[petsc-dev] workflow diagram
Wed Apr 30 20:59:26 CDT 2014
  What does the “delete all graduated branches” box serve? I find it unneeded and confusing. You are just creating a new next based on the current master.  Don’t need that confusing language.
  Barry
On Apr 30, 2014, at 8:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 30 Apr 2014, Satish Balay wrote:
>> On Wed, 30 Apr 2014, Jed Brown wrote:
>>> Satish Balay <balay at mcs.anl.gov> writes:
>>>>> Hmm, feature releases are in first-parent history of both 'maint' and
>>>>> 'master'.  We tag a release on 'master', then do a fast-forward merge of
>>>>> the release tag into 'maint'.
>>>> Ok - updated.
>>> Aesthetically, I like the branches being straight lines, but I think
>>> this still looks like the release tag is not in first-parent history of
>>> 'maint' (like as though there is a no-ff merge).
>> I used vertical lines to convey that master,maint,next at that point are equivalent
> Ok - I added 'action' box to indicate the ff-merge from master to next.
> Satish
