[petsc-dev] [petsc-maint] problem installing petsc 3.4
Sean Farley sean.michael.farley at gmail.com
Wed Apr 16 19:58:40 CDT 2014
Jed Brown <jed at jedbrown.org> writes:
> Satish Balay <balay at mcs.anl.gov> writes:
>> On Wed, 16 Apr 2014, Jed Brown wrote:
>>> Yes, but the current failure case is complicated because people see a
>>> library they've never heard of and probably is not documented anywhere.
>>> "How did PETSc come up with this insane thing?"  I wouldn't take CMake
>>> as a model actor (it's inherent assumptions seem to break more than we
>>> do), but they use the Fortran compiler to link and don't try to include
>>> private libraries on the link line.
>> Perhaps things have improved now. There used to be a bunch of c++
>> compilers which requilred cxx as the linker for a c++ main.
> When PETSc is built as a C library depending on some C++ package (e.g.,
> Elemental), we should have a reliable way for users to link independent
> of whether their main is C, C++, or Fortran.  My recollection is that in
> the majority of cases, C++ ends up just needing -lstdc++ while Fortran
> has all manner of idiosyncrasies.
You misspelled '-lc++' for Mavericks :-)
