[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 15:17:22 CDT 2014
Karl Rupp <rupp at iue.tuwien.ac.at> writes:
> I like the graph pretty much already. Similar to what Barry raised, I
> think there is some more room for improvements on the merge arrows.
> Rather than allowing merge arrows with arbitrary angles, what about
> making them only vertical or horizontal, with corners where needed? For
> example, the merge of a feature branch to next and later master could be
> depicted as follows (ASCII art works at least in gedit):
> --x--------x-------x----------x--- master
>        x---x---x-----x--x...A..B
>            feature          |
> -------x-------x-----x-----x------ next
> At point (A) the feature gets merged to next, and at (B) it gets merged
> to master. Note that the dots are part of the arrow, while dashes are
> commit dependencies in the DAG. I think you can keep the coloring and
> styles of merge lines to master and next as-is.
Thanks, updated.  What do you think now?
> Also make sure you explain in your blog post that the advantage of
> feature branches is a clustering of commits which belong together. With
> a single 'devel'-branch this is all messy, because commits from the
> various features are all mixed up.
Yup.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/af45217f/attachment.sig>
