[petsc-dev] RegisterAllCalled visibility
Fri Dec 12 13:18:21 CST 2014
On Fri, Dec 12, 2014 at 12:43 PM, Tobin Isaac <tisaac at ices.utexas.edu>
wrote:
> Hi all,
> I'm trying to learn about PETSc's dynamic library framework.  I've
> noticed that XXXInitializePackage() routines are idempotent, but
> XXXRegisterAll() routines are not, and usually have a visible
> XXXRegisterAllCalled boolean to guard against multiple calls (but not
> always).  Then there are comments that say "In general, if there is
> more than one DLL then XXXRegisterAll() may be called several times."
> I don't understand the different handling between initialization and
> registration, especially because the initialization routines generally
> call the registration routines.  Any help?
That is just crappy engineering on our part. The RegisterAllCalled() should
be idempotent
just like PackageInitialize(). Does anyone disagree with this?
    Matt
> Thanks,
>   Toby
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141212/2e6b3e4e/attachment.html>
