;
 __uint16_t st_gid;
 __uint16_t st_rdev;
 __int32_t st_size;
 struct timespec st_atimespec;
 struct timespec st_mtimespec;
 struct timespec st_ctimespec;
 __int32_t st_blksize;
 __int32_t st_blocks;
 __uint32_t st_flags;
 __uint32_t st_gen;
# 182 "/usr/include/sys/stat.h" 3 4
struct stat { dev_t st_dev; mode_t st_mode; nlink_t st_nlink; __darwin_ino64_t st_ino; uid_t st_uid; gid_t st_gid; dev_t st_rdev; struct timespec st_atimespec; struct timespec st_mtimespec; struct timespec st_ctimespec; struct timespec st_birthtimespec; off_t st_size; blkcnt_t st_blocks; blksize_t st_blksize; __uint32_t st_flags; __uint32_t st_gen; __int32_t st_lspare; __int64_t st_qspare[2]; };
# 221 "/usr/include/sys/stat.h" 3 4
struct stat64 { dev_t st_dev; mode_t st_mode; nlink_t st_nlink; __darwin_ino64_t st_ino; uid_t st_uid; gid_t st_gid; dev_t st_rdev; struct timespec st_atimespec; struct timespec st_mtimespec; struct timespec st_ctimespec; struct timespec st_birthtimespec; off_t st_size; blkcnt_t st_blocks; blksize_t st_blksize; __uint32_t st_flags; __uint32_t st_gen; __int32_t st_lspare; __int64_t st_qspare[2]; };
# 241 "/usr/include/sys/stat.h" 3 4
# 1 "/usr/include/sys/_types/_s_ifmt.h" 1 3 4
# 242 "/usr/include/sys/stat.h" 2 3 4
# 346 "/usr/include/sys/stat.h" 3 4
int chmod(const char *, mode_t) __asm("_" "chmod") ;
int fchmod(int, mode_t) __asm("_" "fchmod") ;
int fstat(int, struct stat *) __asm("_" "fstat" "$INODE64");
int lstat(const char *, struct stat *) __asm("_" "lstat" "$INODE64");
int mkdir(const char *, mode_t);
int mkfifo(const char *, mode_t);
int stat(const char *, struct stat *) __asm("_" "stat" "$INODE64");
int mknod(const char *, mode_t, dev_t);
mode_t umask(mode_t);
# 1 "/usr/include/sys/_types/_filesec_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_filesec_t.h" 3 4
struct _filesec;
typedef struct _filesec *filesec_t;
# 359 "/usr/include/sys/stat.h" 2 3 4
int chflags(const char *, __uint32_t);
int chmodx_np(const char *, filesec_t);
int fchflags(int, __uint32_t);
int fchmodx_np(int, filesec_t);
int fstatx_np(int, struct stat *, filesec_t) __asm("_" "fstatx_np" "$INODE64");
int lchflags(const char *, __uint32_t) __attribute__((availability(macosx,introduced=10.5)));
int lchmod(const char *, mode_t) __attribute__((availability(macosx,introduced=10.5)));
int lstatx_np(const char *, struct stat *, filesec_t) __asm("_" "lstatx_np" "$INODE64");
int mkdirx_np(const char *, filesec_t);
int mkfifox_np(const char *, filesec_t);
int statx_np(const char *, struct stat *, filesec_t) __asm("_" "statx_np" "$INODE64");
int umaskx_np(filesec_t) __attribute__((availability(macosx,introduced=10.4,deprecated=10.6)));
int fstatx64_np(int, struct stat64 *, filesec_t) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
int lstatx64_np(const char *, struct stat64 *, filesec_t) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
int statx64_np(const char *, struct stat64 *, filesec_t) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
int fstat64(int, struct stat64 *) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
int lstat64(const char *, struct stat64 *) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
int stat64(const char *, struct stat64 *) __attribute__((availability(macosx,introduced=10.5,deprecated=10.6)));
# 6 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
TEST checkSysWait from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
          Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/time.h" 1 3 4
# 66 "/usr/include/time.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 67 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/_structs.h" 1 3 4
# 24 "/usr/include/_structs.h" 3 4
# 1 "/usr/include/sys/_structs.h" 1 3 4
# 73 "/usr/include/sys/_structs.h" 3 4
struct timespec
 long tv_nsec;
# 74 "/usr/include/sys/_structs.h" 2 3 4
# 25 "/usr/include/_structs.h" 2 3 4
# 70 "/usr/include/time.h" 2 3 4
# 71 "/usr/include/time.h" 2 3 4
# 72 "/usr/include/time.h" 2 3 4
# 73 "/usr/include/time.h" 2 3 4
# 74 "/usr/include/time.h" 2 3 4
struct tm {
 int tm_sec;
 int tm_min;
 int tm_hour;
 int tm_mday;
 int tm_mon;
 int tm_year;
 int tm_wday;
 int tm_yday;
 int tm_isdst;
 long tm_gmtoff;
 char *tm_zone;
# 98 "/usr/include/time.h" 3 4
extern char *tzname[];
extern int getdate_err;
extern long timezone __asm("_" "timezone") ;
extern int daylight;
char *asctime(const struct tm *);
clock_t clock(void) __asm("_" "clock") ;
char *ctime(const time_t *);
double difftime(time_t, time_t);
struct tm *getdate(const char *);
struct tm *gmtime(const time_t *);
struct tm *localtime(const time_t *);
time_t mktime(struct tm *) __asm("_" "mktime") ;
size_t strftime(char * restrict, size_t, const char * restrict, const struct tm * restrict) __asm("_" "strftime") ;
char *strptime(const char * restrict, const char * restrict, struct tm * restrict) __asm("_" "strptime") ;
time_t time(time_t *);
void tzset(void);
char *asctime_r(const struct tm * restrict, char * restrict);
char *ctime_r(const time_t *, char *);
struct tm *gmtime_r(const time_t * restrict, struct tm * restrict);
struct tm *localtime_r(const time_t * restrict, struct tm * restrict);
time_t posix2time(time_t);
void tzsetwall(void);
time_t time2posix(time_t);
time_t timelocal(struct tm * const);
time_t timegm(struct tm * const);
int nanosleep(const struct timespec *, struct timespec *) __asm("_" "nanosleep") ;
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/time.h" 1 3 4
# 67 "/usr/include/sys/time.h" 3 4
# 68 "/usr/include/sys/time.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 69 "/usr/include/sys/time.h" 2 3 4
# 70 "/usr/include/sys/time.h" 2 3 4
} fd_set;
static __inline int
# 76 "/usr/include/sys/time.h" 2 3 4
struct timespec
 long tv_nsec;
# 77 "/usr/include/sys/time.h" 2 3 4
struct timeval
# 78 "/usr/include/sys/time.h" 2 3 4
# 80 "/usr/include/sys/time.h" 2 3 4
# 81 "/usr/include/sys/time.h" 2 3 4
struct itimerval {
 struct timeval it_interval;
 struct timeval it_value;
# 105 "/usr/include/sys/time.h" 3 4
# 106 "/usr/include/sys/time.h" 2 3 4
# 107 "/usr/include/sys/time.h" 2 3 4
# 108 "/usr/include/sys/time.h" 2 3 4
# 109 "/usr/include/sys/time.h" 2 3 4
# 110 "/usr/include/sys/time.h" 2 3 4
# 114 "/usr/include/sys/time.h" 2 3 4
# 124 "/usr/include/sys/time.h" 3 4
struct timezone {
 int tz_minuteswest;
 int tz_dsttime;
# 167 "/usr/include/sys/time.h" 3 4
struct clockinfo {
 int hz;
 int tick;
 int tickadj;
 int stathz;
 int profhz;
struct tm {
 int tm_sec;
 int tm_min;
 int tm_hour;
 int tm_mday;
 int tm_mon;
 int tm_year;
 int tm_wday;
 int tm_yday;
 int tm_isdst;
 long tm_gmtoff;
 char *tm_zone;
void tzset(void);
# 179 "/usr/include/sys/time.h" 2 3 4
int adjtime(const struct timeval *, struct timeval *);
int futimes(int, const struct timeval *);
int lutimes(const char *, const struct timeval *) __attribute__((availability(macosx,introduced=10.5)));
int settimeofday(const struct timeval *, const struct timezone *);
int getitimer(int, struct itimerval *);
int gettimeofday(struct timeval * restrict, void * restrict);
# 1 "/usr/include/sys/_select.h" 1 3 4
# 39 "/usr/include/sys/_select.h" 3 4
int select(int, fd_set * restrict, fd_set * restrict,
  fd_set * restrict, struct timeval * restrict)
  __asm("_" "select" "$1050")
# 194 "/usr/include/sys/time.h" 2 3 4
int setitimer(int, const struct itimerval * restrict,
  struct itimerval * restrict);
int utimes(const char *, const struct timeval *);
            Defined "HAVE_SYS_TIME_H" to "1"
Possible ERROR while running compiler:
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:10:8: warning: if statement has empty body [-Wempty-body]
if (tp);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:10:8: note: put the semicolon on a separate line to silence this warning
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
          Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/math.h" 1 3 4
# 30 "/usr/include/math.h" 3 4
# 31 "/usr/include/math.h" 2 3 4
# 32 "/usr/include/math.h" 2 3 4
# 44 "/usr/include/math.h" 3 4
    typedef float float_t;
    typedef double double_t;
# 111 "/usr/include/math.h" 3 4
extern int __math_errhandling(void);
# 144 "/usr/include/math.h" 3 4
extern int __fpclassifyf(float);
extern int __fpclassifyd(double);
extern int __fpclassifyl(long double);
# 188 "/usr/include/math.h" 3 4
inline __attribute__ ((__always_inline__)) int __inline_isfinitef(float);
inline __attribute__ ((__always_inline__)) int __inline_isfinited(double);
inline __attribute__ ((__always_inline__)) int __inline_isfinitel(long double);
inline __attribute__ ((__always_inline__)) int __inline_isinff(float);
inline __attribute__ ((__always_inline__)) int __inline_isinfd(double);
inline __attribute__ ((__always_inline__)) int __inline_isinfl(long double);
inline __attribute__ ((__always_inline__)) int __inline_isnanf(float);
inline __attribute__ ((__always_inline__)) int __inline_isnand(double);
inline __attribute__ ((__always_inline__)) int __inline_isnanl(long double);
inline __attribute__ ((__always_inline__)) int __inline_isnormalf(float);
inline __attribute__ ((__always_inline__)) int __inline_isnormald(double);
inline __attribute__ ((__always_inline__)) int __inline_isnormall(long double);
inline __attribute__ ((__always_inline__)) int __inline_signbitf(float);
inline __attribute__ ((__always_inline__)) int __inline_signbitd(double);
inline __attribute__ ((__always_inline__)) int __inline_signbitl(long double);
inline __attribute__ ((__always_inline__)) int __inline_isfinitef(float __x) {
    return __x == __x && __builtin_fabsf(__x) != __builtin_inff();
inline __attribute__ ((__always_inline__)) int __inline_isfinited(double __x) {
    return __x == __x && __builtin_fabs(__x) != __builtin_inf();
inline __attribute__ ((__always_inline__)) int __inline_isfinitel(long double __x) {
    return __x == __x && __builtin_fabsl(__x) != __builtin_infl();
inline __attribute__ ((__always_inline__)) int __inline_isinff(float __x) {
    return __builtin_fabsf(__x) == __builtin_inff();
inline __attribute__ ((__always_inline__)) int __inline_isinfd(double __x) {
    return __builtin_fabs(__x) == __builtin_inf();
inline __attribute__ ((__always_inline__)) int __inline_isinfl(long double __x) {
    return __builtin_fabsl(__x) == __builtin_infl();
inline __attribute__ ((__always_inline__)) int __inline_isnanf(float __x) {
    return __x != __x;
inline __attribute__ ((__always_inline__)) int __inline_isnand(double __x) {
    return __x != __x;
inline __attribute__ ((__always_inline__)) int __inline_isnanl(long double __x) {
    return __x != __x;
inline __attribute__ ((__always_inline__)) int __inline_signbitf(float __x) {
    union { float __f; unsigned int __u; } __u;
    __u.__f = __x;
    return (int)(__u.__u >> 31);
inline __attribute__ ((__always_inline__)) int __inline_signbitd(double __x) {
    union { double __f; unsigned long long __u; } __u;
    __u.__f = __x;
    return (int)(__u.__u >> 63);
inline __attribute__ ((__always_inline__)) int __inline_signbitl(long double __x) {
    union {
        long double __ld;
        struct{ unsigned long long __m; unsigned short __sexp; } __p;
    } __u;
    __u.__ld = __x;
    return (int)(__u.__p.__sexp >> 15);
inline __attribute__ ((__always_inline__)) int __inline_isnormalf(float __x) {
    return __inline_isfinitef(__x) && __builtin_fabsf(__x) >= 1.17549435e-38F;
inline __attribute__ ((__always_inline__)) int __inline_isnormald(double __x) {
    return __inline_isfinited(__x) && __builtin_fabs(__x) >= 2.2250738585072014e-308;
inline __attribute__ ((__always_inline__)) int __inline_isnormall(long double __x) {
    return __inline_isfinitel(__x) && __builtin_fabsl(__x) >= 3.36210314311209350626e-4932L;
# 322 "/usr/include/math.h" 3 4
extern float acosf(float);
extern double acos(double);
extern long double acosl(long double);
extern float asinf(float);
extern double asin(double);
extern long double asinl(long double);
extern float atanf(float);
extern double atan(double);
extern long double atanl(long double);
extern float atan2f(float, float);
extern double atan2(double, double);
extern long double atan2l(long double, long double);
extern float cosf(float);
extern double cos(double);
extern long double cosl(long double);
extern float sinf(float);
extern double sin(double);
extern long double sinl(long double);
extern float tanf(float);
extern double tan(double);
extern long double tanl(long double);
extern float acoshf(float);
extern double acosh(double);
extern long double acoshl(long double);
extern float asinhf(float);
extern double asinh(double);
extern long double asinhl(long double);
extern float atanhf(float);
extern double atanh(double);
extern long double atanhl(long double);
extern float coshf(float);
extern double cosh(double);
extern long double coshl(long double);
extern float sinhf(float);
extern double sinh(double);
extern long double sinhl(long double);
extern float tanhf(float);
extern double tanh(double);
extern long double tanhl(long double);
extern float expf(float);
extern double exp(double);
extern long double expl(long double);
extern float exp2f(float);
extern double exp2(double);
extern long double exp2l(long double);
extern float expm1f(float);
extern double expm1(double);
extern long double expm1l(long double);
extern float logf(float);
extern double log(double);
extern long double logl(long double);
extern float log10f(float);
extern double log10(double);
extern long double log10l(long double);
extern float log2f(float);
extern double log2(double);
extern long double log2l(long double);
extern float log1pf(float);
extern double log1p(double);
extern long double log1pl(long double);
extern float logbf(float);
extern double logb(double);
extern long double logbl(long double);
extern float modff(float, float *);
extern double modf(double, double *);
extern long double modfl(long double, long double *);
extern float ldexpf(float, int);
extern double ldexp(double, int);
extern long double ldexpl(long double, int);
extern float frexpf(float, int *);
extern double frexp(double, int *);
extern long double frexpl(long double, int *);
extern int ilogbf(float);
extern int ilogb(double);
extern int ilogbl(long double);
extern float scalbnf(float, int);
extern double scalbn(double, int);
extern long double scalbnl(long double, int);
extern float scalblnf(float, long int);
extern double scalbln(double, long int);
extern long double scalblnl(long double, long int);
extern float fabsf(float);
extern double fabs(double);
extern long double fabsl(long double);
extern float cbrtf(float);
extern double cbrt(double);
extern long double cbrtl(long double);
extern float hypotf(float, float);
extern double hypot(double, double);
extern long double hypotl(long double, long double);
extern float powf(float, float);
extern double pow(double, double);
extern long double powl(long double, long double);
extern float sqrtf(float);
extern double sqrt(double);
extern long double sqrtl(long double);
extern float erff(float);
extern double erf(double);
extern long double erfl(long double);
extern float erfcf(float);
extern double erfc(double);
extern long double erfcl(long double);
extern float lgammaf(float);
extern double lgamma(double);
extern long double lgammal(long double);
extern float tgammaf(float);
extern double tgamma(double);
extern long double tgammal(long double);
extern float ceilf(float);
extern double ceil(double);
extern long double ceill(long double);
extern float floorf(float);
extern double floor(double);
extern long double floorl(long double);
extern float nearbyintf(float);
extern double nearbyint(double);
extern long double nearbyintl(long double);
extern float rintf(float);
extern double rint(double);
extern long double rintl(long double);
extern long int lrintf(float);
extern long int lrint(double);
extern long int lrintl(long double);
extern float roundf(float);
extern double round(double);
extern long double roundl(long double);
extern long int lroundf(float);
extern long int lround(double);
extern long int lroundl(long double);
extern long long int llrintf(float);
extern long long int llrint(double);
extern long long int llrintl(long double);
extern long long int llroundf(float);
extern long long int llround(double);
extern long long int llroundl(long double);
extern float truncf(float);
extern double trunc(double);
extern long double truncl(long double);
extern float fmodf(float, float);
extern double fmod(double, double);
extern long double fmodl(long double, long double);
extern float remainderf(float, float);
extern double remainder(double, double);
extern long double remainderl(long double, long double);
extern float remquof(float, float, int *);
extern double remquo(double, double, int *);
extern long double remquol(long double, long double, int *);
extern float copysignf(float, float);
extern double copysign(double, double);
extern long double copysignl(long double, long double);
extern float nanf(const char *);
extern double nan(const char *);
extern long double nanl(const char *);
extern float nextafterf(float, float);
extern double nextafter(double, double);
extern long double nextafterl(long double, long double);
extern double nexttoward(double, long double);
extern float nexttowardf(float, long double);
extern long double nexttowardl(long double, long double);
extern float fdimf(float, float);
extern double fdim(double, double);
extern long double fdiml(long double, long double);
extern float fmaxf(float, float);
extern double fmax(double, double);
extern long double fmaxl(long double, long double);
extern float fminf(float, float);
extern double fmin(double, double);
extern long double fminl(long double, long double);
extern float fmaf(float, float, float);
extern double fma(double, double, double);
extern long double fmal(long double, long double, long double);
# 565 "/usr/include/math.h" 3 4
extern float __inff(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern double __inf(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern long double __infl(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern float __nan(void) __attribute__((availability(macosx,introduced=10.0)));
# 597 "/usr/include/math.h" 3 4
extern float __exp10f(float) __attribute__((availability(macosx,introduced=10.9)));
extern double __exp10(double) __attribute__((availability(macosx,introduced=10.9)));
inline __attribute__ ((__always_inline__)) void __sincosf(float __x, float *__sinp, float *__cosp) __attribute__((availability(macosx,introduced=10.9)));
inline __attribute__ ((__always_inline__)) void __sincos(double __x, double *__sinp, double *__cosp) __attribute__((availability(macosx,introduced=10.9)));
# 614 "/usr/include/math.h" 3 4
extern float __cospif(float) __attribute__((availability(macosx,introduced=10.9)));
extern double __cospi(double) __attribute__((availability(macosx,introduced=10.9)));
extern float __sinpif(float) __attribute__((availability(macosx,introduced=10.9)));
extern double __sinpi(double) __attribute__((availability(macosx,introduced=10.9)));
extern float __tanpif(float) __attribute__((availability(macosx,introduced=10.9)));
extern double __tanpi(double) __attribute__((availability(macosx,introduced=10.9)));
inline __attribute__ ((__always_inline__)) void __sincospif(float __x, float *__sinp, float *__cosp) __attribute__((availability(macosx,introduced=10.9)));
inline __attribute__ ((__always_inline__)) void __sincospi(double __x, double *__sinp, double *__cosp) __attribute__((availability(macosx,introduced=10.9)));
struct __float2 { float __sinval; float __cosval; };
struct __double2 { double __sinval; double __cosval; };
extern struct __float2 __sincosf_stret(float);
extern struct __double2 __sincos_stret(double);
extern struct __float2 __sincospif_stret(float);
extern struct __double2 __sincospi_stret(double);
inline __attribute__ ((__always_inline__)) void __sincosf(float __x, float *__sinp, float *__cosp) {
    const struct __float2 __stret = __sincosf_stret(__x);
    *__sinp = __stret.__sinval; *__cosp = __stret.__cosval;
inline __attribute__ ((__always_inline__)) void __sincos(double __x, double *__sinp, double *__cosp) {
    const struct __double2 __stret = __sincos_stret(__x);
inline __attribute__ ((__always_inline__)) void __sincospif(float __x, float *__sinp, float *__cosp) {
    const struct __float2 __stret = __sincospif_stret(__x);
inline __attribute__ ((__always_inline__)) void __sincospi(double __x, double *__sinp, double *__cosp) {
    const struct __double2 __stret = __sincospi_stret(__x);
extern double j0(double) __attribute__((availability(macosx,introduced=10.0)));
extern double j1(double) __attribute__((availability(macosx,introduced=10.0)));
extern double jn(int, double) __attribute__((availability(macosx,introduced=10.0)));
extern double y0(double) __attribute__((availability(macosx,introduced=10.0)));
extern double y1(double) __attribute__((availability(macosx,introduced=10.0)));
extern double yn(int, double) __attribute__((availability(macosx,introduced=10.0)));
extern double scalb(double, double);
extern int signgam;
# 712 "/usr/include/math.h" 3 4
extern long int rinttol(double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern long int roundtol(double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern double drem(double, double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern int finite(double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern double gamma(double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
extern double significand(double) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
struct exception {
    int type;
    char *name;
    double arg1;
    double arg2;
    double retval;
extern int matherr(struct exception *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.9)));
            Defined "HAVE_MATH_H" to "1"
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:8:8: warning: if statement has empty body [-Wempty-body]
if (pi);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:8:8: note: put the semicolon on a separate line to silence this warning
1 warning generated.
Source:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
        Found math #defines, like M_PI
TEST check from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/sys/socket.h" 1 3 4
# 75 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 1 "/usr/include/sys/_types.h" 1 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 1 "/usr/include/sys/_types/_ssize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ssize_t.h" 3 4
typedef __darwin_ssize_t ssize_t;
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rsize_t.h" 3 4
typedef __darwin_size_t rsize_t;
# 1 "/usr/include/sys/_types/_errno_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_errno_t.h" 3 4
typedef int errno_t;
} fd_set;
static __inline int
# 76 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/machine/_param.h" 1 3 4
# 29 "/usr/include/machine/_param.h" 3 4
# 1 "/usr/include/i386/_param.h" 1 3 4
# 30 "/usr/include/machine/_param.h" 2 3 4
# 78 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 81 "/usr/include/sys/socket.h" 2 3 4
# 93 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/_types/_sa_family_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sa_family_t.h" 3 4
typedef __uint8_t sa_family_t;
# 94 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/sys/_types/_socklen_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_socklen_t.h" 3 4
typedef __darwin_socklen_t socklen_t;
# 95 "/usr/include/sys/socket.h" 2 3 4
# 105 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/_types/_iovec_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_iovec_t.h" 3 4
struct iovec {
 void * iov_base;
 size_t iov_len;
# 106 "/usr/include/sys/socket.h" 2 3 4
# 186 "/usr/include/sys/socket.h" 3 4
struct linger {
 int l_onoff;
 int l_linger;
# 204 "/usr/include/sys/socket.h" 3 4
struct so_np_extensions {
 u_int32_t npx_flags;
 u_int32_t npx_mask;
# 279 "/usr/include/sys/socket.h" 3 4
struct sockaddr {
 __uint8_t sa_len;
 sa_family_t sa_family;
 char sa_data[14];
# 292 "/usr/include/sys/socket.h" 3 4
struct sockproto {
 __uint16_t sp_family;
 __uint16_t sp_protocol;
# 312 "/usr/include/sys/socket.h" 3 4
struct sockaddr_storage {
 __uint8_t ss_len;
 sa_family_t ss_family;
 char __ss_pad1[((sizeof(__int64_t)) - sizeof(__uint8_t) - sizeof(sa_family_t))];
 __int64_t __ss_align;
 char __ss_pad2[(128 - sizeof(__uint8_t) - sizeof(sa_family_t) - ((sizeof(__int64_t)) - sizeof(__uint8_t) - sizeof(sa_family_t)) - (sizeof(__int64_t)))];
# 412 "/usr/include/sys/socket.h" 3 4
struct msghdr {
 void *msg_name;
 socklen_t msg_namelen;
 struct iovec *msg_iov;
 int msg_iovlen;
 void *msg_control;
 socklen_t msg_controllen;
 int msg_flags;
# 452 "/usr/include/sys/socket.h" 3 4
struct cmsghdr {
 socklen_t cmsg_len;
 int cmsg_level;
 int cmsg_type;
# 543 "/usr/include/sys/socket.h" 3 4
struct sf_hdtr {
 struct iovec *headers;
 int hdr_cnt;
 struct iovec *trailers;
 int trl_cnt;
int accept(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "accept") ;
int bind(int, const struct sockaddr *, socklen_t) __asm("_" "bind") ;
int connect(int, const struct sockaddr *, socklen_t) __asm("_" "connect") ;
int getpeername(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "getpeername") ;
int getsockname(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "getsockname") ;
int getsockopt(int, int, int, void * restrict, socklen_t * restrict);
int listen(int, int) __asm("_" "listen") ;
ssize_t recv(int, void *, size_t, int) __asm("_" "recv") ;
ssize_t recvfrom(int, void *, size_t, int, struct sockaddr * restrict,
  socklen_t * restrict) __asm("_" "recvfrom") ;
ssize_t recvmsg(int, struct msghdr *, int) __asm("_" "recvmsg") ;
ssize_t send(int, const void *, size_t, int) __asm("_" "send") ;
ssize_t sendmsg(int, const struct msghdr *, int) __asm("_" "sendmsg") ;
ssize_t sendto(int, const void *, size_t,
  int, const struct sockaddr *, socklen_t) __asm("_" "sendto") ;
int setsockopt(int, int, int, const void *, socklen_t);
int shutdown(int, int);
int sockatmark(int) __attribute__((availability(macosx,introduced=10.5)));
int socket(int, int, int);
int socketpair(int, int, int, int *) __asm("_" "socketpair") ;
int sendfile(int, int, off_t, off_t *, struct sf_hdtr *, int);
void pfctlinput(int, struct sockaddr *);
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
            Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
typedef union {
} __mbstate_t;
 void *__arg;
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
} fd_set;
static __inline int
            Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'malloc.h' file not found
#include <malloc.h>
1 error generated.
Source:
#include <malloc.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'malloc.h' file not found
#include <malloc.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'malloc.h' file not found#include <malloc.h>         ^1 error generated.:
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 32 "/usr/include/machine/_types.h" 3 4
typedef union {
} __mbstate_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
 void *__arg;
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
struct timespec
 long tv_nsec;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
struct tm {
 int tm_sec;
 int tm_min;
 int tm_hour;
 int tm_mday;
 int tm_mon;
 int tm_year;
 int tm_wday;
 int tm_yday;
 int tm_isdst;
 long tm_gmtoff;
 char *tm_zone;
void tzset(void);
Checking for header: Direct.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Direct.h' file not found
#include <Direct.h>
1 error generated.
Source:
#include <Direct.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Direct.h' file not found
#include <Direct.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Direct.h' file not found#include <Direct.h>         ^1 error generated.:
Checking for header: Ws2tcpip.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Ws2tcpip.h' file not found
#include <Ws2tcpip.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Ws2tcpip.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'Ws2tcpip.h' file not found#include <Ws2tcpip.h>         ^1 error generated.:
Checking for header: endian.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'endian.h' file not found
#include <endian.h>
1 error generated.
Source:
#include <endian.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'endian.h' file not found
#include <endian.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'endian.h' file not found#include <endian.h>         ^1 error generated.:
Checking for header: ieeefp.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'ieeefp.h' file not found
#include <ieeefp.h>
1 error generated.
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'ieeefp.h' file not found
#include <ieeefp.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'ieeefp.h' file not found#include <ieeefp.h>         ^1 error generated.:
Checking for header: strings.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/strings.h" 1 3 4
# 61 "/usr/include/strings.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 62 "/usr/include/strings.h" 2 3 4
# 65 "/usr/include/strings.h" 2 3 4
# 66 "/usr/include/strings.h" 2 3 4
int bcmp(const void *, const void *, size_t) ;
void bcopy(const void *, void *, size_t) ;
void bzero(void *, size_t) ;
char *index(const char *, int) ;
char *rindex(const char *, int) ;
int ffs(int);
int strcasecmp(const char *, const char *);
int strncasecmp(const char *, const char *, size_t);
int ffsl(long) __attribute__((availability(macosx,introduced=10.5)));
int ffsll(long long) __attribute__((availability(macosx,introduced=10.9)));
int fls(int) __attribute__((availability(macosx,introduced=10.5)));
int flsl(long) __attribute__((availability(macosx,introduced=10.5)));
int flsll(long long) __attribute__((availability(macosx,introduced=10.9)));
# 1 "/usr/include/string.h" 1 3 4
# 65 "/usr/include/string.h" 3 4
# 66 "/usr/include/string.h" 2 3 4
void *memchr(const void *, int, size_t);
int memcmp(const void *, const void *, size_t);
void *memcpy(void *, const void *, size_t);
void *memmove(void *, const void *, size_t);
void *memset(void *, int, size_t);
char *strcat(char *, const char *);
char *strchr(const char *, int);
int strcmp(const char *, const char *);
int strcoll(const char *, const char *);
char *strcpy(char *, const char *);
size_t strcspn(const char *, const char *);
char *strerror(int) __asm("_" "strerror") ;
size_t strlen(const char *);
char *strncat(char *, const char *, size_t);
int strncmp(const char *, const char *, size_t);
char *strncpy(char *, const char *, size_t);
char *strpbrk(const char *, const char *);
char *strrchr(const char *, int);
size_t strspn(const char *, const char *);
char *strstr(const char *, const char *);
char *strtok(char *, const char *);
size_t strxfrm(char *, const char *, size_t);
# 104 "/usr/include/string.h" 3 4
char *strtok_r(char *, const char *, char **);
# 116 "/usr/include/string.h" 3 4
int strerror_r(int, char *, size_t);
char *strdup(const char *);
void *memccpy(void *, const void *, int, size_t);
# 130 "/usr/include/string.h" 3 4
char *stpcpy(char *, const char *);
char *stpncpy(char *, const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strndup(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
size_t strnlen(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strsignal(int sig);
# 142 "/usr/include/string.h" 2 3 4
# 143 "/usr/include/string.h" 2 3 4
errno_t memset_s(void *, rsize_t, int, rsize_t) __attribute__((availability(macosx,introduced=10.9)));
# 153 "/usr/include/string.h" 2 3 4
void *memmem(const void *, size_t, const void *, size_t) __attribute__((availability(macosx,introduced=10.7)));
void memset_pattern4(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern8(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern16(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
char *strcasestr(const char *, const char *);
char *strnstr(const char *, const char *, size_t);
size_t strlcat(char *, const char *, size_t);
size_t strlcpy(char *, const char *, size_t);
void strmode(int, char *);
char *strsep(char **, const char *);
void swab(const void * restrict, void * restrict, ssize_t);
# 177 "/usr/include/string.h" 2 3 4
# 186 "/usr/include/string.h" 3 4
# 1 "/usr/include/secure/_string.h" 1 3 4
# 33 "/usr/include/secure/_string.h" 3 4
# 1 "/usr/include/secure/_common.h" 1 3 4
# 34 "/usr/include/secure/_string.h" 2 3 4
# 187 "/usr/include/string.h" 2 3 4
# 93 "/usr/include/strings.h" 2 3 4
            Defined "HAVE_STRINGS_H" to "1"
Checking for header: sched.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sched.h" 1 3 4
# 27 "/usr/include/sched.h" 3 4
# 1 "/usr/include/pthread_impl.h" 1 3 4
# 28 "/usr/include/sched.h" 2 3 4
# 29 "/usr/include/sched.h" 2 3 4
struct sched_param { int sched_priority; char __opaque[4]; };
extern int sched_yield(void);
extern int sched_get_priority_min(int);
extern int sched_get_priority_max(int);
            Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/cxxabi.h" 1 3 4
# 18 "/usr/include/cxxabi.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 1 3 4
# 34 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 3 4
typedef long int ptrdiff_t;
typedef long unsigned int size_t;
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 3 4
typedef int wchar_t;
# 19 "/usr/include/cxxabi.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef __signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
typedef union {
} __mbstate_t;
 void *__arg;
# 53 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 20 "/usr/include/cxxabi.h" 2 3 4
# 173 "/usr/include/cxxabi.h" 3 4
namespace abi = __cxxabiv1;
            Defined "HAVE_CXXABI_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/systeminfo.h' file not found
#include <sys/systeminfo.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/systeminfo.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/systeminfo.h' file not found#include <sys/systeminfo.h>         ^1 error generated.:
Checking for header: dos.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'dos.h' file not found
#include <dos.h>
1 error generated.
Source:
#include <dos.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'dos.h' file not found
#include <dos.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'dos.h' file not found#include <dos.h>         ^1 error generated.:
Checking for header: WindowsX.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'WindowsX.h' file not found
#include <WindowsX.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'WindowsX.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'WindowsX.h' file not found#include <WindowsX.h>         ^1 error generated.:
Checking for header: sys/sysinfo.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/sysinfo.h' file not found
#include <sys/sysinfo.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/sysinfo.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/sysinfo.h' file not found#include <sys/sysinfo.h>         ^1 error generated.:
Checking for header: sys/wait.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/wait.h" 1 3 4
# 67 "/usr/include/sys/wait.h" 3 4
# 68 "/usr/include/sys/wait.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 69 "/usr/include/sys/wait.h" 2 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 82 "/usr/include/sys/signal.h" 2 3 4
# 145 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 148 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 153 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 154 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 266 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 328 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 345 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 364 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 387 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
typedef signed char int8_t;
# 73 "/usr/include/sys/resource.h" 2 3 4
# 76 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait") ;
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid") ;
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid") ;
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
Checking for header: stdlib.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 64 "/usr/include/stdlib.h" 2 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
 char __xmm_reg[16];
 __uint16_t __cpu;
 __uint32_t __err;
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
    __uint16_t __cpu;
    __uint32_t __err;
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
 void *ss_sp;
 int ss_flags;
 int uc_onstack;
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 long si_band;
} siginfo_t;
         void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
struct sigvec {
 int sv_mask;
 int sv_flags;
struct sigstack {
 char *ss_sp;
 int ss_onstack;
struct timeval
struct rusage {
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
 uint32_t wm_flags;
 int32_t wm_rate;
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
union wait {
 int w_status;
 struct {
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (*)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *, const void *, size_t,
     size_t, int (*)(const void *, const void *));
void *calloc(size_t, size_t);
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t);
int mblen(const char *, size_t);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **, size_t, size_t) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *, size_t, size_t,
int rand(void);
void *realloc(void *, size_t);
void srand(unsigned);
double strtod(const char *, char **) __asm("_" "strtod") ;
float strtof(const char *, char **) __asm("_" "strtof") ;
long strtol(const char *, char **, int);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *, char **, int);
unsigned long
  strtoul(const char *, char **, int);
unsigned long long
  strtoull(const char *, char **, int);
int system(const char *) __asm("_" "system") ;
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]);
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void);
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void);
long nrand48(unsigned short[3]);
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv") ;
long random(void);
int rand_r(unsigned *);
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char *, const char *, int) __asm("_" "setenv") ;
void setkey(const char *) __asm("_" "setkey") ;
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv") ;
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 239 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 241 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 242 "/usr/include/stdlib.h" 2 3 4
u_int32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int );
void arc4random_buf(void * , size_t ) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
u_int32_t
  arc4random_uniform(u_int32_t ) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *, const void *, size_t,
     size_t, int (^)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *, size_t, size_t,
int heapsort_b(void *, size_t, size_t,
int mergesort(void *, size_t, size_t,
int mergesort_b(void *, size_t, size_t,
void psort(void *, size_t, size_t,
     int (*)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *, size_t, size_t,
void psort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *, size_t, size_t,
void qsort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
  strtoq(const char *, char **, int);
unsigned long long
  strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/pthread.h" 1 3 4
# 55 "/usr/include/pthread.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 56 "/usr/include/pthread.h" 2 3 4
# 58 "/usr/include/pthread.h" 2 3 4
# 35 "/usr/include/sched.h" 3 4
# 60 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/time.h" 1 3 4
# 69 "/usr/include/time.h" 3 4
# 1 "/usr/include/_structs.h" 1 3 4
# 24 "/usr/include/_structs.h" 3 4
# 1 "/usr/include/sys/_structs.h" 1 3 4
# 73 "/usr/include/sys/_structs.h" 3 4
# 1 "/usr/include/sys/_types/_timespec.h" 1 3 4
# 30 "/usr/include/sys/_types/_timespec.h" 3 4
struct timespec
 long tv_nsec;
# 74 "/usr/include/sys/_structs.h" 2 3 4
# 25 "/usr/include/_structs.h" 2 3 4
# 70 "/usr/include/time.h" 2 3 4
# 71 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/sys/_types/_clock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_clock_t.h" 3 4
typedef __darwin_clock_t clock_t;
# 72 "/usr/include/time.h" 2 3 4
# 73 "/usr/include/time.h" 2 3 4
# 1 "/usr/include/sys/_types/_time_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_time_t.h" 3 4
typedef __darwin_time_t time_t;
# 74 "/usr/include/time.h" 2 3 4
struct tm {
 int tm_sec;
 int tm_min;
 int tm_hour;
 int tm_mday;
 int tm_mon;
 int tm_year;
 int tm_wday;
 int tm_yday;
 int tm_isdst;
 long tm_gmtoff;
 char *tm_zone;
# 98 "/usr/include/time.h" 3 4
extern char *tzname[];
extern int getdate_err;
extern long timezone __asm("_" "timezone") ;
extern int daylight;
char *asctime(const struct tm *);
clock_t clock(void) __asm("_" "clock") ;
char *ctime(const time_t *);
double difftime(time_t, time_t);
struct tm *getdate(const char *);
struct tm *gmtime(const time_t *);
struct tm *localtime(const time_t *);
time_t mktime(struct tm *) __asm("_" "mktime") ;
size_t strftime(char * restrict, size_t, const char * restrict, const struct tm * restrict) __asm("_" "strftime") ;
char *strptime(const char * restrict, const char * restrict, struct tm * restrict) __asm("_" "strptime") ;
time_t time(time_t *);
void tzset(void);
char *asctime_r(const struct tm * restrict, char * restrict);
char *ctime_r(const time_t *, char *);
struct tm *gmtime_r(const time_t * restrict, struct tm * restrict);
struct tm *localtime_r(const time_t * restrict, struct tm * restrict);
time_t posix2time(time_t);
void tzsetwall(void);
time_t time2posix(time_t);
time_t timelocal(struct tm * const);
time_t timegm(struct tm * const);
int nanosleep(const struct timespec *, struct timespec *) __asm("_" "nanosleep") ;
# 61 "/usr/include/pthread.h" 2 3 4
# 62 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_cond_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_cond_t.h" 3 4
typedef __darwin_pthread_cond_t pthread_cond_t;
# 63 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_condattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_condattr_t.h" 3 4
typedef __darwin_pthread_condattr_t pthread_condattr_t;
# 64 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_key_t.h" 3 4
typedef __darwin_pthread_key_t pthread_key_t;
# 65 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutex_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutex_t.h" 3 4
typedef __darwin_pthread_mutex_t pthread_mutex_t;
# 66 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 3 4
typedef __darwin_pthread_mutexattr_t pthread_mutexattr_t;
# 67 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_once_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_once_t.h" 3 4
typedef __darwin_pthread_once_t pthread_once_t;
# 68 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlock_t.h" 3 4
typedef __darwin_pthread_rwlock_t pthread_rwlock_t;
# 69 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 3 4
typedef __darwin_pthread_rwlockattr_t pthread_rwlockattr_t;
# 70 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_t.h" 3 4
typedef __darwin_pthread_t pthread_t;
# 71 "/usr/include/pthread.h" 2 3 4
# 1 "/usr/include/sys/_types/_mach_port_t.h" 1 3 4
# 49 "/usr/include/sys/_types/_mach_port_t.h" 3 4
typedef __darwin_mach_port_t mach_port_t;
# 75 "/usr/include/pthread.h" 2 3 4
# 76 "/usr/include/pthread.h" 2 3 4
# 100 "/usr/include/pthread.h" 3 4
# 101 "/usr/include/pthread.h" 2 3 4
# 206 "/usr/include/pthread.h" 3 4
__attribute__((availability(macosx,introduced=10.4)))
int pthread_atfork(void (*)(void), void (*)(void), void (*)(void));
int pthread_attr_destroy(pthread_attr_t *);
int pthread_attr_getdetachstate(const pthread_attr_t *, int *);
int pthread_attr_getguardsize(const pthread_attr_t * restrict, size_t * restrict);
int pthread_attr_getinheritsched(const pthread_attr_t * restrict, int * restrict);
int pthread_attr_getschedparam(const pthread_attr_t * restrict,
  struct sched_param * restrict);
int pthread_attr_getschedpolicy(const pthread_attr_t * restrict, int * restrict);
int pthread_attr_getscope(const pthread_attr_t * restrict, int * restrict);
int pthread_attr_getstack(const pthread_attr_t * restrict, void ** restrict,
  size_t * restrict);
int pthread_attr_getstackaddr(const pthread_attr_t * restrict, void ** restrict);
int pthread_attr_getstacksize(const pthread_attr_t * restrict, size_t * restrict);
int pthread_attr_init(pthread_attr_t *);
int pthread_attr_setdetachstate(pthread_attr_t *, int);
int pthread_attr_setguardsize(pthread_attr_t *, size_t);
int pthread_attr_setinheritsched(pthread_attr_t *, int);
int pthread_attr_setschedparam(pthread_attr_t * restrict,
  const struct sched_param * restrict);
int pthread_attr_setschedpolicy(pthread_attr_t *, int);
int pthread_attr_setscope(pthread_attr_t *, int);
int pthread_attr_setstack(pthread_attr_t *, void *, size_t);
int pthread_attr_setstackaddr(pthread_attr_t *, void *);
int pthread_attr_setstacksize(pthread_attr_t *, size_t);
int pthread_cancel(pthread_t) __asm("_" "pthread_cancel") ;
int pthread_cond_broadcast(pthread_cond_t *);
int pthread_cond_destroy(pthread_cond_t *);
int pthread_cond_init(pthread_cond_t * restrict,
  const pthread_condattr_t * restrict) __asm("_" "pthread_cond_init") ;
int pthread_cond_signal(pthread_cond_t *);
int pthread_cond_timedwait(pthread_cond_t * restrict, pthread_mutex_t * restrict,
  const struct timespec * restrict) __asm("_" "pthread_cond_timedwait") ;
int pthread_cond_wait(pthread_cond_t * restrict,
  pthread_mutex_t * restrict) __asm("_" "pthread_cond_wait") ;
int pthread_condattr_destroy(pthread_condattr_t *);
int pthread_condattr_init(pthread_condattr_t *);
int pthread_condattr_getpshared(const pthread_condattr_t * restrict,
  int * restrict);
int pthread_condattr_setpshared(pthread_condattr_t *, int);
int pthread_create(pthread_t * restrict, const pthread_attr_t * restrict,
  void *(*)(void *), void * restrict);
int pthread_detach(pthread_t);
int pthread_equal(pthread_t, pthread_t);
void pthread_exit(void *) __attribute__((noreturn));
int pthread_getconcurrency(void);
int pthread_getschedparam(pthread_t , int * restrict,
void* pthread_getspecific(pthread_key_t);
int pthread_join(pthread_t , void **) __asm("_" "pthread_join") ;
int pthread_key_create(pthread_key_t *, void (*)(void *));
int pthread_key_delete(pthread_key_t);
int pthread_mutex_destroy(pthread_mutex_t *);
int pthread_mutex_getprioceiling(const pthread_mutex_t * restrict,
  int * restrict);
int pthread_mutex_init(pthread_mutex_t * restrict,
  const pthread_mutexattr_t * restrict);
int pthread_mutex_lock(pthread_mutex_t *);
int pthread_mutex_setprioceiling(pthread_mutex_t * restrict, int,
  int * restrict);
int pthread_mutex_trylock(pthread_mutex_t *);
int pthread_mutex_unlock(pthread_mutex_t *);
int pthread_mutexattr_destroy(pthread_mutexattr_t *) __asm("_" "pthread_mutexattr_destroy") ;
int pthread_mutexattr_getprioceiling(const pthread_mutexattr_t * restrict,
  int * restrict);
int pthread_mutexattr_getprotocol(const pthread_mutexattr_t * restrict,
  int * restrict);
int pthread_mutexattr_getpshared(const pthread_mutexattr_t * restrict,
  int * restrict);
int pthread_mutexattr_gettype(const pthread_mutexattr_t * restrict,
  int * restrict);
int pthread_mutexattr_init(pthread_mutexattr_t *);
int pthread_mutexattr_setprioceiling(pthread_mutexattr_t *, int);
int pthread_mutexattr_setprotocol(pthread_mutexattr_t *, int);
int pthread_mutexattr_setpshared(pthread_mutexattr_t *, int);
int pthread_mutexattr_settype(pthread_mutexattr_t *, int);
int pthread_once(pthread_once_t *, void (*)(void));
int pthread_rwlock_destroy(pthread_rwlock_t * ) __asm("_" "pthread_rwlock_destroy") ;
int pthread_rwlock_init(pthread_rwlock_t * restrict,
  const pthread_rwlockattr_t * restrict) __asm("_" "pthread_rwlock_init") ;
int pthread_rwlock_rdlock(pthread_rwlock_t *) __asm("_" "pthread_rwlock_rdlock") ;
int pthread_rwlock_tryrdlock(pthread_rwlock_t *) __asm("_" "pthread_rwlock_tryrdlock") ;
int pthread_rwlock_trywrlock(pthread_rwlock_t *) __asm("_" "pthread_rwlock_trywrlock") ;
int pthread_rwlock_wrlock(pthread_rwlock_t *) __asm("_" "pthread_rwlock_wrlock") ;
int pthread_rwlock_unlock(pthread_rwlock_t *) __asm("_" "pthread_rwlock_unlock") ;
int pthread_rwlockattr_destroy(pthread_rwlockattr_t *);
int pthread_rwlockattr_getpshared(const pthread_rwlockattr_t * restrict,
  int * restrict);
int pthread_rwlockattr_init(pthread_rwlockattr_t *);
int pthread_rwlockattr_setpshared(pthread_rwlockattr_t *, int);
pthread_t pthread_self(void);
int pthread_setcancelstate(int , int *) __asm("_" "pthread_setcancelstate") ;
int pthread_setcanceltype(int , int *) __asm("_" "pthread_setcanceltype") ;
int pthread_setconcurrency(int);
int pthread_setschedparam(pthread_t, int, const struct sched_param *);
int pthread_setspecific(pthread_key_t , const void *);
void pthread_testcancel(void) __asm("_" "pthread_testcancel") ;
int pthread_is_threaded_np(void);
int pthread_threadid_np(pthread_t,__uint64_t*);
int pthread_getname_np(pthread_t,char*,size_t);
int pthread_setname_np(const char*);
int pthread_main_np(void);
mach_port_t pthread_mach_thread_np(pthread_t);
size_t pthread_get_stacksize_np(pthread_t);
void* pthread_get_stackaddr_np(pthread_t);
int pthread_cond_signal_thread_np(pthread_cond_t *, pthread_t);
int pthread_cond_timedwait_relative_np(pthread_cond_t *, pthread_mutex_t *,
  const struct timespec *);
int pthread_create_suspended_np(pthread_t *, const pthread_attr_t *,
  void *(*)(void *), void *);
int pthread_kill(pthread_t, int);
pthread_t pthread_from_mach_thread_np(mach_port_t);
int pthread_sigmask(int, const sigset_t *, sigset_t *) __asm("_" "pthread_sigmask") ;
void pthread_yield_np(void);
            Defined "HAVE_PTHREAD_H" to "1"
Checking for header: setjmp.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/setjmp.h" 1 3 4
# 26 "/usr/include/setjmp.h" 3 4
# 27 "/usr/include/setjmp.h" 2 3 4
# 36 "/usr/include/setjmp.h" 3 4
typedef int jmp_buf[((9 * 2) + 3 + 16)];
typedef int sigjmp_buf[((9 * 2) + 3 + 16) + 1];
# 73 "/usr/include/setjmp.h" 3 4
extern int setjmp(jmp_buf);
extern void longjmp(jmp_buf, int) __attribute__((noreturn));
int _setjmp(jmp_buf);
void _longjmp(jmp_buf, int) __attribute__((noreturn));
int sigsetjmp(sigjmp_buf, int);
void siglongjmp(sigjmp_buf, int) __attribute__((noreturn));
void longjmperror(void);
            Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/utsname.h" 1 3 4
# 70 "/usr/include/sys/utsname.h" 3 4
# 71 "/usr/include/sys/utsname.h" 2 3 4
struct utsname {
 char sysname[256];
 char nodename[256];
 char release[256];
 char version[256];
 char machine[256];
int uname(struct utsname *);
            Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: machine/endian.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 69 "/usr/include/i386/endian.h" 3 4
# 70 "/usr/include/i386/endian.h" 2 3 4
# 40 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 33 "/usr/include/sys/_types.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 41 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
            Defined "HAVE_MACHINE_ENDIAN_H" to "1"
TEST check from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: limits.h
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/limits.h" 1 3 4
# 38 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/limits.h" 3 4
# 1 "/usr/include/limits.h" 1 3 4
# 63 "/usr/include/limits.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 64 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/machine/limits.h" 1 3 4
# 1 "/usr/include/i386/limits.h" 1 3 4
# 40 "/usr/include/i386/limits.h" 3 4
# 1 "/usr/include/i386/_limits.h" 1 3 4
# 41 "/usr/include/i386/limits.h" 2 3 4
# 7 "/usr/include/machine/limits.h" 2 3 4
# 65 "/usr/include/limits.h" 2 3 4
# 1 "/usr/include/sys/syslimits.h" 1 3 4
# 66 "/usr/include/limits.h" 2 3 4
# 39 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/limits.h" 2 3 4
            Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/fcntl.h" 1 3 4
# 23 "/usr/include/fcntl.h" 3 4
# 1 "/usr/include/sys/fcntl.h" 1 3 4
# 78 "/usr/include/sys/fcntl.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 79 "/usr/include/sys/fcntl.h" 2 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 81 "/usr/include/sys/fcntl.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 84 "/usr/include/sys/fcntl.h" 2 3 4
# 85 "/usr/include/sys/fcntl.h" 2 3 4
# 1 "/usr/include/sys/_types/_off_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_off_t.h" 3 4
typedef __darwin_off_t off_t;
# 86 "/usr/include/sys/fcntl.h" 2 3 4
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 87 "/usr/include/sys/fcntl.h" 2 3 4
# 116 "/usr/include/sys/fcntl.h" 3 4
# 1 "/usr/include/sys/_types/_o_sync.h" 1 3 4
# 117 "/usr/include/sys/fcntl.h" 2 3 4
# 141 "/usr/include/sys/fcntl.h" 3 4
# 1 "/usr/include/sys/_types/_o_dsync.h" 1 3 4
# 142 "/usr/include/sys/fcntl.h" 2 3 4
# 279 "/usr/include/sys/fcntl.h" 3 4
# 1 "/usr/include/sys/_types/_seek_set.h" 1 3 4
# 280 "/usr/include/sys/fcntl.h" 2 3 4
# 1 "/usr/include/sys/_types/_s_ifmt.h" 1 3 4
# 286 "/usr/include/sys/fcntl.h" 2 3 4
# 304 "/usr/include/sys/fcntl.h" 3 4
struct flock {
 off_t l_start;
 off_t l_len;
 pid_t l_pid;
 short l_type;
 short l_whence;
struct timespec
 long tv_nsec;
# 313 "/usr/include/sys/fcntl.h" 2 3 4
struct flocktimeout {
 struct flock fl;
 struct timespec timeout;
# 332 "/usr/include/sys/fcntl.h" 3 4
struct radvisory {
       off_t ra_offset;
       int ra_count;
# 344 "/usr/include/sys/fcntl.h" 3 4
typedef struct fsignatures {
 off_t fs_file_start;
 void *fs_blob_start;
 size_t fs_blob_size;
} fsignatures_t;
# 358 "/usr/include/sys/fcntl.h" 3 4
typedef struct fstore {
 unsigned int fst_flags;
 int fst_posmode;
 off_t fst_offset;
 off_t fst_length;
 off_t fst_bytesalloc;
} fstore_t;
typedef struct fbootstraptransfer {
  off_t fbt_offset;
  size_t fbt_length;
  void *fbt_buffer;
} fbootstraptransfer_t;
# 396 "/usr/include/sys/fcntl.h" 3 4
#pragma pack(4)
struct log2phys {
 unsigned int l2p_flags;
 off_t l2p_contigbytes;
 off_t l2p_devoffset;
#pragma pack()
# 419 "/usr/include/sys/fcntl.h" 3 4
# 1 "/usr/include/sys/_types/_filesec_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_filesec_t.h" 3 4
struct _filesec;
typedef struct _filesec *filesec_t;
# 420 "/usr/include/sys/fcntl.h" 2 3 4
typedef enum {
 FILESEC_OWNER = 1,
 FILESEC_GROUP = 2,
 FILESEC_UUID = 3,
 FILESEC_MODE = 4,
 FILESEC_ACL = 5,
 FILESEC_GRPUUID = 6,
 FILESEC_ACL_RAW = 100,
 FILESEC_ACL_ALLOCSIZE = 101
} filesec_property_t;
int open(const char *, int, ...) __asm("_" "open") ;
int creat(const char *, mode_t) __asm("_" "creat") ;
int fcntl(int, int, ...) __asm("_" "fcntl") ;
int openx_np(const char *, int, filesec_t);
int open_dprotected_np ( const char *, int, int, int, ...);
int flock(int, int);
filesec_t filesec_init(void);
filesec_t filesec_dup(filesec_t);
void filesec_free(filesec_t);
int filesec_get_property(filesec_t, filesec_property_t, void *);
int filesec_query_property(filesec_t, filesec_property_t, int *);
int filesec_set_property(filesec_t, filesec_property_t, const void *);
int filesec_unset_property(filesec_t, filesec_property_t) __attribute__((availability(macosx,introduced=10.6)));
# 24 "/usr/include/fcntl.h" 2 3 4
            Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 61 "/usr/include/string.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 62 "/usr/include/string.h" 2 3 4
# 64 "/usr/include/string.h" 2 3 4
# 65 "/usr/include/string.h" 2 3 4
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rsize_t.h" 3 4
typedef __darwin_size_t rsize_t;
# 1 "/usr/include/sys/_types/_errno_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_errno_t.h" 3 4
typedef int errno_t;
# 1 "/usr/include/sys/_types/_ssize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ssize_t.h" 3 4
typedef __darwin_ssize_t ssize_t;
# 70 "/usr/include/strings.h" 3 4
int ffs(int);
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
            Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/sys/times.h" 1 3 4
# 72 "/usr/include/sys/times.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 73 "/usr/include/sys/times.h" 2 3 4
# 74 "/usr/include/sys/times.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 75 "/usr/include/sys/times.h" 2 3 4
# 78 "/usr/include/sys/times.h" 2 3 4
struct tms {
 clock_t tms_utime;
 clock_t tms_stime;
 clock_t tms_cutime;
 clock_t tms_cstime;
clock_t times(struct tms *);
            Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'io.h' file not found
#include <io.h>
1 error generated.
