[petsc-dev] Jed!!!
Jed Brown jed at jedbrown.org
Mon Apr 28 01:37:15 CDT 2014
Anton Popov <popov at uni-mainz.de> writes:
> The non-scalable conversion from MATNEST to AIJ is already implemented
> in PETSc by Dmitry.
> The function is called MatConvert_Nest_AIJ. It is in the sources, but
> not in documentation.
> I tried it ones, but it didn't work. So maybe it's time to look at it again.
We document interfaces rather than implementations, but I don't think
this function was ever finished.
> As far as I understand it is non-scalable because it exchanges the index
> ranges between all the processors.
> Whereas a smart version would just exchange between the neighboring
> processors in communication graph.
> But as Barry said, the scalability is not an issue for testing, so just
> debugging this function would be enough.
The function can be implemented, and I think it's useful, but it doesn't
solve the problem of people using constraining interfaces to assemble
matrices.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140428/7e131248/attachment.sig>
