[petsc-dev] Zero sized VecSetValues
Pierre Jolivet jolivet at ann.jussieu.fr
Sat Dec 13 12:35:08 CST 2014
Hello Barry,
Thank you for the quick fix.
On a completely unrelated note, in commit
bbe210f1929f67cd37937d8e6757679d89b1c592 that you pushed to master
recently, you introduced an unused variable Vec xx.
Now if I do a make check, I end up with the somehow misleading message
*******************Error detected during compile or
link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/mnt/space/SVN/petsc/src/snes/examples/tutorials ex19
because of -Wunused-variable.
Could you please fix that ?
Thank you in advance,
Pierre
On 2014-12-13 05:50, Barry Smith wrote:
> Pierre,
>    Please find attached a patch to fix this; after applying the patch
> do
> make gnumake
> in the root PETSc directory and relink your code.
>    Thanks for reporting the problem
>   Barry
>> On Dec 12, 2014, at 7:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Pierre,
>>    There is no rational, we will fix it.
>>  Barry
>>> On Dec 12, 2014, at 11:47 AM, Pierre Jolivet <jolivet at ann.jussieu.fr>
>>> wrote:
>>> Hello,
>>> Taking
>>> http://www.mcs.anl.gov/petsc/petsc-current/src/vec/vec/examples/tutorials/ex2.c.html
>>> and changing its 56th line from
>>> VecSetValues(x,1,&i,&one,ADD_VALUES);
>>> to
>>> VecSetValues(x,0,NULL,NULL,ADD_VALUES);
>>> yield the following error (at least --with-debug=1):
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Invalid pointer
>>> [0]PETSC ERROR: Null Pointer: Parameter # 3
>>> What is the rationale behind first checking the pointers, then doing
>>> the work or lack thereof, instead of, first checking if there is some
>>> work to do, and only then check the pointers (à la MPI) ?
>>> Thank you for your help,
>>> Pierre