Source:
#include "confdefs.h"
#include "conffix.h"
#include <io.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'io.h' file not found
#include <io.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'io.h' file not found#include <io.h>         ^1 error generated.:
Checking for header: stdint.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 32 "/usr/include/sys/_types.h" 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 32 "/usr/include/machine/_types.h" 3 4
typedef union {
} __mbstate_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
 void *__arg;
            Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/pwd.h" 1 3 4
# 46 "/usr/include/pwd.h" 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 47 "/usr/include/pwd.h" 2 3 4
# 1 "/usr/include/sys/_types/_gid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_gid_t.h" 3 4
typedef __darwin_gid_t gid_t;
# 48 "/usr/include/pwd.h" 2 3 4
# 49 "/usr/include/pwd.h" 2 3 4
# 50 "/usr/include/pwd.h" 2 3 4
# 84 "/usr/include/pwd.h" 3 4
struct passwd {
 char *pw_name;
 char *pw_passwd;
 uid_t pw_uid;
 gid_t pw_gid;
 __darwin_time_t pw_change;
 char *pw_class;
 char *pw_gecos;
 char *pw_dir;
 char *pw_shell;
 __darwin_time_t pw_expire;
struct passwd *getpwuid(uid_t);
struct passwd *getpwnam(const char *);
int getpwuid_r(uid_t, struct passwd *, char *, size_t, struct passwd **);
int getpwnam_r(const char *, struct passwd *, char *, size_t, struct passwd **);
struct passwd *getpwent(void);
void setpwent(void);
void endpwent(void);
# 1 "/usr/include/uuid/uuid.h" 1 3 4
# 39 "/usr/include/uuid/uuid.h" 3 4
# 1 "/usr/include/sys/_types/_uuid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uuid_t.h" 3 4
typedef __darwin_uuid_t uuid_t;
# 40 "/usr/include/uuid/uuid.h" 2 3 4
typedef __darwin_uuid_string_t uuid_string_t;
# 53 "/usr/include/uuid/uuid.h" 3 4
void uuid_clear(uuid_t uu);
int uuid_compare(const uuid_t uu1, const uuid_t uu2);
void uuid_copy(uuid_t dst, const uuid_t src);
void uuid_generate(uuid_t out);
void uuid_generate_random(uuid_t out);
void uuid_generate_time(uuid_t out);
int uuid_is_null(const uuid_t uu);
int uuid_parse(const uuid_string_t in, uuid_t uu);
void uuid_unparse(const uuid_t uu, uuid_string_t out);
void uuid_unparse_lower(const uuid_t uu, uuid_string_t out);
void uuid_unparse_upper(const uuid_t uu, uuid_string_t out);
# 111 "/usr/include/pwd.h" 2 3 4
int setpassent(int);
char *user_from_uid(uid_t, int);
struct passwd *getpwuuid(uuid_t);
int getpwuuid_r(uuid_t, struct passwd *, char *, size_t, struct passwd **);
            Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/float.h" 1 3 4
            Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/param.h" 1 3 4
# 79 "/usr/include/sys/param.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 80 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 81 "/usr/include/sys/param.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 72 "/usr/include/sys/types.h" 3 4
# 73 "/usr/include/sys/types.h" 2 3 4
# 76 "/usr/include/i386/types.h" 3 4
# 77 "/usr/include/i386/types.h" 2 3 4
# 78 "/usr/include/i386/types.h" 2 3 4
# 79 "/usr/include/i386/types.h" 2 3 4
# 80 "/usr/include/i386/types.h" 2 3 4
# 93 "/usr/include/i386/types.h" 2 3 4
# 94 "/usr/include/i386/types.h" 2 3 4
# 79 "/usr/include/sys/types.h" 2 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
# 82 "/usr/include/sys/types.h" 2 3 4
typedef unsigned char u_char;
typedef unsigned short u_short;
typedef unsigned int u_int;
typedef unsigned long u_long;
typedef unsigned short ushort;
typedef unsigned int uint;
typedef u_int64_t u_quad_t;
typedef int64_t quad_t;
typedef quad_t * qaddr_t;
typedef char * caddr_t;
typedef int32_t daddr_t;
# 103 "/usr/include/sys/types.h" 2 3 4
typedef u_int32_t fixpt_t;
# 1 "/usr/include/sys/_types/_blkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blkcnt_t.h" 3 4
typedef __darwin_blkcnt_t blkcnt_t;
# 107 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_blksize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blksize_t.h" 3 4
typedef __darwin_blksize_t blksize_t;
# 108 "/usr/include/sys/types.h" 2 3 4
# 109 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_addr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_addr_t.h" 3 4
typedef __uint32_t in_addr_t;
# 110 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_port_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_port_t.h" 3 4
typedef __uint16_t in_port_t;
# 111 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino_t.h" 3 4
typedef __darwin_ino_t ino_t;
# 112 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino64_t.h" 3 4
typedef __darwin_ino64_t ino64_t;
# 115 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_key_t.h" 3 4
typedef __int32_t key_t;
# 118 "/usr/include/sys/types.h" 2 3 4
# 119 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_nlink_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_nlink_t.h" 3 4
typedef __uint16_t nlink_t;
# 120 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 121 "/usr/include/sys/types.h" 2 3 4
# 122 "/usr/include/sys/types.h" 2 3 4
# 123 "/usr/include/sys/types.h" 2 3 4
typedef int32_t segsz_t;
typedef int32_t swblk_t;
# 128 "/usr/include/sys/types.h" 2 3 4
# 161 "/usr/include/sys/types.h" 3 4
# 162 "/usr/include/sys/types.h" 2 3 4
# 163 "/usr/include/sys/types.h" 2 3 4
# 164 "/usr/include/sys/types.h" 2 3 4
# 165 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_useconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_useconds_t.h" 3 4
typedef __darwin_useconds_t useconds_t;
# 167 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_suseconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_suseconds_t.h" 3 4
typedef __darwin_suseconds_t suseconds_t;
# 168 "/usr/include/sys/types.h" 2 3 4
# 171 "/usr/include/sys/types.h" 2 3 4
# 172 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_def.h" 1 3 4
# 46 "/usr/include/sys/_types/_fd_def.h" 3 4
typedef struct fd_set {
 __int32_t fds_bits[((((1024) % ((sizeof(__int32_t) * 8))) == 0) ? ((1024) / ((sizeof(__int32_t) * 8))) : (((1024) / ((sizeof(__int32_t) * 8))) + 1))];
} fd_set;
static __inline int
__darwin_fd_isset(int _n, const struct fd_set *_p)
 return (_p->fds_bits[(unsigned long)_n/(sizeof(__int32_t) * 8)] & ((__int32_t)(1<<((unsigned long)_n % (sizeof(__int32_t) * 8)))));
# 181 "/usr/include/sys/types.h" 2 3 4
typedef __int32_t fd_mask;
# 1 "/usr/include/sys/_types/_fd_setsize.h" 1 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_set.h" 1 3 4
# 195 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_clr.h" 1 3 4
# 196 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_zero.h" 1 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_isset.h" 1 3 4
# 198 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_copy.h" 1 3 4
# 201 "/usr/include/sys/types.h" 2 3 4
# 210 "/usr/include/sys/types.h" 3 4
# 211 "/usr/include/sys/types.h" 2 3 4
# 212 "/usr/include/sys/types.h" 2 3 4
# 213 "/usr/include/sys/types.h" 2 3 4
# 214 "/usr/include/sys/types.h" 2 3 4
# 215 "/usr/include/sys/types.h" 2 3 4
# 216 "/usr/include/sys/types.h" 2 3 4
# 217 "/usr/include/sys/types.h" 2 3 4
# 218 "/usr/include/sys/types.h" 2 3 4
# 219 "/usr/include/sys/types.h" 2 3 4
# 223 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsblkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsblkcnt_t.h" 3 4
typedef __darwin_fsblkcnt_t fsblkcnt_t;
# 227 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsfilcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsfilcnt_t.h" 3 4
typedef __darwin_fsfilcnt_t fsfilcnt_t;
# 228 "/usr/include/sys/types.h" 2 3 4
# 84 "/usr/include/sys/param.h" 2 3 4
# 93 "/usr/include/sys/param.h" 3 4
# 94 "/usr/include/sys/param.h" 2 3 4
# 107 "/usr/include/sys/param.h" 3 4
# 1 "/usr/include/machine/param.h" 1 3 4
# 35 "/usr/include/machine/param.h" 3 4
# 1 "/usr/include/i386/param.h" 1 3 4
# 75 "/usr/include/i386/param.h" 3 4
# 1 "/usr/include/i386/_param.h" 1 3 4
# 76 "/usr/include/i386/param.h" 2 3 4
# 36 "/usr/include/machine/param.h" 2 3 4
# 108 "/usr/include/sys/param.h" 2 3 4
# 64 "/usr/include/limits.h" 3 4
# 111 "/usr/include/sys/param.h" 2 3 4
# 81 "/usr/include/sys/signal.h" 3 4
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
 char __xmm_reg[16];
 __uint16_t __cpu;
 __uint32_t __err;
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
    __uint16_t __cpu;
    __uint32_t __err;
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
 void *ss_sp;
 int ss_flags;
 int uc_onstack;
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 long si_band;
} siginfo_t;
         void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
struct sigvec {
 int sv_mask;
 int sv_flags;
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 114 "/usr/include/sys/param.h" 2 3 4
            Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/netdb.h" 1 3 4
# 86 "/usr/include/netdb.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 87 "/usr/include/netdb.h" 2 3 4
# 88 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/sys/_types/_socklen_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_socklen_t.h" 3 4
typedef __darwin_socklen_t socklen_t;
# 89 "/usr/include/netdb.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 91 "/usr/include/netdb.h" 2 3 4
# 1 "/usr/include/netinet/in.h" 1 3 4
# 66 "/usr/include/netinet/in.h" 3 4
# 67 "/usr/include/netinet/in.h" 2 3 4
# 71 "/usr/include/netinet/in.h" 2 3 4
# 73 "/usr/include/netinet/in.h" 2 3 4
# 75 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/sys/socket.h" 1 3 4
# 75 "/usr/include/sys/socket.h" 3 4
# 78 "/usr/include/sys/types.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
} fd_set;
static __inline int
# 76 "/usr/include/sys/socket.h" 2 3 4
# 1 "/usr/include/machine/_param.h" 1 3 4
# 29 "/usr/include/machine/_param.h" 3 4
# 30 "/usr/include/machine/_param.h" 2 3 4
# 78 "/usr/include/sys/socket.h" 2 3 4
# 93 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/_types/_sa_family_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sa_family_t.h" 3 4
typedef __uint8_t sa_family_t;
# 94 "/usr/include/sys/socket.h" 2 3 4
# 105 "/usr/include/sys/socket.h" 3 4
# 1 "/usr/include/sys/_types/_iovec_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_iovec_t.h" 3 4
struct iovec {
 void * iov_base;
 size_t iov_len;
# 106 "/usr/include/sys/socket.h" 2 3 4
# 186 "/usr/include/sys/socket.h" 3 4
struct linger {
 int l_onoff;
 int l_linger;
# 204 "/usr/include/sys/socket.h" 3 4
struct so_np_extensions {
 u_int32_t npx_flags;
 u_int32_t npx_mask;
# 279 "/usr/include/sys/socket.h" 3 4
struct sockaddr {
 __uint8_t sa_len;
 sa_family_t sa_family;
 char sa_data[14];
# 292 "/usr/include/sys/socket.h" 3 4
struct sockproto {
 __uint16_t sp_family;
 __uint16_t sp_protocol;
# 312 "/usr/include/sys/socket.h" 3 4
struct sockaddr_storage {
 __uint8_t ss_len;
 sa_family_t ss_family;
 char __ss_pad1[((sizeof(__int64_t)) - sizeof(__uint8_t) - sizeof(sa_family_t))];
 __int64_t __ss_align;
 char __ss_pad2[(128 - sizeof(__uint8_t) - sizeof(sa_family_t) - ((sizeof(__int64_t)) - sizeof(__uint8_t) - sizeof(sa_family_t)) - (sizeof(__int64_t)))];
# 412 "/usr/include/sys/socket.h" 3 4
struct msghdr {
 void *msg_name;
 socklen_t msg_namelen;
 struct iovec *msg_iov;
 int msg_iovlen;
 void *msg_control;
 socklen_t msg_controllen;
 int msg_flags;
# 452 "/usr/include/sys/socket.h" 3 4
struct cmsghdr {
 socklen_t cmsg_len;
 int cmsg_level;
 int cmsg_type;
# 543 "/usr/include/sys/socket.h" 3 4
struct sf_hdtr {
 struct iovec *headers;
 int hdr_cnt;
 struct iovec *trailers;
 int trl_cnt;
int accept(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "accept") ;
int bind(int, const struct sockaddr *, socklen_t) __asm("_" "bind") ;
int connect(int, const struct sockaddr *, socklen_t) __asm("_" "connect") ;
int getpeername(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "getpeername") ;
int getsockname(int, struct sockaddr * restrict, socklen_t * restrict)
  __asm("_" "getsockname") ;
int getsockopt(int, int, int, void * restrict, socklen_t * restrict);
int listen(int, int) __asm("_" "listen") ;
ssize_t recv(int, void *, size_t, int) __asm("_" "recv") ;
ssize_t recvfrom(int, void *, size_t, int, struct sockaddr * restrict,
  socklen_t * restrict) __asm("_" "recvfrom") ;
ssize_t recvmsg(int, struct msghdr *, int) __asm("_" "recvmsg") ;
ssize_t send(int, const void *, size_t, int) __asm("_" "send") ;
ssize_t sendmsg(int, const struct msghdr *, int) __asm("_" "sendmsg") ;
ssize_t sendto(int, const void *, size_t,
  int, const struct sockaddr *, socklen_t) __asm("_" "sendto") ;
int setsockopt(int, int, int, const void *, socklen_t);
int shutdown(int, int);
int sockatmark(int) __attribute__((availability(macosx,introduced=10.5)));
int socket(int, int, int);
int socketpair(int, int, int, int *) __asm("_" "socketpair") ;
int sendfile(int, int, off_t, off_t *, struct sf_hdtr *, int);
void pfctlinput(int, struct sockaddr *);
# 82 "/usr/include/netinet/in.h" 2 3 4
# 301 "/usr/include/netinet/in.h" 3 4
struct in_addr {
 in_addr_t s_addr;
# 374 "/usr/include/netinet/in.h" 3 4
struct sockaddr_in {
 __uint8_t sin_len;
 sa_family_t sin_family;
 in_port_t sin_port;
 struct in_addr sin_addr;
 char sin_zero[8];
# 393 "/usr/include/netinet/in.h" 3 4
struct ip_opts {
 struct in_addr ip_dst;
 char ip_opts[40];
# 501 "/usr/include/netinet/in.h" 3 4
struct ip_mreq {
 struct in_addr imr_multiaddr;
 struct in_addr imr_interface;
struct ip_mreqn {
 struct in_addr imr_address;
 int imr_ifindex;
#pragma pack(4)
struct ip_mreq_source {
 struct in_addr imr_sourceaddr;
struct group_req {
 uint32_t gr_interface;
 struct sockaddr_storage gr_group;
struct group_source_req {
 uint32_t gsr_interface;
 struct sockaddr_storage gsr_group;
 struct sockaddr_storage gsr_source;
# 549 "/usr/include/netinet/in.h" 3 4
struct __msfilterreq {
 uint32_t msfr_ifindex;
 uint32_t msfr_fmode;
 uint32_t msfr_nsrcs;
 uint32_t __msfr_align;
 struct sockaddr_storage msfr_group;
 struct sockaddr_storage *msfr_srcs;
#pragma pack()
struct sockaddr;
int setipv4sourcefilter(int, struct in_addr, struct in_addr, uint32_t,
     uint32_t, struct in_addr *) __attribute__((availability(macosx,introduced=10.7)));
int getipv4sourcefilter(int, struct in_addr, struct in_addr, uint32_t *,
     uint32_t *, struct in_addr *) __attribute__((availability(macosx,introduced=10.7)));
int setsourcefilter(int, uint32_t, struct sockaddr *, socklen_t,
     uint32_t, uint32_t, struct sockaddr_storage *) __attribute__((availability(macosx,introduced=10.7)));
int getsourcefilter(int, uint32_t, struct sockaddr *, socklen_t,
     uint32_t *, uint32_t *, struct sockaddr_storage *) __attribute__((availability(macosx,introduced=10.7)));
# 612 "/usr/include/netinet/in.h" 3 4
struct in_pktinfo {
 unsigned int ipi_ifindex;
 struct in_addr ipi_spec_dst;
 struct in_addr ipi_addr;
# 654 "/usr/include/netinet/in.h" 3 4
# 1 "/usr/include/netinet6/in6.h" 1 3 4
# 152 "/usr/include/netinet6/in6.h" 3 4
struct in6_addr {
 union {
  __uint8_t __u6_addr8[16];
  __uint16_t __u6_addr16[8];
  __uint32_t __u6_addr32[4];
 } __u6_addr;
# 170 "/usr/include/netinet6/in6.h" 3 4
struct sockaddr_in6 {
 __uint8_t sin6_len;
 sa_family_t sin6_family;
 in_port_t sin6_port;
 __uint32_t sin6_flowinfo;
 struct in6_addr sin6_addr;
 __uint32_t sin6_scope_id;
# 212 "/usr/include/netinet6/in6.h" 3 4
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
extern const struct in6_addr in6addr_nodelocal_allnodes;
extern const struct in6_addr in6addr_linklocal_allnodes;
extern const struct in6_addr in6addr_linklocal_allrouters;
extern const struct in6_addr in6addr_linklocal_allv2routers;
# 528 "/usr/include/netinet6/in6.h" 3 4
struct ipv6_mreq {
 struct in6_addr ipv6mr_multiaddr;
 unsigned int ipv6mr_interface;
struct in6_pktinfo {
 struct in6_addr ipi6_addr;
 unsigned int ipi6_ifindex;
struct ip6_mtuinfo {
 struct sockaddr_in6 ip6m_addr;
 uint32_t ip6m_mtu;
# 625 "/usr/include/netinet6/in6.h" 3 4
struct cmsghdr;
extern int inet6_option_space(int);
extern int inet6_option_init(void *, struct cmsghdr **, int);
extern int inet6_option_append(struct cmsghdr *, const __uint8_t *, int, int);
extern __uint8_t *inet6_option_alloc(struct cmsghdr *, int, int, int);
extern int inet6_option_next(const struct cmsghdr *, __uint8_t **);
extern int inet6_option_find(const struct cmsghdr *, __uint8_t **, int);
extern size_t inet6_rthdr_space(int, int);
extern struct cmsghdr *inet6_rthdr_init(void *, int);
extern int inet6_rthdr_add(struct cmsghdr *, const struct in6_addr *,
    unsigned int);
extern int inet6_rthdr_lasthop(struct cmsghdr *, unsigned int);
extern int inet6_rthdr_segments(const struct cmsghdr *);
extern struct in6_addr *inet6_rthdr_getaddr(struct cmsghdr *, int);
extern int inet6_rthdr_getflags(const struct cmsghdr *, int);
extern int inet6_opt_init(void *, socklen_t);
extern int inet6_opt_append(void *, socklen_t, int, __uint8_t, socklen_t,
    __uint8_t, void **);
extern int inet6_opt_finish(void *, socklen_t, int);
extern int inet6_opt_set_val(void *, int, void *, socklen_t);
extern int inet6_opt_next(void *, socklen_t, int, __uint8_t *, socklen_t *,
    void **);
extern int inet6_opt_find(void *, socklen_t, int, __uint8_t, socklen_t *,
    void **);
extern int inet6_opt_get_val(void *, int, void *, socklen_t);
extern socklen_t inet6_rth_space(int, int);
extern void *inet6_rth_init(void *, socklen_t, int, int);
extern int inet6_rth_add(void *, const struct in6_addr *);
extern int inet6_rth_reverse(const void *, void *);
extern int inet6_rth_segments(const void *);
extern struct in6_addr *inet6_rth_getaddr(const void *, int);
extern void addrsel_policy_init(void);
# 655 "/usr/include/netinet/in.h" 2 3 4
int bindresvport(int, struct sockaddr_in *);
struct sockaddr;
int bindresvport_sa(int, struct sockaddr *);
# 92 "/usr/include/netdb.h" 2 3 4
# 101 "/usr/include/netdb.h" 3 4
extern int h_errno;
# 112 "/usr/include/netdb.h" 3 4
struct hostent {
 char *h_name;
 char **h_aliases;
 int h_addrtype;
 int h_length;
 char **h_addr_list;
struct netent {
 char *n_name;
 char **n_aliases;
 int n_addrtype;
 uint32_t n_net;
struct servent {
 char *s_name;
 char **s_aliases;
 int s_port;
 char *s_proto;
struct protoent {
 char *p_name;
 char **p_aliases;
 int p_proto;
struct addrinfo {
 int ai_flags;
 int ai_family;
 int ai_socktype;
 int ai_protocol;
 socklen_t ai_addrlen;
 char *ai_canonname;
 struct sockaddr *ai_addr;
 struct addrinfo *ai_next;
struct rpcent {
        char *r_name;
        char **r_aliases;
        int r_number;
# 259 "/usr/include/netdb.h" 3 4
void endhostent(void);
void endnetent(void);
void endprotoent(void);
void endservent(void);
void freeaddrinfo(struct addrinfo *);
const char *gai_strerror(int);
int getaddrinfo(const char * restrict, const char * restrict,
       const struct addrinfo * restrict,
       struct addrinfo ** restrict);
struct hostent *gethostbyaddr(const void *, socklen_t, int);
struct hostent *gethostbyname(const char *);
struct hostent *gethostent(void);
int getnameinfo(const struct sockaddr * restrict, socklen_t,
         char * restrict, socklen_t, char * restrict,
         socklen_t, int);
struct netent *getnetbyaddr(uint32_t, int);
struct netent *getnetbyname(const char *);
struct netent *getnetent(void);
struct protoent *getprotobyname(const char *);
struct protoent *getprotobynumber(int);
struct protoent *getprotoent(void);
struct servent *getservbyname(const char *, const char *);
struct servent *getservbyport(int, const char *);
struct servent *getservent(void);
void sethostent(int);
void setnetent(int);
void setprotoent(int);
void setservent(int);
void freehostent(struct hostent *);
struct hostent *gethostbyname2(const char *, int);
struct hostent *getipnodebyaddr(const void *, size_t, int, int *);
struct hostent *getipnodebyname(const char *, int, int, int *);
struct rpcent *getrpcbyname(const char *name);
struct rpcent *getrpcbynumber(int number);
struct rpcent *getrpcent(void);
void setrpcent(int stayopen);
void endrpcent(void);
void herror(const char *);
const char *hstrerror(int);
int innetgr(const char *, const char *, const char *, const char *);
int getnetgrent(char **, char **, char **);
void endnetgrent(void);
void setnetgrent(const char *);
            Defined "HAVE_NETDB_H" to "1"
Checking for header: search.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/search.h" 1 3 4
# 12 "/usr/include/search.h" 3 4
# 13 "/usr/include/search.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 14 "/usr/include/search.h" 2 3 4
# 15 "/usr/include/search.h" 2 3 4
typedef struct entry {
 char *key;
 void *data;
} ENTRY;
typedef enum {
 FIND, ENTER
} ACTION;
typedef enum {
 preorder,
 postorder,
 endorder,
 leaf
} VISIT;
# 45 "/usr/include/search.h" 3 4
int hcreate(size_t);
void hdestroy(void);
ENTRY *hsearch(ENTRY, ACTION);
void insque(void *, void *);
void *lfind(const void *, const void *, size_t *, size_t,
void *lsearch(const void *, void *, size_t *, size_t,
void remque(void *);
void *tdelete(const void * restrict, void ** restrict,
void *tfind(const void *, void * const *,
void *tsearch(const void *, void **, int (*)(const void *, const void *));
void twalk(const void *, void (*)(const void *, VISIT, int));
            Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'mathimf.h' file not found
#include <mathimf.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'mathimf.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'mathimf.h' file not found#include <mathimf.h>         ^1 error generated.:
Checking for header: sys/procfs.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/procfs.h' file not found
#include <sys/procfs.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/procfs.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sys/procfs.h' file not found#include <sys/procfs.h>         ^1 error generated.:
Checking for header: sys/resource.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/sys/resource.h" 1 3 4
# 67 "/usr/include/sys/resource.h" 3 4
# 68 "/usr/include/sys/resource.h" 2 3 4
# 69 "/usr/include/sys/resource.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 70 "/usr/include/sys/resource.h" 2 3 4
typedef signed char int8_t;
# 73 "/usr/include/sys/resource.h" 2 3 4
# 76 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
# 84 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
            Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/unistd.h" 1 3 4
# 71 "/usr/include/unistd.h" 3 4
typedef union {
} __mbstate_t;
 void *__arg;
# 72 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/sys/unistd.h" 1 3 4
# 84 "/usr/include/sys/unistd.h" 3 4
# 1 "/usr/include/sys/_types/_posix_vdisable.h" 1 3 4
# 85 "/usr/include/sys/unistd.h" 2 3 4
# 122 "/usr/include/sys/unistd.h" 3 4
# 123 "/usr/include/sys/unistd.h" 2 3 4
# 132 "/usr/include/sys/unistd.h" 3 4
struct accessx_descriptor {
 unsigned int ad_name_offset;
 int ad_flags;
 int ad_pad[2];
# 73 "/usr/include/unistd.h" 2 3 4
# 74 "/usr/include/unistd.h" 2 3 4
# 75 "/usr/include/unistd.h" 2 3 4
# 76 "/usr/include/unistd.h" 2 3 4
# 77 "/usr/include/unistd.h" 2 3 4
# 78 "/usr/include/unistd.h" 2 3 4
# 81 "/usr/include/unistd.h" 2 3 4
# 82 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 83 "/usr/include/unistd.h" 2 3 4
# 84 "/usr/include/unistd.h" 2 3 4
# 85 "/usr/include/unistd.h" 2 3 4
# 424 "/usr/include/unistd.h" 3 4
void _exit(int) __attribute__((noreturn));
int access(const char *, int);
unsigned int
  alarm(unsigned int);
int chdir(const char *);
int chown(const char *, uid_t, gid_t);
int close(int) __asm("_" "close") ;
int dup(int);
int dup2(int, int);
int execl(const char *, const char *, ...);
int execle(const char *, const char *, ...);
int execlp(const char *, const char *, ...);
int execv(const char *, char * const *);
int execve(const char *, char * const *, char * const *);
int execvp(const char *, char * const *);
pid_t fork(void);
long fpathconf(int, int);
char *getcwd(char *, size_t);
gid_t getegid(void);
uid_t geteuid(void);
gid_t getgid(void);
int getgroups(int, gid_t []);
char *getlogin(void);
pid_t getpgrp(void);
pid_t getpid(void);
pid_t getppid(void);
uid_t getuid(void);
int isatty(int);
int link(const char *, const char *);
off_t lseek(int, off_t, int);
long pathconf(const char *, int);
int pause(void) __asm("_" "pause") ;
int pipe(int [2]);
ssize_t read(int, void *, size_t) __asm("_" "read") ;
int rmdir(const char *);
int setgid(gid_t);
int setpgid(pid_t, pid_t);
pid_t setsid(void);
int setuid(uid_t);
unsigned int
  sleep(unsigned int) __asm("_" "sleep") ;
long sysconf(int);
pid_t tcgetpgrp(int);
int tcsetpgrp(int, pid_t);
char *ttyname(int);
int ttyname_r(int, char *, size_t) __asm("_" "ttyname_r") ;
int unlink(const char *);
ssize_t write(int, const void *, size_t) __asm("_" "write") ;
# 501 "/usr/include/unistd.h" 3 4
size_t confstr(int, char *, size_t) __asm("_" "confstr") ;
int getopt(int, char * const [], const char *) __asm("_" "getopt") ;
extern char *optarg;
extern int optind, opterr, optopt;
# 531 "/usr/include/unistd.h" 3 4
__attribute__((deprecated))
void *brk(const void *);
int chroot(const char *) ;
char *crypt(const char *, const char *);
char *ctermid(char *);
void encrypt(char *, int) __asm("_" "encrypt") ;
int fchdir(int);
long gethostid(void);
pid_t getpgid(pid_t);
pid_t getsid(pid_t);
int getdtablesize(void) ;
int getpagesize(void) __attribute__((const)) ;
char *getpass(const char *) ;
char *getwd(char *) ;
int lchown(const char *, uid_t, gid_t) __asm("_" "lchown") ;
int lockf(int, int, off_t) __asm("_" "lockf") ;
int nice(int) __asm("_" "nice") ;
ssize_t pread(int, void *, size_t, off_t) __asm("_" "pread") ;
ssize_t pwrite(int, const void *, size_t, off_t) __asm("_" "pwrite") ;
void *sbrk(int);
pid_t setpgrp(void) __asm("_" "setpgrp") ;
int setregid(gid_t, gid_t) __asm("_" "setregid") ;
int setreuid(uid_t, uid_t) __asm("_" "setreuid") ;
void swab(const void * restrict, void * restrict, ssize_t);
void sync(void);
int truncate(const char *, off_t);
useconds_t ualarm(useconds_t, useconds_t);
int usleep(useconds_t) __asm("_" "usleep") ;
pid_t vfork(void);
int fsync(int) __asm("_" "fsync") ;
int ftruncate(int, off_t);
int getlogin_r(char *, size_t);
# 619 "/usr/include/unistd.h" 3 4
int fchown(int, uid_t, gid_t);
int gethostname(char *, size_t);
ssize_t readlink(const char * restrict, char * restrict, size_t);
int setegid(gid_t);
int seteuid(uid_t);
int symlink(const char *, const char *);
# 633 "/usr/include/unistd.h" 3 4
# 1 "/usr/include/sys/select.h" 1 3 4
# 66 "/usr/include/sys/select.h" 3 4
# 67 "/usr/include/sys/select.h" 2 3 4
} fd_set;
static __inline int
# 76 "/usr/include/sys/select.h" 2 3 4
struct timespec
 long tv_nsec;
# 77 "/usr/include/sys/select.h" 2 3 4
struct timeval
# 78 "/usr/include/sys/select.h" 2 3 4
# 85 "/usr/include/sys/select.h" 2 3 4
# 86 "/usr/include/sys/select.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 87 "/usr/include/sys/select.h" 2 3 4
# 100 "/usr/include/sys/select.h" 3 4
# 101 "/usr/include/sys/select.h" 2 3 4
# 102 "/usr/include/sys/select.h" 2 3 4
# 103 "/usr/include/sys/select.h" 2 3 4
# 104 "/usr/include/sys/select.h" 2 3 4
# 105 "/usr/include/sys/select.h" 2 3 4
# 108 "/usr/include/sys/select.h" 2 3 4
int pselect(int, fd_set * restrict, fd_set * restrict,
  fd_set * restrict, const struct timespec * restrict,
  const sigset_t * restrict)
  __asm("_" "pselect" "$1050")
# 1 "/usr/include/sys/_select.h" 1 3 4
# 39 "/usr/include/sys/_select.h" 3 4
int select(int, fd_set * restrict, fd_set * restrict,
  fd_set * restrict, struct timeval * restrict)
  __asm("_" "select" "$1050")
# 130 "/usr/include/sys/select.h" 2 3 4
# 634 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 636 "/usr/include/unistd.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 637 "/usr/include/unistd.h" 2 3 4
# 638 "/usr/include/unistd.h" 2 3 4
void _Exit(int) __attribute__((noreturn));
int accessx_np(const struct accessx_descriptor *, size_t, int *, uid_t);
int acct(const char *);
int add_profil(char *, size_t, unsigned long, unsigned int);
void endusershell(void);
int execvP(const char *, const char *, char * const *);
char *fflagstostr(unsigned long);
int getdomainname(char *, int);
int getgrouplist(const char *, int, int *, int *);
# 1 "/usr/include/gethostuuid.h" 1 3 4
# 39 "/usr/include/gethostuuid.h" 3 4
int gethostuuid(uuid_t, const struct timespec *) __attribute__((availability(macosx,introduced=10.5)));
# 654 "/usr/include/unistd.h" 2 3 4
mode_t getmode(const void *, mode_t);
int getpeereid(int, uid_t *, gid_t *);
int getsgroups_np(int *, uuid_t);
char *getusershell(void);
int getwgroups_np(int *, uuid_t);
int initgroups(const char *, int);
int iruserok(unsigned long, int, const char *, const char *);
int iruserok_sa(const void *, int, int, const char *, const char *);
int issetugid(void);
char *mkdtemp(char *);
int mknod(const char *, mode_t, dev_t);
int mkpath_np(const char *path, mode_t omode) __attribute__((availability(macosx,introduced=10.8)));
int mkstemp(char *);
int mkstemps(char *, int);
char *mktemp(char *);
int nfssvc(int, void *);
int profil(char *, size_t, unsigned long, unsigned int);
int pthread_setugid_np(uid_t, gid_t);
int pthread_getugid_np( uid_t *, gid_t *);
int rcmd(char **, int, const char *, const char *, const char *, int *);
int rcmd_af(char **, int, const char *, const char *, const char *, int *,
  int);
int reboot(int);
int revoke(const char *);
int rresvport(int *);
int rresvport_af(int *, int);
int ruserok(const char *, int, const char *, const char *);
int setdomainname(const char *, int);
int setgroups(int, const gid_t *);
void sethostid(long);
int sethostname(const char *, int);
void setkey(const char *) __asm("_" "setkey") ;
int setlogin(const char *);
void *setmode(const char *) __asm("_" "setmode");
int setrgid(gid_t);
int setruid(uid_t);
int setsgroups_np(int, const uuid_t);
void setusershell(void);
int setwgroups_np(int, const uuid_t);
int strtofflags(char **, unsigned long *, unsigned long *);
int swapon(const char *);
int syscall(int, ...);
int ttyslot(void);
int undelete(const char *);
int unwhiteout(const char *);
void *valloc(size_t);
extern char *suboptarg;
int getsubopt(char **, char * const *, char **);
int fgetattrlist(int,void*,void*,size_t,unsigned int) __attribute__((availability(macosx,introduced=10.6)));
int fsetattrlist(int,void*,void*,size_t,unsigned int) __attribute__((availability(macosx,introduced=10.6)));
int getattrlist(const char*,void*,void*,size_t,unsigned int) __asm("_" "getattrlist") ;
int setattrlist(const char*,void*,void*,size_t,unsigned int) __asm("_" "setattrlist") ;
int exchangedata(const char*,const char*,unsigned int);
int getdirentriesattr(int,void*,void*,size_t,unsigned int*,unsigned int*,unsigned int*,unsigned int);
# 731 "/usr/include/unistd.h" 3 4
struct fssearchblock;
struct searchstate;
int searchfs(const char *, struct fssearchblock *, unsigned long *, unsigned int, unsigned int, struct searchstate *);
int fsctl(const char *,unsigned long,void*,unsigned int);
int ffsctl(int,unsigned long,void*,unsigned int) __attribute__((availability(macosx,introduced=10.6)));
int fsync_volume_np(int, int) __attribute__((availability(macosx,introduced=10.8)));
int sync_volume_np(const char *, int) __attribute__((availability(macosx,introduced=10.8)));
extern int optreset;
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Defined "HAVE_UNISTD_H" to "1"
Checking for header: netinet/in.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
typedef union {
} __mbstate_t;
 void *__arg;
# 68 "/usr/include/netinet/in.h" 2 3 4
# 69 "/usr/include/netinet/in.h" 2 3 4
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 1 "/usr/include/sys/_types/_clock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_clock_t.h" 3 4
typedef __darwin_clock_t clock_t;
# 1 "/usr/include/sys/_types/_time_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_time_t.h" 3 4
typedef __darwin_time_t time_t;
} fd_set;
static __inline int
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 1 "/usr/include/sys/_types/_pthread_cond_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_cond_t.h" 3 4
typedef __darwin_pthread_cond_t pthread_cond_t;
# 1 "/usr/include/sys/_types/_pthread_condattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_condattr_t.h" 3 4
typedef __darwin_pthread_condattr_t pthread_condattr_t;
# 1 "/usr/include/sys/_types/_pthread_mutex_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutex_t.h" 3 4
typedef __darwin_pthread_mutex_t pthread_mutex_t;
# 1 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 3 4
typedef __darwin_pthread_mutexattr_t pthread_mutexattr_t;
# 1 "/usr/include/sys/_types/_pthread_once_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_once_t.h" 3 4
typedef __darwin_pthread_once_t pthread_once_t;
# 1 "/usr/include/sys/_types/_pthread_rwlock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlock_t.h" 3 4
typedef __darwin_pthread_rwlock_t pthread_rwlock_t;
# 1 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 3 4
typedef __darwin_pthread_rwlockattr_t pthread_rwlockattr_t;
# 1 "/usr/include/sys/_types/_pthread_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_t.h" 3 4
typedef __darwin_pthread_t pthread_t;
# 1 "/usr/include/sys/_types/_pthread_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_key_t.h" 3 4
typedef __darwin_pthread_key_t pthread_key_t;
# 95 "/usr/include/sys/socket.h" 2 3 4
struct iovec {
 void * iov_base;
 size_t iov_len;
struct linger {
 int l_onoff;
 int l_linger;
 u_int32_t npx_mask;
struct sockaddr {
 __uint8_t sa_len;
 char sa_data[14];
struct sockproto {
 __uint8_t ss_len;
struct msghdr {
 void *msg_name;
 int msg_iovlen;
 void *msg_control;
 int msg_flags;
struct cmsghdr {
 socklen_t cmsg_len;
 int cmsg_level;
 int cmsg_type;
struct sf_hdtr {
 int hdr_cnt;
 int trl_cnt;
struct in_addr {
 in_addr_t s_addr;
 __uint8_t sin_len;
 in_port_t sin_port;
 char sin_zero[8];
struct ip_opts {
 char ip_opts[40];
struct ip_mreq {
struct ip_mreqn {
 int imr_ifindex;
#pragma pack(4)
struct group_req {
#pragma pack()
struct sockaddr;
struct in_pktinfo {
struct in6_addr {
 union {
 } __u6_addr;
 __uint8_t sin6_len;
struct ipv6_mreq {
 uint32_t ip6m_mtu;
struct cmsghdr;
    unsigned int);
    void **);
    void **);
struct sockaddr;
            Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
Successful compile:
Source:
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
            Pushing language C
                      All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.c:4:56: error: use of undeclared identifier '_SC_LEVEL1_DCACHE_SIZE'; did you mean 'getconf_LEVEL1_DCACHE_SIZE'?
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.c:4:6: note: 'getconf_LEVEL1_DCACHE_SIZE' declared here
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.c:4:56: warning: incompatible pointer to integer conversion passing 'long ()' to parameter of type 'int' [-Wint-conversion]
/usr/include/unistd.h:477:18: note: passing argument to parameter here
long     sysconf(int);
1 warning and 1 error generated.
Source:
#include <unistd.h>
int main() {
  return 0;
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <stdio.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val=-1; FILE *f = popen("getconf LEVEL1_DCACHE_SIZE","r"); fscanf(f,"%ld",&val); pclose(f); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
  return 0;
            Popping language C
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <stdio.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails/conftest
          Popping language C
          Defined "LEVEL1_DCACHE_SIZE" to "32768"
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <stdio.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val=-1; FILE *f = popen("getconf LEVEL1_DCACHE_LINESIZE","r"); fscanf(f,"%ld",&val); pclose(f); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
          Popping language C
          Defined "LEVEL1_DCACHE_LINESIZE" to "32"
          Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <stdio.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val=-1; FILE *f = popen("getconf LEVEL1_DCACHE_ASSOC","r"); fscanf(f,"%ld",&val); pclose(f); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
  return 0;
                      Pushing language C
                      Popping language C
          Popping language C
          Defined "LEVEL1_DCACHE_ASSOC" to "2"
TEST checkMemcmp from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:109)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:109)
  Check for 8-bit clean memcmp
                          All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
  return 0;
                      Pushing language C
                      Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest
TEST checkSysinfo from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:133)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:133)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
                    Pushing language C
                    Popping language C
Possible ERROR while running linker: exit code 256
stderr:
Undefined symbols for architecture x86_64:
  "_sysinfo", referenced from:
      _main in conftest.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
TEST checkVPrintf from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:156)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:156)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: warning: incompatible redeclaration of library function 'vprintf' [-Wincompatible-library-redeclaration]
char vprintf();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: note: 'vprintf' is a builtin with type 'int (const char *, __va_list_tag *)'
1 warning generated.
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkVFPrintf from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:163)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:163)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: warning: incompatible redeclaration of library function 'vfprintf' [-Wincompatible-library-redeclaration]
char vfprintf();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: note: 'vfprintf' is a builtin with type 'int ()'
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VFPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkVSNPrintf from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:170)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:170)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Checking for functions [_vsnprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__vsnprintf) || defined (__stub____vsnprintf)
_vsnprintf_will_always_fail_with_ENOSYS();
#else
_vsnprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
  "__vsnprintf", referenced from:
      _main in conftest.o
Checking for functions [vsnprintf]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: warning: incompatible redeclaration of library function 'vsnprintf' [-Wincompatible-library-redeclaration]
char vsnprintf();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: note: 'vsnprintf' is a builtin with type 'int (char *, unsigned long, const char *, __va_list_tag *)'
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
#else
vsnprintf();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE_VSNPRINTF" to "1"
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
                  Pushing language C
                  Popping language C
TEST checkNanosleep from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:214)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:214)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:190)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:190)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
          Pushing language Cxx
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Defined "SIGNAL_CAST" to " "
          Popping language Cxx
TEST checkFreeReturnType from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:200)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:200)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:6:25: error: assigning to 'int' from incompatible type 'void'
int ierr; void *p; ierr = free(p); return 0;
1 error generated.
Source:
#include <stdlib.h>
int main() {
  return 0;
            Compile failed inside link
TEST checkVariableArgumentLists from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:206)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:206)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
                  Pushing language C
                  Popping language C
          Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/Users/patrick/program/petsc/config/BuildSystem/config/functions.py:88)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:88)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time sysctlbyname stricmp]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:16:6: warning: incompatible redeclaration of library function 'snprintf' [-Wincompatible-library-redeclaration]
char snprintf();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:16:6: note: 'snprintf' is a builtin with type 'int (char *, unsigned long, const char *, ...)'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:19:6: warning: incompatible redeclaration of library function 'bzero' [-Wincompatible-library-redeclaration]
char bzero();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:19:6: note: 'bzero' is a builtin with type 'void (void *, unsigned long)'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:48:6: warning: incompatible redeclaration of library function 'strcasecmp' [-Wincompatible-library-redeclaration]
char strcasecmp();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:48:6: note: 'strcasecmp' is a builtin with type 'int (const char *, const char *)'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:52:6: warning: incompatible redeclaration of library function 'memmove' [-Wincompatible-library-redeclaration]
char memmove();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:52:6: note: 'memmove' is a builtin with type 'void *(void *, const void *, unsigned long)'
4 warnings generated.
