[petsc-dev] DMGetDS in fortran
Thu Dec 4 15:46:34 CST 2014
On Sun, Nov 30, 2014 at 4:40 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
>  hi
> On 29/11/14 01:43, Matthew Knepley wrote:
>   Every time we add a type to PETSc, we have to tell the Fortran stub
> generator about it. This is a clunky part of the
> design, but there is not enough momentum to change it. Can you try
> deleting your PETSC_ARCH directory and
> reconfiguring? FIRST,
>    cd $PETSC_DIR
>   mv $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py .
>  so that you can get the same configuration.
> Thanks, that has done the trick! I must remember that in case I run into
> it again.
>> Also, any chance of a fortran interface to DMPlexCreateFromFile()? It
>> appears to be missing at the moment.
>  Yes, I can add this.
> Added to next.
    Matt
> Thanks again, much appreciated.
> Cheers, Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141204/9e0d0930/attachment.html>