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
                        Pushing language C
                        Popping language C
stderr:
  "_PXFGETARG", referenced from:
      _main in conftest.o
  "__access", referenced from:
      _main in conftest.o
  "__getcwd", referenced from:
      _main in conftest.o
  "__lseek", referenced from:
      _main in conftest.o
  "__set_output_format", referenced from:
      _main in conftest.o
  "__sleep", referenced from:
      _main in conftest.o
  "__snprintf", referenced from:
      _main in conftest.o
  "_get_nprocs", referenced from:
      _main in conftest.o
  "_memalign", referenced from:
      _main in conftest.o
  "_sbreak", referenced from:
      _main in conftest.o
  "_stricmp", referenced from:
      _main in conftest.o
Checking for functions [rand getdomainname realpath dlsym bzero getwd uname usleep dlclose gethostname clock dlerror mkstemp fork getpagesize]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:17:6: warning: incompatible redeclaration of library function 'bzero' [-Wincompatible-library-redeclaration]
char bzero();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:17:6: note: 'bzero' is a builtin with type 'void (void *, unsigned long)'
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char getwd();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
getwd();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_RAND" to "1"
                  Defined "HAVE_GETDOMAINNAME" to "1"
                  Defined "HAVE_REALPATH" to "1"
                  Defined "HAVE_DLSYM" to "1"
                  Defined "HAVE_BZERO" to "1"
                  Defined "HAVE_GETWD" to "1"
                  Defined "HAVE_UNAME" to "1"
                  Defined "HAVE_USLEEP" to "1"
                  Defined "HAVE_DLCLOSE" to "1"
                  Defined "HAVE_GETHOSTNAME" to "1"
                  Defined "HAVE_CLOCK" to "1"
                  Defined "HAVE_DLERROR" to "1"
                  Defined "HAVE_MKSTEMP" to "1"
                  Defined "HAVE_FORK" to "1"
                  Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time sysctlbyname]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:18:6: warning: incompatible redeclaration of library function 'strcasecmp' [-Wincompatible-library-redeclaration]
char strcasecmp();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:18:6: note: 'strcasecmp' is a builtin with type 'int (const char *, const char *)'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:22:6: warning: incompatible redeclaration of library function 'memmove' [-Wincompatible-library-redeclaration]
char memmove();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:22:6: note: 'memmove' is a builtin with type 'void *(void *, const void *, unsigned long)'
2 warnings generated.
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
#else
sysctlbyname();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_SIGSET" to "1"
                  Defined "HAVE_GETHOSTBYNAME" to "1"
                  Defined "HAVE_GETTIMEOFDAY" to "1"
                  Defined "HAVE_READLINK" to "1"
                  Defined "HAVE_SIGACTION" to "1"
                  Defined "HAVE_STRCASECMP" to "1"
                  Defined "HAVE_DLOPEN" to "1"
                  Defined "HAVE_DRAND48" to "1"
                  Defined "HAVE_SOCKET" to "1"
                  Defined "HAVE_MEMMOVE" to "1"
                  Defined "HAVE_SIGNAL" to "1"
                  Defined "HAVE_POPEN" to "1"
                  Defined "HAVE_GETRUSAGE" to "1"
                  Defined "HAVE_TIMES" to "1"
                  Defined "HAVE_TIME" to "1"
                  Defined "HAVE_SYSCTLBYNAME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [snprintf]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: warning: incompatible redeclaration of library function 'snprintf' [-Wincompatible-library-redeclaration]
char snprintf();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:6: note: 'snprintf' is a builtin with type 'int (char *, unsigned long, const char *, ...)'
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_LSEEK" to "1"
Checking for functions [get_nprocs]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char get_nprocs();
#ifdef __cplusplus
#endif
int main() {
#else
get_nprocs();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [memalign]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                          Pushing language C
                          Popping language C
                  Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
                          Pushing language C
                          Popping language C
stderr:
      _main in conftest.o
TEST configureMemorySize from config.utilities.getResidentSetSize(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
                        All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize/conftest.c:38:18: warning: implicit declaration of function 'getpagesize' is invalid in C99 [-Wimplicit-function-declaration]
            f2 = getpagesize() * ((double)(temp2.ru_maxrss-temp1.ru_maxrss))/(4.0*ARRAYSIZE);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize/conftest.c:58:2: error: expected '}'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize/conftest.c:12:12: note: to match this '{'
int main() {
Source:
#include <stdio.h>
#include <ctype.h>
#include <sys/times.h>
#include <sys/types.h>
            #include <sys/stat.h>
#include <sys/resource.h>
#include <stdlib.h>
int main() {
#define ARRAYSIZE 10000000
            int i,*m;
            struct   rusage temp1,temp2;
            double f0,f1,f2;
            if (getrusage(RUSAGE_SELF,&temp1)) {
              printf("Error calling getrusage()\n");
              return -1;
            m = malloc(ARRAYSIZE*sizeof(int));
            if (!m) {
              printf("Error calling malloc()\n");
              return -3;
            for (i=0; i<ARRAYSIZE; i++){
              m[i] = i+1;
            if (getrusage(RUSAGE_SELF,&temp2)) {
              return -1;
            f0 = ((double)(temp2.ru_maxrss-temp1.ru_maxrss))/(4.0*ARRAYSIZE);
            f1 = 1024.0 * ((double)(temp2.ru_maxrss-temp1.ru_maxrss))/(4.0*ARRAYSIZE);
            printf("Final value %g Initial value %g Increment %g 1K Scaled Increment %g pagesize scaled Increment %g\n",(double)(temp2.ru_maxrss),(double)(temp1.ru_maxrss),f0,f1,f2);
            if (f1 == 0) {
              printf("getrusage() does not work\n");
              return 0;
            if (f0 > .90 && f0 < 1.1) {
              printf("uses bytes in getrusage()\n");
              return 1;
            if (f1 > .90 && f1 < 1.1) {
              printf("uses 1024 size chunks in getrusage()\n");
              return 2;
            } else if (f2 > .9 && f2 < 1.1) {
              printf("uses getpagesize() chunks in getrusage()\n");
              return 3;
            printf("unable to determine if uses bytes, 1024 or getpagesize() chunks in getrusage()\n");
            return -2;;
  return 0;
          Defined "USE_BYTES_FOR_SIZE" to "1"
        output from getrusage()
TEST configureFPTrap from config.utilities.FPTrap(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sigfpe.h' file not found
#include <sigfpe.h>
1 error generated.
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sigfpe.h' file not found
#include <sigfpe.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'sigfpe.h' file not found#include <sigfpe.h>         ^1 error generated.:
Checking for header: fpxcp.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'fpxcp.h' file not found
#include <fpxcp.h>
1 error generated.
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'fpxcp.h' file not found
#include <fpxcp.h>
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'fpxcp.h' file not found#include <fpxcp.h>         ^1 error generated.:
Checking for header: floatingpoint.h
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'floatingpoint.h' file not found
#include <floatingpoint.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'floatingpoint.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'floatingpoint.h' file not found#include <floatingpoint.h>         ^1 error generated.:
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                    All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.c:4:10: fatal error: 'sysctl.h' file not found
#include <sysctl.h>
1 error generated.
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
          Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
          Defined "_DEFAULT_SOURCE" to "1"
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.c:7:1: error: use of undeclared identifier 'cpu_set_t'
cpu_set_t mset;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.c:8:1: warning: implicit declaration of function 'CPU_ZERO' is invalid in C99 [-Wimplicit-function-declaration]
CPU_ZERO(&mset);;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros/conftest.c:8:11: error: use of undeclared identifier 'mset'
CPU_ZERO(&mset);;
1 warning and 2 errors generated.
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
TEST check_siginfo_t from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
  Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
                      All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:13:11: warning: unused variable 'a' [-Wunused-variable]
siginfo_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
  return 0;
siginfo_t found
          Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:13:1: error: unknown type name '__int64'; did you mean '__int64_t'?
__int64 a;;
__int64_t
/usr/include/i386/_types.h:46:20: note: '__int64_t' declared here
typedef long long               __int64_t;
1 error generated.
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
  return 0;
__int64 found
TEST checkSizeTypes from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:13:8: warning: unused variable 'a' [-Wunused-variable]
size_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
mode_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:13:7: warning: unused variable 'a' [-Wunused-variable]
off_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:13:9: warning: unused variable 'a' [-Wunused-variable]
int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
pid_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
  Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c" 2
# 1 "/usr/include/sys/types.h" 1 3 4
# 72 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 73 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 76 "/usr/include/sys/types.h" 2 3 4
# 70 "/usr/include/i386/types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 71 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 77 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 78 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 79 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 80 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 93 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 94 "/usr/include/i386/types.h" 2 3 4
# 79 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 33 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 80 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 82 "/usr/include/sys/types.h" 2 3 4
typedef unsigned char u_char;
typedef unsigned short u_short;
typedef unsigned int u_int;
typedef unsigned long u_long;
typedef unsigned short ushort;
typedef unsigned int uint;
typedef u_int64_t u_quad_t;
typedef int64_t quad_t;
typedef quad_t * qaddr_t;
typedef char * caddr_t;
typedef int32_t daddr_t;
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 103 "/usr/include/sys/types.h" 2 3 4
typedef u_int32_t fixpt_t;
# 1 "/usr/include/sys/_types/_blkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blkcnt_t.h" 3 4
typedef __darwin_blkcnt_t blkcnt_t;
# 107 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_blksize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blksize_t.h" 3 4
typedef __darwin_blksize_t blksize_t;
# 108 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_gid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_gid_t.h" 3 4
typedef __darwin_gid_t gid_t;
# 109 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_addr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_addr_t.h" 3 4
typedef __uint32_t in_addr_t;
# 110 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_port_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_port_t.h" 3 4
typedef __uint16_t in_port_t;
# 111 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino_t.h" 3 4
typedef __darwin_ino_t ino_t;
# 112 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino64_t.h" 3 4
typedef __darwin_ino64_t ino64_t;
# 115 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_key_t.h" 3 4
typedef __int32_t key_t;
# 118 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 119 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_nlink_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_nlink_t.h" 3 4
typedef __uint16_t nlink_t;
# 120 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 121 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 122 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_off_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_off_t.h" 3 4
typedef __darwin_off_t off_t;
# 123 "/usr/include/sys/types.h" 2 3 4
typedef int32_t segsz_t;
typedef int32_t swblk_t;
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 128 "/usr/include/sys/types.h" 2 3 4
# 161 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/_types/_clock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_clock_t.h" 3 4
typedef __darwin_clock_t clock_t;
# 162 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 163 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ssize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ssize_t.h" 3 4
typedef __darwin_ssize_t ssize_t;
# 164 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_time_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_time_t.h" 3 4
typedef __darwin_time_t time_t;
# 165 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_useconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_useconds_t.h" 3 4
typedef __darwin_useconds_t useconds_t;
# 167 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_suseconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_suseconds_t.h" 3 4
typedef __darwin_suseconds_t suseconds_t;
# 168 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rsize_t.h" 3 4
typedef __darwin_size_t rsize_t;
# 171 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_errno_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_errno_t.h" 3 4
typedef int errno_t;
# 172 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_def.h" 1 3 4
# 46 "/usr/include/sys/_types/_fd_def.h" 3 4
typedef struct fd_set {
 __int32_t fds_bits[((((1024) % ((sizeof(__int32_t) * 8))) == 0) ? ((1024) / ((sizeof(__int32_t) * 8))) : (((1024) / ((sizeof(__int32_t) * 8))) + 1))];
} fd_set;
static __inline int
__darwin_fd_isset(int _n, const struct fd_set *_p)
 return (_p->fds_bits[(unsigned long)_n/(sizeof(__int32_t) * 8)] & ((__int32_t)(1<<((unsigned long)_n % (sizeof(__int32_t) * 8)))));
# 181 "/usr/include/sys/types.h" 2 3 4
typedef __int32_t fd_mask;
# 1 "/usr/include/sys/_types/_fd_setsize.h" 1 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_set.h" 1 3 4
# 195 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_clr.h" 1 3 4
# 196 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_zero.h" 1 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_isset.h" 1 3 4
# 198 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_copy.h" 1 3 4
# 201 "/usr/include/sys/types.h" 2 3 4
# 210 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 211 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_cond_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_cond_t.h" 3 4
typedef __darwin_pthread_cond_t pthread_cond_t;
# 212 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_condattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_condattr_t.h" 3 4
typedef __darwin_pthread_condattr_t pthread_condattr_t;
# 213 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutex_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutex_t.h" 3 4
typedef __darwin_pthread_mutex_t pthread_mutex_t;
# 214 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 3 4
typedef __darwin_pthread_mutexattr_t pthread_mutexattr_t;
# 215 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_once_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_once_t.h" 3 4
typedef __darwin_pthread_once_t pthread_once_t;
# 216 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlock_t.h" 3 4
typedef __darwin_pthread_rwlock_t pthread_rwlock_t;
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 3 4
typedef __darwin_pthread_rwlockattr_t pthread_rwlockattr_t;
# 218 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_t.h" 3 4
typedef __darwin_pthread_t pthread_t;
# 219 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_key_t.h" 3 4
typedef __darwin_pthread_key_t pthread_key_t;
# 223 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsblkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsblkcnt_t.h" 3 4
typedef __darwin_fsblkcnt_t fsblkcnt_t;
# 227 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsfilcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsfilcnt_t.h" 3 4
typedef __darwin_fsfilcnt_t fsfilcnt_t;
# 228 "/usr/include/sys/types.h" 2 3 4
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c" 2
TEST checkSignal from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
  Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
  return 0;
          Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
Successful compile:
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
Successful compile:
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
                  Pushing language C
                  Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
  Check for complex numbers in namespace std
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Defined "HAVE_CXX_COMPLEX" to "1"
TEST checkFortranKind from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
          Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.F
Successful compile:
Source:
      program main
        integer(kind=selected_int_kind(10)) i
        real(kind=selected_real_kind(10)) d
      end
          Defined "USE_FORTRANKIND" to "1"
          Popping language FC
TEST checkConst from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
  Checks for working const, and if not found defines it to empty string
Possible ERROR while running compiler:
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:24:16: warning: if statement has empty body [-Wempty-body]
    if (zero.x);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:24:16: note: put the semicolon on a separate line to silence this warning
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:25:14: warning: if statement has empty body [-Wempty-body]
    if (x[0]);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:25:14: note: put the semicolon on a separate line to silence this warning
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:31:14: warning: if statement has empty body [-Wempty-body]
      if (*s);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:31:14: note: put the semicolon on a separate line to silence this warning
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:52:15: warning: if statement has empty body [-Wempty-body]
      if (foo);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:52:15: note: put the semicolon on a separate line to silence this warning
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:46:20: warning: variable 'b' is uninitialized when used here [-Wuninitialized]
      struct s *b; b->j = 5;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:46:18: note: initialize the variable 'b' to silence this warning
                  = 0
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:30:8: warning: variable 't' is uninitialized when used here [-Wuninitialized]
      *t++ = 0;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:27:14: note: initialize the variable 't' to silence this warning
      char *t;
              = 0
6 warnings generated.
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
    { /* SCO 3.2v4 cc rejects this.  */
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkEndian from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
  If the machine is big endian, defines WORDS_BIGENDIAN
Successful compile:
Source:
#ifdef HAVE_SYS_PARAM_H
  #include <sys/param.h>
#endif
int main() {
#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
  bogus endian macros
#endif
  return 0;
Possible ERROR while running compiler: exit code 256
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest.c:11:3: error: use of undeclared identifier 'not'
  not big endian
1 error generated.
Source:
#endif
int main() {
#if BYTE_ORDER != BIG_ENDIAN
  not big endian
#endif
  return 0;
TEST checkSizeof from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
  return 0;
                        Pushing language C
                        Popping language C
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types/conftest
            Popping language C
            Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
            Pushing language C
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_INT" to "4"
Checking for size of type: long
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
            Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
  return 0;
                        Pushing language C
                        Popping language C
            Popping language C
            Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
  Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
    char val[2];
    int i = 0;
    if (!f) exit(1);
    val[0]='\1';
    val[1]='\0';
    while(val[0]) {val[0] <<= 1; i++;}
    fprintf(f, "%d\n", i);
  return 0;
                      Pushing language C
                      Popping language C
          Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/Users/patrick/program/petsc/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
TEST configureMemAlign from PETSc.options.memAlign(/Users/patrick/program/petsc/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
  Choose alignment
          Defined "MEMALIGN" to "16"
        Memory alignment is 16
TEST check from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
          Checking for functions [socket] in library ['socket', 'nsl'] []
            Pushing language C
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -lsocket -lnsl -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lsocket
clang: error: linker command failed with exit code 1 (use -v to see invocation)
            Popping language C
          Checking for functions [handle_sigfpes] in library ['fpe'] []
            Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -lfpe -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stderr:
ld: library not found for -lfpe
            Popping language C
            Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
            Popping language C
            Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                    Pushing language C
                    Popping language C
stderr:
            Popping language C
TEST checkMath from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:251)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:251)
  Check for sin() in libm, the math library
          Checking for functions [sin floor log10 pow] in library [''] []
            Pushing language C
Successful compile:
Source:
double sin(double);
static void _check_sin() { double x = 0,y; y = sin(x);
double floor(double);
static void _check_floor() { double x = 0,y; y = floor(x);
double log10(double);
static void _check_log10() { double x = 0,y; y = log10(x);
double pow(double, double);
static void _check_pow() { double x = 0,y ; y = pow(x, x);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o   -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Popping language C
        Math functions are linked in by default
TEST checkMathErf from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:267)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:267)
  Check for erf() in libm, the math library
          Checking for functions [erf] in library [] []
            Pushing language C
Successful compile:
Source:
double erf(double);
static void _check_erf() { double x = 0,y; y = erf(x);
int main() {
_check_erf();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
        erf() found
          Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:276)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:276)
  Check for tgama() in libm, the math library
          Checking for functions [tgamma] in library [] []
            Pushing language C
Successful compile:
Source:
double tgamma(double);
static void _check_tgamma() { double x = 0,y; y = tgamma(x);
int main() {
_check_tgamma();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
        tgamma() found
          Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:285)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:285)
  Checks if <fenv.h> can be used with FE_DFL_ENV
          Checking for functions [fesetenv] in library [] []
            Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
                    Pushing language C
                    Popping language C
            Popping language C
          Defined "HAVE_FENV_H" to "1"
TEST checkCompression from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:293)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:293)
  Check for libz, the compression library
          Checking for functions [compress uncompress] in library [''] []
            Pushing language C
Successful compile:
Source:
int   compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret =   compress(dest, &destLen, source, sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
int main() {
_check_compress();
_check_uncompress();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
Undefined symbols for architecture x86_64:
  "_compress", referenced from:
      __check_compress in conftest.o
  "_uncompress", referenced from:
      __check_uncompress in conftest.o
ld: symbol(s) not found for architecture x86_64
            Popping language C
          Checking for functions [compress uncompress] in library ['z'] []
            Pushing language C
Successful compile:
Source:
int main() {
_check_compress();
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -lz -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Defined "HAVE_LIBZ" to "1"
            Popping language C
        Using libz for the compression library
TEST checkRealtime from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:314)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:314)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
          Checking for functions [clock_gettime] in library [''] []
            Pushing language C
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c:5:58: warning: implicit declaration of function 'clock_gettime' is invalid in C99 [-Wimplicit-function-declaration]
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c:5:72: error: use of undeclared identifier 'CLOCK_REALTIME'
1 warning and 1 error generated.
Source:
#include <time.h>
int main() {
_check_clock_gettime();;
  return 0;
              Compile failed inside link
            Popping language C
          Checking for functions [clock_gettime] in library ['rt'] []
            Pushing language C
stderr:
Source:
#include <time.h>
int main() {
  return 0;
            Popping language C
        Warning: No realtime library found
TEST checkDynamic from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:330)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:330)
  Check for the header and libraries necessary for dynamic library manipulation
          Checking for functions [dlopen] in library ['dl'] []
            Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -ldl -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Defined "HAVE_LIBDL" to "1"
            Popping language C
Checking for header: dlfcn.h
Executing: clang -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 37 "/usr/include/dlfcn.h" 3 4
# 38 "/usr/include/dlfcn.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdbool.h" 1 3 4
# 41 "/usr/include/dlfcn.h" 2 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 42 "/usr/include/dlfcn.h" 2 3 4
typedef struct dl_info {
        const char *dli_fname;
        void *dli_fbase;
        const char *dli_sname;
        void *dli_saddr;
} Dl_info;
extern int dladdr(const void *, Dl_info *);
extern int dlclose(void * __handle);
extern char * dlerror(void);
extern void * dlopen(const char * __path, int __mode);
extern void * dlsym(void * __handle, const char * __symbol);
extern _Bool dlopen_preflight(const char* __path) __attribute__((availability(macosx,introduced=10.5)));
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Defined "HAVE_DLFCN_H" to "1"
TEST configureMissingDefines from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
  Checks for limits
                    All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:10:7: warning: if statement has empty body [-Wempty-body]
if (i);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:10:7: note: put the semicolon on a separate line to silence this warning
1 warning generated.
Source:
#ifdef PETSC_HAVE_LIMITS_H
  #include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
  return 0;
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c
stderr:
if (d);
Source:
#ifdef PETSC_HAVE_FLOAT_H
  #include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
  return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:67)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
   Checks if u_short is undefined
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:6:9: warning: unused variable 'foo' [-Wunused-variable]
u_short foo;
Source:
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:73)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
  Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:93)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
  Check for missing signals, and define MISSING_<signal name> if necessary
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:8:7: warning: if statement has empty body [-Wempty-body]
if (i);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:8:7: note: put the semicolon on a separate line to silence this warning
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
stderr:
if (i);
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:110)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.c:21:7: warning: incompatible pointer types initializing 'int (*)(char *, size_t)' with an expression of type 'int (char *, int)' [-Wincompatible-pointer-types]
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
          Pushing language Cxx
Executing: clang++ -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.cc
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.cc:21:7: error: cannot initialize a variable of type 'int (*)(char *, size_t)' with an lvalue of type 'int (char *, int)': type mismatch at 2nd parameter ('size_t' (aka 'unsigned long') vs 'int')
1 error generated.
Source:
#define _BSD_SOURCE
#endif
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,int) = getdomainname;
char test[10];
  return 0;
                  Pushing language CXX
                  Popping language CXX
Executing: clang++  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
          Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/missing.py:135)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/Users/patrick/program/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
          Pushing language FC
          Checking for functions [] in library [''] []
            Pushing language FC
Executing: gfortran-mp-4.9 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.F
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       call get_command_argument(i,arg)
      end
                    Pushing language FC
                    Popping language FC
Executing: gfortran-mp-4.9  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o   -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
            Popping language FC
          Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
          Popping language FC
          Pushing language C
          Checking for functions [get_command_argument_] in library [''] ['-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin', '-lgfortran', '-L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1', '-L/opt/local/lib/gcc49', '-lgfortran', '-lgcc_ext.10.5', '-lquadmath', '-lm', '-lm']
            Pushing language C
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stderr:
  "_get_command_argument_", referenced from:
      __check_get_command_argument_ in conftest.o
            Popping language C
          Checking for functions [getarg_] in library [''] ['-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin', '-lgfortran', '-L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1', '-L/opt/local/lib/gcc49', '-lgfortran', '-lgcc_ext.10.5', '-lquadmath', '-lm', '-lm']
            Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
  return 0;
                    Pushing language C
                    Popping language C
stderr:
  "_getarg_", referenced from:
      __check_getarg_ in conftest.o
            Popping language C
Checking for functions [ipxfargc_]
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
  return 0;
                    Pushing language C
                    Popping language C
Executing: clang  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.o -ldl -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm
stderr:
  "_ipxfargc_", referenced from:
      _main in conftest.o
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
  "_f90_unix_MP_iargc", referenced from:
      _main in conftest.o
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
  "_PXFGETARG", referenced from:
      _main in conftest.o
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
  return 0;
                    Pushing language C
                    Popping language C
stderr:
  "_iargc_", referenced from:
      _main in conftest.o
Checking for functions [GETARG at 16]
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:13:12: error: expected ';' after top level declarator
char GETARG at 16();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:21:27: error: missing ')' after 'defined'
#if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:21:13: note: to match this '('
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:24:7: error: expected ';' after expression
GETARG at 16();
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:24:7: error: expected expression
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions/conftest.c:24:1: warning: expression result unused [-Wunused-value]
GETARG at 16();
1 warning and 4 errors generated.
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
  return 0;
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
  return 0;
                    Pushing language C
                    Popping language C
            Defined "HAVE__GFORTRAN_IARGC" to "1"
          Defined "HAVE_GFORTRAN_IARGC" to "1"
          Popping language C
TEST configureCPURelax from config.atomics(/Users/patrick/program/petsc/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
   Definitions for cpu relax assembly instructions
                    All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("rep; nop" ::: "memory");;
  return 0;
          Defined "CPU_RELAX()" to "asm volatile("rep; nop" ::: "memory")"
TEST configureMemoryBarriers from config.atomics(/Users/patrick/program/petsc/config/BuildSystem/config/atomics.py:36)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
   Definitions for memory barrier instructions
Executing: clang -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics/conftest.c
Successful compile:
Source:
int main() {
asm volatile("mfence":::"memory");
  return 0;
          Defined "MEMORY_BARRIER()" to "asm volatile("mfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("lfence":::"memory");
  return 0;
          Defined "READ_MEMORY_BARRIER()" to "asm volatile("lfence":::"memory")"
Successful compile:
Source:
int main() {
asm volatile("sfence":::"memory");
  return 0;
          Defined "WRITE_MEMORY_BARRIER()" to "asm volatile("sfence":::"memory")"
TEST configureMkdir from config.programs(/Users/patrick/program/petsc/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:22)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /opt/local/bin/mkdir...not found
Checking for program /opt/local/sbin/mkdir...not found
Checking for program /usr/bin/mkdir...not found
Checking for program /bin/mkdir...found
Executing: /bin/mkdir -p .conftest/tmp
        Adding -p flag to /bin/mkdir -p to automatically create directories
          Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/Users/patrick/program/petsc/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:44)
  Check for autoreconf
Checking for program /opt/local/bin/autoreconf...found
          All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs
Executing: cd /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs/autoconfdir&&/opt/local/bin/autoreconf
        autoreconf test successful!
TEST configurePrograms from config.programs(/Users/patrick/program/petsc/config/BuildSystem/config/programs.py:66)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:66)
  Check for the programs needed to build and run PETSc
Checking for program /opt/local/bin/sh...not found
Checking for program /opt/local/sbin/sh...not found
Checking for program /usr/bin/sh...not found
Checking for program /bin/sh...found
            Defined make macro "SHELL" to "/bin/sh"
Checking for program /opt/local/bin/sed...not found
Checking for program /opt/local/sbin/sed...not found
Checking for program /usr/bin/sed...found
            Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs/sed1"
        Rejected SEDINPLACE cmd: /usr/bin/sed -i
Executing: /usr/bin/sed -i "" s/sed/sd/g "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs/sed1"
        Adding SEDINPLACE cmd: /usr/bin/sed -i ""
          Defined make macro "SEDINPLACE" to "/usr/bin/sed -i """
Checking for program /opt/local/bin/mv...not found
Checking for program /opt/local/sbin/mv...not found
Checking for program /usr/bin/mv...not found
Checking for program /bin/mv...found
            Defined make macro "MV" to "/bin/mv"
Checking for program /opt/local/bin/cp...not found
Checking for program /opt/local/sbin/cp...not found
Checking for program /usr/bin/cp...not found
Checking for program /bin/cp...found
            Defined make macro "CP" to "/bin/cp"
Checking for program /opt/local/bin/grep...found
            Defined make macro "GREP" to "/opt/local/bin/grep"
Checking for program /opt/local/bin/rm...not found
Checking for program /opt/local/sbin/rm...not found
Checking for program /usr/bin/rm...not found
Checking for program /bin/rm...found
            Defined make macro "RM" to "/bin/rm -f"
Checking for program /opt/local/bin/diff...not found
Checking for program /opt/local/sbin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs/diff1" "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.programs/diff2"
          Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /Users/patrick/ps...not found
Checking for program /Users/patrick/program/petsc/bin/win32fe/ps...not found
Checking for program /opt/local/bin/gzip...not found
Checking for program /opt/local/sbin/gzip...not found
Checking for program /usr/bin/gzip...found
            Defined make macro "GZIP" to "/usr/bin/gzip"
          Defined "HAVE_GZIP" to "1"
          Defined make macro "PYTHON" to "/usr/bin/python"
TEST configureMake from config.packages.make(/Users/patrick/program/petsc/config/BuildSystem/config/packages/make.py:67)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:67)
  Check for user specified make - or gmake, make
Checking for program /opt/local/bin/gmake...not found
Checking for program /opt/local/sbin/gmake...not found
Checking for program /usr/bin/gmake...not found
Checking for program /bin/gmake...not found
Checking for program /usr/sbin/gmake...not found
Checking for program /sbin/gmake...not found
Checking for program /usr/local/bin/gmake...not found
Checking for program /opt/X11/bin/gmake...not found
Checking for program /Users/patrick/gmake...not found
Checking for program /Users/patrick/program/petsc/bin/win32fe/gmake...not found
Checking for program /opt/local/bin/make...not found
Checking for program /opt/local/sbin/make...not found
Checking for program /usr/bin/make...found
            Defined make macro "MAKE" to "/usr/bin/make"
TEST configureCheckGNUMake from config.packages.make(/Users/patrick/program/petsc/config/BuildSystem/config/packages/make.py:85)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:85)
  Check for GNU make
Executing: /usr/bin/make --version
stdout:
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i386-apple-darwin11.3.0
          Defined make macro "MAKE_IS_GNUMAKE" to "1"
          Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
          Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
          Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
          Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/Users/patrick/program/petsc/config/BuildSystem/config/packages/make.py:120)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:120)
  check no of cores on the build machine [perhaps to do make '-j ncores']
        module multiprocessing found 8 cores: using make_np = 7
          Defined make macro "MAKE_NP" to "7"
      Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/make  --print-directory"
      Defined make macro "OMAKE" to "/usr/bin/make  --no-print-directory"
      Pushing language C
TEST configureLibrary from config.packages.MPICH(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
        Checking for a functional MPICH
Executing: uname -s
stdout: Darwin
                  Looking for MPICH in directory starting with mpich
                  Found a copy of MPICH in mpich-3.1.3
                          Pushing language C
                              All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.MPICH
                          Popping language C
                          Pushing language FC
Executing: gfortran-mp-4.9 -v
                          Popping language FC
                      MPICH is rejecting configure arguments ['--disable-f90', '--enable-f90', 'F90="gfortran-mp-4.9"', 'F90FLAGS=" -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0  "']
Do not need to rebuild MPICH
                        Deleting "CC"
                        Deleting "CXX"
                        Deleting "FC"
TEST printEnvVariables from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1534)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1534)
                            **** printenv ****
VERSIONER_PYTHON_PREFER_32_BIT=no
LC_CTYPE=UTF-8
LOGNAME=patrick
USER=patrick
PATH=/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/opt/X11/bin
HOME=/Users/patrick
DISPLAY=/tmp/launch-FrMKw2/org.macosforge.xquartz:0
TERM_PROGRAM=iTerm.app
TERM=xterm-256color
SHELL=/bin/bash
COLORFGBG=12;8
VERSIONER_PYTHON_VERSION=2.7
SHLVL=1
PETSC_ARCH=arch-darwin-double-debug
LD_LIBRARY_PATH=/Users/patrick/program/petsc/arch-darwin-double-debug/lib
ITERM_SESSION_ID=w4t0p0
PETSC_DIR=/Users/patrick/program/petsc
_=./configure
SSH_AUTH_SOCK=/tmp/launch-OY9ieD/Listeners
Apple_PubSub_Socket_Render=/tmp/launch-hHYAUR/Render
ITERM_PROFILE=Default
TMPDIR=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/
HISTIGNORE=&:ls:pwd
OLDPWD=/Users/patrick/program/petsc/src/ksp/ksp/examples/tutorials
CLICOLOR=1
__CF_USER_TEXT_ENCODING=0x1F5:0:4
PMPI=/Users/patrick/program/petsc/bin/petscmpiexec
__CHECKFIX1436934=1
TEST resetEnvCompilers from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1541)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1541)
TEST checkMPICompilerOverride from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1506)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1506)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1525)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1525)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:398)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:398)
  Determine the compiler vendor
                            Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:408)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:408)
  Initialize the compiler and linker flags
                              Pushing language C
                            Initialized CFLAGS to
                            Initialized LDFLAGS to
                              Popping language C
                              Pushing language CUDA
                            Initialized CUDAFLAGS to
                              Popping language CUDA
                            Initialized CXXFLAGS to
                            Initialized CXX_CXXFLAGS to
                              Pushing language FC
                            Initialized FFLAGS to
                              Popping language FC
                            Initialized CPPFLAGS to
                            Initialized CUDAPPFLAGS to
                            Initialized CXXCPPFLAGS to
                            Initialized CC_LINKER_FLAGS to ['-Wl,-multiply_defined,suppress', '-Wl,-multiply_defined -Wl,suppress', '-Wl,-commons,use_dylibs', '-Wl,-search_paths_first']
                            Initialized CXX_LINKER_FLAGS to ['-Wl,-multiply_defined,suppress', '-Wl,-multiply_defined -Wl,suppress', '-Wl,-commons,use_dylibs', '-Wl,-search_paths_first']
                            Initialized FC_LINKER_FLAGS to ['-Wl,-multiply_defined,suppress', '-Wl,-multiply_defined -Wl,suppress', '-Wl,-commons,use_dylibs', '-Wl,-search_paths_first']
                            Initialized CUDAC_LINKER_FLAGS to []
                            Initialized sharedLibraryFlags to []
                            Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:534)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:534)
  Locate a functional C compiler
Checking for program /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc...found
                                Defined make macro "CC" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc"
                                Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language C
                                        Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
int main() {
  return 0;
                                            Pushing language C
                                            Popping language C
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest
                                Popping language C
TEST checkCPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:567)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:567)
  Locate a functional C preprocessor
                                Defined make macro "CPP" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E"
                              Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 82 "/usr/include/sys/signal.h" 2 3 4
# 145 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 148 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 153 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 154 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 266 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 328 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 345 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 364 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 387 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait") ;
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid") ;
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid") ;
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (*)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *, const void *, size_t,
     size_t, int (*)(const void *, const void *));
void *calloc(size_t, size_t);
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t);
int mblen(const char *, size_t);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **, size_t, size_t) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *, size_t, size_t,
int rand(void);
void *realloc(void *, size_t);
void srand(unsigned);
double strtod(const char *, char **) __asm("_" "strtod") ;
float strtof(const char *, char **) __asm("_" "strtof") ;
long strtol(const char *, char **, int);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *, char **, int);
unsigned long
  strtoul(const char *, char **, int);
unsigned long long
  strtoull(const char *, char **, int);
int system(const char *) __asm("_" "system") ;
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]);
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void);
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void);
long nrand48(unsigned short[3]);
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv") ;
long random(void);
int rand_r(unsigned *);
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char *, const char *, int) __asm("_" "setenv") ;
void setkey(const char *) __asm("_" "setkey") ;
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv") ;
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 239 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 241 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 242 "/usr/include/stdlib.h" 2 3 4
u_int32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int );
void arc4random_buf(void * , size_t ) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
u_int32_t
  arc4random_uniform(u_int32_t ) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *, const void *, size_t,
     size_t, int (^)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *, size_t, size_t,
int heapsort_b(void *, size_t, size_t,
int mergesort(void *, size_t, size_t,
int mergesort_b(void *, size_t, size_t,
void psort(void *, size_t, size_t,
     int (*)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *, size_t, size_t,
void psort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *, size_t, size_t,
void qsort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
  strtoq(const char *, char **, int);
unsigned long long
  strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                              Popping language C
TEST checkCUDACompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:608)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:608)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:648)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:648)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:760)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:760)
  Locate a functional Cxx compiler
Checking for program /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx...found
                                Defined make macro "CXX" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx"
                                Pushing language Cxx
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing     /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                        Pushing language CXX
                                        Popping language CXX
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
                                Popping language Cxx
TEST checkCxxPreprocessor from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:798)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:798)
  Locate a functional Cxx preprocessor
                                Defined make macro "CXXCPP" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -E"
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 175 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
extern "C" {
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 1 3
# 85 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 1 3
# 16 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
# 226 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
typedef __char16_t char16_t;
typedef __char32_t char32_t;
# 349 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
namespace std {
  inline namespace __1 {
# 494 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config" 3
template <bool> struct __static_assert_test;
template <> struct __static_assert_test<true> {};
template <unsigned> struct __static_assert_check {};
# 86 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 2 3
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
typedef union {
} __mbstate_t;
 void *__arg;
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
 char __xmm_reg[16];
 __uint16_t __cpu;
 __uint32_t __err;
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
    __uint16_t __cpu;
    __uint32_t __err;
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
 void *ss_sp;
 int ss_flags;
 int uc_onstack;
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 long si_band;
} siginfo_t;
         void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
struct sigvec {
 int sv_mask;
 int sv_flags;
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 386 "/usr/include/sys/signal.h" 3 4
extern "C" {
struct timeval
struct rusage {
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
 uint32_t wm_flags;
 int32_t wm_rate;
# 346 "/usr/include/sys/resource.h" 3 4
extern "C" {
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
union wait {
 int w_status;
 struct {
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 247 "/usr/include/sys/wait.h" 3 4
extern "C" {
# 31 "/usr/include/alloca.h" 3 4
extern "C" {
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 127 "/usr/include/stdlib.h" 3 4
extern "C" {
long long
void free(void *);
long long
  llabs(long long);
size_t mbstowcs(wchar_t * , const char * , size_t);
int mbtowc(wchar_t * , const char * , size_t);
int rand(void);
long double
long long
unsigned long
unsigned long long
size_t wcstombs(char * , const wchar_t * , size_t);
char *ecvt(double, int, int *, int *);
char *fcvt(double, int, int *, int *);
int grantpt(int);
char *l64a(long);
long lrand48(void);
long mrand48(void);
char *ptsname(int);
long random(void);
char *realpath(const char * , char * ) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
void srand48(long);
int unlockpt(int);
u_int32_t
const char
 *getprogname(void);
     unsigned);
     unsigned);
long long
unsigned long long
# 87 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 2 3
# 93 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
namespace std {inline namespace __1 {
using ::size_t;
using ::div_t;
using ::ldiv_t;
using ::lldiv_t;
using ::atof;
using ::atoi;
using ::atol;
using ::atoll;
using ::strtod;
using ::strtof;
using ::strtold;
using ::strtol;
using ::strtoll;
using ::strtoul;
using ::strtoull;
using ::rand;
using ::srand;
using ::calloc;
using ::free;
using ::malloc;
using ::realloc;
using ::abort;
using ::atexit;
using ::exit;
using ::_Exit;
using ::getenv;
using ::system;
using ::bsearch;
using ::qsort;
using ::abs;
using ::labs;
using ::llabs;
using ::div;
using ::ldiv;
using ::lldiv;
using ::mblen;
using ::mbtowc;
using ::wctomb;
using ::mbstowcs;
using ::wcstombs;
# 159 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/cstdlib" 3
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long abs( long __x) throw() {return labs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long long abs(long long __x) throw() {return llabs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) ldiv_t div( long __x, long __y) throw() {return ldiv(__x, __y);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) lldiv_t div(long long __x, long long __y) throw() {return lldiv(__x, __y);}
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc" 2
TEST checkFortranCompiler from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:915)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:915)
  Locate a functional Fortran compiler
Checking for program /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90...found
                                Defined make macro "FC" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90"
                                Pushing language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                        Pushing language FC
                                        Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                                        Pushing language FC
                                        Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                                            Pushing language FC
                                            Popping language FC
                                Popping language FC
TEST checkFortranComments from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:936)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:936)
  Make sure fortran comment "!" works
                              Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
                            Fortran comments can use ! in column 1
                              Popping language FC
TEST checkPIC from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:999)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:999)
  Determine the PIC option for each compiler
       - There needs to be a test that checks that the functionality is actually working
                              Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc --help
stdout:
OVERVIEW: clang LLVM compiler
USAGE: clang [options] <inputs>
OPTIONS:
  -###                    Print (but do not run) the commands to run for this compilation
  --analyze               Run the static analyzer
  -arcmt-migrate-emit-errors
                          Emit ARC errors even if the migrator can fix them
  -arcmt-migrate-report-output <value>
                          Output path for the plist report
  -cxx-isystem <directory>
                          Add directory to the C++ SYSTEM include search path
  -c                      Only run preprocess, compile, and assemble steps
  -dD                     Print macro definitions in -E mode in addition to normal output
  -dependency-dot <value> Filename to write DOT-formatted header dependencies to
  -dependency-file <value>
                          Filename (or -) to write dependency output to
  -dM                     Print macro definitions in -E mode instead of normal output
  -emit-ast               Emit Clang AST files for source inputs
  -emit-llvm              Use the LLVM representation for assembler and object files
  -E                      Only run the preprocessor
  -faltivec               Enable AltiVec vector initializer syntax
  -fansi-escape-codes     Use ANSI escape codes for diagnostics
  -fapple-kext            Use Apple's kernel extensions ABI
  -fapple-pragma-pack     Enable Apple gcc-compatible #pragma pack handling
  -fapplication-extension Restrict code to those available for App Extensions
  -fblocks                Enable the 'blocks' language feature
  -fborland-extensions    Accept non-standard constructs supported by the Borland compiler
  -fbounds-checking       Enable run-time bounds checks
  -fbuild-session-timestamp=<time since Epoch in seconds>
                          Time when the current build session started
  -fcolor-diagnostics     Use colors in diagnostics
  -fcomment-block-commands=<arg>
                          Treat each comma separated argument in <arg> as a documentation comment block command
  -fcxx-exceptions        Enable C++ exceptions
  -fdata-sections         Place each data in its own section (ELF Only)
  -fdebug-types-section   Place debug types in their own section (ELF Only)
  -fdelayed-template-parsing
                          Parse templated function definitions at the end of the translation unit
  -fdiagnostics-parseable-fixits
                          Print fix-its in machine parseable form
  -fdiagnostics-print-source-range-info
                          Print source range spans in numeric form
  -fdiagnostics-show-note-include-stack
                          Display include stacks for diagnostic notes
  -fdiagnostics-show-option
                          Print option name with mappable diagnostics
  -fdiagnostics-show-template-tree
                          Print a template comparison tree for differing templates
  -fdollars-in-identifiers
                          Allow '$' in identifiers
  -femit-all-decls        Emit all declarations, even if unused
  -fexceptions            Enable support for exception handling
  -ffast-math             Enable the *frontend*'s 'fast-math' mode. This has no effect on optimizations, but provides a preprocessor macro __FAST_MATH__ the same as GCC's -ffast-math flag
  -ffixed-r9              Reserve the r9 register (ARM only)
  -ffp-contract=<value>   Form fused FP ops (e.g. FMAs): fast (everywhere) | on (according to FP_CONTRACT pragma, default) | off (never fuse)
  -ffreestanding          Assert that the compilation takes place in a freestanding environment
  -ffunction-sections     Place each function in its own section (ELF Only)
  -fgnu-keywords          Allow GNU-extension keywords regardless of language standard
  -fgnu-runtime           Generate output compatible with the standard GNU Objective-C runtime
  -fgnu89-inline          Use the gnu89 inline semantics
  -finstrument-functions  Generate calls to instrument function entry and exit
  -fmath-errno            Require math functions to indicate errors by setting errno
  -fmodule-implementation-of <name>
                          Specify the name of the module whose implementation file this is
  -fmodule-map-file= <file>
                          Load this module map file
  -fmodule-maps           Read module maps to understand the structure of library headers
  -fmodule-name= <name>   Specify the name of the module to build
  -fmodules-cache-path=<directory>
                          Specify the module cache path
  -fmodules-decluse       Require declaration of modules used within a module
  -fmodules-ignore-macro=<value>
                          Ignore the definition of the given macro when building and loading modules
  -fmodules-prune-after=<seconds>
                          Specify the interval (in seconds) after which a module file will be considered unused
  -fmodules-prune-interval=<seconds>
                          Specify the interval (in seconds) between attempts to prune the module cache
  -fmodules-user-build-path <directory>
                          Specify the module user build path
  -fmodules-validate-once-per-build-session
                          Don't verify input files for the modules if the module has been successfully validate or loaded during this build session
  -fmodules-validate-system-headers
                          Validate the system headers that a module depends on when loading the module
  -fmodules               Enable the 'modules' language feature
  -fms-compatibility      Enable full Microsoft Visual C++ compatibility
  -fms-extensions         Accept some non-standard constructs supported by the Microsoft compiler
  -fmsc-version=<value>   Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fno-access-control     Disable C++ access control
  -fno-assume-sane-operator-new
                          Don't assume that C++'s global operator new can't alias any pointer
  -fno-autolink           Disable generation of linker directives for automatic library linking
  -fno-builtin-<value>    Disable implicit builtin knowledge of a specific function
  -fno-builtin            Disable implicit builtin knowledge of functions
  -fno-common             Compile common globals like normal definitions
  -fno-constant-cfstrings Disable creation of CodeFoundation-type constant strings
  -fno-diagnostics-fixit-info
                          Do not include fixit information in diagnostics
  -fno-dollars-in-identifiers
                          Disallow '$' in identifiers
  -fno-elide-constructors Disable C++ copy constructor elision
  -fno-elide-type         Do not elide types when printing diagnostics
  -fno-lax-vector-conversions
                          Disallow implicit conversions between vectors with a different number of elements or different element types
  -fno-math-builtin       Disable implicit builtin knowledge of math functions
  -fno-merge-all-constants
                          Disallow merging of constants
  -fno-objc-infer-related-result-type
                          do not infer Objective-C related result type based on method family
  -fno-operator-names     Do not treat C++ operator name keywords as synonyms for operators
  -fno-reroll-loops       Turn off loop reroller
  -fno-rtti               Disable generation of rtti information
  -fno-sanitize-blacklist Don't use blacklist file for sanitizers
  -fno-sanitize-recover   Disable sanitizer check recovery
  -fno-show-column        Do not include column number on diagnostics
  -fno-show-source-location
                          Do not include source location information with diagnostics
  -fno-signed-char        Char is unsigned
  -fno-spell-checking     Disable spell-checking
  -fno-standalone-debug   Limit debug information produced to reduce size of debug binary
  -fno-threadsafe-statics Do not emit code to make initialization of local statics thread safe
  -fno-unroll-loops       Turn off loop unroller
  -fno-use-cxa-atexit     Don't use __cxa_atexit for calling destructors
  -fno-use-init-array     Don't use .init_array instead of .ctors
  -fobjc-arc-exceptions   Use EH-safe code when synthesizing retains and releases in -fobjc-arc
  -fobjc-arc              Synthesize retain and release calls for Objective-C pointers
  -fobjc-exceptions       Enable Objective-C exceptions
  -fobjc-gc-only          Use GC exclusively for Objective-C related memory management
  -fobjc-gc               Enable Objective-C garbage collection
  -fobjc-runtime=<value>  Specify the target Objective-C runtime kind and version
  -fpack-struct=<value>   Specify the default maximum struct packing alignment
  -fpascal-strings        Recognize and construct Pascal-style string literals
  -fpcc-struct-return     Override the default ABI to return all structs on the stack
  -fprofile-instr-generate
                          Generate instrumented code to collect execution counts
  -fprofile-instr-use=<value>
                          Use instrumentation data for profile-guided optimization
  -fprofile-sample-use=<value>
                          Enable sample-based profile guided optimizations
  -freg-struct-return     Override the default ABI to return small structs in registers
  -freroll-loops          Turn on loop reroller
  -fsanitize-blacklist=<value>
                          Path to blacklist file for sanitizers
  -fsanitize-memory-track-origins
                          Enable origins tracking in MemorySanitizer
  -fsanitize=<check>      Enable runtime instrumentation for bug detection: undefined (miscellaneous undefined behavior)
  -fshort-enums           Allocate to an enum type only as many bytes as it needs for the declared range of possible values
  -fshort-wchar           Force wchar_t to be a short unsigned int
  -fshow-overloads=<value>
                          Which overload candidates to show when overload resolution fails: best|all; defaults to all
  -fslp-vectorize-aggressive
                          Enable the BB vectorization passes
  -fslp-vectorize         Enable the superword-level parallelism vectorization passes
  -fstandalone-debug      Emit full debug info for all types used by the program
  -fstrict-enums          Enable optimizations based on the strict definition of an enum's value range
  -ftrap-function=<value> Issue call to specified function rather than a trap instruction
  -ftrapv-handler=<function name>
                          Specify the function to be called on overflow
  -ftrapv                 Trap on integer overflow
  -funroll-loops          Turn on loop unroller
  -fuse-init-array        Use .init_array instead of .ctors
  -fvectorize             Enable the loop vectorization passes
  -fvisibility-inlines-hidden
                          Give inline C++ member functions default visibility by default
  -fvisibility-ms-compat  Give global types 'default' visibility and global functions and variables 'hidden' visibility by default
  -fvisibility=<value>    Set the default symbol visibility for all global declarations
  -fwrapv                 Treat signed integer overflow as two's complement
  -fwritable-strings      Store string literals as writable data
  -F <value>              Add directory to framework include search path
  --gcc-toolchain=<value> Use the gcc toolchain at the given directory
  -gdwarf-2               Generate source level debug information with dwarf version 2
  -gdwarf-3               Generate source level debug information with dwarf version 3
  -gdwarf-4               Generate source level debug information with dwarf version 4
  -gline-tables-only      Emit debug line number tables only
  -g                      Generate source level debug information
  -help                   Display available options
  -H                      Show header includes and nesting depth
  -idirafter <value>      Add directory to AFTER include search path
  -iframework <value>     Add directory to SYSTEM framework search path
  -imacros <file>         Include macros from file before parsing
  -include-pch <file>     Include precompiled header file
  -include <file>         Include file before parsing
  -index-header-map       Make the next included directory (-I or -F) an indexer header map
  -iprefix <dir>          Set the -iwithprefix/-iwithprefixbefore prefix
  -iquote <directory>     Add directory to QUOTE include search path
  -isysroot <dir>         Set the system root directory (usually /)
  -isystem <directory>    Add directory to SYSTEM include search path
  -ivfsoverlay <value>    Overlay the virtual filesystem described by file over the real file system
  -iwithprefixbefore <dir>
                          Set directory to include search path with prefix
  -iwithprefix <dir>      Set directory to SYSTEM include search path with prefix
  -iwithsysroot <directory>
                          Add directory to SYSTEM include search path, absolute paths are relative to -isysroot
  -I <value>              Add directory to include search path
  -mcrc                   Allow use of CRC instructions (ARM only)
  -MD                     Write a depfile containing user and system headers
  -mfp32                  Use 32-bit floating point registers (MIPS only)
  -mfp64                  Use 64-bit floating point registers (MIPS only)
  -MF <file>              Write depfile output from -MMD, -MD, -MM, or -M to <file>
  -MG                     Add missing headers to depfile
  --migrate-xct           Apply modifications and produces temporary files to migrate to XCTest framework
  --migrate               Run the migrator
  -mllvm <value>          Additional arguments to forward to LLVM's option processing
  -MMD                    Write a depfile containing user headers
  -mms-bitfields          Set the default structure layout to be compatible with the Microsoft compiler standard
  -mmsa                   Enable MSA ASE (MIPS only)
  -MM                     Like -MMD, but also implies -E and writes to stdout by default
  -mno-global-merge       Disable merging of globals
  -mno-implicit-float     Don't generate implicit floating point instructions
  -mno-msa                Disable MSA ASE (MIPS only)
  -mno-restrict-it        Allow generation of deprecated IT blocks for ARMv8. It is off by default for ARMv8 Thumb mode
  -mno-unaligned-access   Force all memory accesses to be aligned (AArch32/AArch64 only)
  -mnocrc                 Disallow use of CRC instructions (ARM only)
  -module-dependency-dir <value>
                          Directory to dump module dependencies to
  -momit-leaf-frame-pointer
                          Omit frame pointer setup for leaf functions
  -MP                     Create phony target for each dependency (other than main file)
  -mqdsp6-compat          Enable hexagon-qdsp6 backward compatibility
  -MQ <value>             Specify name of main file output to quote in depfile
  -mrelax-all             (integrated-as) Relax all machine instructions
  -mrestrict-it           Disallow generation of deprecated IT blocks for ARMv8. It is on by default for ARMv8 Thumb mode.
  -mrtd                   Make StdCall calling convention the default
  -msoft-float            Use software floating point
  -mstack-alignment=<value>
                          Set the stack alignment
  -mstackrealign          Force realign the stack at entry to every function
  -MT <value>             Specify name of main file output in depfile
  -munaligned-access      Allow memory accesses to be unaligned (AArch32/AArch64 only)
  -M                      Like -MD, but also implies -E and writes to stdout by default
  -nobuiltininc           Disable builtin #include directories
  -nostdinc++             Disable standard #include directories for the C++ standard library
  -ObjC++                 Treat source input files as Objective-C++ inputs
  -objcmt-atomic-property Make migration to 'atomic' properties
  -objcmt-migrate-all     Enable migration to modern ObjC
  -objcmt-migrate-annotation
                          Enable migration to property and method annotations
  -objcmt-migrate-designated-init
                          Enable migration to infer NS_DESIGNATED_INITIALIZER for initializer methods
  -objcmt-migrate-instancetype
                          Enable migration to infer instancetype for method result type
  -objcmt-migrate-literals
                          Enable migration to modern ObjC literals
  -objcmt-migrate-ns-macros
                          Enable migration to NS_ENUM/NS_OPTIONS macros
  -objcmt-migrate-property
                          Enable migration to modern ObjC property
  -objcmt-migrate-protocol-conformance
                          Enable migration to add protocol conformance on classes
  -objcmt-migrate-readonly-property
                          Enable migration to modern ObjC readonly property
  -objcmt-migrate-readwrite-property
                          Enable migration to modern ObjC readwrite property
  -objcmt-migrate-subscripting
                          Enable migration to modern ObjC subscripting
  -objcmt-ns-nonatomic-iosonly
                          Enable migration to use NS_NONATOMIC_IOSONLY macro for setting property's 'atomic' attribute
  -objcmt-returns-innerpointer-property
                          Enable migration to annotate property with NS_RETURNS_INNER_POINTER
  -objcmt-whitelist-dir-path=<value>
                          Only modify files with a filename contained in the provided directory path
  -ObjC                   Treat source input files as Objective-C inputs
  -o <file>               Write output to <file>
  -pg                     Enable mcount instrumentation
  -pipe                   Use pipes between commands, when possible
  -print-file-name=<file> Print the full library path of <file>
  -print-ivar-layout      Enable Objective-C Ivar layout bitmap print trace
  -print-libgcc-file-name Print the library path for "libgcc.a"
  -print-prog-name=<name> Print the full program path of <name>
  -print-search-dirs      Print the paths used for finding libraries and programs
  -pthread                Support POSIX threads in generated code
  -P                      Disable linemarker output in -E mode
  -Qunused-arguments      Don't emit warning for unused driver arguments
  -relocatable-pch        Whether to build a relocatable precompiled header
  -rewrite-legacy-objc    Rewrite Legacy Objective-C source to C++
  -rewrite-objc           Rewrite Objective-C source to C++
  -save-temps             Save intermediate compilation results
  -serialize-diagnostics <value>
                          Serialize compiler diagnostics to a file
  -std=<value>            Language standard to compile for
  -stdlib=<value>         C++ standard library to use
  -S                      Only run preprocess and compilation steps
  --target=<value>        Generate code for the given target
  -time                   Time individual commands
  -traditional-cpp        Enable some traditional CPP emulation
  -trigraphs              Process trigraph sequences
  -undef                  undef all system defines
  --verify-debug-info     Verify the binary representation of debug output
  -verify-pch             Load and verify that a pre-compiled header file is not stale
  -v                      Show commands to run and use verbose output
  -Wa,<arg>               Pass the comma separated arguments in <arg> to the assembler
  -Wl,<arg>               Pass the comma separated arguments in <arg> to the linker
  -working-directory <value>
                          Resolve file paths relative to the specified directory
  -Wp,<arg>               Pass the comma separated arguments in <arg> to the preprocessor
  -W<warning>             Enable the specified warning
  -w                      Suppress all warnings
  -Xanalyzer <arg>        Pass <arg> to the static analyzer
  -Xassembler <arg>       Pass <arg> to the assembler
  -Xclang <arg>           Pass <arg> to the clang compiler
  -Xlinker <arg>          Pass <arg> to the linker
  -Xpreprocessor <arg>    Pass <arg> to the preprocessor
  -x <language>           Treat subsequent input files as having type <language>
                            Trying C compiler flag -fPIC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -fPIC
                            Adding C compiler flag -fPIC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fPIC
                              Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx --help
stdout:
OPTIONS:
                            Trying Cxx compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid Cxx linker flag -fPIC
                            Adding Cxx compiler flag -fPIC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -fPIC    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fPIC
                              Pushing language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 --help
stdout:
Usage: gfortran-mp-4.9 [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase
  --help                   Display this information
  --target-help            Display target specific command line options
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...]
                           Display specific types of command line options
  (Use '-v --help' to display command line options of sub-processes)
  --version                Display compiler version information
  -dumpspecs               Display all of the built in spec strings
  -dumpversion             Display the version of the compiler
  -dumpmachine             Display the compiler's target processor
  -print-search-dirs       Display the directories in the compiler's search path
  -print-libgcc-file-name  Display the name of the compiler's companion library
  -print-file-name=<lib>   Display the full path to library <lib>
  -print-prog-name=<prog>  Display the full path to compiler component <prog>
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path
  -print-multi-directory   Display the root directory for versions of libgcc
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories
  -print-multi-os-directory Display the relative path to OS libraries
  -print-sysroot           Display the target libraries directory
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers
  -Wa,<options>            Pass comma-separated <options> on to the assembler
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor
  -Wl,<options>            Pass comma-separated <options> on to the linker
  -Xassembler <arg>        Pass <arg> on to the assembler
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor
  -Xlinker <arg>           Pass <arg> on to the linker
  -save-temps              Do not delete intermediate files
  -save-temps=<arg>        Do not delete intermediate files
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components
  -pipe                    Use pipes rather than intermediate files
  -time                    Time the execution of each subprocess
  -specs=<file>            Override built-in specs with the contents of <file>
  -std=<standard>          Assume that the input sources are for <standard>
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries
  -B <directory>           Add <directory> to the compiler's search paths
  -v                       Display the programs invoked by the compiler
  -###                     Like -v but options quoted and commands not executed
  -E                       Preprocess only; do not compile, assemble or link
  -S                       Compile only; do not assemble or link
  -c                       Compile and assemble, but do not link
  -o <file>                Place the output into <file>
  -pie                     Create a position independent executable
  -shared                  Create a shared library
  -x <language>            Specify the language of the following input files
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gfortran-mp-4.9.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://trac.macports.org/newticket>.
                            Trying FC compiler flag -fPIC
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -fPIC -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid FC linker flag -fPIC
                            Adding FC compiler flag -fPIC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -fPIC
                              Popping language FC
TEST checkLargeFileIO from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1032)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1032)
TEST checkArchiver from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1131)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1131)
  Check that the archiver exists and can make a library usable by the compiler
                              Pushing language C
Executing: ar -V
Executing: ar -V
                                  Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /opt/local/bin/ar...found
                                Defined make macro "AR" to "/opt/local/bin/ar"
Checking for program /opt/local/bin/ranlib...found
                                Defined make macro "RANLIB" to "/opt/local/bin/ranlib -c"
Executing: /opt/local/bin/ar cr /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconf1.a /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conf1.o
Executing: /opt/local/bin/ranlib -c /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconf1.a
Possible ERROR while running compiler:
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:6:26: warning: if statement has empty body [-Wempty-body]
  int b = foo(1);  if (b);
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:6:26: note: put the semicolon on a separate line to silence this warning
1 warning generated.
Source:
extern int foo(int);
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -lconf1
                              Defined make macro "AR_FLAGS" to "cr"
                              Defined make macro "AR_LIB_SUFFIX" to "a"
                              Popping language C
TEST checkSharedLinker from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1242)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1242)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Darwin
                            Checking shared linker /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc using flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress']
Checking for program /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc...found
                                Defined make macro "LD_SHARED" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc"
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -dynamiclib -single_module -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -dynamiclib -single_module
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -undefined dynamic_lookup -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -undefined dynamic_lookup
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -multiply_defined suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -multiply_defined suppress
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:7:8: warning: if statement has empty body [-Wempty-body]
if(ret);;
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:7:8: note: put the semicolon on a separate line to silence this warning
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o  -L/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -lconftest
                            Using shared linker /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc with flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress'] and library extension dylib
Executing: uname -s
stdout: Darwin
TEST checkLinkerMac from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1300)
TESTING: checkLinkerMac from config.setCompilers(config/BuildSystem/config/setCompilers.py:1300)
  Tests some Apple Mac specific linker flags
                              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid C linker flag -Wl,-search_paths_first
                              Popping language C
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid Cxx linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid Cxx linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid Cxx linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid Cxx linker flag -Wl,-search_paths_first
                              Pushing language FC
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid FC linker flag -Wl,-multiply_defined,suppress
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined -Wl,suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid FC linker flag -Wl,-multiply_defined -Wl,suppress
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-commons,use_dylibs -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid FC linker flag -Wl,-commons,use_dylibs
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o
                              Valid FC linker flag -Wl,-search_paths_first
                              Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1320)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1320)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
                              Pushing language C
Executing: uname -s
stdout: Darwin
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -V
                              Popping language C
Executing: uname -s
stdout: Darwin
                              Pushing language FC
Executing: uname -s
stdout: Darwin
                              Popping language FC
TEST checkLibC from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1355)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1355)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                                      Pushing language C
                                      Popping language C
                            Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1404)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1404)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/usr/include/dlfcn.h" 1 3 4
# 37 "/usr/include/dlfcn.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 38 "/usr/include/dlfcn.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdbool.h" 1 3 4
# 41 "/usr/include/dlfcn.h" 2 3 4
# 42 "/usr/include/dlfcn.h" 2 3 4
typedef struct dl_info {
        const char *dli_fname;
        void *dli_fbase;
        const char *dli_sname;
        void *dli_saddr;
} Dl_info;
extern int dladdr(const void *, Dl_info *);
extern int dlclose(void * __handle);
extern char * dlerror(void);
extern void * dlopen(const char * __path, int __mode);
extern void * dlsym(void * __handle, const char * __symbol);
extern _Bool dlopen_preflight(const char* __path) __attribute__((availability(macosx,introduced=10.5)));
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
                                Defined "HAVE_DLFCN_H" to "1"
                                Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
                                  Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
                                          Pushing language C
                                          Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -ldl
                                  Defined "HAVE_LIBDL" to "1"
                                  Popping language C
                              Adding ['dl'] to LIBS
Executing: uname -s
stdout: Darwin
                            Checking dynamic linker /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc using flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress']
                                Defined make macro "DYNAMICLINKER" to "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc"
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -dynamiclib -single_module -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -undefined dynamic_lookup -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -multiply_defined suppress -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib  -dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:11:3: warning: implicitly declaring library function 'printf' with type 'int (const char *, ...)'
  printf("Could not load symbol\n");
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:11:3: note: please include the header <stdio.h> or explicitly provide a declaration for 'printf'
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/libconftest.dylib", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  return -1;
if ((*foo)()) {
  printf("Invalid return from foo()\n");
  return -1;
if (dlclose(handle)) {
  printf("Could not close library\n");
  return -1;
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -ldl
                            Using dynamic linker /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc with flags ['-dynamiclib -single_module', '-undefined dynamic_lookup', '-multiply_defined suppress'] and library extension dylib
TEST output from config.setCompilers(/Users/patrick/program/petsc/config/BuildSystem/config/setCompilers.py:1450)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1450)
  Output module data as defines and substitutions
                              Substituting "CC" with "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc"
                              Substituting "CFLAGS" with " -fPIC"
                              Defined make macro "CC_LINKER_SLFLAG" to "-L"
                              Substituting "CPP" with "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E"
                              Substituting "CPPFLAGS" with ""
                              Substituting "CXX" with "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx"
                              Substituting "CXX_CXXFLAGS" with " -fPIC"
                              Substituting "CXXFLAGS" with ""
                              Substituting "CXX_LINKER_SLFLAG" with "-L"
                              Substituting "CXXCPP" with "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -E"
                              Substituting "CXXCPPFLAGS" with ""
                              Substituting "FC" with "/Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90"
                              Substituting "FFLAGS" with " -fPIC"
                              Defined make macro "FC_LINKER_SLFLAG" to "-L"
                              Substituting "LDFLAGS" with ""
                              Substituting "LIBS" with "-ldl "
                              Substituting "SHARED_LIBRARY_FLAG" with "-dynamiclib -single_module -undefined dynamic_lookup -multiply_defined suppress"
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.c
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.c:5:18: warning: unused variable 'x' [-Wunused-variable]
float * restrict x;;
Source:
int main() {
  return 0;
                            Defined "C_RESTRICT" to "restrict"
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
                            Defined "C_STATIC_INLINE" to "static inline"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
  return 0;
                                    Pushing language C
                                    Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl
                            Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
  return 0;
                                    Pushing language C
                                    Popping language C
                            Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
  return 0;
                                    Pushing language C
                                    Popping language C
                            Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
  return 0;
                                    Pushing language C
                                    Popping language C
                            Defined "HAVE_RTLD_GLOBAL" to "1"
Successful compile:
Source:
int main() {
  return 0;
                                  Pushing language C
                                  Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl
stdout: mpicc for MPICH version 3.1.3
Possible ERROR while running linker:
stdout:
mpicc for MPICH version 3.1.3stderr:
Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
Target: x86_64-apple-darwin13.4.0
Thread model: posix
 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -dynamic -arch x86_64 -macosx_version_min 10.9.0 -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -flat_namespace -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lmpi -lpmpi -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
                              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
      program main
      end
                                          Pushing language FC
                                          Popping language FC
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest
                              Popping language FC
                            Pushing language C
                          Trying C compiler flag -MMD -MP
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -MMD -MP  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
                            Defined make macro "C_DEPFLAGS" to "-MMD -MP"
                            Popping language C
                            Pushing language Cxx
                          Trying Cxx compiler flag -MMD -MP
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -fPIC -MMD -MP   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
                            Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
                            Popping language Cxx
                            Pushing language FC
                          Trying FC compiler flag -MMD -MP
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -MMD -MP  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
                            Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
                            Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc
Possible ERROR while running compiler: exit code 256
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc:5:17: error: expected ';' at end of declaration
1 error generated.
Source:
int main() {
  return 0;
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.cc:5:23: warning: unused variable 'x' [-Wunused-variable]
float *  __restrict__ x;;
Source:
int main() {
  return 0;
                            Defined "CXX_RESTRICT" to " __restrict__"
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
                            Defined "HAVE_CXX_NAMESPACE" to "1"
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing     -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
stderr:
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c:5:22: warning: private field 'i' is not used [-Wunused-private-field]
class somename { int i; };;
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
                            Defined "CXX_STATIC_INLINE" to "static inline"
Successful compile:
Source:
int main() {
  return 0;
                                  Pushing language CXX
                                  Popping language CXX
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stdout: mpicxx for MPICH version 3.1.3
stdout:
mpicxx for MPICH version 3.1.3stderr:
Thread model: posix
 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -dynamic -arch x86_64 -macosx_version_min 10.9.0 -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -flat_namespace -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -ldl -lmpi -lpmpi -lSystem -lclang_rt.osx -ldl -lmpicxx -lmpi -lpmpi -lc++ -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin/libclang_rt.osx.a
                              Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
                              Popping language C
                              Pushing language FC
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
      program main
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lclang_rt.osx -lmpicxx -lc++ -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                                          Pushing language FC
                                          Popping language FC
                              Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing     -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:32: error: unknown type name 'constexpr'
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:42: warning: variable templates are a C++1y extension [-Wc++1y-extensions]
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:43: error: expected ';' at end of declaration
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:51: error: unknown type name 'T'
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:5:44: error: C++ requires a type specifier for all declarations
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc:13:24: warning: unused variable 'x' [-Wunused-variable]
          const double x = dist(mt);
2 warnings and 4 errors generated.
Source:
          #include <random>
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
  return 0;
                            Rejecting compiler flag  due to nonzero status from link
PETSc Error: No output file produced
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      program main
      real*8 variable
      end
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confc.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
                            Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
Successful compile:
Source:
void d1_chk__(void){return;}
Successful compile:
Source:
      program main
       call d1_chk()
      end
                                      Pushing language FC
                                      Popping language FC
stderr:
Undefined symbols for architecture x86_64:
  "_d1_chk_", referenced from:
      _MAIN__ in conftest.o
     (maybe you meant: _d1_chk__)
ld: symbol(s) not found for architecture x86_64
                            Pushing language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC    /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
                            Popping language FC
                            Pushing language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -DTesting  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
                            Defined make macro "FC_DEFINE_FLAG" to "-D"
                            Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -V
Successful compile:
Source:
      program main
      end
                                  Pushing language FC
                                  Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
stdout: mpifort for MPICH version 3.1.3
stdout:
mpifort for MPICH version 3.1.3stderr:
Driving: gfortran-mp-4.9 -mmacosx-version-min=10.9.4 -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -Wl,-flat_namespace -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -v -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpifort -lmpi -lpmpi -l gfortran -shared-libgcc
Using built-in specs.
COLLECT_GCC=gfortran-mp-4.9
COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/lto-wrapper
Configured with: /opt/local/var/macports/build/_opt_mports_dports_lang_gcc49/gcc49/work/gcc-4.9.1/configure --prefix=/opt/local --build=x86_64-apple-darwin13 --enable-languages=c,c++,objc,obj-c++,lto,fortran,java --libdir=/opt/local/lib/gcc49 --includedir=/opt/local/include/gcc49 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-4.9 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-4.9 --with-gxx-include-dir=/opt/local/include/gcc49/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-cloog=/opt/local --enable-cloog-backend=isl --disable-cloog-version-check --enable-stage1-checking --disable-multilib --enable-lto --enable-libstdcxx-time --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --with-pkgversion='MacPorts gcc49 4.9.1_1'
Thread model: posix
gcc version 4.9.1 (MacPorts gcc49 4.9.1_1)
Reading specs from /opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-mmacosx-version-min=10.9.4' '-Wall' '-Wno-unused-variable' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-O0' '-o' '/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest' '-v' '-fPIC' '-L/Users/patrick/program/petsc/arch-darwin-double-debug/lib' '-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin' '-L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin' '-I' '/Users/patrick/program/petsc/arch-darwin-double-debug/include' '-I' '/Users/patrick/program/petsc/arch-darwin-double-debug/include' '-L/Users/patrick/program/petsc/arch-darwin-double-debug/lib' '-shared-libgcc' '-mtune=core2'
COMPILER_PATH=/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/libexec/gcc/x86_64-apple-darwin13/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/
LIBRARY_PATH=/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/:/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../../:/usr/lib/
 /opt/local/libexec/gcc/x86_64-apple-darwin13/4.9.1/collect2 -dynamic -arch x86_64 -macosx_version_min 10.9.4 -weak_reference_mismatches non-weak -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../.. -flat_namespace -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -lmpi -lpmpi -lSystem -lclang_rt.osx -lmpifort -lmpi -lpmpi -lgfortran -no_compact_unwind -lSystem -lgcc_ext.10.5 -lgcc -lquadmath -lm -lgcc_ext.10.5 -lgcc -lSystem -v -idsym
collect2 version 4.9.1
/opt/local/bin/ld -dynamic -arch x86_64 -macosx_version_min 10.9.4 -weak_reference_mismatches non-weak -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1/../../.. -flat_namespace -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first -multiply_defined suppress -multiply_defined suppress -commons use_dylibs -search_paths_first /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -lmpi -lpmpi -lSystem -lclang_rt.osx -lmpifort -lmpi -lpmpi -lgfortran -no_compact_unwind -lSystem -lgcc_ext.10.5 -lgcc -lquadmath -lm -lgcc_ext.10.5 -lgcc -lSystem -v
@(#)PROGRAM:ld  PROJECT:ld64-236.3
configured to support archs: i386 x86_64 x86_64h armv6 armv7 armv7s armv7m arm64
Library search paths:
	/usr/lib
	/usr/local/lib
Framework search paths:
	/Library/Frameworks/
	/System/Library/Frameworks/
 /opt/local/bin/nm -n /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o
                              Pushing language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpifort -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
                                      Pushing language C
                                      Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpifort -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
                                          Pushing language C
                                          Popping language C
                              Popping language C
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpifort -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpifort -lgfortran -L/opt/local/lib/gcc49/gcc/x86_64-apple-darwin13/4.9.1 -L/opt/local/lib/gcc49 -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
                                      Pushing language FC
                                      Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/cxxobj.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confc.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                                    Pushing language FC
                                    Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
                            Defined "USING_F90" to "1"
Successful compile:
Source:
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
                                    Pushing language FC
                                    Popping language FC
                            Defined "USING_F2003" to "1"
Executing: uname -s
stdout: Darwin
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
  printf("arrays [%p %p %p]\n",a1,a2,a3);
  fflush(stdout);
  return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
  if ((p1 == p3) && (p1 != p2)) {
    printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
  } else {
    printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
    fflush(stdout);
    abort();
  return;
Successful compile:
Source:
      program main
      Interface
         Subroutine f90ptrtest(p1,p2,p3,i)
         integer, pointer :: p1(:,:)
         integer, pointer :: p2(:,:)
         integer, pointer :: p3(:,:)
         integer i
         End Subroutine
      End Interface
      integer, pointer :: ptr1(:,:),ptr2(:,:)
      integer, target  :: array(6:8,9:21)
      integer  in
      in   = 25
      ptr1 => array
      ptr2 => array
      call f90arraytest(ptr1,ptr2,ptr1,in)
      call f90ptrtest(ptr1,ptr2,ptr1,in)
      end
                                        Pushing language FC
                                        Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/fooobj.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Testing executable /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest to see if it can be run
Executing: /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest
stdout:
arrays [0x7fff57ccf900 0x7fff57ccf900 0x7fff57ccf900]
arrays [0x7fff57ccf8b0 0x7fff57ccf860 0x7fff57ccf8b0]
pointers do not match! [0x40 0x7fff57ccf900] [0x7fff57ccf700]
ERROR while running executable: Could not execute "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest":
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
#0  0x10830a3fc
#1  0x10830a91f
#2  0x7fff935d75a9
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                                    Pushing language FC
                                    Popping language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/configtest.o -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -module /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-module'
Source:
      module configtest
      integer testint
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -module:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-module:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir'
Source:
      module configtest
      integer testint
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -fmod=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
stderr:
gfortran-mp-4.9: error: unrecognized command line option '-fmod=/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir'
Source:
      module configtest
      integer testint
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -J/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/confdir  -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers/conftest.F
Successful compile:
Source:
      module configtest
      integer testint
TEST configureCompilerFlags from config.compilerFlags(/Users/patrick/program/petsc/config/BuildSystem/config/compilerFlags.py:71)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:71)
  Get the default compiler flags
                            Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc --version
stdout:
Thread model: posix
getCompilerVersion: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -show
stdout: clang -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpi -lpmpi
                                Defined make macro "MPICC_SHOW" to "clang -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpi -lpmpi"
                          Trying C compiler flag -Wall
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
                          Trying C compiler flag -Wwrite-strings
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
                          Trying C compiler flag -Wno-strict-aliasing
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
                          Trying C compiler flag -Wno-unknown-pragmas
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
                          Trying C compiler flag -g3
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g3
                          Trying C compiler flag -O0
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -O0
                            Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx --version
stdout:
Thread model: posix
getCompilerVersion: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn)
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -show
stdout: clang++ -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0 -fPIC -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpicxx -lmpi -lpmpi
                                Defined make macro "MPICXX_SHOW" to "clang++ -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0 -fPIC -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpicxx -lmpi -lpmpi"
                          Trying Cxx compiler flag -Wall
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
                          Trying Cxx compiler flag -Wwrite-strings
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall -Wwrite-strings   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
                          Trying Cxx compiler flag -Wno-strict-aliasing
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall -Wwrite-strings -Wno-strict-aliasing   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
                          Trying Cxx compiler flag -Wno-unknown-pragmas
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
                          Trying Cxx compiler flag -g
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
                          Trying Cxx compiler flag -O0
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicxx -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -O0   -fPIC   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O0
                            Pushing language FC
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 --version
stdout:
GNU Fortran (MacPorts gcc49 4.9.1_1) 4.9.1
Copyright (C) 2014 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
getCompilerVersion: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 GNU Fortran (MacPorts gcc49 4.9.1_1) 4.9.1
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -show
stdout: gfortran-mp-4.9 -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpifort -lmpi -lpmpi
                                Defined make macro "MPIFC_SHOW" to "gfortran-mp-4.9 -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0 -Wl,-flat_namespace -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -lmpifort -lmpi -lpmpi"
Executing: gfortran-mp-4.9 --version
stdout:
stdout:
                          Trying FC compiler flag -Wall
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
                          Trying FC compiler flag -Wno-unused-variable
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall -Wno-unused-variable   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-variable
                          Trying FC compiler flag -ffree-line-length-0
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
                          Trying FC compiler flag -Wno-unused-dummy-argument
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
                          Trying FC compiler flag -g
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
                          Trying FC compiler flag -O0
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpif90 -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers/conftest.F
Successful compile:
Source:
      program main
      end
Added FC compiler flag -O0
                            Popping language FC
        Not checking for library in Download MPICH: [] because no functions given to check for
TEST check from config.libraries(/Users/patrick/program/petsc/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            No functions to check for in library [] []
        Checking for headers Download MPICH: ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
TEST checkSharedLibrary from config.packages.MPICH(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:592)
TESTING: checkSharedLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:592)
  By default we don't care about checking if the library is shared
      Popping language C
TEST alternateConfigureLibrary from config.packages.OpenMPI(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:596)
  Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.yaml(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.valgrind(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:538)
TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:538)
  Find an installation and check if it can work with PETSc
        Checking for a functional valgrind
        Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
        Checking for headers Package specific search directory VALGRIND: ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
            Pushing language C
TEST checkInclude from config.headers(/Users/patrick/program/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['valgrind/valgrind.h'] in ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
              Checking include with compiler flags var CPPFLAGS ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -I/Users/patrick/program/petsc/arch-darwin-double-debug/include /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 170 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/confdefs.h" 1
# 2 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
# 1 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conffix.h" 1
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
Possible ERROR while running preprocessor: exit code 256
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 3 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2stderr:
/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'valgrind/valgrind.h' file not found
#include <valgrind/valgrind.h>
1 error generated.
Source:
Preprocess stderr before filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'valgrind/valgrind.h' file not found
1 error generated.
Preprocess stderr after filtering:/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c:3:10: fatal error: 'valgrind/valgrind.h' file not found#include <valgrind/valgrind.h>         ^1 error generated.:
            Popping language C
            Pushing language C
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
1 error generated.
Source:
1 error generated.
            Popping language C
        Checking for headers Package specific search directory VALGRIND: ['/usr/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
            Pushing language C
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
              Checking include with compiler flags var CPPFLAGS ['/usr/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -I/usr/local/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
1 error generated.
Source:
1 error generated.
            Popping language C
            Pushing language C
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
1 error generated.
Source:
1 error generated.
            Popping language C
        Checking for headers Package specific search directory VALGRIND: ['/opt/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
            Pushing language C
Checking for header files ['valgrind/valgrind.h'] in ['/opt/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
              Checking include with compiler flags var CPPFLAGS ['/opt/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -E  -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -I/opt/local/include -I/Users/patrick/program/petsc/arch-darwin-double-debug/include /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/opt/local/include/valgrind/valgrind.h" 1
# 95 "/opt/local/include/valgrind/valgrind.h"
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 1 3 4
# 30 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 3 4
typedef __builtin_va_list va_list;
# 48 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 96 "/opt/local/include/valgrind/valgrind.h" 2
# 390 "/opt/local/include/valgrind/valgrind.h"
typedef
   struct {
      unsigned long long int nraddr;
   OrigFn;
# 6111 "/opt/local/include/valgrind/valgrind.h"
typedef
   enum { VG_USERREQ__RUNNING_ON_VALGRIND = 0x1001,
          VG_USERREQ__DISCARD_TRANSLATIONS = 0x1002,
          VG_USERREQ__CLIENT_CALL0 = 0x1101,
          VG_USERREQ__CLIENT_CALL1 = 0x1102,
          VG_USERREQ__CLIENT_CALL2 = 0x1103,
          VG_USERREQ__CLIENT_CALL3 = 0x1104,
          VG_USERREQ__COUNT_ERRORS = 0x1201,
          VG_USERREQ__GDB_MONITOR_COMMAND = 0x1202,
          VG_USERREQ__MALLOCLIKE_BLOCK = 0x1301,
          VG_USERREQ__RESIZEINPLACE_BLOCK = 0x130b,
          VG_USERREQ__FREELIKE_BLOCK = 0x1302,
          VG_USERREQ__CREATE_MEMPOOL = 0x1303,
          VG_USERREQ__DESTROY_MEMPOOL = 0x1304,
          VG_USERREQ__MEMPOOL_ALLOC = 0x1305,
          VG_USERREQ__MEMPOOL_FREE = 0x1306,
          VG_USERREQ__MEMPOOL_TRIM = 0x1307,
          VG_USERREQ__MOVE_MEMPOOL = 0x1308,
          VG_USERREQ__MEMPOOL_CHANGE = 0x1309,
          VG_USERREQ__MEMPOOL_EXISTS = 0x130a,
# 6156 "/opt/local/include/valgrind/valgrind.h"
          VG_USERREQ__PRINTF = 0x1401,
          VG_USERREQ__PRINTF_BACKTRACE = 0x1402,
          VG_USERREQ__PRINTF_VALIST_BY_REF = 0x1403,
          VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF = 0x1404,
          VG_USERREQ__STACK_REGISTER = 0x1501,
          VG_USERREQ__STACK_DEREGISTER = 0x1502,
          VG_USERREQ__STACK_CHANGE = 0x1503,
          VG_USERREQ__LOAD_PDB_DEBUGINFO = 0x1601,
          VG_USERREQ__MAP_IP_TO_SRCLOC = 0x1701,
          VG_USERREQ__CHANGE_ERR_DISABLEMENT = 0x1801,
          VG_USERREQ__VEX_INIT_FOR_IRI = 0x1901
   } Vg_ClientRequest;
# 6216 "/opt/local/include/valgrind/valgrind.h"
static int VALGRIND_PRINTF(const char *format, ...)
   __attribute__((format(__printf__, 1, 2), __unused__));
static int
   unsigned long _qzz_res;
   va_list vargs;
   __builtin_va_start(vargs, format);
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; });
   __builtin_va_end(vargs);
   return (int)_qzz_res;
static int VALGRIND_PRINTF_BACKTRACE(const char *format, ...)
static int
   va_list vargs;
   _qzz_res = __extension__ ({ volatile unsigned long long int _zzq_args[6]; volatile unsigned long long int _zzq_result; _zzq_args[0] = (unsigned long long int)(VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF); _zzq_args[1] = (unsigned long long int)((unsigned long)format); _zzq_args[2] = (unsigned long long int)((unsigned long)&vargs); _zzq_args[3] = (unsigned long long int)(0); _zzq_args[4] = (unsigned long long int)(0); _zzq_args[5] = (unsigned long long int)(0); __asm__ volatile("rolq $3,  %%rdi ; rolq $13, %%rdi\n\t" "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" "xchgq %%rbx,%%rbx" : "=d" (_zzq_result) : "a" (&_zzq_args[0]), "0" (0) : "cc", "memory" ); _zzq_result; });
# 4 "/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['valgrind/valgrind.h'] in ['/opt/local/include', '/Users/patrick/program/petsc/arch-darwin-double-debug/include']
            Popping language C
                All intermediate test results are stored in /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.valgrind
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.valgrind/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.valgrind -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  -I/opt/local/include /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.valgrind/conftest.c
Successful compile:
Source:
int main() {
RUNNING_ON_VALGRIND;
  return 0;
      Popping language C
TEST alternateConfigureLibrary from config.packages.threadcomm(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.threadcomm(config/BuildSystem/config/package.py:596)
TEST alternateConfigureLibrary from config.packages.tetgen(/Users/patrick/program/petsc/config/BuildSystem/config/package.py:596)
TESTING: alternateConfigureLibrary from config.packages.tetgen(config/BuildSystem/config/package.py:596)
      Pushing language C
TEST configureLibrary from config.packages.ssl(/Users/patrick/program/petsc/config/BuildSystem/config/packages/ssl.py:26)
TESTING: configureLibrary from config.packages.ssl(config/BuildSystem/config/packages/ssl.py:26)
          Checking for a functional ssl
          Checking for library in Package specific search directory SSL: ['libssl.a', 'libcrypto.a']
              Checking for functions [SSLv23_method] in library ['libssl.a', 'libcrypto.a'] []
                Pushing language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc -c -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.closure -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.headers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.cacheDetails -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.getResidentSetSize -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.featureTestMacros -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.types -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.utilities.missing -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.functions -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.packages.valgrind -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.atomics -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.compilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.setCompilers -I/var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char SSLv23_method();
static void _check_SSLv23_method() { SSLv23_method(); }
int main() {
_check_SSLv23_method();;
  return 0;
                        Pushing language C
                        Popping language C
Executing: /Users/patrick/program/petsc/arch-darwin-double-debug/bin/mpicc  -o /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest  -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0 /var/folders/y6/qgc09ys10yz14byp_sb2ll340000gn/T/petsc-zW5y34/config.libraries/conftest.o  -lssl -lcrypto -L/Users/patrick/program/petsc/arch-darwin-double-debug/lib -ldl -lmpi -lpmpi -lSystem -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
                Defined "HAVE_LIBSSL" to "1"
                Defined "HAVE_LIBCRYPTO" to "1"
                Popping language C
          Checking for headers Package specific search directory SSL: ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
              Pushing language C
Checking for header files ['openssl/ssl.h'] in ['/Users/patrick/program/petsc/arch-darwin-double-debug/include']
stdout:
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 1 "<built-in>" 2
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 173 "/usr/include/openssl/ssl.h" 3 4
# 1 "/usr/include/AvailabilityMacros.h" 1 3 4
# 220 "/usr/include/AvailabilityMacros.h" 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 148 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 149 "/usr/include/Availability.h" 2 3 4
# 221 "/usr/include/AvailabilityMacros.h" 2 3 4
# 174 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 176 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/comp.h" 1 3 4
# 1 "/usr/include/openssl/crypto.h" 1 3 4
# 122 "/usr/include/openssl/crypto.h" 3 4
# 1 "/usr/include/stdlib.h" 1 3 4
# 63 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 484 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 485 "/usr/include/sys/cdefs.h" 2 3 4
# 550 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 551 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 58 "/usr/include/sys/_types.h" 3 4
struct __darwin_pthread_handler_rec
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_cond_t { long __sig; char __opaque[40]; };
struct _opaque_pthread_condattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_mutex_t { long __sig; char __opaque[56]; };
struct _opaque_pthread_mutexattr_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_once_t { long __sig; char __opaque[8]; };
struct _opaque_pthread_rwlock_t { long __sig; char __opaque[192]; };
struct _opaque_pthread_rwlockattr_t { long __sig; char __opaque[16]; };
struct _opaque_pthread_t { long __sig; struct __darwin_pthread_handler_rec *__cleanup_stack; char __opaque[1168]; };
# 94 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef struct _opaque_pthread_attr_t
   __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t
   __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t
   __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t
   __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t
   __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t
   __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t
   __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t
   __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t
   *__darwin_pthread_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 82 "/usr/include/sys/signal.h" 2 3 4
# 145 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 148 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 153 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 154 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 266 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 328 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 345 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 364 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 387 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 1 3 4
# 64 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 65 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdint.h" 2 3 4
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 151 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 162 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 190 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
# 290 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 317 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 347 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit") ;
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit") ;
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 124 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 125 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait") ;
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid") ;
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid") ;
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (*)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *, const void *, size_t,
     size_t, int (*)(const void *, const void *));
void *calloc(size_t, size_t);
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t);
int mblen(const char *, size_t);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **, size_t, size_t) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *, size_t, size_t,
int rand(void);
void *realloc(void *, size_t);
void srand(unsigned);
double strtod(const char *, char **) __asm("_" "strtod") ;
float strtof(const char *, char **) __asm("_" "strtof") ;
long strtol(const char *, char **, int);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *, char **, int);
unsigned long
  strtoul(const char *, char **, int);
unsigned long long
  strtoull(const char *, char **, int);
int system(const char *) __asm("_" "system") ;
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]);
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void);
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void);
long nrand48(unsigned short[3]);
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv") ;
long random(void);
int rand_r(unsigned *);
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char *, const char *, int) __asm("_" "setenv") ;
void setkey(const char *) __asm("_" "setkey") ;
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv") ;
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
typedef unsigned char u_int8_t;
typedef unsigned short u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long long u_int64_t;
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 1 "/usr/include/sys/_types/___offsetof.h" 1 3 4
# 114 "/usr/include/i386/types.h" 2 3 4
# 36 "/usr/include/machine/types.h" 2 3 4
# 239 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 241 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 242 "/usr/include/stdlib.h" 2 3 4
u_int32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int );
void arc4random_buf(void * , size_t ) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
u_int32_t
  arc4random_uniform(u_int32_t ) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *, const void *, size_t,
     size_t, int (^)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *, size_t, size_t,
int heapsort_b(void *, size_t, size_t,
int mergesort(void *, size_t, size_t,
int mergesort_b(void *, size_t, size_t,
void psort(void *, size_t, size_t,
     int (*)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *, size_t, size_t,
void psort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *, size_t, size_t,
void qsort_r(void *, size_t, size_t, void *,
     int (*)(void *, const void *, const void *));
int radixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void setprogname(const char *);
int sradixsort(const unsigned char **, int, const unsigned char *,
     unsigned);
void sranddev(void);
void srandomdev(void);
void *reallocf(void *, size_t);
long long
  strtoq(const char *, char **, int);
unsigned long long
  strtouq(const char *, char **, int);
extern char *suboptarg;
void *valloc(size_t);
# 123 "/usr/include/openssl/crypto.h" 2 3 4
# 125 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/stdio.h" 1 3 4
# 71 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/sys/_types/_va_list.h" 1 3 4
# 31 "/usr/include/sys/_types/_va_list.h" 3 4
typedef __darwin_va_list va_list;
# 72 "/usr/include/stdio.h" 2 3 4
typedef __darwin_off_t fpos_t;
# 86 "/usr/include/stdio.h" 3 4
struct __sbuf {
 unsigned char *_base;
 int _size;
struct __sFILEX;
# 120 "/usr/include/stdio.h" 3 4
typedef struct __sFILE {
 unsigned char *_p;
 int _r;
 int _w;
 short _flags;
 short _file;
 struct __sbuf _bf;
 int _lbfsize;
 void *_cookie;
 int (*_close)(void *);
 int (*_read) (void *, char *, int);
 fpos_t (*_seek) (void *, fpos_t, int);
 int (*_write)(void *, const char *, int);
 struct __sbuf _ub;
 struct __sFILEX *_extra;
 int _ur;
 unsigned char _ubuf[3];
 unsigned char _nbuf[1];
 struct __sbuf _lb;
 int _blksize;
 fpos_t _offset;
} FILE;
extern FILE *__stdinp;
extern FILE *__stdoutp;
extern FILE *__stderrp;
# 229 "/usr/include/stdio.h" 3 4
void clearerr(FILE *);
int fclose(FILE *);
int feof(FILE *);
int ferror(FILE *);
int fflush(FILE *);
int fgetc(FILE *);
int fgetpos(FILE * restrict, fpos_t *);
char *fgets(char * restrict, int, FILE *);
FILE *fopen(const char * restrict, const char * restrict) __asm("_" "fopen");
int fprintf(FILE * restrict, const char * restrict, ...) __attribute__((__format__ (__printf__, 2, 3)));
int fputc(int, FILE *);
int fputs(const char * restrict, FILE * restrict) __asm("_" "fputs") ;
size_t fread(void * restrict, size_t, size_t, FILE * restrict);
FILE *freopen(const char * restrict, const char * restrict,
                 FILE * restrict) __asm("_" "freopen") ;
int fscanf(FILE * restrict, const char * restrict, ...) __attribute__((__format__ (__scanf__, 2, 3)));
int fseek(FILE *, long, int);
int fsetpos(FILE *, const fpos_t *);
long ftell(FILE *);
size_t fwrite(const void * restrict, size_t, size_t, FILE * restrict) __asm("_" "fwrite") ;
int getc(FILE *);
int getchar(void);
char *gets(char *);
void perror(const char *);
int printf(const char * restrict, ...) __attribute__((__format__ (__printf__, 1, 2)));
int putc(int, FILE *);
int putchar(int);
int puts(const char *);
int remove(const char *);
int rename (const char *, const char *);
void rewind(FILE *);
int scanf(const char * restrict, ...) __attribute__((__format__ (__scanf__, 1, 2)));
void setbuf(FILE * restrict, char * restrict);
int setvbuf(FILE * restrict, char * restrict, int, size_t);
int sprintf(char * restrict, const char * restrict, ...) __attribute__((__format__ (__printf__, 2, 3)));
int sscanf(const char * restrict, const char * restrict, ...) __attribute__((__format__ (__scanf__, 2, 3)));
FILE *tmpfile(void);
__attribute__((deprecated("This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of tmpnam(3), it is highly recommended that you use mkstemp(3) instead.")))
char *tmpnam(char *);
int ungetc(int, FILE *);
int vfprintf(FILE * restrict, const char * restrict, va_list) __attribute__((__format__ (__printf__, 2, 0)));
int vprintf(const char * restrict, va_list) __attribute__((__format__ (__printf__, 1, 0)));
int vsprintf(char * restrict, const char * restrict, va_list) __attribute__((__format__ (__printf__, 2, 0)));
# 294 "/usr/include/stdio.h" 3 4
char *ctermid(char *);
FILE *fdopen(int, const char *) __asm("_" "fdopen");
int fileno(FILE *);
# 313 "/usr/include/stdio.h" 3 4
int pclose(FILE *);
FILE *popen(const char *, const char *) __asm("_" "popen");
# 335 "/usr/include/stdio.h" 3 4
int __srget(FILE *);
int __svfscanf(FILE *, const char *, va_list) __attribute__((__format__ (__scanf__, 2, 0)));
int __swbuf(int, FILE *);
# 346 "/usr/include/stdio.h" 3 4
inline __attribute__ ((__always_inline__)) int __sputc(int _c, FILE *_p) {
 if (--_p->_w >= 0 || (_p->_w >= _p->_lbfsize && (char)_c != '\n'))
  return (*_p->_p++ = _c);
 else
  return (__swbuf(_c, _p));
# 372 "/usr/include/stdio.h" 3 4
void flockfile(FILE *);
int ftrylockfile(FILE *);
void funlockfile(FILE *);
int getc_unlocked(FILE *);
int getchar_unlocked(void);
int putc_unlocked(int, FILE *);
int putchar_unlocked(int);
int getw(FILE *);
int putw(int, FILE *);
__attribute__((deprecated("This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of tempnam(3), it is highly recommended that you use mkstemp(3) instead.")))
char *tempnam(const char *, const char *) __asm("_" "tempnam") ;
# 409 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/sys/_types/_off_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_off_t.h" 3 4
typedef __darwin_off_t off_t;
# 410 "/usr/include/stdio.h" 2 3 4
int fseeko(FILE *, off_t, int);
off_t ftello(FILE *);
int snprintf(char * restrict, size_t, const char * restrict, ...) __attribute__((__format__ (__printf__, 3, 4)));
int vfscanf(FILE * restrict, const char * restrict, va_list) __attribute__((__format__ (__scanf__, 2, 0)));
int vscanf(const char * restrict, va_list) __attribute__((__format__ (__scanf__, 1, 0)));
int vsnprintf(char * restrict, size_t, const char * restrict, va_list) __attribute__((__format__ (__printf__, 3, 0)));
int vsscanf(const char * restrict, const char * restrict, va_list) __attribute__((__format__ (__scanf__, 2, 0)));
# 434 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/sys/_types/_ssize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ssize_t.h" 3 4
typedef __darwin_ssize_t ssize_t;
# 435 "/usr/include/stdio.h" 2 3 4
int dprintf(int, const char * restrict, ...) __attribute__((__format__ (__printf__, 2, 3))) __attribute__((availability(macosx,introduced=10.7)));
int vdprintf(int, const char * restrict, va_list) __attribute__((__format__ (__printf__, 2, 0))) __attribute__((availability(macosx,introduced=10.7)));
ssize_t getdelim(char ** restrict, size_t * restrict, int, FILE * restrict) __attribute__((availability(macosx,introduced=10.7)));
ssize_t getline(char ** restrict, size_t * restrict, FILE * restrict) __attribute__((availability(macosx,introduced=10.7)));
# 450 "/usr/include/stdio.h" 3 4
extern const int sys_nerr;
extern const char *const sys_errlist[];
int asprintf(char ** restrict, const char * restrict, ...) __attribute__((__format__ (__printf__, 2, 3)));
char *ctermid_r(char *);
char *fgetln(FILE *, size_t *);
const char *fmtcheck(const char *, const char *);
int fpurge(FILE *);
void setbuffer(FILE *, char *, int);
int setlinebuf(FILE *);
int vasprintf(char ** restrict, const char * restrict, va_list) __attribute__((__format__ (__printf__, 2, 0)));
FILE *zopen(const char *, const char *, int);
FILE *funopen(const void *,
                 int (*)(void *, char *, int),
                 int (*)(void *, const char *, int),
                 fpos_t (*)(void *, fpos_t, int),
                 int (*)(void *));
# 490 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/secure/_stdio.h" 1 3 4
# 31 "/usr/include/secure/_stdio.h" 3 4
# 1 "/usr/include/secure/_common.h" 1 3 4
# 32 "/usr/include/secure/_stdio.h" 2 3 4
# 42 "/usr/include/secure/_stdio.h" 3 4
extern int __sprintf_chk (char * restrict, int, size_t,
     const char * restrict, ...);
# 52 "/usr/include/secure/_stdio.h" 3 4
extern int __snprintf_chk (char * restrict, size_t, int, size_t,
extern int __vsprintf_chk (char * restrict, int, size_t,
      const char * restrict, va_list);
extern int __vsnprintf_chk (char * restrict, size_t, int, size_t,
# 491 "/usr/include/stdio.h" 2 3 4
# 128 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/stack.h" 1 3 4
# 68 "/usr/include/openssl/stack.h" 3 4
typedef struct stack_st
 int num;
 char **data;
 int sorted;
 int num_alloc;
 int (*comp)(const char * const *, const char * const *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } STACK;
int sk_num(const STACK *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_value(const STACK *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_set(STACK *, int, char *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *sk_new(int (*cmp)(const char * const *, const char * const *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *sk_new_null(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void sk_free(STACK *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void sk_pop_free(STACK *st, void (*func)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_insert(STACK *sk,char *data,int where) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_delete(STACK *st,int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_delete_ptr(STACK *st, char *p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_find(STACK *st,char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_find_ex(STACK *st,char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_push(STACK *st,char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_unshift(STACK *st,char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_shift(STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *sk_pop(STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void sk_zero(STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*sk_set_cmp_func(STACK *sk, int (*c)(const char * const *,
   const char * const *)))
STACK *sk_dup(STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void sk_sort(STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int sk_is_sorted(const STACK *st) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 131 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/safestack.h" 1 3 4
# 132 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/opensslv.h" 1 3 4
# 133 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/ossl_typ.h" 1 3 4
# 58 "/usr/include/openssl/ossl_typ.h" 3 4
# 59 "/usr/include/openssl/ossl_typ.h" 2 3 4
# 79 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct asn1_string_st ASN1_INTEGER;
typedef struct asn1_string_st ASN1_ENUMERATED;
typedef struct asn1_string_st ASN1_BIT_STRING;
typedef struct asn1_string_st ASN1_OCTET_STRING;
typedef struct asn1_string_st ASN1_PRINTABLESTRING;
typedef struct asn1_string_st ASN1_T61STRING;
typedef struct asn1_string_st ASN1_IA5STRING;
typedef struct asn1_string_st ASN1_GENERALSTRING;
typedef struct asn1_string_st ASN1_UNIVERSALSTRING;
typedef struct asn1_string_st ASN1_BMPSTRING;
typedef struct asn1_string_st ASN1_UTCTIME;
typedef struct asn1_string_st ASN1_TIME;
typedef struct asn1_string_st ASN1_GENERALIZEDTIME;
typedef struct asn1_string_st ASN1_VISIBLESTRING;
typedef struct asn1_string_st ASN1_UTF8STRING;
typedef int ASN1_BOOLEAN;
typedef int ASN1_NULL;
# 110 "/usr/include/openssl/ossl_typ.h" 3 4
typedef struct bignum_st BIGNUM;
typedef struct bignum_ctx BN_CTX;
typedef struct bn_blinding_st BN_BLINDING;
typedef struct bn_mont_ctx_st BN_MONT_CTX;
typedef struct bn_recp_ctx_st BN_RECP_CTX;
typedef struct bn_gencb_st BN_GENCB;
typedef struct buf_mem_st BUF_MEM;
typedef struct evp_cipher_st EVP_CIPHER;
typedef struct evp_cipher_ctx_st EVP_CIPHER_CTX;
typedef struct env_md_st EVP_MD;
typedef struct env_md_ctx_st EVP_MD_CTX;
typedef struct evp_pkey_st EVP_PKEY;
typedef struct dh_st DH;
typedef struct dh_method DH_METHOD;
typedef struct dsa_st DSA;
typedef struct dsa_method DSA_METHOD;
typedef struct rsa_st RSA;
typedef struct rsa_meth_st RSA_METHOD;
typedef struct rand_meth_st RAND_METHOD;
typedef struct ecdh_method ECDH_METHOD;
typedef struct ecdsa_method ECDSA_METHOD;
typedef struct x509_st X509;
typedef struct X509_algor_st X509_ALGOR;
typedef struct X509_crl_st X509_CRL;
typedef struct X509_name_st X509_NAME;
typedef struct x509_store_st X509_STORE;
typedef struct x509_store_ctx_st X509_STORE_CTX;
typedef struct ssl_st SSL;
typedef struct ssl_ctx_st SSL_CTX;
typedef struct v3_ext_ctx X509V3_CTX;
typedef struct conf_st CONF;
typedef struct store_st STORE;
typedef struct store_method_st STORE_METHOD;
typedef struct ui_st UI;
typedef struct ui_method_st UI_METHOD;
typedef struct st_ERR_FNS ERR_FNS;
typedef struct engine_st ENGINE;
typedef struct X509_POLICY_NODE_st X509_POLICY_NODE;
typedef struct X509_POLICY_LEVEL_st X509_POLICY_LEVEL;
typedef struct X509_POLICY_TREE_st X509_POLICY_TREE;
typedef struct X509_POLICY_CACHE_st X509_POLICY_CACHE;
typedef struct crypto_ex_data_st CRYPTO_EX_DATA;
typedef int CRYPTO_EX_new(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
     int idx, long argl, void *argp);
typedef void CRYPTO_EX_free(void *parent, void *ptr, CRYPTO_EX_DATA *ad,
typedef int CRYPTO_EX_dup(CRYPTO_EX_DATA *to, CRYPTO_EX_DATA *from, void *from_d,
typedef struct ocsp_req_ctx_st OCSP_REQ_CTX;
typedef struct ocsp_response_st OCSP_RESPONSE;
typedef struct ocsp_responder_id_st OCSP_RESPID;
# 134 "/usr/include/openssl/crypto.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 58 "/usr/include/openssl/symhacks.h" 3 4
# 59 "/usr/include/openssl/symhacks.h" 2 3 4
# 142 "/usr/include/openssl/crypto.h" 2 3 4
# 173 "/usr/include/openssl/crypto.h" 3 4
typedef struct openssl_item_st
 int code;
 void *value;
 size_t value_size;
 size_t *value_length;
 } OPENSSL_ITEM;
# 262 "/usr/include/openssl/crypto.h" 3 4
typedef struct
 int references;
 struct CRYPTO_dynlock_value *data;
 } CRYPTO_dynlock;
# 289 "/usr/include/openssl/crypto.h" 3 4
typedef struct bio_st BIO_dummy;
 STACK *sk;
 int dummy;
typedef struct crypto_ex_data_func_st
 long argl;
 void *argp;
 CRYPTO_EX_new *new_func;
 CRYPTO_EX_free *free_func;
 CRYPTO_EX_dup *dup_func;
 } CRYPTO_EX_DATA_FUNCS;
# 352 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_malloc_debug_init(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_mem_ctrl(int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_is_mem_check_on(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 382 "/usr/include/openssl/crypto.h" 3 4
const char *SSLeay_version(int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long SSLeay(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OPENSSL_issetugid(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef struct st_CRYPTO_EX_DATA_IMPL CRYPTO_EX_DATA_IMPL;
const CRYPTO_EX_DATA_IMPL *CRYPTO_get_ex_data_implementation(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_set_ex_data_implementation(const CRYPTO_EX_DATA_IMPL *i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_ex_data_new_class(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_get_ex_new_index(int class_index, long argl, void *argp,
  CRYPTO_EX_new *new_func, CRYPTO_EX_dup *dup_func,
  CRYPTO_EX_free *free_func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_new_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_dup_ex_data(int class_index, CRYPTO_EX_DATA *to,
  CRYPTO_EX_DATA *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_free_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_set_ex_data(CRYPTO_EX_DATA *ad, int idx, void *val) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *CRYPTO_get_ex_data(const CRYPTO_EX_DATA *ad,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_cleanup_all_ex_data(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_get_new_lockid(char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_num_locks(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_lock(int mode, int type,const char *file,int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_locking_callback(void (*func)(int mode,int type,
           const char *file,int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void (*CRYPTO_get_locking_callback(void))(int mode,int type,const char *file,
void CRYPTO_set_add_lock_callback(int (*func)(int *num,int mount,int type,
           const char *file, int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*CRYPTO_get_add_lock_callback(void))(int *num,int mount,int type,
void CRYPTO_set_id_callback(unsigned long (*func)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long (*CRYPTO_get_id_callback(void))(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long CRYPTO_thread_id(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *CRYPTO_get_lock_name(int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_add_lock(int *pointer,int amount,int type, const char *file,
void int_CRYPTO_set_do_dynlock_callback(
 void (*do_dynlock_cb)(int mode, int type, const char *file, int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_get_new_dynlockid(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_destroy_dynlockid(int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct CRYPTO_dynlock_value *CRYPTO_get_dynlock_value(int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_dynlock_create_callback(struct CRYPTO_dynlock_value *(*dyn_create_function)(const char *file, int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_dynlock_lock_callback(void (*dyn_lock_function)(int mode, struct CRYPTO_dynlock_value *l, const char *file, int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_dynlock_destroy_callback(void (*dyn_destroy_function)(struct CRYPTO_dynlock_value *l, const char *file, int line)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct CRYPTO_dynlock_value *(*CRYPTO_get_dynlock_create_callback(void))(const char *file,int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void (*CRYPTO_get_dynlock_lock_callback(void))(int mode, struct CRYPTO_dynlock_value *l, const char *file,int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void (*CRYPTO_get_dynlock_destroy_callback(void))(struct CRYPTO_dynlock_value *l, const char *file,int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_set_mem_functions(void *(*m)(size_t),void *(*r)(void *,size_t), void (*f)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_set_locked_mem_functions(void *(*m)(size_t), void (*free_func)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_set_mem_ex_functions(void *(*m)(size_t,const char *,int),
                                void *(*r)(void *,size_t,const char *,int),
int CRYPTO_set_locked_mem_ex_functions(void *(*m)(size_t,const char *,int),
int CRYPTO_set_mem_debug_functions(void (*m)(void *,int,const char *,int,int),
       void (*r)(void *,void *,int,const char *,int,int),
       void (*f)(void *,int),
       void (*so)(long),
       long (*go)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_mem_info_functions(
 int (*push_info_fn)(const char *info, const char *file, int line),
 int (*pop_info_fn)(void),
 int (*remove_all_info_fn)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_get_mem_functions(void *(**m)(size_t),void *(**r)(void *, size_t), void (**f)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_get_locked_mem_functions(void *(**m)(size_t), void (**f)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_get_mem_ex_functions(void *(**m)(size_t,const char *,int),
                                 void *(**r)(void *, size_t,const char *,int),
void CRYPTO_get_locked_mem_ex_functions(void *(**m)(size_t,const char *,int),
void CRYPTO_get_mem_debug_functions(void (**m)(void *,int,const char *,int,int),
        void (**r)(void *,void *,int,const char *,int,int),
        void (**f)(void *,int),
        void (**so)(long),
        long (**go)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *CRYPTO_malloc_locked(int num, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_free_locked(void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *CRYPTO_malloc(int num, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *CRYPTO_strdup(const char *str, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_free(void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *CRYPTO_realloc(void *addr,int num, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *CRYPTO_realloc_clean(void *addr,int old_num,int num,const char *file,
void *CRYPTO_remalloc(void *addr,int num, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OPENSSL_cleanse(void *ptr, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_set_mem_debug_options(long bits) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long CRYPTO_get_mem_debug_options(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_push_info_(const char *info, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_pop_info(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_remove_all_info(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 505 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_malloc(void *addr,int num,const char *file,int line,int before_p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_dbg_realloc(void *addr1,void *addr2,int num,const char *file,int line,int before_p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_dbg_free(void *addr,int before_p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 516 "/usr/include/openssl/crypto.h" 3 4
void CRYPTO_dbg_set_options(long bits) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long CRYPTO_dbg_get_options(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_dbg_push_info(const char *info, const char *file, int line) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_dbg_pop_info(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_dbg_remove_all_info(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_mem_leaks_fp(FILE *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void CRYPTO_mem_leaks(struct bio_st *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef void *CRYPTO_MEM_LEAK_CB(unsigned long, const char *, int, int, void *);
void CRYPTO_mem_leaks_cb(CRYPTO_MEM_LEAK_CB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OpenSSLDie(const char *file,int line,const char *assertion) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long *OPENSSL_ia32cap_loc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OPENSSL_isservice(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 594 "/usr/include/openssl/crypto.h" 3 4
void OPENSSL_init(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int CRYPTO_memcmp(const void *a, const void *b, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_CRYPTO_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 8 "/usr/include/openssl/comp.h" 2 3 4
typedef struct comp_ctx_st COMP_CTX;
typedef struct comp_method_st
 int type;
 const char *name;
 int (*init)(COMP_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*finish)(COMP_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*compress)(COMP_CTX *ctx,
   unsigned char *out, unsigned int olen,
   unsigned char *in, unsigned int ilen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*expand)(COMP_CTX *ctx,
 long (*ctrl)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*callback_ctrl)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } COMP_METHOD;
struct comp_ctx_st
 COMP_METHOD *meth;
 unsigned long compress_in;
 unsigned long compress_out;
 unsigned long expand_in;
 unsigned long expand_out;
 CRYPTO_EX_DATA ex_data;
COMP_CTX *COMP_CTX_new(COMP_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void COMP_CTX_free(COMP_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int COMP_compress_block(COMP_CTX *ctx, unsigned char *out, int olen,
 unsigned char *in, int ilen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int COMP_expand_block(COMP_CTX *ctx, unsigned char *out, int olen,
COMP_METHOD *COMP_rle(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
COMP_METHOD *COMP_zlib(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void COMP_zlib_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 64 "/usr/include/openssl/comp.h" 3 4
void ERR_load_COMP_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 179 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/bio.h" 1 3 4
# 64 "/usr/include/openssl/bio.h" 3 4
# 65 "/usr/include/openssl/bio.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 1 3 4
# 30 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 3 4
typedef __builtin_va_list va_list;
# 48 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stdarg.h" 3 4
typedef __builtin_va_list __gnuc_va_list;
# 70 "/usr/include/openssl/bio.h" 2 3 4
# 206 "/usr/include/openssl/bio.h" 3 4
typedef struct bio_st BIO;
void BIO_set_flags(BIO *b, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_test_flags(const BIO *b, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_clear_flags(BIO *b, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 260 "/usr/include/openssl/bio.h" 3 4
long (*BIO_get_callback(const BIO *b)) (struct bio_st *,int,const char *,int, long,long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_set_callback(BIO *b,
 long (*callback)(struct bio_st *,int,const char *,int, long,long)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *BIO_get_callback_arg(const BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_set_callback_arg(BIO *b, char *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * BIO_method_name(const BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_method_type(const BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef void bio_info_cb(struct bio_st *, int, const char *, int, long, long);
typedef struct bio_method_st
 int type;
 const char *name;
 int (*bwrite)(BIO *, const char *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bread)(BIO *, char *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bputs)(BIO *, const char *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bgets)(BIO *, char *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ctrl)(BIO *, int, long, void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*create)(BIO *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*destroy)(BIO *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
        long (*callback_ctrl)(BIO *, int, bio_info_cb *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } BIO_METHOD;
# 301 "/usr/include/openssl/bio.h" 3 4
struct bio_st
 BIO_METHOD *method;
 long (*callback)(struct bio_st *,int,const char *,int, long,long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 char *cb_arg;
 int init;
 int shutdown;
 int flags;
 int retry_reason;
 int num;
 void *ptr;
 struct bio_st *next_bio;
 struct bio_st *prev_bio;
 int references;
 unsigned long num_read;
 unsigned long num_write;
typedef struct bio_f_buffer_ctx_struct
# 337 "/usr/include/openssl/bio.h" 3 4
 int ibuf_size;
 int obuf_size;
 char *ibuf;
 int ibuf_len;
 int ibuf_off;
 char *obuf;
 int obuf_len;
 int obuf_off;
 } BIO_F_BUFFER_CTX;
# 527 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_pending(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t BIO_ctrl_wpending(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 546 "/usr/include/openssl/bio.h" 3 4
size_t BIO_ctrl_get_write_guarantee(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t BIO_ctrl_get_read_request(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_ctrl_reset_read_request(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 567 "/usr/include/openssl/bio.h" 3 4
int BIO_set_ex_data(BIO *bio,int idx,void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *BIO_get_ex_data(BIO *bio,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BIO_number_read(BIO *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BIO_number_written(BIO *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 583 "/usr/include/openssl/bio.h" 3 4
BIO_METHOD *BIO_s_file(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_file(const char *filename, const char *mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_fp(FILE *stream, int close_flag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_new(BIO_METHOD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_set(BIO *a,BIO_METHOD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_free(BIO *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_vfree(BIO *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_read(BIO *b, void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_gets(BIO *bp,char *buf, int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_write(BIO *b, const void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_puts(BIO *bp,const char *buf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_indent(BIO *b,int indent,int max) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long BIO_ctrl(BIO *bp,int cmd,long larg,void *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long BIO_callback_ctrl(BIO *b, int cmd, void (*fp)(struct bio_st *, int, const char *, int, long, long)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BIO_ptr_ctrl(BIO *bp,int cmd,long larg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long BIO_int_ctrl(BIO *bp,int cmd,long larg,int iarg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_push(BIO *b,BIO *append) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_pop(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_free_all(BIO *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_find_type(BIO *b,int bio_type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_next(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_get_retry_BIO(BIO *bio, int *reason) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_get_retry_reason(BIO *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * BIO_dup_chain(BIO *in) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_nread0(BIO *bio, char **buf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_nread(BIO *bio, char **buf, int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_nwrite0(BIO *bio, char **buf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_nwrite(BIO *bio, char **buf, int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long BIO_debug_callback(BIO *bio,int cmd,const char *argp,int argi,
 long argl,long ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_mem(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_mem_buf(void *buf, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_socket(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_connect(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_accept(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_fd(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_log(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_bio(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_null(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_null(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_buffer(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_nbio_test(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_s_datagram(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_sock_should_retry(int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_sock_non_fatal_error(int error) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dgram_non_fatal_error(int error) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_fd_should_retry(int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_fd_non_fatal_error(int error) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump_cb(int (*cb)(const void *data, size_t len, void *u),
  void *u, const char *s, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump_indent_cb(int (*cb)(const void *data, size_t len, void *u),
         void *u, const char *s, int len, int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump(BIO *b,const char *bytes,int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump_indent(BIO *b,const char *bytes,int len,int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump_fp(FILE *fp, const char *s, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_dump_indent_fp(FILE *fp, const char *s, int len, int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct hostent *BIO_gethostbyname(const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 674 "/usr/include/openssl/bio.h" 3 4
int BIO_sock_error(int sock) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_socket_ioctl(int fd, long type, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_socket_nbio(int fd,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_get_port(const char *str, unsigned short *port_ptr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_get_host_ip(const char *str, unsigned char *ip) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_get_accept_socket(char *host_port,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_accept(int sock,char **ip_port) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_sock_init(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_sock_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_set_tcp_ndelay(int sock,int turn_on) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_socket(int sock, int close_flag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_dgram(int fd, int close_flag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_fd(int fd, int close_flag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_connect(char *host_port) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_accept(char *host_port) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_new_bio_pair(BIO **bio1, size_t writebuf1,
 BIO **bio2, size_t writebuf2) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_copy_next_retry(BIO *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 707 "/usr/include/openssl/bio.h" 3 4
int BIO_printf(BIO *bio, const char *format, ...)
 __attribute__((__format__(__printf__,2,3))) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_vprintf(BIO *bio, const char *format, va_list args)
 __attribute__((__format__(__printf__,2,0))) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_snprintf(char *buf, size_t n, const char *format, ...)
 __attribute__((__format__(__printf__,3,4))) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_vsnprintf(char *buf, size_t n, const char *format, va_list args)
 __attribute__((__format__(__printf__,3,0))) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_BIO_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 182 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/x509.h" 1 3 4
# 69 "/usr/include/openssl/x509.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 70 "/usr/include/openssl/x509.h" 2 3 4
# 71 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/buffer.h" 1 3 4
# 70 "/usr/include/openssl/buffer.h" 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 1 3 4
# 34 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 3 4
typedef long int ptrdiff_t;
# 53 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 3 4
typedef long unsigned int rsize_t;
# 71 "/usr/include/openssl/buffer.h" 2 3 4
# 1 "/usr/include/sys/types.h" 1 3 4
# 84 "/usr/include/sys/types.h" 3 4
typedef unsigned char u_char;
typedef unsigned short u_short;
typedef unsigned int u_int;
typedef unsigned long u_long;
typedef unsigned short ushort;
typedef unsigned int uint;
typedef u_int64_t u_quad_t;
typedef int64_t quad_t;
typedef quad_t * qaddr_t;
typedef char * caddr_t;
typedef int32_t daddr_t;
typedef u_int32_t fixpt_t;
# 1 "/usr/include/sys/_types/_blkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blkcnt_t.h" 3 4
typedef __darwin_blkcnt_t blkcnt_t;
# 107 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_blksize_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_blksize_t.h" 3 4
typedef __darwin_blksize_t blksize_t;
# 108 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_gid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_gid_t.h" 3 4
typedef __darwin_gid_t gid_t;
# 109 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_addr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_addr_t.h" 3 4
typedef __uint32_t in_addr_t;
# 110 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_in_port_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_in_port_t.h" 3 4
typedef __uint16_t in_port_t;
# 111 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino_t.h" 3 4
typedef __darwin_ino_t ino_t;
# 112 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_ino64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_ino64_t.h" 3 4
typedef __darwin_ino64_t ino64_t;
# 115 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_key_t.h" 3 4
typedef __int32_t key_t;
# 118 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_nlink_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_nlink_t.h" 3 4
typedef __uint16_t nlink_t;
# 120 "/usr/include/sys/types.h" 2 3 4
typedef int32_t segsz_t;
typedef int32_t swblk_t;
# 161 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/_types/_clock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_clock_t.h" 3 4
typedef __darwin_clock_t clock_t;
# 162 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_time_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_time_t.h" 3 4
typedef __darwin_time_t time_t;
# 165 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_useconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_useconds_t.h" 3 4
typedef __darwin_useconds_t useconds_t;
# 167 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_suseconds_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_suseconds_t.h" 3 4
typedef __darwin_suseconds_t suseconds_t;
# 168 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 171 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_errno_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_errno_t.h" 3 4
typedef int errno_t;
# 172 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_def.h" 1 3 4
# 46 "/usr/include/sys/_types/_fd_def.h" 3 4
typedef struct fd_set {
 __int32_t fds_bits[((((1024) % ((sizeof(__int32_t) * 8))) == 0) ? ((1024) / ((sizeof(__int32_t) * 8))) : (((1024) / ((sizeof(__int32_t) * 8))) + 1))];
} fd_set;
static __inline int
__darwin_fd_isset(int _n, const struct fd_set *_p)
 return (_p->fds_bits[(unsigned long)_n/(sizeof(__int32_t) * 8)] & ((__int32_t)(1<<((unsigned long)_n % (sizeof(__int32_t) * 8)))));
# 181 "/usr/include/sys/types.h" 2 3 4
typedef __int32_t fd_mask;
# 1 "/usr/include/sys/_types/_fd_setsize.h" 1 3 4
# 194 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_set.h" 1 3 4
# 195 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_clr.h" 1 3 4
# 196 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_zero.h" 1 3 4
# 197 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_isset.h" 1 3 4
# 198 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fd_copy.h" 1 3 4
# 201 "/usr/include/sys/types.h" 2 3 4
# 211 "/usr/include/sys/types.h" 3 4
# 1 "/usr/include/sys/_types/_pthread_cond_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_cond_t.h" 3 4
typedef __darwin_pthread_cond_t pthread_cond_t;
# 212 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_condattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_condattr_t.h" 3 4
typedef __darwin_pthread_condattr_t pthread_condattr_t;
# 213 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutex_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutex_t.h" 3 4
typedef __darwin_pthread_mutex_t pthread_mutex_t;
# 214 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_mutexattr_t.h" 3 4
typedef __darwin_pthread_mutexattr_t pthread_mutexattr_t;
# 215 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_once_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_once_t.h" 3 4
typedef __darwin_pthread_once_t pthread_once_t;
# 216 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlock_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlock_t.h" 3 4
typedef __darwin_pthread_rwlock_t pthread_rwlock_t;
# 217 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_rwlockattr_t.h" 3 4
typedef __darwin_pthread_rwlockattr_t pthread_rwlockattr_t;
# 218 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_t.h" 3 4
typedef __darwin_pthread_t pthread_t;
# 219 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_pthread_key_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pthread_key_t.h" 3 4
typedef __darwin_pthread_key_t pthread_key_t;
# 223 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsblkcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsblkcnt_t.h" 3 4
typedef __darwin_fsblkcnt_t fsblkcnt_t;
# 227 "/usr/include/sys/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_fsfilcnt_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_fsfilcnt_t.h" 3 4
typedef __darwin_fsfilcnt_t fsfilcnt_t;
# 228 "/usr/include/sys/types.h" 2 3 4
# 74 "/usr/include/openssl/buffer.h" 2 3 4
struct buf_mem_st
 int length;
 char *data;
 int max;
BUF_MEM *BUF_MEM_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BUF_MEM_free(BUF_MEM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BUF_MEM_grow(BUF_MEM *str, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BUF_MEM_grow_clean(BUF_MEM *str, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BUF_strdup(const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BUF_strndup(const char *str, size_t siz) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * BUF_memdup(const void *data, size_t siz) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t BUF_strlcpy(char *dst,const char *src,size_t siz) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t BUF_strlcat(char *dst,const char *src,size_t siz) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_BUF_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 73 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/evp.h" 1 3 4
# 68 "/usr/include/openssl/evp.h" 3 4
# 69 "/usr/include/openssl/evp.h" 2 3 4
# 75 "/usr/include/openssl/evp.h" 2 3 4
# 100 "/usr/include/openssl/evp.h" 3 4
# 1 "/usr/include/openssl/objects.h" 1 3 4
# 67 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/obj_mac.h" 1 3 4
# 68 "/usr/include/openssl/objects.h" 2 3 4
# 962 "/usr/include/openssl/objects.h" 3 4
# 1 "/usr/include/openssl/asn1.h" 1 3 4
# 64 "/usr/include/openssl/asn1.h" 3 4
# 1 "/usr/include/time.h" 1 3 4
# 69 "/usr/include/time.h" 3 4
# 1 "/usr/include/_structs.h" 1 3 4
# 24 "/usr/include/_structs.h" 3 4
# 1 "/usr/include/sys/_structs.h" 1 3 4
# 73 "/usr/include/sys/_structs.h" 3 4
# 1 "/usr/include/sys/_types/_timespec.h" 1 3 4
# 30 "/usr/include/sys/_types/_timespec.h" 3 4
struct timespec
 long tv_nsec;
# 74 "/usr/include/sys/_structs.h" 2 3 4
# 25 "/usr/include/_structs.h" 2 3 4
# 70 "/usr/include/time.h" 2 3 4
struct tm {
 int tm_sec;
 int tm_min;
 int tm_hour;
 int tm_mday;
 int tm_mon;
 int tm_year;
 int tm_wday;
 int tm_yday;
 int tm_isdst;
 long tm_gmtoff;
 char *tm_zone;
# 98 "/usr/include/time.h" 3 4
extern char *tzname[];
extern int getdate_err;
extern long timezone __asm("_" "timezone") ;
extern int daylight;
char *asctime(const struct tm *);
clock_t clock(void) __asm("_" "clock") ;
char *ctime(const time_t *);
double difftime(time_t, time_t);
struct tm *getdate(const char *);
struct tm *gmtime(const time_t *);
struct tm *localtime(const time_t *);
time_t mktime(struct tm *) __asm("_" "mktime") ;
size_t strftime(char * restrict, size_t, const char * restrict, const struct tm * restrict) __asm("_" "strftime") ;
char *strptime(const char * restrict, const char * restrict, struct tm * restrict) __asm("_" "strptime") ;
time_t time(time_t *);
void tzset(void);
char *asctime_r(const struct tm * restrict, char * restrict);
char *ctime_r(const time_t *, char *);
struct tm *gmtime_r(const time_t * restrict, struct tm * restrict);
struct tm *localtime_r(const time_t * restrict, struct tm * restrict);
time_t posix2time(time_t);
void tzsetwall(void);
time_t time2posix(time_t);
time_t timelocal(struct tm * const);
time_t timegm(struct tm * const);
int nanosleep(const struct timespec *, struct timespec *) __asm("_" "nanosleep") ;
# 65 "/usr/include/openssl/asn1.h" 2 3 4
# 66 "/usr/include/openssl/asn1.h" 2 3 4
# 73 "/usr/include/openssl/asn1.h" 2 3 4
# 1 "/usr/include/openssl/bn.h" 1 3 4
# 77 "/usr/include/openssl/bn.h" 3 4
# 78 "/usr/include/openssl/bn.h" 2 3 4
# 290 "/usr/include/openssl/bn.h" 3 4
struct bignum_st
 unsigned long *d;
 int top;
 int dmax;
 int neg;
 int flags;
 int ri;
 BIGNUM RR;
 BIGNUM N;
 BIGNUM Ni;
 unsigned long n0;
 int flags;
 BIGNUM N;
 BIGNUM Nr;
 int num_bits;
 int shift;
 int flags;
struct bn_gencb_st
 unsigned int ver;
 void *arg;
 union
  void (*cb_1)(int, int, void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
  int (*cb_2)(int, int, BN_GENCB *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
  } cb;
int BN_GENCB_call(BN_GENCB *cb, int a, int b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 401 "/usr/include/openssl/bn.h" 3 4
const BIGNUM *BN_value_one(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BN_options(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_CTX *BN_CTX_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_CTX_init(BN_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_CTX_free(BN_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_CTX_start(BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_CTX_get(BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_CTX_end(BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_rand(BIGNUM *rnd, int bits, int top,int bottom) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_pseudo_rand(BIGNUM *rnd, int bits, int top,int bottom) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_rand_range(BIGNUM *rnd, const BIGNUM *range) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_pseudo_rand_range(BIGNUM *rnd, const BIGNUM *range) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_num_bits(const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_num_bits_word(unsigned long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_init(BIGNUM *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_clear_free(BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_copy(BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_swap(BIGNUM *a, BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_bin2bn(const unsigned char *s,int len,BIGNUM *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_bn2bin(const BIGNUM *a, unsigned char *to) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_mpi2bn(const unsigned char *s,int len,BIGNUM *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_bn2mpi(const BIGNUM *a, unsigned char *to) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_usub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_uadd(BIGNUM *r, const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_sqr(BIGNUM *r, const BIGNUM *a,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_set_negative(BIGNUM *b, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_div(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m, const BIGNUM *d,
int BN_nnmod(BIGNUM *r, const BIGNUM *m, const BIGNUM *d, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_add_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_sub_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_lshift1(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_lshift1_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *m) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_lshift(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_lshift_quick(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BN_mod_word(const BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BN_div_word(BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mul_word(BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_add_word(BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_sub_word(BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_set_word(BIGNUM *a, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BN_get_word(const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_cmp(const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_free(BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_is_bit_set(const BIGNUM *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_lshift(BIGNUM *r, const BIGNUM *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_lshift1(BIGNUM *r, const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp_mont(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp_mont_consttime(BIGNUM *rr, const BIGNUM *a, const BIGNUM *p,
 const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *in_mont) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp_mont_word(BIGNUM *r, unsigned long a, const BIGNUM *p,
int BN_mod_exp2_mont(BIGNUM *r, const BIGNUM *a1, const BIGNUM *p1,
 const BIGNUM *a2, const BIGNUM *p2,const BIGNUM *m,
 BN_CTX *ctx,BN_MONT_CTX *m_ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp_simple(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_mask_bits(BIGNUM *a,int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_print_fp(FILE *fp, const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_print(BIO *fp, const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_reciprocal(BIGNUM *r, const BIGNUM *m, int len, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_rshift(BIGNUM *r, const BIGNUM *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_rshift1(BIGNUM *r, const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_clear(BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_dup(const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_ucmp(const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_set_bit(BIGNUM *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_clear_bit(BIGNUM *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BN_bn2hex(const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * BN_bn2dec(const BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_hex2bn(BIGNUM **a, const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_dec2bn(BIGNUM **a, const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_gcd(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_kronecker(const BIGNUM *a,const BIGNUM *b,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_mod_inverse(BIGNUM *ret,
 const BIGNUM *a, const BIGNUM *n,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_mod_sqrt(BIGNUM *ret,
void BN_consttime_swap(unsigned long swap, BIGNUM *a, BIGNUM *b, int nwords) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *BN_generate_prime(BIGNUM *ret,int bits,int safe,
 const BIGNUM *add, const BIGNUM *rem,
 void (*callback)(int,int,void *),void *cb_arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_is_prime(const BIGNUM *p,int nchecks,
 BN_CTX *ctx,void *cb_arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_is_prime_fasttest(const BIGNUM *p,int nchecks,
 void (*callback)(int,int,void *),BN_CTX *ctx,void *cb_arg,
 int do_trial_division) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_generate_prime_ex(BIGNUM *ret,int bits,int safe, const BIGNUM *add,
  const BIGNUM *rem, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_is_prime_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_is_prime_fasttest_ex(const BIGNUM *p,int nchecks, BN_CTX *ctx,
  int do_trial_division, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_X931_generate_Xpq(BIGNUM *Xp, BIGNUM *Xq, int nbits, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_X931_derive_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   const BIGNUM *Xp, const BIGNUM *Xp1, const BIGNUM *Xp2,
   const BIGNUM *e, BN_CTX *ctx, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_X931_generate_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
   BIGNUM *Xp1, BIGNUM *Xp2,
   const BIGNUM *Xp,
BN_MONT_CTX *BN_MONT_CTX_new(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_MONT_CTX_init(BN_MONT_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_mul_montgomery(BIGNUM *r,const BIGNUM *a,const BIGNUM *b,
 BN_MONT_CTX *mont, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_from_montgomery(BIGNUM *r,const BIGNUM *a,
void BN_MONT_CTX_free(BN_MONT_CTX *mont) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_MONT_CTX_set(BN_MONT_CTX *mont,const BIGNUM *mod,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_MONT_CTX *BN_MONT_CTX_copy(BN_MONT_CTX *to,BN_MONT_CTX *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_MONT_CTX *BN_MONT_CTX_set_locked(BN_MONT_CTX **pmont, int lock,
     const BIGNUM *mod, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_BLINDING *BN_BLINDING_new(const BIGNUM *A, const BIGNUM *Ai, BIGNUM *mod) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_BLINDING_free(BN_BLINDING *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_BLINDING_update(BN_BLINDING *b,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_BLINDING_convert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_BLINDING_invert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_BLINDING_convert_ex(BIGNUM *n, BIGNUM *r, BN_BLINDING *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_BLINDING_invert_ex(BIGNUM *n, const BIGNUM *r, BN_BLINDING *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BN_BLINDING_get_thread_id(const BN_BLINDING *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_BLINDING_set_thread_id(BN_BLINDING *, unsigned long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long BN_BLINDING_get_flags(const BN_BLINDING *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_BLINDING_set_flags(BN_BLINDING *, unsigned long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_BLINDING *BN_BLINDING_create_param(BN_BLINDING *b,
 const BIGNUM *e, BIGNUM *m, BN_CTX *ctx,
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx),
void BN_set_params(int mul,int high,int low,int mont) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_get_params(int which) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_RECP_CTX_init(BN_RECP_CTX *recp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_RECP_CTX *BN_RECP_CTX_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BN_RECP_CTX_free(BN_RECP_CTX *recp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_RECP_CTX_set(BN_RECP_CTX *recp,const BIGNUM *rdiv,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_mul_reciprocal(BIGNUM *r, const BIGNUM *x, const BIGNUM *y,
 BN_RECP_CTX *recp,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_mod_exp_recp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_div_recp(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m,
 BN_RECP_CTX *recp, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 609 "/usr/include/openssl/bn.h" 3 4
int BN_GF2m_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_mod(BIGNUM *r, const BIGNUM *a, const BIGNUM *p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
 const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_GF2m_mod_inv(BIGNUM *r, const BIGNUM *b, const BIGNUM *p,
int BN_GF2m_mod_div(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_GF2m_mod_solve_quad(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_GF2m_mod_arr(BIGNUM *r, const BIGNUM *a, const unsigned int p[]) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_mod_mul_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
 const unsigned int p[], BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_mod_sqr_arr(BIGNUM *r, const BIGNUM *a, const unsigned int p[],
int BN_GF2m_mod_inv_arr(BIGNUM *r, const BIGNUM *b, const unsigned int p[],
int BN_GF2m_mod_div_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_mod_solve_quad_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_poly2arr(const BIGNUM *a, unsigned int p[], int max) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_GF2m_arr2poly(const unsigned int p[], BIGNUM *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_nist_mod_192(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_nist_mod_224(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_nist_mod_256(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_nist_mod_384(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_nist_mod_521(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *BN_get0_nist_prime_192(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *BN_get0_nist_prime_224(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *BN_get0_nist_prime_256(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *BN_get0_nist_prime_384(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *BN_get0_nist_prime_521(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *bn_expand2(BIGNUM *a, int words) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *bn_dup_expand(const BIGNUM *a, int words) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 775 "/usr/include/openssl/bn.h" 3 4
unsigned long bn_mul_add_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long bn_mul_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void bn_sqr_words(unsigned long *rp, const unsigned long *ap, int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long bn_div_words(unsigned long h, unsigned long l, unsigned long d) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long bn_add_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long bn_sub_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc2409_prime_768(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc2409_prime_1024(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_1536(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_2048(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_3072(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_4096(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_6144(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *get_rfc3526_prime_8192(BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BN_bntest_rand(BIGNUM *rnd, int bits, int top,int bottom) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_BN_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 77 "/usr/include/openssl/asn1.h" 2 3 4
# 167 "/usr/include/openssl/asn1.h" 3 4
struct X509_algor_st;
# 177 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_ctx_st
 unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 unsigned char *max;
 unsigned char *q;
 unsigned char **pp;
 int line;
 } ASN1_CTX;
typedef struct asn1_const_ctx_st
 const unsigned char *p;
 int eos;
 int error;
 int inf;
 int tag;
 int xclass;
 long slen;
 const unsigned char *max;
 const unsigned char *q;
 const unsigned char **pp;
 int line;
 } ASN1_const_CTX;
typedef struct asn1_object_st
 const char *sn,*ln;
 int nid;
 int length;
 unsigned char *data;
 int flags;
 } ASN1_OBJECT;
# 236 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_string_st
 int length;
 int type;
 long flags;
 } ASN1_STRING;
typedef struct ASN1_ENCODING_st
 unsigned char *enc;
 long len;
 int modified;
 } ASN1_ENCODING;
# 269 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_string_table_st {
 int nid;
 long minsize;
 long maxsize;
 unsigned long mask;
 unsigned long flags;
} ASN1_STRING_TABLE;
# 293 "/usr/include/openssl/asn1.h" 3 4
typedef struct ASN1_TEMPLATE_st ASN1_TEMPLATE;
typedef struct ASN1_ITEM_st ASN1_ITEM;
typedef struct ASN1_TLC_st ASN1_TLC;
typedef struct ASN1_VALUE_st ASN1_VALUE;
# 356 "/usr/include/openssl/asn1.h" 3 4
typedef void *d2i_of_void(void **,const unsigned char **,long); typedef int i2d_of_void(void *,unsigned char **);
# 396 "/usr/include/openssl/asn1.h" 3 4
typedef const ASN1_ITEM ASN1_ITEM_EXP;
# 515 "/usr/include/openssl/asn1.h" 3 4
typedef struct asn1_type_st
 int type;
 union {
  char *ptr;
  ASN1_BOOLEAN boolean;
  ASN1_STRING * asn1_string;
  ASN1_OBJECT * object;
  ASN1_INTEGER * integer;
  ASN1_ENUMERATED * enumerated;
  ASN1_BIT_STRING * bit_string;
  ASN1_OCTET_STRING * octet_string;
  ASN1_PRINTABLESTRING * printablestring;
  ASN1_T61STRING * t61string;
  ASN1_IA5STRING * ia5string;
  ASN1_GENERALSTRING * generalstring;
  ASN1_BMPSTRING * bmpstring;
  ASN1_UNIVERSALSTRING * universalstring;
  ASN1_UTCTIME * utctime;
  ASN1_GENERALIZEDTIME * generalizedtime;
  ASN1_VISIBLESTRING * visiblestring;
  ASN1_UTF8STRING * utf8string;
  ASN1_STRING * set;
  ASN1_STRING * sequence;
  ASN1_VALUE * asn1_value;
  } value;
 } ASN1_TYPE;
typedef struct asn1_method_st
 i2d_of_void *i2d;
 d2i_of_void *d2i;
 void *(*create)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*destroy)(void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } ASN1_METHOD;
typedef struct asn1_header_st
 ASN1_OCTET_STRING *header;
 void *data;
 ASN1_METHOD *meth;
 } ASN1_HEADER;
typedef struct BIT_STRING_BITNAME_st {
 int bitnum;
 const char *lname;
 const char *sname;
} BIT_STRING_BITNAME;
# 769 "/usr/include/openssl/asn1.h" 3 4
ASN1_TYPE * ASN1_TYPE_new(void); void ASN1_TYPE_free(ASN1_TYPE *a); ASN1_TYPE *d2i_ASN1_TYPE(ASN1_TYPE **a, const unsigned char **in, long len); int i2d_ASN1_TYPE(ASN1_TYPE *a, unsigned char **out); extern const ASN1_ITEM ASN1_ANY_it;
int ASN1_TYPE_get(ASN1_TYPE *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_TYPE_set(ASN1_TYPE *a, int type, void *value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_TYPE_set1(ASN1_TYPE *a, int type, const void *value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT * ASN1_OBJECT_new(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_OBJECT_free(ASN1_OBJECT *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ASN1_OBJECT(ASN1_OBJECT *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT * c2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
   long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT * d2i_ASN1_OBJECT(ASN1_OBJECT **a,const unsigned char **pp,
extern const ASN1_ITEM ASN1_OBJECT_it;
ASN1_STRING * ASN1_STRING_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_STRING_free(ASN1_STRING *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING * ASN1_STRING_dup(ASN1_STRING *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING * ASN1_STRING_type_new(int type ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_cmp(ASN1_STRING *a, ASN1_STRING *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_set(ASN1_STRING *str, const void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_STRING_set0(ASN1_STRING *str, void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_length(ASN1_STRING *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_STRING_length_set(ASN1_STRING *x, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_type(ASN1_STRING *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char * ASN1_STRING_data(ASN1_STRING *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_BIT_STRING * ASN1_BIT_STRING_new(void); void ASN1_BIT_STRING_free(ASN1_BIT_STRING *a); ASN1_BIT_STRING *d2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a, const unsigned char **in, long len); int i2d_ASN1_BIT_STRING(ASN1_BIT_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BIT_STRING_it;
int i2c_ASN1_BIT_STRING(ASN1_BIT_STRING *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_BIT_STRING *c2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a,const unsigned char **pp,
int ASN1_BIT_STRING_set(ASN1_BIT_STRING *a, unsigned char *d,
   int length ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_BIT_STRING_set_bit(ASN1_BIT_STRING *a, int n, int value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_BIT_STRING_get_bit(ASN1_BIT_STRING *a, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_BIT_STRING_name_print(BIO *out, ASN1_BIT_STRING *bs,
    BIT_STRING_BITNAME *tbl, int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_BIT_STRING_num_asc(char *name, BIT_STRING_BITNAME *tbl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_BIT_STRING_set_asc(ASN1_BIT_STRING *bs, char *name, int value,
int i2d_ASN1_BOOLEAN(int a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int d2i_ASN1_BOOLEAN(int *a,const unsigned char **pp,long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_INTEGER * ASN1_INTEGER_new(void); void ASN1_INTEGER_free(ASN1_INTEGER *a); ASN1_INTEGER *d2i_ASN1_INTEGER(ASN1_INTEGER **a, const unsigned char **in, long len); int i2d_ASN1_INTEGER(ASN1_INTEGER *a, unsigned char **out); extern const ASN1_ITEM ASN1_INTEGER_it;
int i2c_ASN1_INTEGER(ASN1_INTEGER *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_INTEGER *c2i_ASN1_INTEGER(ASN1_INTEGER **a,const unsigned char **pp,
ASN1_INTEGER *d2i_ASN1_UINTEGER(ASN1_INTEGER **a,const unsigned char **pp,
ASN1_INTEGER * ASN1_INTEGER_dup(ASN1_INTEGER *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_INTEGER_cmp(ASN1_INTEGER *x, ASN1_INTEGER *y) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_ENUMERATED * ASN1_ENUMERATED_new(void); void ASN1_ENUMERATED_free(ASN1_ENUMERATED *a); ASN1_ENUMERATED *d2i_ASN1_ENUMERATED(ASN1_ENUMERATED **a, const unsigned char **in, long len); int i2d_ASN1_ENUMERATED(ASN1_ENUMERATED *a, unsigned char **out); extern const ASN1_ITEM ASN1_ENUMERATED_it;
int ASN1_UTCTIME_check(ASN1_UTCTIME *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_UTCTIME *ASN1_UTCTIME_set(ASN1_UTCTIME *s,time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_UTCTIME_set_string(ASN1_UTCTIME *s, const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_UTCTIME_cmp_time_t(const ASN1_UTCTIME *s, time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_GENERALIZEDTIME_check(ASN1_GENERALIZEDTIME *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_set(ASN1_GENERALIZEDTIME *s,time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_GENERALIZEDTIME_set_string(ASN1_GENERALIZEDTIME *s, const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OCTET_STRING * ASN1_OCTET_STRING_new(void); void ASN1_OCTET_STRING_free(ASN1_OCTET_STRING *a); ASN1_OCTET_STRING *d2i_ASN1_OCTET_STRING(ASN1_OCTET_STRING **a, const unsigned char **in, long len); int i2d_ASN1_OCTET_STRING(ASN1_OCTET_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_OCTET_STRING_it;
ASN1_OCTET_STRING * ASN1_OCTET_STRING_dup(ASN1_OCTET_STRING *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_OCTET_STRING_cmp(ASN1_OCTET_STRING *a, ASN1_OCTET_STRING *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_OCTET_STRING_set(ASN1_OCTET_STRING *str, const unsigned char *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_VISIBLESTRING * ASN1_VISIBLESTRING_new(void); void ASN1_VISIBLESTRING_free(ASN1_VISIBLESTRING *a); ASN1_VISIBLESTRING *d2i_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_VISIBLESTRING_it;
ASN1_UNIVERSALSTRING * ASN1_UNIVERSALSTRING_new(void); void ASN1_UNIVERSALSTRING_free(ASN1_UNIVERSALSTRING *a); ASN1_UNIVERSALSTRING *d2i_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UNIVERSALSTRING_it;
ASN1_UTF8STRING * ASN1_UTF8STRING_new(void); void ASN1_UTF8STRING_free(ASN1_UTF8STRING *a); ASN1_UTF8STRING *d2i_ASN1_UTF8STRING(ASN1_UTF8STRING **a, const unsigned char **in, long len); int i2d_ASN1_UTF8STRING(ASN1_UTF8STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTF8STRING_it;
ASN1_NULL * ASN1_NULL_new(void); void ASN1_NULL_free(ASN1_NULL *a); ASN1_NULL *d2i_ASN1_NULL(ASN1_NULL **a, const unsigned char **in, long len); int i2d_ASN1_NULL(ASN1_NULL *a, unsigned char **out); extern const ASN1_ITEM ASN1_NULL_it;
ASN1_BMPSTRING * ASN1_BMPSTRING_new(void); void ASN1_BMPSTRING_free(ASN1_BMPSTRING *a); ASN1_BMPSTRING *d2i_ASN1_BMPSTRING(ASN1_BMPSTRING **a, const unsigned char **in, long len); int i2d_ASN1_BMPSTRING(ASN1_BMPSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_BMPSTRING_it;
int UTF8_getc(const unsigned char *str, int len, unsigned long *val) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int UTF8_putc(unsigned char *str, int len, unsigned long value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING * ASN1_PRINTABLE_new(void); void ASN1_PRINTABLE_free(ASN1_STRING *a); ASN1_STRING *d2i_ASN1_PRINTABLE(ASN1_STRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLE(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLE_it;
ASN1_STRING * DIRECTORYSTRING_new(void); void DIRECTORYSTRING_free(ASN1_STRING *a); ASN1_STRING *d2i_DIRECTORYSTRING(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DIRECTORYSTRING(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DIRECTORYSTRING_it;
ASN1_STRING * DISPLAYTEXT_new(void); void DISPLAYTEXT_free(ASN1_STRING *a); ASN1_STRING *d2i_DISPLAYTEXT(ASN1_STRING **a, const unsigned char **in, long len); int i2d_DISPLAYTEXT(ASN1_STRING *a, unsigned char **out); extern const ASN1_ITEM DISPLAYTEXT_it;
ASN1_PRINTABLESTRING * ASN1_PRINTABLESTRING_new(void); void ASN1_PRINTABLESTRING_free(ASN1_PRINTABLESTRING *a); ASN1_PRINTABLESTRING *d2i_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING **a, const unsigned char **in, long len); int i2d_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_PRINTABLESTRING_it;
ASN1_T61STRING * ASN1_T61STRING_new(void); void ASN1_T61STRING_free(ASN1_T61STRING *a); ASN1_T61STRING *d2i_ASN1_T61STRING(ASN1_T61STRING **a, const unsigned char **in, long len); int i2d_ASN1_T61STRING(ASN1_T61STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_T61STRING_it;
ASN1_IA5STRING * ASN1_IA5STRING_new(void); void ASN1_IA5STRING_free(ASN1_IA5STRING *a); ASN1_IA5STRING *d2i_ASN1_IA5STRING(ASN1_IA5STRING **a, const unsigned char **in, long len); int i2d_ASN1_IA5STRING(ASN1_IA5STRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_IA5STRING_it;
ASN1_GENERALSTRING * ASN1_GENERALSTRING_new(void); void ASN1_GENERALSTRING_free(ASN1_GENERALSTRING *a); ASN1_GENERALSTRING *d2i_ASN1_GENERALSTRING(ASN1_GENERALSTRING **a, const unsigned char **in, long len); int i2d_ASN1_GENERALSTRING(ASN1_GENERALSTRING *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALSTRING_it;
ASN1_UTCTIME * ASN1_UTCTIME_new(void); void ASN1_UTCTIME_free(ASN1_UTCTIME *a); ASN1_UTCTIME *d2i_ASN1_UTCTIME(ASN1_UTCTIME **a, const unsigned char **in, long len); int i2d_ASN1_UTCTIME(ASN1_UTCTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_UTCTIME_it;
ASN1_GENERALIZEDTIME * ASN1_GENERALIZEDTIME_new(void); void ASN1_GENERALIZEDTIME_free(ASN1_GENERALIZEDTIME *a); ASN1_GENERALIZEDTIME *d2i_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME **a, const unsigned char **in, long len); int i2d_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_GENERALIZEDTIME_it;
ASN1_TIME * ASN1_TIME_new(void); void ASN1_TIME_free(ASN1_TIME *a); ASN1_TIME *d2i_ASN1_TIME(ASN1_TIME **a, const unsigned char **in, long len); int i2d_ASN1_TIME(ASN1_TIME *a, unsigned char **out); extern const ASN1_ITEM ASN1_TIME_it;
extern const ASN1_ITEM ASN1_OCTET_STRING_NDEF_it;
ASN1_TIME *ASN1_TIME_set(ASN1_TIME *s,time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_TIME_check(ASN1_TIME *t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_GENERALIZEDTIME *ASN1_TIME_to_generalizedtime(ASN1_TIME *t, ASN1_GENERALIZEDTIME **out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ASN1_SET(STACK *a, unsigned char **pp,
   i2d_of_void *i2d, int ex_tag, int ex_class, int is_set) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK * d2i_ASN1_SET(STACK **a, const unsigned char **pp, long length,
       d2i_of_void *d2i, void (*free_func)(void *),
       int ex_tag, int ex_class) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2a_ASN1_INTEGER(BIO *bp, ASN1_INTEGER *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int a2i_ASN1_INTEGER(BIO *bp,ASN1_INTEGER *bs,char *buf,int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2a_ASN1_ENUMERATED(BIO *bp, ASN1_ENUMERATED *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int a2i_ASN1_ENUMERATED(BIO *bp,ASN1_ENUMERATED *bs,char *buf,int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2a_ASN1_OBJECT(BIO *bp,ASN1_OBJECT *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int a2i_ASN1_STRING(BIO *bp,ASN1_STRING *bs,char *buf,int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2a_ASN1_STRING(BIO *bp, ASN1_STRING *a, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2t_ASN1_OBJECT(char *buf,int buf_len,ASN1_OBJECT *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int a2d_ASN1_OBJECT(unsigned char *out,int olen, const char *buf, int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT *ASN1_OBJECT_create(int nid, unsigned char *data,int len,
 const char *sn, const char *ln) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_INTEGER_set(ASN1_INTEGER *a, long v) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long ASN1_INTEGER_get(ASN1_INTEGER *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_INTEGER *BN_to_ASN1_INTEGER(BIGNUM *bn, ASN1_INTEGER *ai) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *ASN1_INTEGER_to_BN(ASN1_INTEGER *ai,BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_ENUMERATED_set(ASN1_ENUMERATED *a, long v) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long ASN1_ENUMERATED_get(ASN1_ENUMERATED *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_ENUMERATED *BN_to_ASN1_ENUMERATED(BIGNUM *bn, ASN1_ENUMERATED *ai) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *ASN1_ENUMERATED_to_BN(ASN1_ENUMERATED *ai,BIGNUM *bn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_PRINTABLE_type(const unsigned char *s, int max) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ASN1_bytes(ASN1_STRING *a, unsigned char **pp, int tag, int xclass) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING *d2i_ASN1_bytes(ASN1_STRING **a, const unsigned char **pp,
 long length, int Ptag, int Pclass) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long ASN1_tag2bit(int tag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING *d2i_ASN1_type_bytes(ASN1_STRING **a,const unsigned char **pp,
  long length,int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int asn1_Finish(ASN1_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int asn1_const_Finish(ASN1_const_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_get_object(const unsigned char **pp, long *plength, int *ptag,
 int *pclass, long omax) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_check_infinite_end(unsigned char **p,long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_const_check_infinite_end(const unsigned char **p,long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_put_object(unsigned char **pp, int constructed, int length,
int ASN1_put_eoc(unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_object_size(int constructed, int length, int tag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_dup(i2d_of_void *i2d, d2i_of_void *d2i, char *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 947 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_item_dup(const ASN1_ITEM *it, void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 956 "/usr/include/openssl/asn1.h" 3 4
void *ASN1_d2i_fp(void *(*xnew)(void), d2i_of_void *d2i, FILE *in, void **x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_item_d2i_fp(const ASN1_ITEM *it, FILE *in, void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_i2d_fp(i2d_of_void *i2d,FILE *out,void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 977 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_fp(const ASN1_ITEM *it, FILE *out, void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_print_ex_fp(FILE *fp, ASN1_STRING *str, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_to_UTF8(unsigned char **out, ASN1_STRING *in) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_d2i_bio(void *(*xnew)(void), d2i_of_void *d2i, BIO *in, void **x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_item_d2i_bio(const ASN1_ITEM *it, BIO *in, void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_i2d_bio(i2d_of_void *i2d,BIO *out, unsigned char *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 1005 "/usr/include/openssl/asn1.h" 3 4
int ASN1_item_i2d_bio(const ASN1_ITEM *it, BIO *out, void *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_UTCTIME_print(BIO *fp,ASN1_UTCTIME *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_GENERALIZEDTIME_print(BIO *fp,ASN1_GENERALIZEDTIME *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_TIME_print(BIO *fp,ASN1_TIME *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_print(BIO *bp,ASN1_STRING *v) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_print_ex(BIO *out, ASN1_STRING *str, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_parse(BIO *bp,const unsigned char *pp,long len,int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_parse_dump(BIO *bp,const unsigned char *pp,long len,int indent,int dump) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *ASN1_tag2str(int tag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ASN1_HEADER(ASN1_HEADER *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_HEADER *d2i_ASN1_HEADER(ASN1_HEADER **a,const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_HEADER *ASN1_HEADER_new(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_HEADER_free(ASN1_HEADER *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_UNIVERSALSTRING_to_string(ASN1_UNIVERSALSTRING *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_METHOD *X509_asn1_meth(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_METHOD *RSAPrivateKey_asn1_meth(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_METHOD *ASN1_IA5STRING_asn1_meth(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_METHOD *ASN1_BIT_STRING_asn1_meth(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_TYPE_set_octetstring(ASN1_TYPE *a,
int ASN1_TYPE_get_octetstring(ASN1_TYPE *a,
 unsigned char *data, int max_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_TYPE_set_int_octetstring(ASN1_TYPE *a, long num,
int ASN1_TYPE_get_int_octetstring(ASN1_TYPE *a,long *num,
STACK *ASN1_seq_unpack(const unsigned char *buf, int len,
         d2i_of_void *d2i, void (*free_func)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *ASN1_seq_pack(STACK *safes, i2d_of_void *i2d,
        unsigned char **buf, int *len ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_unpack_string(ASN1_STRING *oct, d2i_of_void *d2i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ASN1_item_unpack(ASN1_STRING *oct, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING *ASN1_pack_string(void *obj, i2d_of_void *i2d,
         ASN1_OCTET_STRING **oct) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING *ASN1_item_pack(void *obj, const ASN1_ITEM *it, ASN1_OCTET_STRING **oct) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_STRING_set_default_mask(unsigned long mask) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_set_default_mask_asc(const char *p) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long ASN1_STRING_get_default_mask(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_mbstring_copy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_mbstring_ncopy(ASN1_STRING **out, const unsigned char *in, int len,
     int inform, unsigned long mask,
     long minsize, long maxsize) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING *ASN1_STRING_set_by_NID(ASN1_STRING **out,
  const unsigned char *in, int inlen, int inform, int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING_TABLE *ASN1_STRING_TABLE_get(int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_STRING_TABLE_add(int, long, long, unsigned long, unsigned long) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_STRING_TABLE_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_VALUE *ASN1_item_new(const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_item_free(ASN1_VALUE *val, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_VALUE * ASN1_item_d2i(ASN1_VALUE **val, const unsigned char **in, long len, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_item_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_item_ndef_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ASN1_add_oid_module(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TYPE *ASN1_generate_nconf(char *str, CONF *nconf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TYPE *ASN1_generate_v3(char *str, X509V3_CTX *cnf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef int asn1_output_data_fn(BIO *out, BIO *data, ASN1_VALUE *val, int flags,
     const ASN1_ITEM *it);
int int_smime_write_ASN1(BIO *bio, ASN1_VALUE *val, BIO *data, int flags,
    int ctype_nid, int econt_nid,
    STACK *mdalgs,
    asn1_output_data_fn *data_fn,
ASN1_VALUE *SMIME_read_ASN1(BIO *bio, BIO **bcont, const ASN1_ITEM *it) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_ASN1_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 963 "/usr/include/openssl/objects.h" 2 3 4
# 981 "/usr/include/openssl/objects.h" 3 4
typedef struct obj_name_st
 int type;
 int alias;
 const char *name;
 const char *data;
 } OBJ_NAME;
int OBJ_NAME_init(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_NAME_new_index(unsigned long (*hash_func)(const char *),
         int (*cmp_func)(const char *, const char *),
         void (*free_func)(const char *, int, const char *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *OBJ_NAME_get(const char *name,int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_NAME_add(const char *name,int type,const char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_NAME_remove(const char *name,int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OBJ_NAME_cleanup(int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OBJ_NAME_do_all(int type,void (*fn)(const OBJ_NAME *,void *arg),
       void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OBJ_NAME_do_all_sorted(int type,void (*fn)(const OBJ_NAME *,void *arg),
ASN1_OBJECT * OBJ_dup(const ASN1_OBJECT *o) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT * OBJ_nid2obj(int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * OBJ_nid2ln(int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * OBJ_nid2sn(int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_obj2nid(const ASN1_OBJECT *o) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT * OBJ_txt2obj(const char *s, int no_name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_obj2txt(char *buf, int buf_len, const ASN1_OBJECT *a, int no_name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_txt2nid(const char *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_ln2nid(const char *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_sn2nid(const char *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_cmp(const ASN1_OBJECT *a,const ASN1_OBJECT *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * OBJ_bsearch(const char *key,const char *base,int num,int size,
 int (*cmp)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * OBJ_bsearch_ex(const char *key,const char *base,int num,
 int size, int (*cmp)(const void *, const void *), int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_new_nid(int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_add_object(const ASN1_OBJECT *obj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_create(const char *oid,const char *sn,const char *ln) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OBJ_cleanup(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int OBJ_create_objects(BIO *in) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_OBJ_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 101 "/usr/include/openssl/evp.h" 2 3 4
# 132 "/usr/include/openssl/evp.h" 3 4
struct evp_pkey_st
 int type;
 int save_type;
 int references;
 union {
  char *ptr;
  struct rsa_st *rsa;
  struct dsa_st *dsa;
  struct dh_st *dh;
  struct ec_key_st *ec;
  } pkey;
 int save_parameters;
 STACK *attributes;
# 229 "/usr/include/openssl/evp.h" 3 4
struct env_md_st
 int type;
 int pkey_type;
 int md_size;
 int (*init)(EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*update)(EVP_MD_CTX *ctx,const void *data,size_t count) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*final)(EVP_MD_CTX *ctx,unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*copy)(EVP_MD_CTX *to,const EVP_MD_CTX *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*cleanup)(EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*sign)(int type, const unsigned char *m, unsigned int m_length,
      unsigned char *sigret, unsigned int *siglen, void *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*verify)(int type, const unsigned char *m, unsigned int m_length,
        const unsigned char *sigbuf, unsigned int siglen,
 int required_pkey_type[5];
 int block_size;
 int ctx_size;
typedef int evp_sign_method(int type,const unsigned char *m,
       unsigned int m_length,unsigned char *sigret,
       unsigned int *siglen, void *key);
typedef int evp_verify_method(int type,const unsigned char *m,
       unsigned int m_length,const unsigned char *sigbuf,
       unsigned int siglen, void *key);
typedef struct
 EVP_MD_CTX *mctx;
 void *key;
 } EVP_MD_SVCTX;
# 306 "/usr/include/openssl/evp.h" 3 4
struct env_md_ctx_st
 const EVP_MD *digest;
 ENGINE *engine;
 void *md_data;
# 334 "/usr/include/openssl/evp.h" 3 4
struct evp_cipher_st
 int nid;
 int block_size;
 int key_len;
 int iv_len;
 int (*init)(EVP_CIPHER_CTX *ctx, const unsigned char *key,
      const unsigned char *iv, int enc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*do_cipher)(EVP_CIPHER_CTX *ctx, unsigned char *out,
    const unsigned char *in, unsigned int inl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*cleanup)(EVP_CIPHER_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int ctx_size;
 int (*set_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_asn1_parameters)(EVP_CIPHER_CTX *, ASN1_TYPE *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ctrl)(EVP_CIPHER_CTX *, int type, int arg, void *ptr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void *app_data;
# 396 "/usr/include/openssl/evp.h" 3 4
typedef struct evp_cipher_info_st
 const EVP_CIPHER *cipher;
 unsigned char iv[16];
 } EVP_CIPHER_INFO;
struct evp_cipher_ctx_st
 ENGINE *engine;
 int encrypt;
 int buf_len;
 unsigned char oiv[16];
 unsigned char buf[32];
 int num;
 void *app_data;
 int key_len;
 void *cipher_data;
 int final_used;
 int block_mask;
 unsigned char final[32];
typedef struct evp_Encode_Ctx_st
 int num;
 int length;
 unsigned char enc_data[80];
 int line_num;
 int expect_nl;
 } EVP_ENCODE_CTX;
typedef int (EVP_PBE_KEYGEN)(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
  ASN1_TYPE *param, const EVP_CIPHER *cipher,
                const EVP_MD *md, int en_de);
# 479 "/usr/include/openssl/evp.h" 3 4
int EVP_MD_type(const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_pkey_type(const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_size(const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_block_size(const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD * EVP_MD_CTX_md(const EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_nid(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_block_size(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_key_length(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_iv_length(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long EVP_CIPHER_flags(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER * EVP_CIPHER_CTX_cipher(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_nid(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_block_size(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_key_length(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_iv_length(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * EVP_CIPHER_CTX_get_app_data(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_CIPHER_CTX_set_app_data(EVP_CIPHER_CTX *ctx, void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long EVP_CIPHER_CTX_flags(const EVP_CIPHER_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 533 "/usr/include/openssl/evp.h" 3 4
int EVP_Cipher(EVP_CIPHER_CTX *c,
  unsigned char *out,
# 547 "/usr/include/openssl/evp.h" 3 4
void EVP_MD_CTX_init(EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_CTX_cleanup(EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_MD_CTX *EVP_MD_CTX_create(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_MD_CTX_destroy(EVP_MD_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_CTX_copy_ex(EVP_MD_CTX *out,const EVP_MD_CTX *in) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_MD_CTX_set_flags(EVP_MD_CTX *ctx, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_MD_CTX_clear_flags(EVP_MD_CTX *ctx, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_CTX_test_flags(const EVP_MD_CTX *ctx,int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DigestInit_ex(EVP_MD_CTX *ctx, const EVP_MD *type, ENGINE *impl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DigestUpdate(EVP_MD_CTX *ctx,const void *d,
    size_t cnt) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DigestFinal_ex(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_Digest(const void *data, size_t count,
  unsigned char *md, unsigned int *size, const EVP_MD *type, ENGINE *impl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_MD_CTX_copy(EVP_MD_CTX *out,const EVP_MD_CTX *in) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DigestInit(EVP_MD_CTX *ctx, const EVP_MD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DigestFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_read_pw_string(char *buf,int length,const char *prompt,int verify) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_set_pw_prompt(const char *prompt) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * EVP_get_pw_prompt(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_BytesToKey(const EVP_CIPHER *type,const EVP_MD *md,
  const unsigned char *salt, const unsigned char *data,
  int datal, int count, unsigned char *key,unsigned char *iv) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_CIPHER_CTX_set_flags(EVP_CIPHER_CTX *ctx, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_CIPHER_CTX_clear_flags(EVP_CIPHER_CTX *ctx, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_test_flags(const EVP_CIPHER_CTX *ctx,int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_EncryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
  const unsigned char *key, const unsigned char *iv) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_EncryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_EncryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
  int *outl, const unsigned char *in, int inl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_EncryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_EncryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DecryptInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
int EVP_DecryptInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_DecryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_DecryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DecryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CipherInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher,
         const unsigned char *key,const unsigned char *iv,
int EVP_CipherInit_ex(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *cipher, ENGINE *impl,
int EVP_CipherUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out,
int EVP_CipherFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CipherFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_SignFinal(EVP_MD_CTX *ctx,unsigned char *md,unsigned int *s,
  EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_VerifyFinal(EVP_MD_CTX *ctx,const unsigned char *sigbuf,
  unsigned int siglen,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_OpenInit(EVP_CIPHER_CTX *ctx,const EVP_CIPHER *type,
  const unsigned char *ek, int ekl, const unsigned char *iv,
  EVP_PKEY *priv) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_OpenFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_SealInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *type,
   unsigned char **ek, int *ekl, unsigned char *iv,
  EVP_PKEY **pubk, int npubk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_SealFinal(EVP_CIPHER_CTX *ctx,unsigned char *out,int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_EncodeInit(EVP_ENCODE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_EncodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
  const unsigned char *in,int inl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_EncodeFinal(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_EncodeBlock(unsigned char *t, const unsigned char *f, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_DecodeInit(EVP_ENCODE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_DecodeUpdate(EVP_ENCODE_CTX *ctx,unsigned char *out,int *outl,
int EVP_DecodeFinal(EVP_ENCODE_CTX *ctx, unsigned
int EVP_DecodeBlock(unsigned char *t, const unsigned char *f, int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_CIPHER_CTX_init(EVP_CIPHER_CTX *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_cleanup(EVP_CIPHER_CTX *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_CIPHER_CTX *EVP_CIPHER_CTX_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_CIPHER_CTX_free(EVP_CIPHER_CTX *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_set_key_length(EVP_CIPHER_CTX *x, int keylen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_set_padding(EVP_CIPHER_CTX *c, int pad) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_ctrl(EVP_CIPHER_CTX *ctx, int type, int arg, void *ptr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_CTX_rand_key(EVP_CIPHER_CTX *ctx, unsigned char *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_md(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_base64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_cipher(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO_METHOD *BIO_f_reliable(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_set_cipher(BIO *b,const EVP_CIPHER *c,const unsigned char *k,
  const unsigned char *i, int enc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_md_null(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_md2(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_md4(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_md5(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_dss(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_dss1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_ecdsa(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha224(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha256(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha384(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_sha512(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_mdc2(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_ripemd160(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_enc_null(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_cfb1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_cfb8(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_cfb1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_cfb8(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_des_ede3_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_desx_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 724 "/usr/include/openssl/evp.h" 3 4
const EVP_CIPHER *EVP_rc4(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc4_40(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_40_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_64_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc2_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_bf_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_bf_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_bf_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_bf_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_cast5_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_cast5_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_cast5_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_cast5_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc5_32_12_16_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc5_32_12_16_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc5_32_12_16_cfb64(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_rc5_32_12_16_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_cfb1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_cfb8(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_cfb128(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_128_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_cfb1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_cfb8(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_cfb128(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_192_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_cfb1(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_cfb8(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_cfb128(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_aes_256_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 814 "/usr/include/openssl/evp.h" 3 4
const EVP_CIPHER *EVP_seed_ecb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_seed_cbc(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_seed_cfb128(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_seed_ofb(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OPENSSL_add_all_algorithms_noconf(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OPENSSL_add_all_algorithms_conf(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 832 "/usr/include/openssl/evp.h" 3 4
void OpenSSL_add_all_ciphers(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void OpenSSL_add_all_digests(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_add_cipher(const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_add_digest(const EVP_MD *digest) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_CIPHER *EVP_get_cipherbyname(const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EVP_MD *EVP_get_digestbyname(const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_decrypt(unsigned char *dec_key,
   const unsigned char *enc_key,int enc_key_len,
   EVP_PKEY *private_key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_encrypt(unsigned char *enc_key,
   const unsigned char *key,int key_len,
   EVP_PKEY *pub_key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_type(int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_bits(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_size(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_assign(EVP_PKEY *pkey,int type,char *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct rsa_st;
int EVP_PKEY_set1_RSA(EVP_PKEY *pkey,struct rsa_st *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct rsa_st *EVP_PKEY_get1_RSA(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dsa_st;
int EVP_PKEY_set1_DSA(EVP_PKEY *pkey,struct dsa_st *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dsa_st *EVP_PKEY_get1_DSA(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dh_st;
int EVP_PKEY_set1_DH(EVP_PKEY *pkey,struct dh_st *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dh_st *EVP_PKEY_get1_DH(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct ec_key_st;
int EVP_PKEY_set1_EC_KEY(EVP_PKEY *pkey,struct ec_key_st *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct ec_key_st *EVP_PKEY_get1_EC_KEY(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * EVP_PKEY_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_PKEY_free(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * d2i_PublicKey(int type,EVP_PKEY **a, const unsigned char **pp,
int i2d_PublicKey(EVP_PKEY *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * d2i_PrivateKey(int type,EVP_PKEY **a, const unsigned char **pp,
EVP_PKEY * d2i_AutoPrivateKey(EVP_PKEY **a, const unsigned char **pp,
int i2d_PrivateKey(EVP_PKEY *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_copy_parameters(EVP_PKEY *to, const EVP_PKEY *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_missing_parameters(const EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_save_parameters(EVP_PKEY *pkey,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_cmp_parameters(const EVP_PKEY *a, const EVP_PKEY *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_cmp(const EVP_PKEY *a, const EVP_PKEY *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_type(const EVP_CIPHER *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_param_to_asn1(EVP_CIPHER_CTX *c, ASN1_TYPE *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_asn1_to_param(EVP_CIPHER_CTX *c, ASN1_TYPE *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_set_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_CIPHER_get_asn1_iv(EVP_CIPHER_CTX *c,ASN1_TYPE *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS5_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
    ASN1_TYPE *param, const EVP_CIPHER *cipher, const EVP_MD *md,
    int en_de) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS5_PBKDF2_HMAC_SHA1(const char *pass, int passlen,
      const unsigned char *salt, int saltlen, int iter,
      int keylen, unsigned char *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS5_v2_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
void PKCS5_PBE_add(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PBE_CipherInit (ASN1_OBJECT *pbe_obj, const char *pass, int passlen,
      ASN1_TYPE *param, EVP_CIPHER_CTX *ctx, int en_de) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PBE_alg_add(int nid, const EVP_CIPHER *cipher, const EVP_MD *md,
      EVP_PBE_KEYGEN *keygen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EVP_PBE_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 942 "/usr/include/openssl/evp.h" 3 4
void EVP_add_alg_module(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_EVP_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 76 "/usr/include/openssl/x509.h" 2 3 4
# 85 "/usr/include/openssl/x509.h" 3 4
# 1 "/usr/include/openssl/ec.h" 1 3 4
# 77 "/usr/include/openssl/ec.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 78 "/usr/include/openssl/ec.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 85 "/usr/include/openssl/ec.h" 2 3 4
# 102 "/usr/include/openssl/ec.h" 3 4
typedef enum {
 POINT_CONVERSION_COMPRESSED = 2,
 POINT_CONVERSION_UNCOMPRESSED = 4,
 POINT_CONVERSION_HYBRID = 6
} point_conversion_form_t;
typedef struct ec_method_st EC_METHOD;
typedef struct ec_group_st
# 121 "/usr/include/openssl/ec.h" 3 4
 EC_GROUP;
typedef struct ec_point_st EC_POINT;
const EC_METHOD *EC_GFp_simple_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_METHOD *EC_GFp_mont_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_METHOD *EC_GFp_nist_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_METHOD *EC_GF2m_simple_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_GROUP *EC_GROUP_new(const EC_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_GROUP_free(EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_GROUP_clear_free(EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_copy(EC_GROUP *, const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_GROUP *EC_GROUP_dup(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_METHOD *EC_GROUP_method_of(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_METHOD_get_field_type(const EC_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_set_generator(EC_GROUP *, const EC_POINT *generator, const BIGNUM *order, const BIGNUM *cofactor) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_POINT *EC_GROUP_get0_generator(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_order(const EC_GROUP *, BIGNUM *order, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_cofactor(const EC_GROUP *, BIGNUM *cofactor, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_GROUP_set_curve_name(EC_GROUP *, int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_curve_name(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_GROUP_set_asn1_flag(EC_GROUP *, int flag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_asn1_flag(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_GROUP_set_point_conversion_form(EC_GROUP *, point_conversion_form_t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
point_conversion_form_t EC_GROUP_get_point_conversion_form(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *EC_GROUP_get0_seed(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t EC_GROUP_get_seed_len(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t EC_GROUP_set_seed(EC_GROUP *, const unsigned char *, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_set_curve_GFp(EC_GROUP *, const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_curve_GFp(const EC_GROUP *, BIGNUM *p, BIGNUM *a, BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_set_curve_GF2m(EC_GROUP *, const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_curve_GF2m(const EC_GROUP *, BIGNUM *p, BIGNUM *a, BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_degree(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_check(const EC_GROUP *group, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_check_discriminant(const EC_GROUP *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_cmp(const EC_GROUP *, const EC_GROUP *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_GROUP *EC_GROUP_new_curve_GFp(const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_GROUP *EC_GROUP_new_curve_GF2m(const BIGNUM *p, const BIGNUM *a, const BIGNUM *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_GROUP *EC_GROUP_new_by_curve_name(int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef struct {
 int nid;
 const char *comment;
 } EC_builtin_curve;
size_t EC_get_builtin_curves(EC_builtin_curve *r, size_t nitems) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_POINT *EC_POINT_new(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_POINT_free(EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_POINT_clear_free(EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_copy(EC_POINT *, const EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_POINT *EC_POINT_dup(const EC_POINT *, const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_METHOD *EC_POINT_method_of(const EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_set_to_infinity(const EC_GROUP *, EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_set_Jprojective_coordinates_GFp(const EC_GROUP *, EC_POINT *,
 const BIGNUM *x, const BIGNUM *y, const BIGNUM *z, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_get_Jprojective_coordinates_GFp(const EC_GROUP *, const EC_POINT *,
 BIGNUM *x, BIGNUM *y, BIGNUM *z, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_set_affine_coordinates_GFp(const EC_GROUP *, EC_POINT *,
 const BIGNUM *x, const BIGNUM *y, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_get_affine_coordinates_GFp(const EC_GROUP *, const EC_POINT *,
 BIGNUM *x, BIGNUM *y, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_set_compressed_coordinates_GFp(const EC_GROUP *, EC_POINT *,
 const BIGNUM *x, int y_bit, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_set_affine_coordinates_GF2m(const EC_GROUP *, EC_POINT *,
int EC_POINT_get_affine_coordinates_GF2m(const EC_GROUP *, const EC_POINT *,
int EC_POINT_set_compressed_coordinates_GF2m(const EC_GROUP *, EC_POINT *,
size_t EC_POINT_point2oct(const EC_GROUP *, const EC_POINT *, point_conversion_form_t form,
        unsigned char *buf, size_t len, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_oct2point(const EC_GROUP *, EC_POINT *,
        const unsigned char *buf, size_t len, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIGNUM *EC_POINT_point2bn(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BIGNUM *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_POINT *EC_POINT_bn2point(const EC_GROUP *, const BIGNUM *,
 EC_POINT *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *EC_POINT_point2hex(const EC_GROUP *, const EC_POINT *,
 point_conversion_form_t form, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_POINT *EC_POINT_hex2point(const EC_GROUP *, const char *,
int EC_POINT_add(const EC_GROUP *, EC_POINT *r, const EC_POINT *a, const EC_POINT *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_dbl(const EC_GROUP *, EC_POINT *r, const EC_POINT *a, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_invert(const EC_GROUP *, EC_POINT *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_is_at_infinity(const EC_GROUP *, const EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_is_on_curve(const EC_GROUP *, const EC_POINT *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_cmp(const EC_GROUP *, const EC_POINT *a, const EC_POINT *b, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_make_affine(const EC_GROUP *, EC_POINT *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINTs_make_affine(const EC_GROUP *, size_t num, EC_POINT *[], BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINTs_mul(const EC_GROUP *, EC_POINT *r, const BIGNUM *, size_t num, const EC_POINT *[], const BIGNUM *[], BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_POINT_mul(const EC_GROUP *, EC_POINT *r, const BIGNUM *, const EC_POINT *, const BIGNUM *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_precompute_mult(EC_GROUP *, BN_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_have_precompute_mult(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_basis_type(const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_trinomial_basis(const EC_GROUP *, unsigned int *k) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_GROUP_get_pentanomial_basis(const EC_GROUP *, unsigned int *k1,
 unsigned int *k2, unsigned int *k3) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef struct ecpk_parameters_st ECPKPARAMETERS;
EC_GROUP *d2i_ECPKParameters(EC_GROUP **, const unsigned char **in, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ECPKParameters(const EC_GROUP *, unsigned char **out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 292 "/usr/include/openssl/ec.h" 3 4
int ECPKParameters_print(BIO *bp, const EC_GROUP *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECPKParameters_print_fp(FILE *fp, const EC_GROUP *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
typedef struct ec_key_st EC_KEY;
EC_KEY *EC_KEY_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *EC_KEY_new_by_curve_name(int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_KEY_free(EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *EC_KEY_copy(EC_KEY *, const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *EC_KEY_dup(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_up_ref(EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_GROUP *EC_KEY_get0_group(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_set_group(EC_KEY *, const EC_GROUP *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const BIGNUM *EC_KEY_get0_private_key(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_set_private_key(EC_KEY *, const BIGNUM *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const EC_POINT *EC_KEY_get0_public_key(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_set_public_key(EC_KEY *, const EC_POINT *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned EC_KEY_get_enc_flags(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_KEY_set_enc_flags(EC_KEY *, unsigned int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
point_conversion_form_t EC_KEY_get_conv_form(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void EC_KEY_set_conv_form(EC_KEY *, point_conversion_form_t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *EC_KEY_get_key_method_data(EC_KEY *,
 void *(*dup_func)(void *), void (*free_func)(void *), void (*clear_free_func)(void *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 334 "/usr/include/openssl/ec.h" 3 4
void *EC_KEY_insert_key_method_data(EC_KEY *key, void *data,
void EC_KEY_set_asn1_flag(EC_KEY *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_precompute_mult(EC_KEY *, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_generate_key(EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_check_key(const EC_KEY *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_ECPrivateKey(EC_KEY **a, const unsigned char **in, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ECPrivateKey(EC_KEY *a, unsigned char **out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_ECParameters(EC_KEY **a, const unsigned char **in, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ECParameters(EC_KEY *a, unsigned char **out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *o2i_ECPublicKey(EC_KEY **a, const unsigned char **in, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2o_ECPublicKey(EC_KEY *a, unsigned char **out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECParameters_print(BIO *bp, const EC_KEY *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_print(BIO *bp, const EC_KEY *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECParameters_print_fp(FILE *fp, const EC_KEY *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EC_KEY_print_fp(FILE *fp, const EC_KEY *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 379 "/usr/include/openssl/ec.h" 3 4
void ERR_load_EC_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 86 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdsa.h" 1 3 4
# 64 "/usr/include/openssl/ecdsa.h" 3 4
# 65 "/usr/include/openssl/ecdsa.h" 2 3 4
# 80 "/usr/include/openssl/ecdsa.h" 3 4
typedef struct ECDSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } ECDSA_SIG;
ECDSA_SIG *ECDSA_SIG_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ECDSA_SIG_free(ECDSA_SIG *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 105 "/usr/include/openssl/ecdsa.h" 3 4
int i2d_ECDSA_SIG(const ECDSA_SIG *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 115 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *d2i_ECDSA_SIG(ECDSA_SIG **v, const unsigned char **pp, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 125 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign(const unsigned char *dgst,int dgst_len,EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 138 "/usr/include/openssl/ecdsa.h" 3 4
ECDSA_SIG *ECDSA_do_sign_ex(const unsigned char *dgst, int dgstlen,
  const BIGNUM *kinv, const BIGNUM *rp, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 150 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_do_verify(const unsigned char *dgst, int dgst_len,
  const ECDSA_SIG *sig, EC_KEY* eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const ECDSA_METHOD *ECDSA_OpenSSL(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ECDSA_set_default_method(const ECDSA_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const ECDSA_METHOD *ECDSA_get_default_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDSA_set_method(EC_KEY *eckey, const ECDSA_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDSA_size(const EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 190 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_setup(EC_KEY *eckey, BN_CTX *ctx, BIGNUM **kinv,
  BIGNUM **rp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 204 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 222 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_sign_ex(int type, const unsigned char *dgst, int dgstlen,
  unsigned char *sig, unsigned int *siglen, const BIGNUM *kinv,
# 237 "/usr/include/openssl/ecdsa.h" 3 4
int ECDSA_verify(int type, const unsigned char *dgst, int dgstlen,
  const unsigned char *sig, int siglen, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
  *new_func, CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDSA_set_ex_data(EC_KEY *d, int idx, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ECDSA_get_ex_data(EC_KEY *d, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_ECDSA_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 90 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/ecdh.h" 1 3 4
# 74 "/usr/include/openssl/ecdh.h" 3 4
# 75 "/usr/include/openssl/ecdh.h" 2 3 4
# 90 "/usr/include/openssl/ecdh.h" 3 4
const ECDH_METHOD *ECDH_OpenSSL(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ECDH_set_default_method(const ECDH_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const ECDH_METHOD *ECDH_get_default_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDH_set_method(EC_KEY *, const ECDH_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDH_compute_key(void *out, size_t outlen, const EC_POINT *pub_key, EC_KEY *ecdh,
                     void *(*KDF)(const void *in, size_t inlen, void *out, size_t *outlen)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ECDH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new
int ECDH_set_ex_data(EC_KEY *d, int idx, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *ECDH_get_ex_data(EC_KEY *d, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_ECDH_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 94 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/rsa.h" 1 3 4
# 106 "/usr/include/openssl/rsa.h" 3 4
struct rsa_meth_st
 const char *name;
 int (*rsa_pub_enc)(int flen,const unsigned char *from,
      unsigned char *to,
      RSA *rsa,int padding) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*rsa_pub_dec)(int flen,const unsigned char *from,
      unsigned char *to,
 int (*rsa_priv_enc)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_priv_dec)(int flen,const unsigned char *from,
       unsigned char *to,
 int (*rsa_mod_exp)(BIGNUM *r0,const BIGNUM *I,RSA *rsa,BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bn_mod_exp)(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
     const BIGNUM *m, BN_CTX *ctx,
     BN_MONT_CTX *m_ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*init)(RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*finish)(RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int flags;
 char *app_data;
 int (*rsa_sign)(int type,
  unsigned char *sigret, unsigned int *siglen, const RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*rsa_verify)(int dtype,
  unsigned char *sigbuf, unsigned int siglen, const RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*rsa_keygen)(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct rsa_st
 int pad;
 long version;
 const RSA_METHOD *meth;
 ENGINE *engine;
 BIGNUM *n;
 BIGNUM *e;
 BIGNUM *d;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *dmp1;
 BIGNUM *dmq1;
 BIGNUM *iqmp;
 CRYPTO_EX_DATA ex_data;
 int references;
 int flags;
 BN_MONT_CTX *_method_mod_n;
 BN_MONT_CTX *_method_mod_p;
 BN_MONT_CTX *_method_mod_q;
 char *bignum_data;
 BN_BLINDING *blinding;
 BN_BLINDING *mt_blinding;
# 254 "/usr/include/openssl/rsa.h" 3 4
RSA * RSA_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA * RSA_new_method(ENGINE *engine) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_size(const RSA *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA * RSA_generate_key(int bits, unsigned long e,void
  (*callback)(int,int,void *),void *cb_arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_generate_key_ex(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_X931_derive_ex(RSA *rsa, BIGNUM *p1, BIGNUM *p2, BIGNUM *q1, BIGNUM *q2,
   const BIGNUM *Xp1, const BIGNUM *Xp2, const BIGNUM *Xp,
   const BIGNUM *Xq1, const BIGNUM *Xq2, const BIGNUM *Xq,
   const BIGNUM *e, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_X931_generate_key_ex(RSA *rsa, int bits, const BIGNUM *e, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_check_key(const RSA *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_public_encrypt(int flen, const unsigned char *from,
  unsigned char *to, RSA *rsa,int padding) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_private_encrypt(int flen, const unsigned char *from,
int RSA_public_decrypt(int flen, const unsigned char *from,
int RSA_private_decrypt(int flen, const unsigned char *from,
void RSA_free (RSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_up_ref(RSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_flags(const RSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void RSA_set_default_method(const RSA_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const RSA_METHOD *RSA_get_default_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const RSA_METHOD *RSA_get_method(const RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_set_method(RSA *rsa, const RSA_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_memory_lock(RSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const RSA_METHOD *RSA_PKCS1_SSLeay(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const RSA_METHOD *RSA_null_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSAPublicKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPublicKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPublicKey_it;
RSA *d2i_RSAPrivateKey(RSA **a, const unsigned char **in, long len); int i2d_RSAPrivateKey(const RSA *a, unsigned char **out); extern const ASN1_ITEM RSAPrivateKey_it;
int RSA_print_fp(FILE *fp, const RSA *r,int offset) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_print(BIO *bp, const RSA *r,int offset) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSA_NET(const RSA *a, unsigned char **pp,
  int (*cb)(char *buf, int len, const char *prompt, int verify),
  int sgckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSA_NET(RSA **a, const unsigned char **pp, long length,
int i2d_Netscape_RSA(const RSA *a, unsigned char **pp,
          int verify)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_Netscape_RSA(RSA **a, const unsigned char **pp, long length,
int RSA_sign(int type, const unsigned char *m, unsigned int m_length,
 unsigned char *sigret, unsigned int *siglen, RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_verify(int type, const unsigned char *m, unsigned int m_length,
 unsigned char *sigbuf, unsigned int siglen, RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_sign_ASN1_OCTET_STRING(int type,
int RSA_verify_ASN1_OCTET_STRING(int type,
int RSA_blinding_on(RSA *rsa, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void RSA_blinding_off(RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BN_BLINDING *RSA_setup_blinding(RSA *rsa, BN_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_add_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_check_PKCS1_type_1(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_add_PKCS1_type_2(unsigned char *to,int tlen,
int RSA_padding_check_PKCS1_type_2(unsigned char *to,int tlen,
int PKCS1_MGF1(unsigned char *mask, long len,
 const unsigned char *seed, long seedlen, const EVP_MD *dgst) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_add_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *p,int pl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_check_PKCS1_OAEP(unsigned char *to,int tlen,
 const unsigned char *f,int fl,int rsa_len,
int RSA_padding_add_SSLv23(unsigned char *to,int tlen,
int RSA_padding_check_SSLv23(unsigned char *to,int tlen,
int RSA_padding_add_none(unsigned char *to,int tlen,
int RSA_padding_check_none(unsigned char *to,int tlen,
int RSA_padding_add_X931(unsigned char *to,int tlen,
int RSA_padding_check_X931(unsigned char *to,int tlen,
int RSA_X931_hash_id(int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_verify_PKCS1_PSS(RSA *rsa, const unsigned char *mHash,
   const EVP_MD *Hash, const unsigned char *EM, int sLen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_padding_add_PKCS1_PSS(RSA *rsa, unsigned char *EM,
   const EVP_MD *Hash, int sLen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int RSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int RSA_set_ex_data(RSA *r,int idx,void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *RSA_get_ex_data(const RSA *r, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *RSAPublicKey_dup(RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *RSAPrivateKey_dup(RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_RSA_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 99 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/dsa.h" 1 3 4
# 70 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 71 "/usr/include/openssl/dsa.h" 2 3 4
# 85 "/usr/include/openssl/dsa.h" 3 4
# 1 "/usr/include/openssl/dh.h" 1 3 4
# 64 "/usr/include/openssl/dh.h" 3 4
# 65 "/usr/include/openssl/dh.h" 2 3 4
# 101 "/usr/include/openssl/dh.h" 3 4
struct dh_method
 const char *name;
 int (*generate_key)(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*compute_key)(unsigned char *key,const BIGNUM *pub_key,DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bn_mod_exp)(const DH *dh, BIGNUM *r, const BIGNUM *a,
    const BIGNUM *p, const BIGNUM *m, BN_CTX *ctx,
 int (*init)(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*finish)(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int flags;
 char *app_data;
 int (*generate_params)(DH *dh, int prime_len, int generator, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dh_st
 int pad;
 int version;
 BIGNUM *p;
 BIGNUM *g;
 long length;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 int flags;
 BN_MONT_CTX *method_mont_p;
 BIGNUM *q;
 BIGNUM *j;
 unsigned char *seed;
 int seedlen;
 BIGNUM *counter;
 int references;
 const DH_METHOD *meth;
 ENGINE *engine;
# 172 "/usr/include/openssl/dh.h" 3 4
const DH_METHOD *DH_OpenSSL(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void DH_set_default_method(const DH_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const DH_METHOD *DH_get_default_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_set_method(DH *dh, const DH_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DH *DH_new_method(ENGINE *engine) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DH * DH_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void DH_free(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_up_ref(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_size(const DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DH_set_ex_data(DH *d, int idx, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *DH_get_ex_data(DH *d, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DH * DH_generate_parameters(int prime_len,int generator,
  void (*callback)(int,int,void *),void *cb_arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_generate_parameters_ex(DH *dh, int prime_len,int generator, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_check(const DH *dh,int *codes) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_check_pub_key(const DH *dh,const BIGNUM *pub_key, int *codes) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_generate_key(DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DH_compute_key(unsigned char *key,const BIGNUM *pub_key,DH *dh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DH * d2i_DHparams(DH **a,const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DHparams(const DH *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DHparams_print_fp(FILE *fp, const DH *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DHparams_print(BIO *bp, const DH *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 221 "/usr/include/openssl/dh.h" 3 4
void ERR_load_DH_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 86 "/usr/include/openssl/dsa.h" 2 3 4
# 131 "/usr/include/openssl/dsa.h" 3 4
typedef struct DSA_SIG_st
 BIGNUM *r;
 BIGNUM *s;
 } DSA_SIG;
struct dsa_method
 const char *name;
 DSA_SIG * (*dsa_do_sign)(const unsigned char *dgst, int dlen, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*dsa_sign_setup)(DSA *dsa, BN_CTX *ctx_in, BIGNUM **kinvp,
 int (*dsa_do_verify)(const unsigned char *dgst, int dgst_len,
       DSA_SIG *sig, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*dsa_mod_exp)(DSA *dsa, BIGNUM *rr, BIGNUM *a1, BIGNUM *p1,
   BIGNUM *a2, BIGNUM *p2, BIGNUM *m, BN_CTX *ctx,
   BN_MONT_CTX *in_mont) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*bn_mod_exp)(DSA *dsa, BIGNUM *r, BIGNUM *a, const BIGNUM *p,
 int (*init)(DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*finish)(DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int flags;
 char *app_data;
 int (*dsa_paramgen)(DSA *dsa, int bits,
   unsigned char *seed, int seed_len,
   int *counter_ret, unsigned long *h_ret,
 int (*dsa_keygen)(DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
struct dsa_st
 int pad;
 long version;
 int write_params;
 BIGNUM *p;
 BIGNUM *q;
 BIGNUM *g;
 BIGNUM *pub_key;
 BIGNUM *priv_key;
 BIGNUM *kinv;
 BIGNUM *r;
 int flags;
 int references;
 const DSA_METHOD *meth;
 ENGINE *engine;
# 200 "/usr/include/openssl/dsa.h" 3 4
DSA_SIG * DSA_SIG_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void DSA_SIG_free(DSA_SIG *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSA_SIG(const DSA_SIG *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA_SIG * d2i_DSA_SIG(DSA_SIG **v, const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA_SIG * DSA_do_sign(const unsigned char *dgst,int dlen,DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_do_verify(const unsigned char *dgst,int dgst_len,
        DSA_SIG *sig,DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const DSA_METHOD *DSA_OpenSSL(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void DSA_set_default_method(const DSA_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const DSA_METHOD *DSA_get_default_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_set_method(DSA *dsa, const DSA_METHOD *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * DSA_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * DSA_new_method(ENGINE *engine) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void DSA_free (DSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_up_ref(DSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_size(const DSA *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_sign_setup( DSA *dsa,BN_CTX *ctx_in,BIGNUM **kinvp,BIGNUM **rp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_sign(int type,const unsigned char *dgst,int dlen,
  unsigned char *sig, unsigned int *siglen, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_verify(int type,const unsigned char *dgst,int dgst_len,
  const unsigned char *sigbuf, int siglen, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DSA_set_ex_data(DSA *d, int idx, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *DSA_get_ex_data(DSA *d, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * d2i_DSAPublicKey(DSA **a, const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * d2i_DSAPrivateKey(DSA **a, const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * d2i_DSAparams(DSA **a, const unsigned char **pp, long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * DSA_generate_parameters(int bits,
  unsigned char *seed,int seed_len,
  int *counter_ret, unsigned long *h_ret,void
  (*callback)(int, int, void *),void *cb_arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_generate_parameters_ex(DSA *dsa, int bits,
  int *counter_ret, unsigned long *h_ret, BN_GENCB *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_generate_key(DSA *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSAPublicKey(const DSA *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSAPrivateKey(const DSA *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSAparams(const DSA *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSAparams_print(BIO *bp, const DSA *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_print(BIO *bp, const DSA *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSAparams_print_fp(FILE *fp, const DSA *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int DSA_print_fp(FILE *bp, const DSA *x, int off) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 277 "/usr/include/openssl/dsa.h" 3 4
DH *DSA_dup_DH(const DSA *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 289 "/usr/include/openssl/dsa.h" 3 4
void ERR_load_DSA_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 102 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/sha.h" 1 3 4
# 64 "/usr/include/openssl/sha.h" 3 4
# 65 "/usr/include/openssl/sha.h" 2 3 4
# 1 "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/include/stddef.h" 1 3 4
# 66 "/usr/include/openssl/sha.h" 2 3 4
# 102 "/usr/include/openssl/sha.h" 3 4
typedef struct SHAstate_st
 unsigned int h0,h1,h2,h3,h4;
 unsigned int Nl,Nh;
 unsigned int data[16];
 unsigned int num;
 } SHA_CTX;
int SHA_Init(SHA_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA_Update(SHA_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA_Final(unsigned char *md, SHA_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA(const unsigned char *d, size_t n, unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SHA_Transform(SHA_CTX *c, const unsigned char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA1_Init(SHA_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA1_Update(SHA_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA1_Final(unsigned char *md, SHA_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA1(const unsigned char *d, size_t n, unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SHA1_Transform(SHA_CTX *c, const unsigned char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 134 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA256state_st
 unsigned int h[8];
 unsigned int Nl,Nh;
 unsigned int num,md_len;
 } SHA256_CTX;
int SHA224_Init(SHA256_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA224_Update(SHA256_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA224_Final(unsigned char *md, SHA256_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA224(const unsigned char *d, size_t n,unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA256_Init(SHA256_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA256_Update(SHA256_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA256_Final(unsigned char *md, SHA256_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA256(const unsigned char *d, size_t n,unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SHA256_Transform(SHA256_CTX *c, const unsigned char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 177 "/usr/include/openssl/sha.h" 3 4
typedef struct SHA512state_st
 unsigned long long h[8];
 unsigned long long Nl,Nh;
 union {
  unsigned long long d[16];
  unsigned char p[(16*8)];
 } u;
 } SHA512_CTX;
int SHA384_Init(SHA512_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA384_Update(SHA512_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA384_Final(unsigned char *md, SHA512_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA384(const unsigned char *d, size_t n,unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA512_Init(SHA512_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA512_Update(SHA512_CTX *c, const void *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SHA512_Final(unsigned char *md, SHA512_CTX *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *SHA512(const unsigned char *d, size_t n,unsigned char *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SHA512_Transform(SHA512_CTX *c, const unsigned char *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 110 "/usr/include/openssl/x509.h" 2 3 4
# 139 "/usr/include/openssl/x509.h" 3 4
typedef struct X509_objects_st
 int nid;
 int (*a2i)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*i2a)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } X509_OBJECTS;
struct X509_algor_st
 ASN1_OBJECT *algorithm;
 ASN1_TYPE *parameter;
typedef STACK X509_ALGORS;
typedef struct X509_val_st
 ASN1_TIME *notBefore;
 ASN1_TIME *notAfter;
 } X509_VAL;
typedef struct X509_pubkey_st
 X509_ALGOR *algor;
 ASN1_BIT_STRING *public_key;
 EVP_PKEY *pkey;
 } X509_PUBKEY;
typedef struct X509_sig_st
 X509_ALGOR *algor;
 ASN1_OCTET_STRING *digest;
 } X509_SIG;
typedef struct X509_name_entry_st
 ASN1_OBJECT *object;
 ASN1_STRING *value;
 int set;
 int size;
 } X509_NAME_ENTRY;
struct X509_name_st
 STACK *entries;
 int modified;
 BUF_MEM *bytes;
 unsigned long hash;
typedef struct X509_extension_st
 ASN1_BOOLEAN critical;
 ASN1_OCTET_STRING *value;
 } X509_EXTENSION;
typedef STACK X509_EXTENSIONS;
typedef struct x509_attributes_st
 int single;
 union {
  char *ptr;
         STACK *set;
         ASN1_TYPE *single;
  } value;
 } X509_ATTRIBUTE;
typedef struct X509_req_info_st
 ASN1_ENCODING enc;
 ASN1_INTEGER *version;
 X509_NAME *subject;
 X509_PUBKEY *pubkey;
 STACK *attributes;
 } X509_REQ_INFO;
typedef struct X509_req_st
 X509_REQ_INFO *req_info;
 X509_ALGOR *sig_alg;
 ASN1_BIT_STRING *signature;
 int references;
 } X509_REQ;
typedef struct x509_cinf_st
 ASN1_INTEGER *serialNumber;
 X509_ALGOR *signature;
 X509_NAME *issuer;
 X509_VAL *validity;
 X509_NAME *subject;
 X509_PUBKEY *key;
 ASN1_BIT_STRING *issuerUID;
 ASN1_BIT_STRING *subjectUID;
 STACK *extensions;
 ASN1_ENCODING enc;
 } X509_CINF;
typedef struct x509_cert_aux_st
 STACK *trust;
 STACK *reject;
 ASN1_UTF8STRING *alias;
 ASN1_OCTET_STRING *keyid;
 STACK *other;
 } X509_CERT_AUX;
struct x509_st
 X509_CINF *cert_info;
 int valid;
 int references;
 char *name;
 long ex_pathlen;
 long ex_pcpathlen;
 unsigned long ex_flags;
 unsigned long ex_kusage;
 unsigned long ex_xkusage;
 unsigned long ex_nscert;
 ASN1_OCTET_STRING *skid;
 struct AUTHORITY_KEYID_st *akid;
 X509_POLICY_CACHE *policy_cache;
 unsigned char sha1_hash[20];
 X509_CERT_AUX *aux;
typedef struct x509_trust_st {
 int trust;
 int flags;
 int (*check_trust)(struct x509_trust_st *, X509 *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 char *name;
 int arg1;
 void *arg2;
} X509_TRUST;
typedef struct x509_cert_pair_st {
 X509 *forward;
 X509 *reverse;
} X509_CERT_PAIR;
# 430 "/usr/include/openssl/x509.h" 3 4
typedef struct X509_revoked_st
 ASN1_TIME *revocationDate;
 STACK *extensions;
 int sequence;
 } X509_REVOKED;
typedef struct X509_crl_info_st
 X509_NAME *issuer;
 ASN1_TIME *lastUpdate;
 ASN1_TIME *nextUpdate;
 STACK *revoked;
 STACK *extensions;
 ASN1_ENCODING enc;
 } X509_CRL_INFO;
struct X509_crl_st
 X509_CRL_INFO *crl;
 int references;
typedef struct private_key_st
 int version;
 X509_ALGOR *enc_algor;
 ASN1_OCTET_STRING *enc_pkey;
 EVP_PKEY *dec_pkey;
 int key_length;
 char *key_data;
 int key_free;
 EVP_CIPHER_INFO cipher;
 int references;
 } X509_PKEY;
typedef struct X509_info_st
 X509 *x509;
 X509_CRL *crl;
 X509_PKEY *x_pkey;
 EVP_CIPHER_INFO enc_cipher;
 int enc_len;
 char *enc_data;
 int references;
 } X509_INFO;
# 507 "/usr/include/openssl/x509.h" 3 4
typedef struct Netscape_spkac_st
 ASN1_IA5STRING *challenge;
 } NETSCAPE_SPKAC;
typedef struct Netscape_spki_st
 NETSCAPE_SPKAC *spkac;
 X509_ALGOR *sig_algor;
 } NETSCAPE_SPKI;
typedef struct Netscape_certificate_sequence
 ASN1_OBJECT *type;
 STACK *certs;
 } NETSCAPE_CERT_SEQUENCE;
# 536 "/usr/include/openssl/x509.h" 3 4
typedef struct PBEPARAM_st {
ASN1_OCTET_STRING *salt;
ASN1_INTEGER *iter;
} PBEPARAM;
typedef struct PBE2PARAM_st {
X509_ALGOR *keyfunc;
X509_ALGOR *encryption;
} PBE2PARAM;
typedef struct PBKDF2PARAM_st {
ASN1_TYPE *salt;
ASN1_INTEGER *iter;
ASN1_INTEGER *keylength;
X509_ALGOR *prf;
} PBKDF2PARAM;
typedef struct pkcs8_priv_key_info_st
        int broken;
        X509_ALGOR *pkeyalg;
        ASN1_TYPE *pkey;
        STACK *attributes;
        } PKCS8_PRIV_KEY_INFO;
# 1 "/usr/include/openssl/x509_vfy.h" 1 3 4
# 70 "/usr/include/openssl/x509_vfy.h" 3 4
# 71 "/usr/include/openssl/x509_vfy.h" 2 3 4
# 1 "/usr/include/openssl/lhash.h" 1 3 4
# 68 "/usr/include/openssl/lhash.h" 3 4
# 69 "/usr/include/openssl/lhash.h" 2 3 4
# 81 "/usr/include/openssl/lhash.h" 3 4
typedef struct lhash_node_st
 void *data;
 struct lhash_node_st *next;
 unsigned long hash;
 } LHASH_NODE;
typedef int (*LHASH_COMP_FN_TYPE)(const void *, const void *);
typedef unsigned long (*LHASH_HASH_FN_TYPE)(const void *);
typedef void (*LHASH_DOALL_FN_TYPE)(void *);
typedef void (*LHASH_DOALL_ARG_FN_TYPE)(void *, void *);
# 140 "/usr/include/openssl/lhash.h" 3 4
typedef struct lhash_st
 LHASH_NODE **b;
 LHASH_COMP_FN_TYPE comp;
 LHASH_HASH_FN_TYPE hash;
 unsigned int num_nodes;
 unsigned int num_alloc_nodes;
 unsigned int p;
 unsigned int pmax;
 unsigned long up_load;
 unsigned long down_load;
 unsigned long num_items;
 unsigned long num_expands;
 unsigned long num_expand_reallocs;
 unsigned long num_contracts;
 unsigned long num_contract_reallocs;
 unsigned long num_hash_calls;
 unsigned long num_comp_calls;
 unsigned long num_insert;
 unsigned long num_replace;
 unsigned long num_delete;
 unsigned long num_no_delete;
 unsigned long num_retrieve;
 unsigned long num_retrieve_miss;
 unsigned long num_hash_comps;
 int error;
 } LHASH;
LHASH *lh_new(LHASH_HASH_FN_TYPE h, LHASH_COMP_FN_TYPE c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_free(LHASH *lh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *lh_insert(LHASH *lh, void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *lh_delete(LHASH *lh, const void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *lh_retrieve(LHASH *lh, const void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_doall(LHASH *lh, LHASH_DOALL_FN_TYPE func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_doall_arg(LHASH *lh, LHASH_DOALL_ARG_FN_TYPE func, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long lh_strhash(const char *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long lh_num_items(const LHASH *lh) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_stats(const LHASH *lh, FILE *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_node_stats(const LHASH *lh, FILE *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_node_usage_stats(const LHASH *lh, FILE *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_stats_bio(const LHASH *lh, BIO *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_node_stats_bio(const LHASH *lh, BIO *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void lh_node_usage_stats_bio(const LHASH *lh, BIO *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 73 "/usr/include/openssl/x509_vfy.h" 2 3 4
# 77 "/usr/include/openssl/x509_vfy.h" 2 3 4
typedef struct x509_hash_dir_st
 int num_dirs;
 char **dirs;
 int *dirs_type;
 int num_dirs_alloced;
 } X509_HASH_DIR_CTX;
typedef struct x509_file_st
 int num_paths;
 int num_alloced;
 char **paths;
 int *path_type;
 } X509_CERT_FILE_CTX;
# 123 "/usr/include/openssl/x509_vfy.h" 3 4
typedef struct x509_object_st
 int type;
 union {
  char *ptr;
  X509 *x509;
  X509_CRL *crl;
  EVP_PKEY *pkey;
  } data;
 } X509_OBJECT;
typedef struct x509_lookup_st X509_LOOKUP;
typedef struct x509_lookup_method_st
 const char *name;
 int (*new_item)(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*free)(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*init)(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*shutdown)(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ctrl)(X509_LOOKUP *ctx,int cmd,const char *argc,long argl,
   char **ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_by_subject)(X509_LOOKUP *ctx,int type,X509_NAME *name,
         X509_OBJECT *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_by_issuer_serial)(X509_LOOKUP *ctx,int type,X509_NAME *name,
        ASN1_INTEGER *serial,X509_OBJECT *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_by_fingerprint)(X509_LOOKUP *ctx,int type,
      unsigned char *bytes,int len,
 int (*get_by_alias)(X509_LOOKUP *ctx,int type,char *str,int len,
 } X509_LOOKUP_METHOD;
typedef struct X509_VERIFY_PARAM_st
 char *name;
 time_t check_time;
 unsigned long inh_flags;
 unsigned long flags;
 int purpose;
 int trust;
 int depth;
 STACK *policies;
 } X509_VERIFY_PARAM;
struct x509_store_st
 int cache;
 STACK *objs;
 STACK *get_cert_methods;
 X509_VERIFY_PARAM *param;
 int (*verify)(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*verify_cb)(int ok,X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_issuer)(X509 **issuer, X509_STORE_CTX *ctx, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*check_issued)(X509_STORE_CTX *ctx, X509 *x, X509 *issuer) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*check_revocation)(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*get_crl)(X509_STORE_CTX *ctx, X509_CRL **crl, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*check_crl)(X509_STORE_CTX *ctx, X509_CRL *crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*cert_crl)(X509_STORE_CTX *ctx, X509_CRL *crl, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*cleanup)(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int references;
int X509_STORE_set_depth(X509_STORE *store, int depth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int init;
 int skip;
 X509_LOOKUP_METHOD *method;
 char *method_data;
 X509_STORE *store_ctx;
struct x509_store_ctx_st
 X509_STORE *ctx;
 int current_method;
 X509 *cert;
 STACK *untrusted;
 STACK *crls;
 void *other_ctx;
 int (*check_policy)(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int valid;
 int last_untrusted;
 STACK *chain;
 X509_POLICY_TREE *tree;
 int explicit_policy;
 int error_depth;
 int error;
 X509 *current_cert;
 X509 *current_issuer;
 X509_CRL *current_crl;
void X509_STORE_CTX_set_depth(X509_STORE_CTX *ctx, int depth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 383 "/usr/include/openssl/x509_vfy.h" 3 4
int X509_OBJECT_idx_by_subject(STACK *h, int type,
      X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_OBJECT *X509_OBJECT_retrieve_by_subject(STACK *h,int type,X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_OBJECT *X509_OBJECT_retrieve_match(STACK *h, X509_OBJECT *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_OBJECT_up_ref_count(X509_OBJECT *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_OBJECT_free_contents(X509_OBJECT *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_STORE *X509_STORE_new(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_free(X509_STORE *v) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_set_flags(X509_STORE *ctx, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_set_purpose(X509_STORE *ctx, int purpose) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_set_trust(X509_STORE *ctx, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_set1_param(X509_STORE *ctx, X509_VERIFY_PARAM *pm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_STORE_CTX *X509_STORE_CTX_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_get1_issuer(X509 **issuer, X509_STORE_CTX *ctx, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_free(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_init(X509_STORE_CTX *ctx, X509_STORE *store,
    X509 *x509, STACK *chain) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_trusted_stack(X509_STORE_CTX *ctx, STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_cleanup(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_LOOKUP *X509_STORE_add_lookup(X509_STORE *v, X509_LOOKUP_METHOD *m) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_LOOKUP_METHOD *X509_LOOKUP_hash_dir(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_LOOKUP_METHOD *X509_LOOKUP_file(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_add_cert(X509_STORE *ctx, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_add_crl(X509_STORE *ctx, X509_CRL *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_get_by_subject(X509_STORE_CTX *vs,int type,X509_NAME *name,
int X509_LOOKUP_ctrl(X509_LOOKUP *ctx, int cmd, const char *argc,
 long argl, char **ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_load_cert_file(X509_LOOKUP *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_load_crl_file(X509_LOOKUP *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_load_cert_crl_file(X509_LOOKUP *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_LOOKUP *X509_LOOKUP_new(X509_LOOKUP_METHOD *method) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_LOOKUP_free(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_LOOKUP_init(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_LOOKUP_by_subject(X509_LOOKUP *ctx, int type, X509_NAME *name,
int X509_LOOKUP_by_issuer_serial(X509_LOOKUP *ctx, int type, X509_NAME *name,
 ASN1_INTEGER *serial, X509_OBJECT *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_LOOKUP_by_fingerprint(X509_LOOKUP *ctx, int type,
 unsigned char *bytes, int len, X509_OBJECT *ret) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_LOOKUP_by_alias(X509_LOOKUP *ctx, int type, char *str,
int X509_LOOKUP_shutdown(X509_LOOKUP *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_load_locations (X509_STORE *ctx,
  const char *file, const char *dir) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_set_default_paths(X509_STORE *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_STORE_CTX_set_ex_data(X509_STORE_CTX *ctx,int idx,void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * X509_STORE_CTX_get_ex_data(X509_STORE_CTX *ctx,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_get_error(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_error(X509_STORE_CTX *ctx,int s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_get_error_depth(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 * X509_STORE_CTX_get_current_cert(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *X509_STORE_CTX_get_chain(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *X509_STORE_CTX_get1_chain(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_cert(X509_STORE_CTX *c,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_chain(X509_STORE_CTX *c,STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set0_crls(X509_STORE_CTX *c,STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_set_purpose(X509_STORE_CTX *ctx, int purpose) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_set_trust(X509_STORE_CTX *ctx, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_purpose_inherit(X509_STORE_CTX *ctx, int def_purpose,
    int purpose, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_flags(X509_STORE_CTX *ctx, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_time(X509_STORE_CTX *ctx, unsigned long flags,
        time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set_verify_cb(X509_STORE_CTX *ctx,
      int (*verify_cb)(int, X509_STORE_CTX *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_POLICY_TREE *X509_STORE_CTX_get0_policy_tree(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_get_explicit_policy(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_VERIFY_PARAM *X509_STORE_CTX_get0_param(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_STORE_CTX_set0_param(X509_STORE_CTX *ctx, X509_VERIFY_PARAM *param) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_STORE_CTX_set_default(X509_STORE_CTX *ctx, const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_VERIFY_PARAM *X509_VERIFY_PARAM_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_VERIFY_PARAM_free(X509_VERIFY_PARAM *param) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_inherit(X509_VERIFY_PARAM *to,
      const X509_VERIFY_PARAM *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_set1(X509_VERIFY_PARAM *to,
int X509_VERIFY_PARAM_set1_name(X509_VERIFY_PARAM *param, const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_set_flags(X509_VERIFY_PARAM *param, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_clear_flags(X509_VERIFY_PARAM *param,
unsigned long X509_VERIFY_PARAM_get_flags(X509_VERIFY_PARAM *param) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_set_purpose(X509_VERIFY_PARAM *param, int purpose) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_set_trust(X509_VERIFY_PARAM *param, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_VERIFY_PARAM_set_depth(X509_VERIFY_PARAM *param, int depth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_VERIFY_PARAM_set_time(X509_VERIFY_PARAM *param, time_t t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_add0_policy(X509_VERIFY_PARAM *param,
      ASN1_OBJECT *policy) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_set1_policies(X509_VERIFY_PARAM *param,
     STACK *policies) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_get_depth(const X509_VERIFY_PARAM *param) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_VERIFY_PARAM_add0_table(X509_VERIFY_PARAM *param) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const X509_VERIFY_PARAM *X509_VERIFY_PARAM_lookup(const char *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_VERIFY_PARAM_table_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_policy_check(X509_POLICY_TREE **ptree, int *pexplicit_policy,
   STACK *certs,
   STACK *policy_oids,
   unsigned int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_policy_tree_free(X509_POLICY_TREE *tree) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_policy_tree_level_count(const X509_POLICY_TREE *tree) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_POLICY_LEVEL *
 X509_policy_tree_get0_level(const X509_POLICY_TREE *tree, int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *
 X509_policy_tree_get0_policies(const X509_POLICY_TREE *tree) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *
 X509_policy_tree_get0_user_policies(const X509_POLICY_TREE *tree) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_policy_level_node_count(X509_POLICY_LEVEL *level) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_POLICY_NODE *X509_policy_level_get0_node(X509_POLICY_LEVEL *level, int i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const ASN1_OBJECT *X509_policy_node_get0_policy(const X509_POLICY_NODE *node) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *
 X509_policy_node_get0_qualifiers(const X509_POLICY_NODE *node) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 X509_policy_node_get0_parent(const X509_POLICY_NODE *node) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 576 "/usr/include/openssl/x509.h" 2 3 4
# 1 "/usr/include/openssl/pkcs7.h" 1 3 4
# 66 "/usr/include/openssl/pkcs7.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 67 "/usr/include/openssl/pkcs7.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 69 "/usr/include/openssl/pkcs7.h" 2 3 4
# 88 "/usr/include/openssl/pkcs7.h" 3 4
typedef struct pkcs7_issuer_and_serial_st
 X509_NAME *issuer;
 ASN1_INTEGER *serial;
 } PKCS7_ISSUER_AND_SERIAL;
typedef struct pkcs7_signer_info_st
 PKCS7_ISSUER_AND_SERIAL *issuer_and_serial;
 X509_ALGOR *digest_alg;
 STACK *auth_attr;
 X509_ALGOR *digest_enc_alg;
 ASN1_OCTET_STRING *enc_digest;
 STACK *unauth_attr;
 EVP_PKEY *pkey;
 } PKCS7_SIGNER_INFO;
typedef struct pkcs7_recip_info_st
 X509_ALGOR *key_enc_algor;
 ASN1_OCTET_STRING *enc_key;
 X509 *cert;
 } PKCS7_RECIP_INFO;
typedef struct pkcs7_signed_st
 STACK *md_algs;
 STACK *cert;
 STACK *crl;
 STACK *signer_info;
 struct pkcs7_st *contents;
 } PKCS7_SIGNED;
typedef struct pkcs7_enc_content_st
 ASN1_OBJECT *content_type;
 X509_ALGOR *algorithm;
 ASN1_OCTET_STRING *enc_data;
 const EVP_CIPHER *cipher;
 } PKCS7_ENC_CONTENT;
typedef struct pkcs7_enveloped_st
 STACK *recipientinfo;
 PKCS7_ENC_CONTENT *enc_data;
 } PKCS7_ENVELOPE;
typedef struct pkcs7_signedandenveloped_st
 STACK *md_algs;
 STACK *cert;
 STACK *crl;
 STACK *signer_info;
 } PKCS7_SIGN_ENVELOPE;
typedef struct pkcs7_digest_st
 X509_ALGOR *md;
 } PKCS7_DIGEST;
typedef struct pkcs7_encrypted_st
 } PKCS7_ENCRYPT;
typedef struct pkcs7_st
 unsigned char *asn1;
 long length;
 int state;
 int detached;
 ASN1_OBJECT *type;
 union {
  char *ptr;
  ASN1_OCTET_STRING *data;
  PKCS7_SIGNED *sign;
  PKCS7_ENVELOPE *enveloped;
  PKCS7_SIGN_ENVELOPE *signed_and_enveloped;
  PKCS7_DIGEST *digest;
  PKCS7_ENCRYPT *encrypted;
  ASN1_TYPE *other;
  } d;
 } PKCS7;
# 284 "/usr/include/openssl/pkcs7.h" 3 4
PKCS7_ISSUER_AND_SERIAL * PKCS7_ISSUER_AND_SERIAL_new(void); void PKCS7_ISSUER_AND_SERIAL_free(PKCS7_ISSUER_AND_SERIAL *a); PKCS7_ISSUER_AND_SERIAL *d2i_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL **a, const unsigned char **in, long len); int i2d_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ISSUER_AND_SERIAL_it;
int PKCS7_ISSUER_AND_SERIAL_digest(PKCS7_ISSUER_AND_SERIAL *data,const EVP_MD *type,
 unsigned char *md,unsigned int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *d2i_PKCS7_fp(FILE *fp,PKCS7 **p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS7_fp(FILE *fp,PKCS7 *p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *PKCS7_dup(PKCS7 *p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *d2i_PKCS7_bio(BIO *bp,PKCS7 **p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS7_bio(BIO *bp,PKCS7 *p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7_SIGNER_INFO * PKCS7_SIGNER_INFO_new(void); void PKCS7_SIGNER_INFO_free(PKCS7_SIGNER_INFO *a); PKCS7_SIGNER_INFO *d2i_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNER_INFO_it;
PKCS7_RECIP_INFO * PKCS7_RECIP_INFO_new(void); void PKCS7_RECIP_INFO_free(PKCS7_RECIP_INFO *a); PKCS7_RECIP_INFO *d2i_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO **a, const unsigned char **in, long len); int i2d_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS7_RECIP_INFO_it;
PKCS7_SIGNED * PKCS7_SIGNED_new(void); void PKCS7_SIGNED_free(PKCS7_SIGNED *a); PKCS7_SIGNED *d2i_PKCS7_SIGNED(PKCS7_SIGNED **a, const unsigned char **in, long len); int i2d_PKCS7_SIGNED(PKCS7_SIGNED *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGNED_it;
PKCS7_ENC_CONTENT * PKCS7_ENC_CONTENT_new(void); void PKCS7_ENC_CONTENT_free(PKCS7_ENC_CONTENT *a); PKCS7_ENC_CONTENT *d2i_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT **a, const unsigned char **in, long len); int i2d_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENC_CONTENT_it;
PKCS7_ENVELOPE * PKCS7_ENVELOPE_new(void); void PKCS7_ENVELOPE_free(PKCS7_ENVELOPE *a); PKCS7_ENVELOPE *d2i_PKCS7_ENVELOPE(PKCS7_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_ENVELOPE(PKCS7_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENVELOPE_it;
PKCS7_SIGN_ENVELOPE * PKCS7_SIGN_ENVELOPE_new(void); void PKCS7_SIGN_ENVELOPE_free(PKCS7_SIGN_ENVELOPE *a); PKCS7_SIGN_ENVELOPE *d2i_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE **a, const unsigned char **in, long len); int i2d_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE *a, unsigned char **out); extern const ASN1_ITEM PKCS7_SIGN_ENVELOPE_it;
PKCS7_DIGEST * PKCS7_DIGEST_new(void); void PKCS7_DIGEST_free(PKCS7_DIGEST *a); PKCS7_DIGEST *d2i_PKCS7_DIGEST(PKCS7_DIGEST **a, const unsigned char **in, long len); int i2d_PKCS7_DIGEST(PKCS7_DIGEST *a, unsigned char **out); extern const ASN1_ITEM PKCS7_DIGEST_it;
PKCS7_ENCRYPT * PKCS7_ENCRYPT_new(void); void PKCS7_ENCRYPT_free(PKCS7_ENCRYPT *a); PKCS7_ENCRYPT *d2i_PKCS7_ENCRYPT(PKCS7_ENCRYPT **a, const unsigned char **in, long len); int i2d_PKCS7_ENCRYPT(PKCS7_ENCRYPT *a, unsigned char **out); extern const ASN1_ITEM PKCS7_ENCRYPT_it;
PKCS7 * PKCS7_new(void); void PKCS7_free(PKCS7 *a); PKCS7 *d2i_PKCS7(PKCS7 **a, const unsigned char **in, long len); int i2d_PKCS7(PKCS7 *a, unsigned char **out); extern const ASN1_ITEM PKCS7_it;
extern const ASN1_ITEM PKCS7_ATTR_SIGN_it;
extern const ASN1_ITEM PKCS7_ATTR_VERIFY_it;
int i2d_PKCS7_NDEF(PKCS7 *a, unsigned char **out);
long PKCS7_ctrl(PKCS7 *p7, int cmd, long larg, char *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set_type(PKCS7 *p7, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set0_type_other(PKCS7 *p7, int type, ASN1_TYPE *other) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set_content(PKCS7 *p7, PKCS7 *p7_data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_SIGNER_INFO_set(PKCS7_SIGNER_INFO *p7i, X509 *x509, EVP_PKEY *pkey,
int PKCS7_add_signer(PKCS7 *p7, PKCS7_SIGNER_INFO *p7i) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_add_certificate(PKCS7 *p7, X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_add_crl(PKCS7 *p7, X509_CRL *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_content_new(PKCS7 *p7, int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_dataVerify(X509_STORE *cert_store, X509_STORE_CTX *ctx,
 BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_signatureVerify(BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si,
BIO *PKCS7_dataInit(PKCS7 *p7, BIO *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_dataFinal(PKCS7 *p7, BIO *bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *PKCS7_dataDecode(PKCS7 *p7, EVP_PKEY *pkey, BIO *in_bio, X509 *pcert) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7_SIGNER_INFO *PKCS7_add_signature(PKCS7 *p7, X509 *x509,
 EVP_PKEY *pkey, const EVP_MD *dgst) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 *PKCS7_cert_from_signer_info(PKCS7 *p7, PKCS7_SIGNER_INFO *si) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set_digest(PKCS7 *p7, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *PKCS7_get_signer_info(PKCS7 *p7) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7_RECIP_INFO *PKCS7_add_recipient(PKCS7 *p7, X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_add_recipient_info(PKCS7 *p7, PKCS7_RECIP_INFO *ri) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_RECIP_INFO_set(PKCS7_RECIP_INFO *p7i, X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set_cipher(PKCS7 *p7, const EVP_CIPHER *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7_ISSUER_AND_SERIAL *PKCS7_get_issuer_and_serial(PKCS7 *p7, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OCTET_STRING *PKCS7_digest_from_attributes(STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_add_signed_attribute(PKCS7_SIGNER_INFO *p7si,int nid,int type,
int PKCS7_add_attribute (PKCS7_SIGNER_INFO *p7si, int nid, int atrtype,
 void *value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TYPE *PKCS7_get_attribute(PKCS7_SIGNER_INFO *si, int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TYPE *PKCS7_get_signed_attribute(PKCS7_SIGNER_INFO *si, int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_set_signed_attributes(PKCS7_SIGNER_INFO *p7si,
int PKCS7_set_attributes(PKCS7_SIGNER_INFO *p7si,STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *PKCS7_sign(X509 *signcert, EVP_PKEY *pkey, STACK *certs,
       BIO *data, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_verify(PKCS7 *p7, STACK *certs, X509_STORE *store,
     BIO *indata, BIO *out, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *PKCS7_get0_signers(PKCS7 *p7, STACK *certs, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *PKCS7_encrypt(STACK *certs, BIO *in, const EVP_CIPHER *cipher,
int PKCS7_decrypt(PKCS7 *p7, EVP_PKEY *pkey, X509 *cert, BIO *data, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_add_attrib_smimecap(PKCS7_SIGNER_INFO *si,
         STACK *cap) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *PKCS7_get_smimecap(PKCS7_SIGNER_INFO *si) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PKCS7_simple_smimecap(STACK *sk, int nid, int arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SMIME_write_PKCS7(BIO *bio, PKCS7 *p7, BIO *data, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS7 *SMIME_read_PKCS7(BIO *bio, BIO **bcont) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SMIME_crlf_copy(BIO *in, BIO *out, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SMIME_text(BIO *in, BIO *out) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_PKCS7_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 577 "/usr/include/openssl/x509.h" 2 3 4
# 752 "/usr/include/openssl/x509.h" 3 4
const char *X509_verify_cert_error_string(long n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_verify(X509 *a, EVP_PKEY *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_verify(X509_REQ *a, EVP_PKEY *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_verify(X509_CRL *a, EVP_PKEY *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int NETSCAPE_SPKI_verify(NETSCAPE_SPKI *a, EVP_PKEY *r) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
NETSCAPE_SPKI * NETSCAPE_SPKI_b64_decode(const char *str, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * NETSCAPE_SPKI_b64_encode(NETSCAPE_SPKI *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY *NETSCAPE_SPKI_get_pubkey(NETSCAPE_SPKI *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int NETSCAPE_SPKI_set_pubkey(NETSCAPE_SPKI *x, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int NETSCAPE_SPKI_print(BIO *out, NETSCAPE_SPKI *spki) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_signature_print(BIO *bp,X509_ALGOR *alg, ASN1_STRING *sig) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_sign(X509 *x, EVP_PKEY *pkey, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_sign(X509_REQ *x, EVP_PKEY *pkey, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_sign(X509_CRL *x, EVP_PKEY *pkey, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int NETSCAPE_SPKI_sign(NETSCAPE_SPKI *x, EVP_PKEY *pkey, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_pubkey_digest(const X509 *data,const EVP_MD *type,
  unsigned char *md, unsigned int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_digest(const X509 *data,const EVP_MD *type,
int X509_CRL_digest(const X509_CRL *data,const EVP_MD *type,
int X509_REQ_digest(const X509_REQ *data,const EVP_MD *type,
int X509_NAME_digest(const X509_NAME *data,const EVP_MD *type,
X509 *d2i_X509_fp(FILE *fp, X509 **x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_fp(FILE *fp,X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_CRL *d2i_X509_CRL_fp(FILE *fp,X509_CRL **crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_CRL_fp(FILE *fp,X509_CRL *crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_REQ *d2i_X509_REQ_fp(FILE *fp,X509_REQ **req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_REQ_fp(FILE *fp,X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSAPrivateKey_fp(FILE *fp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSAPrivateKey_fp(FILE *fp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSAPublicKey_fp(FILE *fp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSAPublicKey_fp(FILE *fp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSA_PUBKEY_fp(FILE *fp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSA_PUBKEY_fp(FILE *fp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA *d2i_DSA_PUBKEY_fp(FILE *fp, DSA **dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSA_PUBKEY_fp(FILE *fp, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA *d2i_DSAPrivateKey_fp(FILE *fp, DSA **dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSAPrivateKey_fp(FILE *fp, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_EC_PUBKEY_fp(FILE *fp, EC_KEY **eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_EC_PUBKEY_fp(FILE *fp, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_ECPrivateKey_fp(FILE *fp, EC_KEY **eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ECPrivateKey_fp(FILE *fp, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_SIG *d2i_PKCS8_fp(FILE *fp,X509_SIG **p8) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8_fp(FILE *fp,X509_SIG *p8) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,
      PKCS8_PRIV_KEY_INFO **p8inf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,PKCS8_PRIV_KEY_INFO *p8inf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8PrivateKeyInfo_fp(FILE *fp, EVP_PKEY *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PrivateKey_fp(FILE *fp, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY *d2i_PrivateKey_fp(FILE *fp, EVP_PKEY **a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PUBKEY_fp(FILE *fp, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY *d2i_PUBKEY_fp(FILE *fp, EVP_PKEY **a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 *d2i_X509_bio(BIO *bp,X509 **x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_bio(BIO *bp,X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_CRL *d2i_X509_CRL_bio(BIO *bp,X509_CRL **crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_CRL_bio(BIO *bp,X509_CRL *crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_REQ *d2i_X509_REQ_bio(BIO *bp,X509_REQ **req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_REQ_bio(BIO *bp,X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSAPrivateKey_bio(BIO *bp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSAPrivateKey_bio(BIO *bp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSAPublicKey_bio(BIO *bp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSAPublicKey_bio(BIO *bp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA *d2i_RSA_PUBKEY_bio(BIO *bp,RSA **rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_RSA_PUBKEY_bio(BIO *bp,RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA *d2i_DSA_PUBKEY_bio(BIO *bp, DSA **dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSA_PUBKEY_bio(BIO *bp, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA *d2i_DSAPrivateKey_bio(BIO *bp, DSA **dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_DSAPrivateKey_bio(BIO *bp, DSA *dsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_EC_PUBKEY_bio(BIO *bp, EC_KEY **eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_EC_PUBKEY_bio(BIO *bp, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_ECPrivateKey_bio(BIO *bp, EC_KEY **eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_ECPrivateKey_bio(BIO *bp, EC_KEY *eckey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_SIG *d2i_PKCS8_bio(BIO *bp,X509_SIG **p8) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8_bio(BIO *bp,X509_SIG *p8) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,
int i2d_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,PKCS8_PRIV_KEY_INFO *p8inf) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8PrivateKeyInfo_bio(BIO *bp, EVP_PKEY *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PrivateKey_bio(BIO *bp, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY *d2i_PrivateKey_bio(BIO *bp, EVP_PKEY **a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PUBKEY_bio(BIO *bp, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY *d2i_PUBKEY_bio(BIO *bp, EVP_PKEY **a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 *X509_dup(X509 *x509) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509_ATTRIBUTE_dup(X509_ATTRIBUTE *xa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_EXTENSION_dup(X509_EXTENSION *ex) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_CRL *X509_CRL_dup(X509_CRL *crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_REQ *X509_REQ_dup(X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ALGOR *X509_ALGOR_dup(X509_ALGOR *xn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_ALGOR_set0(X509_ALGOR *alg, ASN1_OBJECT *aobj, int ptype, void *pval) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_ALGOR_get0(ASN1_OBJECT **paobj, int *pptype, void **ppval,
      X509_ALGOR *algor) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME *X509_NAME_dup(X509_NAME *xn) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME_ENTRY *X509_NAME_ENTRY_dup(X509_NAME_ENTRY *ne) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_cmp_time(ASN1_TIME *s, time_t *t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_cmp_current_time(ASN1_TIME *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TIME * X509_time_adj(ASN1_TIME *s, long adj, time_t *t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TIME * X509_gmtime_adj(ASN1_TIME *s, long adj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_cert_area(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_cert_dir(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_cert_file(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_cert_dir_env(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_cert_file_env(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * X509_get_default_private_dir(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_REQ * X509_to_X509_REQ(X509 *x, EVP_PKEY *pkey, const EVP_MD *md) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 * X509_REQ_to_X509(X509_REQ *r, int days,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ALGOR * X509_ALGOR_new(void); void X509_ALGOR_free(X509_ALGOR *a); X509_ALGOR *d2i_X509_ALGOR(X509_ALGOR **a, const unsigned char **in, long len); int i2d_X509_ALGOR(X509_ALGOR *a, unsigned char **out); extern const ASN1_ITEM X509_ALGOR_it;
X509_ALGORS *d2i_X509_ALGORS(X509_ALGORS **a, const unsigned char **in, long len); int i2d_X509_ALGORS(X509_ALGORS *a, unsigned char **out); extern const ASN1_ITEM X509_ALGORS_it;
X509_VAL * X509_VAL_new(void); void X509_VAL_free(X509_VAL *a); X509_VAL *d2i_X509_VAL(X509_VAL **a, const unsigned char **in, long len); int i2d_X509_VAL(X509_VAL *a, unsigned char **out); extern const ASN1_ITEM X509_VAL_it;
X509_PUBKEY * X509_PUBKEY_new(void); void X509_PUBKEY_free(X509_PUBKEY *a); X509_PUBKEY *d2i_X509_PUBKEY(X509_PUBKEY **a, const unsigned char **in, long len); int i2d_X509_PUBKEY(X509_PUBKEY *a, unsigned char **out); extern const ASN1_ITEM X509_PUBKEY_it;
int X509_PUBKEY_set(X509_PUBKEY **x, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * X509_PUBKEY_get(X509_PUBKEY *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_get_pubkey_parameters(EVP_PKEY *pkey,
int i2d_PUBKEY(EVP_PKEY *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * d2i_PUBKEY(EVP_PKEY **a,const unsigned char **pp,
int i2d_RSA_PUBKEY(RSA *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
RSA * d2i_RSA_PUBKEY(RSA **a,const unsigned char **pp,
int i2d_DSA_PUBKEY(DSA *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
DSA * d2i_DSA_PUBKEY(DSA **a,const unsigned char **pp,
int i2d_EC_PUBKEY(EC_KEY *a, unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EC_KEY *d2i_EC_PUBKEY(EC_KEY **a, const unsigned char **pp,
X509_SIG * X509_SIG_new(void); void X509_SIG_free(X509_SIG *a); X509_SIG *d2i_X509_SIG(X509_SIG **a, const unsigned char **in, long len); int i2d_X509_SIG(X509_SIG *a, unsigned char **out); extern const ASN1_ITEM X509_SIG_it;
X509_REQ_INFO * X509_REQ_INFO_new(void); void X509_REQ_INFO_free(X509_REQ_INFO *a); X509_REQ_INFO *d2i_X509_REQ_INFO(X509_REQ_INFO **a, const unsigned char **in, long len); int i2d_X509_REQ_INFO(X509_REQ_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_INFO_it;
X509_REQ * X509_REQ_new(void); void X509_REQ_free(X509_REQ *a); X509_REQ *d2i_X509_REQ(X509_REQ **a, const unsigned char **in, long len); int i2d_X509_REQ(X509_REQ *a, unsigned char **out); extern const ASN1_ITEM X509_REQ_it;
X509_ATTRIBUTE * X509_ATTRIBUTE_new(void); void X509_ATTRIBUTE_free(X509_ATTRIBUTE *a); X509_ATTRIBUTE *d2i_X509_ATTRIBUTE(X509_ATTRIBUTE **a, const unsigned char **in, long len); int i2d_X509_ATTRIBUTE(X509_ATTRIBUTE *a, unsigned char **out); extern const ASN1_ITEM X509_ATTRIBUTE_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_create(int nid, int atrtype, void *value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION * X509_EXTENSION_new(void); void X509_EXTENSION_free(X509_EXTENSION *a); X509_EXTENSION *d2i_X509_EXTENSION(X509_EXTENSION **a, const unsigned char **in, long len); int i2d_X509_EXTENSION(X509_EXTENSION *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSION_it;
X509_EXTENSIONS *d2i_X509_EXTENSIONS(X509_EXTENSIONS **a, const unsigned char **in, long len); int i2d_X509_EXTENSIONS(X509_EXTENSIONS *a, unsigned char **out); extern const ASN1_ITEM X509_EXTENSIONS_it;
X509_NAME_ENTRY * X509_NAME_ENTRY_new(void); void X509_NAME_ENTRY_free(X509_NAME_ENTRY *a); X509_NAME_ENTRY *d2i_X509_NAME_ENTRY(X509_NAME_ENTRY **a, const unsigned char **in, long len); int i2d_X509_NAME_ENTRY(X509_NAME_ENTRY *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_ENTRY_it;
X509_NAME * X509_NAME_new(void); void X509_NAME_free(X509_NAME *a); X509_NAME *d2i_X509_NAME(X509_NAME **a, const unsigned char **in, long len); int i2d_X509_NAME(X509_NAME *a, unsigned char **out); extern const ASN1_ITEM X509_NAME_it;
int X509_NAME_set(X509_NAME **xn, X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_CINF * X509_CINF_new(void); void X509_CINF_free(X509_CINF *a); X509_CINF *d2i_X509_CINF(X509_CINF **a, const unsigned char **in, long len); int i2d_X509_CINF(X509_CINF *a, unsigned char **out); extern const ASN1_ITEM X509_CINF_it;
X509 * X509_new(void); void X509_free(X509 *a); X509 *d2i_X509(X509 **a, const unsigned char **in, long len); int i2d_X509(X509 *a, unsigned char **out); extern const ASN1_ITEM X509_it;
X509_CERT_AUX * X509_CERT_AUX_new(void); void X509_CERT_AUX_free(X509_CERT_AUX *a); X509_CERT_AUX *d2i_X509_CERT_AUX(X509_CERT_AUX **a, const unsigned char **in, long len); int i2d_X509_CERT_AUX(X509_CERT_AUX *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_AUX_it;
X509_CERT_PAIR * X509_CERT_PAIR_new(void); void X509_CERT_PAIR_free(X509_CERT_PAIR *a); X509_CERT_PAIR *d2i_X509_CERT_PAIR(X509_CERT_PAIR **a, const unsigned char **in, long len); int i2d_X509_CERT_PAIR(X509_CERT_PAIR *a, unsigned char **out); extern const ASN1_ITEM X509_CERT_PAIR_it;
int X509_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
      CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_ex_data(X509 *r, int idx, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *X509_get_ex_data(X509 *r, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_AUX(X509 *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 * d2i_X509_AUX(X509 **a,const unsigned char **pp,long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_alias_set1(X509 *x, unsigned char *name, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_keyid_set1(X509 *x, unsigned char *id, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char * X509_alias_get0(X509 *x, int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char * X509_keyid_get0(X509 *x, int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*X509_TRUST_set_default(int (*trust)(int , X509 *, int)))(int, X509 *, int) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_set(int *t, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_add1_trust_object(X509 *x, ASN1_OBJECT *obj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_add1_reject_object(X509 *x, ASN1_OBJECT *obj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_trust_clear(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_reject_clear(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_REVOKED * X509_REVOKED_new(void); void X509_REVOKED_free(X509_REVOKED *a); X509_REVOKED *d2i_X509_REVOKED(X509_REVOKED **a, const unsigned char **in, long len); int i2d_X509_REVOKED(X509_REVOKED *a, unsigned char **out); extern const ASN1_ITEM X509_REVOKED_it;
X509_CRL_INFO * X509_CRL_INFO_new(void); void X509_CRL_INFO_free(X509_CRL_INFO *a); X509_CRL_INFO *d2i_X509_CRL_INFO(X509_CRL_INFO **a, const unsigned char **in, long len); int i2d_X509_CRL_INFO(X509_CRL_INFO *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_INFO_it;
X509_CRL * X509_CRL_new(void); void X509_CRL_free(X509_CRL *a); X509_CRL *d2i_X509_CRL(X509_CRL **a, const unsigned char **in, long len); int i2d_X509_CRL(X509_CRL *a, unsigned char **out); extern const ASN1_ITEM X509_CRL_it;
int X509_CRL_add0_revoked(X509_CRL *crl, X509_REVOKED *rev) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_PKEY * X509_PKEY_new(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_PKEY_free(X509_PKEY *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_X509_PKEY(X509_PKEY *a,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_PKEY * d2i_X509_PKEY(X509_PKEY **a,const unsigned char **pp,long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
NETSCAPE_SPKI * NETSCAPE_SPKI_new(void); void NETSCAPE_SPKI_free(NETSCAPE_SPKI *a); NETSCAPE_SPKI *d2i_NETSCAPE_SPKI(NETSCAPE_SPKI **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKI(NETSCAPE_SPKI *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKI_it;
NETSCAPE_SPKAC * NETSCAPE_SPKAC_new(void); void NETSCAPE_SPKAC_free(NETSCAPE_SPKAC *a); NETSCAPE_SPKAC *d2i_NETSCAPE_SPKAC(NETSCAPE_SPKAC **a, const unsigned char **in, long len); int i2d_NETSCAPE_SPKAC(NETSCAPE_SPKAC *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_SPKAC_it;
NETSCAPE_CERT_SEQUENCE * NETSCAPE_CERT_SEQUENCE_new(void); void NETSCAPE_CERT_SEQUENCE_free(NETSCAPE_CERT_SEQUENCE *a); NETSCAPE_CERT_SEQUENCE *d2i_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE **a, const unsigned char **in, long len); int i2d_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE *a, unsigned char **out); extern const ASN1_ITEM NETSCAPE_CERT_SEQUENCE_it;
X509_INFO * X509_INFO_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_INFO_free(X509_INFO *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * X509_NAME_oneline(X509_NAME *a,char *buf,int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_verify(i2d_of_void *i2d, X509_ALGOR *algor1,
  ASN1_BIT_STRING *signature,char *data,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_digest(i2d_of_void *i2d,const EVP_MD *type,char *data,
int ASN1_sign(i2d_of_void *i2d, X509_ALGOR *algor1,
       X509_ALGOR *algor2, ASN1_BIT_STRING *signature,
       char *data,EVP_PKEY *pkey, const EVP_MD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_item_digest(const ASN1_ITEM *it,const EVP_MD *type,void *data,
int ASN1_item_verify(const ASN1_ITEM *it, X509_ALGOR *algor1,
 ASN1_BIT_STRING *signature,void *data,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int ASN1_item_sign(const ASN1_ITEM *it, X509_ALGOR *algor1, X509_ALGOR *algor2,
 void *data, EVP_PKEY *pkey, const EVP_MD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_version(X509 *x,long version) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_serialNumber(X509 *x, ASN1_INTEGER *serial) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_INTEGER * X509_get_serialNumber(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_issuer_name(X509 *x, X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME * X509_get_issuer_name(X509 *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_subject_name(X509 *x, X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME * X509_get_subject_name(X509 *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_notBefore(X509 *x, ASN1_TIME *tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_notAfter(X509 *x, ASN1_TIME *tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_set_pubkey(X509 *x, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * X509_get_pubkey(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_BIT_STRING * X509_get0_pubkey_bitstr(const X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_certificate_type(X509 *x,EVP_PKEY *pubkey ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_set_version(X509_REQ *x,long version) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_set_subject_name(X509_REQ *req,X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_set_pubkey(X509_REQ *x, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
EVP_PKEY * X509_REQ_get_pubkey(X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_extension_nid(int nid) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int * X509_REQ_get_extension_nids(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_REQ_set_extension_nids(int *nids) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *X509_REQ_get_extensions(X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_add_extensions_nid(X509_REQ *req, STACK *exts,
int X509_REQ_add_extensions(X509_REQ *req, STACK *exts) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_get_attr_count(const X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_get_attr_by_NID(const X509_REQ *req, int nid,
     int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_get_attr_by_OBJ(const X509_REQ *req, ASN1_OBJECT *obj,
X509_ATTRIBUTE *X509_REQ_get_attr(const X509_REQ *req, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509_REQ_delete_attr(X509_REQ *req, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_add1_attr(X509_REQ *req, X509_ATTRIBUTE *attr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_add1_attr_by_OBJ(X509_REQ *req,
   const ASN1_OBJECT *obj, int type,
   const unsigned char *bytes, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_add1_attr_by_NID(X509_REQ *req,
   int nid, int type,
int X509_REQ_add1_attr_by_txt(X509_REQ *req,
   const char *attrname, int type,
int X509_CRL_set_version(X509_CRL *x, long version) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_set_issuer_name(X509_CRL *x, X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_set_lastUpdate(X509_CRL *x, ASN1_TIME *tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_set_nextUpdate(X509_CRL *x, ASN1_TIME *tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_sort(X509_CRL *crl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_set_serialNumber(X509_REVOKED *x, ASN1_INTEGER *serial) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_set_revocationDate(X509_REVOKED *r, ASN1_TIME *tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_check_private_key(X509_REQ *x509,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_check_private_key(X509 *x509,EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_issuer_and_serial_cmp(const X509 *a, const X509 *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long X509_issuer_and_serial_hash(X509 *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_issuer_name_cmp(const X509 *a, const X509 *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long X509_issuer_name_hash(X509 *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_subject_name_cmp(const X509 *a, const X509 *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long X509_subject_name_hash(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_cmp(const X509 *a, const X509 *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_cmp(const X509_NAME *a, const X509_NAME *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long X509_NAME_hash(X509_NAME *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_cmp(const X509_CRL *a, const X509_CRL *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_print_ex_fp(FILE *bp,X509 *x, unsigned long nmflag, unsigned long cflag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_print_fp(FILE *bp,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_print_fp(FILE *bp,X509_CRL *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_print_fp(FILE *bp,X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_print_ex_fp(FILE *fp, X509_NAME *nm, int indent, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_print(BIO *bp, X509_NAME *name, int obase) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_print_ex(BIO *out, X509_NAME *nm, int indent, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_print_ex(BIO *bp,X509 *x, unsigned long nmflag, unsigned long cflag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_print(BIO *bp,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_ocspid_print(BIO *bp,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CERT_AUX_print(BIO *bp,X509_CERT_AUX *x, int indent) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_print(BIO *bp,X509_CRL *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_print_ex(BIO *bp, X509_REQ *x, unsigned long nmflag, unsigned long cflag) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REQ_print(BIO *bp,X509_REQ *req) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_entry_count(X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_get_text_by_NID(X509_NAME *name, int nid,
   char *buf,int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_get_text_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj,
int X509_NAME_get_index_by_NID(X509_NAME *name,int nid,int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_get_index_by_OBJ(X509_NAME *name,ASN1_OBJECT *obj,
X509_NAME_ENTRY *X509_NAME_get_entry(X509_NAME *name, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME_ENTRY *X509_NAME_delete_entry(X509_NAME *name, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_add_entry(X509_NAME *name,X509_NAME_ENTRY *ne,
   int loc, int set) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_add_entry_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj, int type,
   unsigned char *bytes, int len, int loc, int set) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_add_entry_by_NID(X509_NAME *name, int nid, int type,
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_txt(X509_NAME_ENTRY **ne,
  const char *field, int type, const unsigned char *bytes, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_NID(X509_NAME_ENTRY **ne, int nid,
   int type,unsigned char *bytes, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_NAME_add_entry_by_txt(X509_NAME *name, const char *field, int type,
   const unsigned char *bytes, int len, int loc, int set) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_OBJ(X509_NAME_ENTRY **ne,
   ASN1_OBJECT *obj, int type,const unsigned char *bytes,
int X509_NAME_ENTRY_set_object(X509_NAME_ENTRY *ne,
int X509_NAME_ENTRY_set_data(X509_NAME_ENTRY *ne, int type,
ASN1_OBJECT * X509_NAME_ENTRY_get_object(X509_NAME_ENTRY *ne) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_STRING * X509_NAME_ENTRY_get_data(X509_NAME_ENTRY *ne) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509v3_get_ext_count(const STACK *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509v3_get_ext_by_NID(const STACK *x,
          int nid, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509v3_get_ext_by_OBJ(const STACK *x,
          ASN1_OBJECT *obj,int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509v3_get_ext_by_critical(const STACK *x,
        int crit, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509v3_get_ext(const STACK *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509v3_delete_ext(STACK *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *X509v3_add_ext(STACK **x,
      X509_EXTENSION *ex, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_get_ext_count(X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_get_ext_by_NID(X509 *x, int nid, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_get_ext_by_OBJ(X509 *x,ASN1_OBJECT *obj,int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_get_ext_by_critical(X509 *x, int crit, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_get_ext(X509 *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_delete_ext(X509 *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_add_ext(X509 *x, X509_EXTENSION *ex, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * X509_get_ext_d2i(X509 *x, int nid, int *crit, int *idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_add1_ext_i2d(X509 *x, int nid, void *value, int crit,
int X509_CRL_get_ext_count(X509_CRL *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_get_ext_by_NID(X509_CRL *x, int nid, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_get_ext_by_OBJ(X509_CRL *x,ASN1_OBJECT *obj,int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_get_ext_by_critical(X509_CRL *x, int crit, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_CRL_get_ext(X509_CRL *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_CRL_delete_ext(X509_CRL *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_add_ext(X509_CRL *x, X509_EXTENSION *ex, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * X509_CRL_get_ext_d2i(X509_CRL *x, int nid, int *crit, int *idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_CRL_add1_ext_i2d(X509_CRL *x, int nid, void *value, int crit,
int X509_REVOKED_get_ext_count(X509_REVOKED *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_get_ext_by_NID(X509_REVOKED *x, int nid, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_get_ext_by_OBJ(X509_REVOKED *x,ASN1_OBJECT *obj,int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_get_ext_by_critical(X509_REVOKED *x, int crit, int lastpos) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_REVOKED_get_ext(X509_REVOKED *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_REVOKED_delete_ext(X509_REVOKED *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_add_ext(X509_REVOKED *x, X509_EXTENSION *ex, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * X509_REVOKED_get_ext_d2i(X509_REVOKED *x, int nid, int *crit, int *idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_REVOKED_add1_ext_i2d(X509_REVOKED *x, int nid, void *value, int crit,
X509_EXTENSION *X509_EXTENSION_create_by_NID(X509_EXTENSION **ex,
   int nid, int crit, ASN1_OCTET_STRING *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_EXTENSION *X509_EXTENSION_create_by_OBJ(X509_EXTENSION **ex,
   ASN1_OBJECT *obj,int crit,ASN1_OCTET_STRING *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_EXTENSION_set_object(X509_EXTENSION *ex,ASN1_OBJECT *obj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_EXTENSION_set_critical(X509_EXTENSION *ex, int crit) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_EXTENSION_set_data(X509_EXTENSION *ex,
ASN1_OBJECT * X509_EXTENSION_get_object(X509_EXTENSION *ex) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OCTET_STRING *X509_EXTENSION_get_data(X509_EXTENSION *ne) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_EXTENSION_get_critical(X509_EXTENSION *ex) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509at_get_attr_count(const STACK *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509at_get_attr_by_NID(const STACK *x, int nid,
int X509at_get_attr_by_OBJ(const STACK *sk, ASN1_OBJECT *obj,
X509_ATTRIBUTE *X509at_get_attr(const STACK *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509at_delete_attr(STACK *x, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *X509at_add1_attr(STACK **x,
STACK *X509at_add1_attr_by_OBJ(STACK **x,
STACK *X509at_add1_attr_by_NID(STACK **x,
   int nid, int type,
STACK *X509at_add1_attr_by_txt(STACK **x,
void *X509at_get0_data_by_OBJ(STACK *x,
    ASN1_OBJECT *obj, int lastpos, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_NID(X509_ATTRIBUTE **attr, int nid,
      int atrtype, const void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_OBJ(X509_ATTRIBUTE **attr,
      const ASN1_OBJECT *obj, int atrtype, const void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_txt(X509_ATTRIBUTE **attr,
  const char *atrname, int type, const unsigned char *bytes, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_ATTRIBUTE_set1_object(X509_ATTRIBUTE *attr, const ASN1_OBJECT *obj) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_ATTRIBUTE_set1_data(X509_ATTRIBUTE *attr, int attrtype, const void *data, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *X509_ATTRIBUTE_get0_data(X509_ATTRIBUTE *attr, int idx,
     int atrtype, void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_ATTRIBUTE_count(X509_ATTRIBUTE *attr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_OBJECT *X509_ATTRIBUTE_get0_object(X509_ATTRIBUTE *attr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
ASN1_TYPE *X509_ATTRIBUTE_get0_type(X509_ATTRIBUTE *attr, int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_get_attr_count(const EVP_PKEY *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_get_attr_by_NID(const EVP_PKEY *key, int nid,
int EVP_PKEY_get_attr_by_OBJ(const EVP_PKEY *key, ASN1_OBJECT *obj,
X509_ATTRIBUTE *EVP_PKEY_get_attr(const EVP_PKEY *key, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ATTRIBUTE *EVP_PKEY_delete_attr(EVP_PKEY *key, int loc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_add1_attr(EVP_PKEY *key, X509_ATTRIBUTE *attr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int EVP_PKEY_add1_attr_by_OBJ(EVP_PKEY *key,
int EVP_PKEY_add1_attr_by_NID(EVP_PKEY *key,
   int nid, int type,
int EVP_PKEY_add1_attr_by_txt(EVP_PKEY *key,
int X509_verify_cert(X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 *X509_find_by_issuer_and_serial(STACK *sk,X509_NAME *name,
X509 *X509_find_by_subject(STACK *sk,X509_NAME *name) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PBEPARAM * PBEPARAM_new(void); void PBEPARAM_free(PBEPARAM *a); PBEPARAM *d2i_PBEPARAM(PBEPARAM **a, const unsigned char **in, long len); int i2d_PBEPARAM(PBEPARAM *a, unsigned char **out); extern const ASN1_ITEM PBEPARAM_it;
PBE2PARAM * PBE2PARAM_new(void); void PBE2PARAM_free(PBE2PARAM *a); PBE2PARAM *d2i_PBE2PARAM(PBE2PARAM **a, const unsigned char **in, long len); int i2d_PBE2PARAM(PBE2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBE2PARAM_it;
PBKDF2PARAM * PBKDF2PARAM_new(void); void PBKDF2PARAM_free(PBKDF2PARAM *a); PBKDF2PARAM *d2i_PBKDF2PARAM(PBKDF2PARAM **a, const unsigned char **in, long len); int i2d_PBKDF2PARAM(PBKDF2PARAM *a, unsigned char **out); extern const ASN1_ITEM PBKDF2PARAM_it;
X509_ALGOR *PKCS5_pbe_set(int alg, int iter, unsigned char *salt, int saltlen) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_ALGOR *PKCS5_pbe2_set(const EVP_CIPHER *cipher, int iter,
PKCS8_PRIV_KEY_INFO * PKCS8_PRIV_KEY_INFO_new(void); void PKCS8_PRIV_KEY_INFO_free(PKCS8_PRIV_KEY_INFO *a); PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO **a, const unsigned char **in, long len); int i2d_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO *a, unsigned char **out); extern const ASN1_ITEM PKCS8_PRIV_KEY_INFO_it;
EVP_PKEY *EVP_PKCS82PKEY(PKCS8_PRIV_KEY_INFO *p8) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8(EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8_broken(EVP_PKEY *pkey, int broken) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
PKCS8_PRIV_KEY_INFO *PKCS8_set_broken(PKCS8_PRIV_KEY_INFO *p8, int broken) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_check_trust(X509 *x, int id, int flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_get_count(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_TRUST * X509_TRUST_get0(int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_get_by_id(int id) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_add(int id, int flags, int (*ck)(X509_TRUST *, X509 *, int),
     char *name, int arg1, void *arg2) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void X509_TRUST_cleanup(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_get_flags(X509_TRUST *xp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *X509_TRUST_get0_name(X509_TRUST *xp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int X509_TRUST_get_trust(X509_TRUST *xp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void ERR_load_X509_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 186 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/pem.h" 1 3 4
# 64 "/usr/include/openssl/pem.h" 3 4
# 1 "/usr/include/openssl/e_os2.h" 1 3 4
# 56 "/usr/include/openssl/e_os2.h" 3 4
# 57 "/usr/include/openssl/e_os2.h" 2 3 4
# 65 "/usr/include/openssl/pem.h" 2 3 4
# 1 "/usr/include/openssl/pem2.h" 1 3 4
# 74 "/usr/include/openssl/pem.h" 2 3 4
# 143 "/usr/include/openssl/pem.h" 3 4
typedef struct PEM_Encode_Seal_st
 EVP_ENCODE_CTX encode;
 EVP_MD_CTX md;
 EVP_CIPHER_CTX cipher;
 } PEM_ENCODE_SEAL_CTX;
typedef struct pem_recip_st
 char *name;
 X509_NAME *dn;
 int cipher;
 int key_enc;
 } PEM_USER;
typedef struct pem_ctx_st
 int type;
 struct {
  int version;
  int mode;
  } proc_type;
 char *domain;
 struct {
  int cipher;
  } DEK_info;
 PEM_USER *originator;
 int num_recipient;
 PEM_USER **recipient;
 STACK *x509_chain;
 EVP_MD *md;
 int md_enc;
 int md_len;
 char *md_data;
 EVP_CIPHER *dec;
 int key_len;
 unsigned char *key;
 int data_enc;
 int data_len;
 unsigned char *data;
 } PEM_CTX;
# 567 "/usr/include/openssl/pem.h" 3 4
typedef int pem_password_cb(char *buf, int size, int rwflag, void *userdata);
int PEM_get_EVP_CIPHER_INFO(char *header, EVP_CIPHER_INFO *cipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_do_header (EVP_CIPHER_INFO *cipher, unsigned char *data,long *len,
 pem_password_cb *callback,void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_read_bio(BIO *bp, char **name, char **header,
  unsigned char **data,long *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_write_bio(BIO *bp,const char *name,char *hdr,unsigned char *data,
  long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_bytes_read_bio(unsigned char **pdata, long *plen, char **pnm, const char *name, BIO *bp,
      pem_password_cb *cb, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * PEM_ASN1_read_bio(d2i_of_void *d2i, const char *name, BIO *bp,
     void **x, pem_password_cb *cb, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_ASN1_write_bio(i2d_of_void *i2d,const char *name,BIO *bp,char *x,
      const EVP_CIPHER *enc,unsigned char *kstr,int klen,
STACK * PEM_X509_INFO_read_bio(BIO *bp, STACK *sk, pem_password_cb *cb, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_X509_INFO_write_bio(BIO *bp,X509_INFO *xi, EVP_CIPHER *enc,
  unsigned char *kstr, int klen, pem_password_cb *cd, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_read(FILE *fp, char **name, char **header,
int PEM_write(FILE *fp,char *name,char *hdr,unsigned char *data,long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void * PEM_ASN1_read(d2i_of_void *d2i, const char *name, FILE *fp, void **x,
int PEM_ASN1_write(i2d_of_void *i2d,const char *name,FILE *fp,
         char *x,const EVP_CIPHER *enc,unsigned char *kstr,
         int klen,pem_password_cb *callback, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK * PEM_X509_INFO_read(FILE *fp, STACK *sk,
int PEM_SealInit(PEM_ENCODE_SEAL_CTX *ctx, EVP_CIPHER *type,
  EVP_MD *md_type, unsigned char **ek, int *ekl,
  unsigned char *iv, EVP_PKEY **pubk, int npubk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void PEM_SealUpdate(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *out, int *outl,
  unsigned char *in, int inl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_SealFinal(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *sig,int *sigl,
  unsigned char *out, int *outl, EVP_PKEY *priv) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void PEM_SignInit(EVP_MD_CTX *ctx, EVP_MD *type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void PEM_SignUpdate(EVP_MD_CTX *ctx,unsigned char *d,unsigned int cnt) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_SignFinal(EVP_MD_CTX *ctx, unsigned char *sigret,
  unsigned int *siglen, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_def_callback(char *buf, int num, int w, void *key) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void PEM_proc_type(char *buf, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void PEM_dek_info(char *buf, const char *type, int len, char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 641 "/usr/include/openssl/pem.h" 2 3 4
X509 *PEM_read_bio_X509(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509(BIO *bp, X509 *x); int PEM_write_X509(FILE *fp, X509 *x);
X509 *PEM_read_bio_X509_AUX(BIO *bp, X509 **x, pem_password_cb *cb, void *u); X509 *PEM_read_X509_AUX(FILE *fp, X509 **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_AUX(BIO *bp, X509 *x); int PEM_write_X509_AUX(FILE *fp, X509 *x);
X509_CERT_PAIR *PEM_read_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); X509_CERT_PAIR *PEM_read_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR *x); int PEM_write_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR *x);
X509_REQ *PEM_read_bio_X509_REQ(BIO *bp, X509_REQ **x, pem_password_cb *cb, void *u); X509_REQ *PEM_read_X509_REQ(FILE *fp, X509_REQ **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_REQ(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ(FILE *fp, X509_REQ *x);
int PEM_write_bio_X509_REQ_NEW(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ_NEW(FILE *fp, X509_REQ *x);
X509_CRL *PEM_read_bio_X509_CRL(BIO *bp, X509_CRL **x, pem_password_cb *cb, void *u); X509_CRL *PEM_read_X509_CRL(FILE *fp, X509_CRL **x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CRL(BIO *bp, X509_CRL *x); int PEM_write_X509_CRL(FILE *fp, X509_CRL *x);
PKCS7 *PEM_read_bio_PKCS7(BIO *bp, PKCS7 **x, pem_password_cb *cb, void *u); PKCS7 *PEM_read_PKCS7(FILE *fp, PKCS7 **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS7(BIO *bp, PKCS7 *x); int PEM_write_PKCS7(FILE *fp, PKCS7 *x);
NETSCAPE_CERT_SEQUENCE *PEM_read_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); NETSCAPE_CERT_SEQUENCE *PEM_read_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE **x, pem_password_cb *cb, void *u); int PEM_write_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE *x); int PEM_write_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE *x);
X509_SIG *PEM_read_bio_PKCS8(BIO *bp, X509_SIG **x, pem_password_cb *cb, void *u); X509_SIG *PEM_read_PKCS8(FILE *fp, X509_SIG **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8(BIO *bp, X509_SIG *x); int PEM_write_PKCS8(FILE *fp, X509_SIG *x);
PKCS8_PRIV_KEY_INFO *PEM_read_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); PKCS8_PRIV_KEY_INFO *PEM_read_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO **x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO *x); int PEM_write_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO *x);
RSA *PEM_read_bio_RSAPrivateKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPrivateKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPrivateKey(BIO *bp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_RSAPrivateKey(FILE *fp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
RSA *PEM_read_bio_RSAPublicKey(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPublicKey(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPublicKey(BIO *bp, const RSA *x); int PEM_write_RSAPublicKey(FILE *fp, const RSA *x);
RSA *PEM_read_bio_RSA_PUBKEY(BIO *bp, RSA **x, pem_password_cb *cb, void *u); RSA *PEM_read_RSA_PUBKEY(FILE *fp, RSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_RSA_PUBKEY(BIO *bp, RSA *x); int PEM_write_RSA_PUBKEY(FILE *fp, RSA *x);
DSA *PEM_read_bio_DSAPrivateKey(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAPrivateKey(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAPrivateKey(BIO *bp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_DSAPrivateKey(FILE *fp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
DSA *PEM_read_bio_DSA_PUBKEY(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSA_PUBKEY(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSA_PUBKEY(BIO *bp, DSA *x); int PEM_write_DSA_PUBKEY(FILE *fp, DSA *x);
DSA *PEM_read_bio_DSAparams(BIO *bp, DSA **x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAparams(FILE *fp, DSA **x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAparams(BIO *bp, const DSA *x); int PEM_write_DSAparams(FILE *fp, const DSA *x);
EC_GROUP *PEM_read_bio_ECPKParameters(BIO *bp, EC_GROUP **x, pem_password_cb *cb, void *u); EC_GROUP *PEM_read_ECPKParameters(FILE *fp, EC_GROUP **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPKParameters(BIO *bp, const EC_GROUP *x); int PEM_write_ECPKParameters(FILE *fp, const EC_GROUP *x);
EC_KEY *PEM_read_bio_ECPrivateKey(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_ECPrivateKey(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_ECPrivateKey(BIO *bp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_ECPrivateKey(FILE *fp, EC_KEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EC_KEY *PEM_read_bio_EC_PUBKEY(BIO *bp, EC_KEY **x, pem_password_cb *cb, void *u); EC_KEY *PEM_read_EC_PUBKEY(FILE *fp, EC_KEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_EC_PUBKEY(BIO *bp, EC_KEY *x); int PEM_write_EC_PUBKEY(FILE *fp, EC_KEY *x);
DH *PEM_read_bio_DHparams(BIO *bp, DH **x, pem_password_cb *cb, void *u); DH *PEM_read_DHparams(FILE *fp, DH **x, pem_password_cb *cb, void *u); int PEM_write_bio_DHparams(BIO *bp, const DH *x); int PEM_write_DHparams(FILE *fp, const DH *x);
EVP_PKEY *PEM_read_bio_PrivateKey(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PrivateKey(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PrivateKey(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_PrivateKey(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EVP_PKEY *PEM_read_bio_PUBKEY(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PUBKEY(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u); int PEM_write_bio_PUBKEY(BIO *bp, EVP_PKEY *x); int PEM_write_PUBKEY(FILE *fp, EVP_PKEY *x);
int PEM_write_bio_PKCS8PrivateKey_nid(BIO *bp, EVP_PKEY *x, int nid,
int PEM_write_bio_PKCS8PrivateKey(BIO *, EVP_PKEY *, const EVP_CIPHER *,
                                  char *, int, pem_password_cb *, void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_bio(BIO *bp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY **x, pem_password_cb *cb, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_fp(FILE *fp, EVP_PKEY *x, int nid,
int PEM_write_PKCS8PrivateKey_nid(FILE *fp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY **x, pem_password_cb *cb, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int PEM_write_PKCS8PrivateKey(FILE *fp,EVP_PKEY *x,const EVP_CIPHER *enc,
         char *kstr,int klen, pem_password_cb *cd, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 731 "/usr/include/openssl/pem.h" 3 4
void ERR_load_PEM_strings(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 192 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/hmac.h" 1 3 4
# 63 "/usr/include/openssl/hmac.h" 3 4
# 1 "/usr/include/openssl/opensslconf.h" 1 3 4
# 64 "/usr/include/openssl/hmac.h" 2 3 4
# 77 "/usr/include/openssl/hmac.h" 3 4
typedef struct hmac_ctx_st
 const EVP_MD *md;
 EVP_MD_CTX md_ctx;
 EVP_MD_CTX i_ctx;
 EVP_MD_CTX o_ctx;
 unsigned int key_length;
 unsigned char key[128];
 } HMAC_CTX;
void HMAC_CTX_init(HMAC_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void HMAC_CTX_cleanup(HMAC_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void HMAC_Init(HMAC_CTX *ctx, const void *key, int len,
void HMAC_Init_ex(HMAC_CTX *ctx, const void *key, int len,
    const EVP_MD *md, ENGINE *impl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void HMAC_Update(HMAC_CTX *ctx, const unsigned char *data, size_t len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void HMAC_Final(HMAC_CTX *ctx, unsigned char *md, unsigned int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned char *HMAC(const EVP_MD *evp_md, const void *key, int key_len,
      const unsigned char *d, size_t n, unsigned char *md,
      unsigned int *md_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void HMAC_CTX_set_flags(HMAC_CTX *ctx, unsigned long flags) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 193 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/kssl.h" 1 3 4
# 68 "/usr/include/openssl/kssl.h" 3 4
# 69 "/usr/include/openssl/kssl.h" 2 3 4
# 195 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/symhacks.h" 1 3 4
# 197 "/usr/include/openssl/ssl.h" 2 3 4
# 348 "/usr/include/openssl/ssl.h" 3 4
typedef struct ssl_st *ssl_crock_st;
typedef struct ssl_cipher_st
 int valid;
 const char *name;
 unsigned long id;
 unsigned long algorithms;
 unsigned long algo_strength;
 unsigned long algorithm2;
 int strength_bits;
 int alg_bits;
 unsigned long mask;
 unsigned long mask_strength;
 } SSL_CIPHER;
typedef struct ssl_method_st
 int version;
 int (*ssl_new)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*ssl_clear)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*ssl_free)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_accept)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_connect)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_read)(SSL *s,void *buf,int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_peek)(SSL *s,void *buf,int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_write)(SSL *s,const void *buf,int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_shutdown)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_renegotiate)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_renegotiate_check)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ssl_get_message)(SSL *s, int st1, int stn, int mt, long
  max, int *ok) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_read_bytes)(SSL *s, int type, unsigned char *buf, int len,
  int peek) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_write_bytes)(SSL *s, int type, const void *buf_, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_dispatch_alert)(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ssl_ctrl)(SSL *s,int cmd,long larg,void *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ssl_ctx_ctrl)(SSL_CTX *ctx,int cmd,long larg,void *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 SSL_CIPHER *(*get_cipher_by_char)(const unsigned char *ptr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*put_cipher_by_char)(const SSL_CIPHER *cipher,unsigned char *ptr) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*ssl_pending)(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*num_ciphers)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 SSL_CIPHER *(*get_cipher)(unsigned ncipher) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 struct ssl_method_st *(*get_ssl_method)(int version) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*get_timeout)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 struct ssl3_enc_method *ssl3_enc;
 int (*ssl_version)(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ssl_callback_ctrl)(SSL *s, int cb_id, void (*fp)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 long (*ssl_ctx_callback_ctrl)(SSL_CTX *s, int cb_id, void (*fp)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 } SSL_METHOD;
# 422 "/usr/include/openssl/ssl.h" 3 4
typedef struct ssl_session_st
 int ssl_version;
 unsigned int key_arg_length;
 unsigned char key_arg[8];
 int master_key_length;
 unsigned char master_key[48];
 unsigned int session_id_length;
 unsigned char session_id[32];
 unsigned int sid_ctx_length;
 unsigned char sid_ctx[32];
 int not_resumable;
 struct sess_cert_st *sess_cert;
 X509 *peer;
 long verify_result;
 int references;
 long timeout;
 long time;
 int compress_meth;
 SSL_CIPHER *cipher;
 unsigned long cipher_id;
 STACK *ciphers;
 CRYPTO_EX_DATA ex_data;
 struct ssl_session_st *prev,*next;
 char *tlsext_hostname;
 unsigned char *tlsext_tick;
 size_t tlsext_ticklen;
 long tlsext_tick_lifetime_hint;
 } SSL_SESSION;
# 604 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_set_msg_callback(SSL_CTX *ctx, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_msg_callback(SSL *ssl, void (*cb)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 632 "/usr/include/openssl/ssl.h" 3 4
typedef int (*GEN_SESSION_CB)(const SSL *ssl, unsigned char *id,
    unsigned int *id_len);
typedef struct ssl_comp_st
 int id;
 const char *name;
 COMP_METHOD *method;
 } SSL_COMP;
struct ssl_ctx_st
 SSL_METHOD *method;
 STACK *cipher_list;
 STACK *cipher_list_by_id;
 struct x509_store_st *cert_store;
 struct lhash_st *sessions;
 unsigned long session_cache_size;
 struct ssl_session_st *session_cache_head;
 struct ssl_session_st *session_cache_tail;
 int session_cache_mode;
 long session_timeout;
# 684 "/usr/include/openssl/ssl.h" 3 4
 int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl,
  unsigned char *data,int len,int *copy) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 struct
  int sess_connect;
  int sess_connect_renegotiate;
  int sess_connect_good;
  int sess_accept;
  int sess_accept_renegotiate;
  int sess_accept_good;
  int sess_miss;
  int sess_timeout;
  int sess_cache_full;
  int sess_hit;
  int sess_cb_hit;
  } stats;
 int references;
 int (*app_verify_callback)(X509_STORE_CTX *, void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void *app_verify_arg;
 pem_password_cb *default_passwd_callback;
 void *default_passwd_callback_userdata;
 int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
    int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int *cookie_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
    int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie,
        unsigned int cookie_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 const EVP_MD *rsa_md5;
 const EVP_MD *md5;
 const EVP_MD *sha1;
 STACK *extra_certs;
 STACK *comp_methods;
 void (*info_callback)(const SSL *ssl,int type,int val) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 STACK *client_CA;
 unsigned long options;
 unsigned long mode;
 long max_cert_list;
 struct cert_st *cert;
 int read_ahead;
 void (*msg_callback)(int write_p, int version, int content_type, const void *buf, size_t len, SSL *ssl, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void *msg_callback_arg;
 int verify_mode;
 int (*default_verify_callback)(int ok,X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 GEN_SESSION_CB generate_session_id;
 X509_VERIFY_PARAM *param;
 int quiet_shutdown;
 ENGINE *client_cert_engine;
 int (*tlsext_servername_callback)(SSL*, int *, void *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void *tlsext_servername_arg;
 unsigned char tlsext_tick_key_name[16];
 unsigned char tlsext_tick_hmac_key[16];
 unsigned char tlsext_tick_aes_key[16];
 int (*tlsext_ticket_key_cb)(SSL *ssl,
     unsigned char *name, unsigned char *iv,
     EVP_CIPHER_CTX *ectx,
     HMAC_CTX *hctx, int enc) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int (*tlsext_status_cb)(SSL *ssl, void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 void *tlsext_status_arg;
# 821 "/usr/include/openssl/ssl.h" 3 4
  struct lhash_st *SSL_CTX_sessions(SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 847 "/usr/include/openssl/ssl.h" 3 4
void SSL_CTX_sess_set_new_cb(SSL_CTX *ctx, int (*new_session_cb)(struct ssl_st *ssl,SSL_SESSION *sess)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*SSL_CTX_sess_get_new_cb(SSL_CTX *ctx))(struct ssl_st *ssl, SSL_SESSION *sess) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_sess_set_remove_cb(SSL_CTX *ctx, void (*remove_session_cb)(struct ssl_ctx_st *ctx,SSL_SESSION *sess)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void (*SSL_CTX_sess_get_remove_cb(SSL_CTX *ctx))(struct ssl_ctx_st *ctx, SSL_SESSION *sess) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_sess_set_get_cb(SSL_CTX *ctx, SSL_SESSION *(*get_session_cb)(struct ssl_st *ssl, unsigned char *data,int len,int *copy)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_SESSION *(*SSL_CTX_sess_get_get_cb(SSL_CTX *ctx))(struct ssl_st *ssl, unsigned char *Data, int len, int *copy) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_info_callback(SSL_CTX *ctx, void (*cb)(const SSL *ssl,int type,int val)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void (*SSL_CTX_get_info_callback(SSL_CTX *ctx))(const SSL *ssl,int type,int val) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_client_cert_cb(SSL_CTX *ctx, int (*client_cert_cb)(SSL *ssl, X509 **x509, EVP_PKEY **pkey)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*SSL_CTX_get_client_cert_cb(SSL_CTX *ctx))(SSL *ssl, X509 **x509, EVP_PKEY **pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_client_cert_engine(SSL_CTX *ctx, ENGINE *e) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_cookie_generate_cb(SSL_CTX *ctx, int (*app_gen_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int *cookie_len)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_cookie_verify_cb(SSL_CTX *ctx, int (*app_verify_cookie_cb)(SSL *ssl, unsigned char *cookie, unsigned int cookie_len)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 874 "/usr/include/openssl/ssl.h" 3 4
struct ssl_st
 int version;
 int type;
 SSL_METHOD *method;
 BIO *rbio;
 BIO *wbio;
 BIO *bbio;
# 902 "/usr/include/openssl/ssl.h" 3 4
 int rwstate;
 int in_handshake;
 int (*handshake_func)(SSL *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 916 "/usr/include/openssl/ssl.h" 3 4
 int server;
 int new_session;
 int quiet_shutdown;
 int shutdown;
 int state;
 int rstate;
 BUF_MEM *init_buf;
 void *init_msg;
 int init_num;
 int init_off;
 unsigned char *packet;
 unsigned int packet_length;
 struct ssl2_state_st *s2;
 struct ssl3_state_st *s3;
 struct dtls1_state_st *d1;
 int read_ahead;
 int hit;
 STACK *cipher_list;
 EVP_CIPHER_CTX *enc_read_ctx;
 const EVP_MD *read_hash;
 COMP_CTX *expand;
 EVP_CIPHER_CTX *enc_write_ctx;
 const EVP_MD *write_hash;
 COMP_CTX *compress;
# 986 "/usr/include/openssl/ssl.h" 3 4
 SSL_SESSION *session;
 int verify_mode;
 int (*verify_callback)(int ok,X509_STORE_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
 int error;
 int error_code;
 SSL_CTX *ctx;
 int debug;
 long verify_result;
 STACK *client_CA;
 int references;
 unsigned long mode;
 long max_cert_list;
 int first_packet;
 int client_version;
 void (*tlsext_debug_cb)(SSL *s, int client_server, int type,
     unsigned char *data, int len,
 void *tlsext_debug_arg;
 int servername_done;
 int tlsext_status_type;
 int tlsext_status_expected;
 STACK *tlsext_ocsp_ids;
 X509_EXTENSIONS *tlsext_ocsp_exts;
 unsigned char *tlsext_ocsp_resp;
 int tlsext_ocsp_resplen;
 int tlsext_ticket_expected;
 SSL_CTX * initial_ctx;
# 1 "/usr/include/openssl/ssl2.h" 1 3 4
# 158 "/usr/include/openssl/ssl2.h" 3 4
typedef struct ssl2_state_st
 int three_byte_header;
 int clear_text;
 int escape;
 int ssl2_rollback;
 unsigned int wnum;
 int wpend_tot;
 const unsigned char *wpend_buf;
 int wpend_off;
 int wpend_len;
 int wpend_ret;
 int rbuf_left;
 int rbuf_offs;
 unsigned char *rbuf;
 unsigned char *wbuf;
 unsigned char *write_ptr;
 unsigned int padding;
 unsigned int rlength;
 int ract_data_length;
 unsigned int wlength;
 int wact_data_length;
 unsigned char *ract_data;
 unsigned char *wact_data;
 unsigned char *mac_data;
 unsigned char *read_key;
 unsigned char *write_key;
 unsigned int challenge_length;
 unsigned char challenge[32];
 unsigned int conn_id_length;
 unsigned char conn_id[16];
 unsigned int key_material_length;
 unsigned char key_material[24*2];
 unsigned long read_sequence;
 unsigned long write_sequence;
 struct {
  unsigned int cert_type;
  unsigned int cert_length;
  unsigned int csl;
  unsigned int clear;
  unsigned int enc;
  unsigned char ccl[32];
  unsigned int cipher_spec_length;
  unsigned int clen;
  unsigned int rlen;
  } tmp;
 } SSL2_STATE;
# 1070 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl3.h" 1 3 4
# 125 "/usr/include/openssl/ssl3.h" 3 4
# 1 "/usr/include/openssl/ssl.h" 1 3 4
# 126 "/usr/include/openssl/ssl3.h" 2 3 4
# 1 "/usr/include/openssl/pq_compat.h" 1 3 4
# 63 "/usr/include/openssl/pq_compat.h" 3 4
# 64 "/usr/include/openssl/pq_compat.h" 2 3 4
# 127 "/usr/include/openssl/ssl3.h" 2 3 4
# 297 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_record_st
       int type;
       unsigned int length;
       unsigned int off;
       unsigned char *input;
       unsigned char *comp;
        unsigned long epoch;
        unsigned long seq_num;
 } SSL3_RECORD;
typedef struct ssl3_buffer_st
 unsigned char *buf;
 size_t len;
 int offset;
 int left;
 } SSL3_BUFFER;
# 349 "/usr/include/openssl/ssl3.h" 3 4
typedef struct ssl3_state_st
 long flags;
 int delay_buf_pop_ret;
 unsigned char read_sequence[8];
 unsigned char read_mac_secret[64];
 unsigned char write_sequence[8];
 unsigned char write_mac_secret[64];
 unsigned char server_random[32];
 unsigned char client_random[32];
 int need_empty_fragments;
 int empty_fragment_done;
 SSL3_BUFFER rbuf;
 SSL3_BUFFER wbuf;
 SSL3_RECORD rrec;
 SSL3_RECORD wrec;
 unsigned char alert_fragment[2];
 unsigned int alert_fragment_len;
 unsigned char handshake_fragment[4];
 unsigned int handshake_fragment_len;
 unsigned int wnum;
 int wpend_tot;
 int wpend_type;
 int wpend_ret;
 EVP_MD_CTX finish_dgst1;
 EVP_MD_CTX finish_dgst2;
 int change_cipher_spec;
 int warn_alert;
 int fatal_alert;
 int alert_dispatch;
 unsigned char send_alert[2];
 int renegotiate;
 int total_renegotiations;
 int num_renegotiations;
 int in_read_app_data;
 struct {
  unsigned char cert_verify_md[64*2];
  unsigned char finish_md[64*2];
  int finish_md_len;
  unsigned char peer_finish_md[64*2];
  int peer_finish_md_len;
  unsigned long message_size;
  int message_type;
  SSL_CIPHER *new_cipher;
  DH *dh;
  EC_KEY *ecdh;
  int next_state;
  int reuse_message;
  int cert_req;
  int ctype_num;
  char ctype[7];
  STACK *ca_names;
  int use_rsa_tmp;
  int key_block_length;
  unsigned char *key_block;
  const EVP_CIPHER *new_sym_enc;
  const EVP_MD *new_hash;
  const SSL_COMP *new_compression;
  int cert_request;
  } tmp;
        unsigned char previous_client_finished[64];
        unsigned char previous_client_finished_len;
        unsigned char previous_server_finished[64];
        unsigned char previous_server_finished_len;
        int send_connection_binding;
 char is_probably_safari;
 } SSL3_STATE;
# 1071 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/tls1.h" 1 3 4
# 146 "/usr/include/openssl/tls1.h" 3 4
const char *SSL_get_servername(const SSL *s, const int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_servername_type(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 1072 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/dtls1.h" 1 3 4
# 64 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/openssl/pqueue.h" 1 3 4
# 67 "/usr/include/openssl/pqueue.h" 3 4
# 1 "/usr/include/string.h" 1 3 4
# 70 "/usr/include/string.h" 3 4
void *memchr(const void *, int, size_t);
int memcmp(const void *, const void *, size_t);
void *memcpy(void *, const void *, size_t);
void *memmove(void *, const void *, size_t);
void *memset(void *, int, size_t);
char *strcat(char *, const char *);
char *strchr(const char *, int);
int strcmp(const char *, const char *);
int strcoll(const char *, const char *);
char *strcpy(char *, const char *);
size_t strcspn(const char *, const char *);
char *strerror(int) __asm("_" "strerror") ;
size_t strlen(const char *);
char *strncat(char *, const char *, size_t);
int strncmp(const char *, const char *, size_t);
char *strncpy(char *, const char *, size_t);
char *strpbrk(const char *, const char *);
char *strrchr(const char *, int);
size_t strspn(const char *, const char *);
char *strstr(const char *, const char *);
char *strtok(char *, const char *);
size_t strxfrm(char *, const char *, size_t);
# 104 "/usr/include/string.h" 3 4
char *strtok_r(char *, const char *, char **);
# 116 "/usr/include/string.h" 3 4
int strerror_r(int, char *, size_t);
char *strdup(const char *);
void *memccpy(void *, const void *, int, size_t);
# 130 "/usr/include/string.h" 3 4
char *stpcpy(char *, const char *);
char *stpncpy(char *, const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strndup(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
size_t strnlen(const char *, size_t) __attribute__((availability(macosx,introduced=10.7)));
char *strsignal(int sig);
# 1 "/usr/include/sys/_types/_rsize_t.h" 1 3 4
# 142 "/usr/include/string.h" 2 3 4
errno_t memset_s(void *, rsize_t, int, rsize_t) __attribute__((availability(macosx,introduced=10.9)));
# 155 "/usr/include/string.h" 3 4
void *memmem(const void *, size_t, const void *, size_t) __attribute__((availability(macosx,introduced=10.7)));
void memset_pattern4(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern8(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
void memset_pattern16(void *, const void *, size_t) __attribute__((availability(macosx,introduced=10.5)));
char *strcasestr(const char *, const char *);
char *strnstr(const char *, const char *, size_t);
size_t strlcat(char *, const char *, size_t);
size_t strlcpy(char *, const char *, size_t);
void strmode(int, char *);
char *strsep(char **, const char *);
void swab(const void * restrict, void * restrict, ssize_t);
# 1 "/usr/include/strings.h" 1 3 4
# 70 "/usr/include/strings.h" 3 4
int bcmp(const void *, const void *, size_t) ;
void bcopy(const void *, void *, size_t) ;
void bzero(void *, size_t) ;
char *index(const char *, int) ;
char *rindex(const char *, int) ;
int ffs(int);
int strcasecmp(const char *, const char *);
int strncasecmp(const char *, const char *, size_t);
int ffsl(long) __attribute__((availability(macosx,introduced=10.5)));
int ffsll(long long) __attribute__((availability(macosx,introduced=10.9)));
int fls(int) __attribute__((availability(macosx,introduced=10.5)));
int flsl(long) __attribute__((availability(macosx,introduced=10.5)));
int flsll(long long) __attribute__((availability(macosx,introduced=10.9)));
# 93 "/usr/include/strings.h" 2 3 4
# 177 "/usr/include/string.h" 2 3 4
# 186 "/usr/include/string.h" 3 4
# 1 "/usr/include/secure/_string.h" 1 3 4
# 187 "/usr/include/string.h" 2 3 4
# 68 "/usr/include/openssl/pqueue.h" 2 3 4
typedef struct _pqueue *pqueue;
typedef struct _pitem
 unsigned long priority;
 void *data;
 struct _pitem *next;
 } pitem;
typedef struct _pitem *piterator;
pitem *pitem_new(unsigned long priority, void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void pitem_free(pitem *item) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pqueue pqueue_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void pqueue_free(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_insert(pqueue pq, pitem *item) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_peek(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_pop(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_find(pqueue pq, unsigned long priority) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_iterator(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
pitem *pqueue_next(piterator *iter) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void pqueue_print(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int pqueue_size(pqueue pq) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 65 "/usr/include/openssl/dtls1.h" 2 3 4
# 75 "/usr/include/openssl/dtls1.h" 3 4
# 1 "/usr/include/sys/time.h" 1 3 4
# 86 "/usr/include/sys/time.h" 3 4
struct itimerval {
 struct timeval it_interval;
 struct timeval it_value;
# 124 "/usr/include/sys/time.h" 3 4
struct timezone {
 int tz_minuteswest;
 int tz_dsttime;
# 167 "/usr/include/sys/time.h" 3 4
struct clockinfo {
 int hz;
 int tick;
 int tickadj;
 int stathz;
 int profhz;
# 184 "/usr/include/sys/time.h" 3 4
int adjtime(const struct timeval *, struct timeval *);
int futimes(int, const struct timeval *);
int lutimes(const char *, const struct timeval *) __attribute__((availability(macosx,introduced=10.5)));
int settimeofday(const struct timeval *, const struct timezone *);
int getitimer(int, struct itimerval *);
int gettimeofday(struct timeval * restrict, void * restrict);
# 1 "/usr/include/sys/_select.h" 1 3 4
# 39 "/usr/include/sys/_select.h" 3 4
int select(int, fd_set * restrict, fd_set * restrict,
  fd_set * restrict, struct timeval * restrict)
  __asm("_" "select" "$1050")
# 194 "/usr/include/sys/time.h" 2 3 4
int setitimer(int, const struct itimerval * restrict,
  struct itimerval * restrict);
int utimes(const char *, const struct timeval *);
# 76 "/usr/include/openssl/dtls1.h" 2 3 4
# 109 "/usr/include/openssl/dtls1.h" 3 4
typedef struct dtls1_bitmap_st
 unsigned long map;
 unsigned long length;
 unsigned long max_seq_num;
 } DTLS1_BITMAP;
struct dtls1_retransmit_state
 COMP_CTX *compress;
 unsigned short epoch;
struct hm_header_st
 unsigned char type;
 unsigned long msg_len;
 unsigned short seq;
 unsigned long frag_off;
 unsigned long frag_len;
 unsigned int is_ccs;
 struct dtls1_retransmit_state saved_retransmit_state;
struct ccs_header_st
 unsigned char type;
 unsigned short seq;
struct dtls1_timeout_st
 unsigned int read_timeouts;
 unsigned int write_timeouts;
 unsigned int num_alerts;
typedef struct record_pqueue_st
 pqueue q;
 } record_pqueue;
typedef struct hm_fragment_st
 struct hm_header_st msg_header;
 unsigned char *fragment;
 unsigned char *reassembly;
 } hm_fragment;
typedef struct dtls1_state_st
 unsigned int send_cookie;
 unsigned char cookie[256];
 unsigned char rcvd_cookie[256];
 unsigned int cookie_len;
 unsigned short r_epoch;
 unsigned short w_epoch;
 DTLS1_BITMAP bitmap;
 DTLS1_BITMAP next_bitmap;
 unsigned short handshake_write_seq;
 unsigned short next_handshake_write_seq;
 unsigned short handshake_read_seq;
 unsigned char last_write_sequence[8];
 record_pqueue unprocessed_rcds;
 record_pqueue processed_rcds;
 pqueue buffered_messages;
 pqueue sent_messages;
 record_pqueue buffered_app_data;
 unsigned int listen;
 unsigned int mtu;
 struct hm_header_st w_msg_hdr;
 struct hm_header_st r_msg_hdr;
 struct dtls1_timeout_st timeout;
 struct timeval next_timeout;
 unsigned short timeout_duration;
 unsigned char handshake_fragment[12];
 unsigned int retransmitting;
 unsigned int change_cipher_spec_ok;
 } DTLS1_STATE;
typedef struct dtls1_record_data_st
 SSL3_BUFFER rbuf;
 SSL3_RECORD rrec;
 } DTLS1_RECORD_DATA;
# 1073 "/usr/include/openssl/ssl.h" 2 3 4
# 1 "/usr/include/openssl/ssl23.h" 1 3 4
# 1074 "/usr/include/openssl/ssl.h" 2 3 4
# 1134 "/usr/include/openssl/ssl.h" 3 4
size_t SSL_get_finished(const SSL *s, void *buf, size_t count) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
size_t SSL_get_peer_finished(const SSL *s, void *buf, size_t count) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
# 1341 "/usr/include/openssl/ssl.h" 3 4
BIO_METHOD *BIO_f_ssl(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_ssl(SSL_CTX *ctx,int client) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_ssl_connect(SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO *BIO_new_buffer_ssl_connect(SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int BIO_ssl_copy_session_id(BIO *to,BIO *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void BIO_ssl_shutdown(BIO *ssl_bio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_cipher_list(SSL_CTX *,const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_CTX *SSL_CTX_new(SSL_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_free(SSL_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_CTX_set_timeout(SSL_CTX *ctx,long t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_CTX_get_timeout(const SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509_STORE *SSL_CTX_get_cert_store(const SSL_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_cert_store(SSL_CTX *,X509_STORE *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_want(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_clear(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_flush_sessions(SSL_CTX *ctx,long tm) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_CIPHER *SSL_get_current_cipher(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CIPHER_get_bits(const SSL_CIPHER *c,int *alg_bits) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * SSL_CIPHER_get_version(const SSL_CIPHER *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * SSL_CIPHER_get_name(const SSL_CIPHER *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_fd(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_rfd(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_wfd(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char * SSL_get_cipher_list(const SSL *s,int n) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char * SSL_get_shared_ciphers(const SSL *s, char *buf, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_read_ahead(const SSL * s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_pending(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_fd(SSL *s, int fd) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_rfd(SSL *s, int fd) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_wfd(SSL *s, int fd) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_bio(SSL *s, BIO *rbio,BIO *wbio) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * SSL_get_rbio(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
BIO * SSL_get_wbio(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_cipher_list(SSL *s, const char *str) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_read_ahead(SSL *s, int yes) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_verify_mode(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_verify_depth(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*SSL_get_verify_callback(const SSL *s))(int,X509_STORE_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_verify(SSL *s, int mode,
         int (*callback)(int ok,X509_STORE_CTX *ctx)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_verify_depth(SSL *s, int depth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_RSAPrivateKey(SSL *ssl, RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_RSAPrivateKey_ASN1(SSL *ssl, unsigned char *d, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_PrivateKey(SSL *ssl, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_PrivateKey_ASN1(int pk,SSL *ssl, const unsigned char *d, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_certificate(SSL *ssl, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_certificate_ASN1(SSL *ssl, const unsigned char *d, int len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_RSAPrivateKey_file(SSL *ssl, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_PrivateKey_file(SSL *ssl, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_use_certificate_file(SSL *ssl, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_RSAPrivateKey_file(SSL_CTX *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_PrivateKey_file(SSL_CTX *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_certificate_file(SSL_CTX *ctx, const char *file, int type) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_certificate_chain_file(SSL_CTX *ctx, const char *file) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_load_client_CA_file(const char *file) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_add_file_cert_subjects_to_stack(STACK *stackCAs,
int SSL_add_dir_cert_subjects_to_stack(STACK *stackCAs,
        const char *dir) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_load_error_strings(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_state_string(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_rstate_string(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_state_string_long(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_rstate_string_long(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_SESSION_get_time(const SSL_SESSION *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_SESSION_set_time(SSL_SESSION *s, long t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_SESSION_get_timeout(const SSL_SESSION *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_SESSION_set_timeout(SSL_SESSION *s, long t) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_copy_session_id(SSL *to,const SSL *from) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_SESSION *SSL_SESSION_new(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
unsigned long SSL_SESSION_hash(const SSL_SESSION *a) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_SESSION_cmp(const SSL_SESSION *a,const SSL_SESSION *b) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const unsigned char *SSL_SESSION_get_id(const SSL_SESSION *s, unsigned int *len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_SESSION_print_fp(FILE *fp,const SSL_SESSION *ses) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_SESSION_print(BIO *fp,const SSL_SESSION *ses) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_SESSION_free(SSL_SESSION *ses) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int i2d_SSL_SESSION(SSL_SESSION *in,unsigned char **pp) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_session(SSL *to, SSL_SESSION *session) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_add_session(SSL_CTX *s, SSL_SESSION *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_remove_session(SSL_CTX *,SSL_SESSION *c) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_generate_session_id(SSL_CTX *, GEN_SESSION_CB) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_generate_session_id(SSL *, GEN_SESSION_CB) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_has_matching_session_id(const SSL *ssl, const unsigned char *id,
     unsigned int id_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_SESSION *d2i_SSL_SESSION(SSL_SESSION **a,const unsigned char **pp,
        long length) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 * SSL_get_peer_certificate(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_get_peer_cert_chain(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_get_verify_mode(const SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_get_verify_depth(const SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int (*SSL_CTX_get_verify_callback(const SSL_CTX *ctx))(int,X509_STORE_CTX *) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_verify(SSL_CTX *ctx,int mode,
   int (*callback)(int, X509_STORE_CTX *)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_verify_depth(SSL_CTX *ctx,int depth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_cert_verify_callback(SSL_CTX *ctx, int (*cb)(X509_STORE_CTX *,void *), void *arg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_RSAPrivateKey(SSL_CTX *ctx, RSA *rsa) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_RSAPrivateKey_ASN1(SSL_CTX *ctx, const unsigned char *d, long len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_PrivateKey(SSL_CTX *ctx, EVP_PKEY *pkey) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_PrivateKey_ASN1(int pk,SSL_CTX *ctx,
int SSL_CTX_use_certificate(SSL_CTX *ctx, X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_use_certificate_ASN1(SSL_CTX *ctx, int len, const unsigned char *d) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_default_passwd_cb(SSL_CTX *ctx, pem_password_cb *cb) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_default_passwd_cb_userdata(SSL_CTX *ctx, void *u) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_check_private_key(const SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_check_private_key(const SSL *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_session_id_context(SSL_CTX *ctx,const unsigned char *sid_ctx,
           unsigned int sid_ctx_len) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL * SSL_new(SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_session_id_context(SSL *ssl,const unsigned char *sid_ctx,
int SSL_CTX_set_purpose(SSL_CTX *s, int purpose) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_purpose(SSL *s, int purpose) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_trust(SSL_CTX *s, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_trust(SSL *s, int trust) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_free(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_accept(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_connect(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_read(SSL *ssl,void *buf,int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_peek(SSL *ssl,void *buf,int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_write(SSL *ssl,const void *buf,int num) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_ctrl(SSL *ssl,int cmd, long larg, void *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_callback_ctrl(SSL *, int, void (*)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_CTX_ctrl(SSL_CTX *ctx,int cmd, long larg, void *parg) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_CTX_callback_ctrl(SSL_CTX *, int, void (*)(void)) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_error(const SSL *s,int ret_code) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_get_version(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_ssl_version(SSL_CTX *ctx,SSL_METHOD *meth) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv2_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv2_server_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv2_client_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv3_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv3_server_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv3_client_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv23_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv23_server_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSLv23_client_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *TLSv1_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *TLSv1_server_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *TLSv1_client_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *DTLSv1_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *DTLSv1_server_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *DTLSv1_client_method(void) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_get_ciphers(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_do_handshake(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_renegotiate(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_renegotiate_pending(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_shutdown(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_METHOD *SSL_get_ssl_method(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_ssl_method(SSL *s,SSL_METHOD *method) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_alert_type_string_long(int value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_alert_type_string(int value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_alert_desc_string_long(int value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
const char *SSL_alert_desc_string(int value) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_client_CA_list(SSL *s, STACK *name_list) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_client_CA_list(SSL_CTX *ctx, STACK *name_list) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_get_client_CA_list(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_CTX_get_client_CA_list(const SSL_CTX *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_add_client_CA(SSL *ssl,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_add_client_CA(SSL_CTX *ctx,X509 *x) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_connect_state(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_accept_state(SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_get_default_timeout(const SSL *s) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_library_init(void ) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
char *SSL_CIPHER_description(const SSL_CIPHER *,char *buf,int size) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
STACK *SSL_dup_CA_list(STACK *sk) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL *SSL_dup(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
X509 *SSL_get_certificate(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
               struct evp_pkey_st *SSL_get_privatekey(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_CTX_set_quiet_shutdown(SSL_CTX *ctx,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_get_quiet_shutdown(const SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_quiet_shutdown(SSL *ssl,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_quiet_shutdown(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_shutdown(SSL *ssl,int mode) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_shutdown(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_version(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_set_default_verify_paths(SSL_CTX *ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_load_verify_locations(SSL_CTX *ctx, const char *CAfile,
 const char *CApath) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_SESSION *SSL_get_session(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_SESSION *SSL_get1_session(SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_CTX *SSL_get_SSL_CTX(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
SSL_CTX *SSL_set_SSL_CTX(SSL *ssl, SSL_CTX* ctx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_info_callback(SSL *ssl,
void (*SSL_get_info_callback(const SSL *ssl))(const SSL *ssl,int type,int val) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_state(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void SSL_set_verify_result(SSL *ssl,long v) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
long SSL_get_verify_result(const SSL *ssl) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_set_ex_data(SSL *ssl,int idx,void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *SSL_get_ex_data(const SSL *ssl,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
 CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_SESSION_set_ex_data(SSL_SESSION *ss,int idx,void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *SSL_SESSION_get_ex_data(const SSL_SESSION *ss,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_SESSION_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_CTX_set_ex_data(SSL_CTX *ssl,int idx,void *data) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
void *SSL_CTX_get_ex_data(const SSL_CTX *ssl,int idx) __attribute__((availability(macosx,introduced=10.0,deprecated=10.7)));
int SSL_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
