[petsc-dev] PETSC_VERSION_GE
Mark Adams mfadams at lbl.gov
Wed Apr 16 16:55:47 CDT 2014
Ed, you can try this on Titan:
> module swap PrgEnv-pgi PrgEnv-intel
> make PETSC_DIR=/autofs/na3_home1/adams/petsc
PETSC_ARCH=arch-titan-opt-intel
On Wed, Apr 16, 2014 at 5:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Apr 16, 2014, at 3:46 PM, Ed D'Azevedo <dazevedoef at ornl.gov> wrote:
> > Hi Barry,
> > I find that if I launch it multiple times, it may crash at different
> locations where it may not produce a stack trace.
>   Ed,
>    This is the issue I was seeing with the C code that did not
> consistently even on my machine where your code works fine.
>     So it may be your luck on this machine has failed until we get a
> proper support for this particular use of threads in PETSc which I hope
> will be by the end of the summer.
>    Barry
> > I tried to capture one case where it produced a stack trace.
> > Ed
> > On 04/16/2014 04:22 PM, Barry Smith wrote:
> >>    This is puzzling. At one place it has
> >>> Assertion failed in file
> /notbackedup/tmp/ulib/mpt/nightly/6.2/111913/mpich2/src/mpi/attr/comm_delete_attr.c
> at line 68: MPIU_Object_get_ref((p->keyval)) >= 0
> >>> *** glibc detected *** ./tpetsc_madams: double free or corruption
> (!prev): 0x000000000164e0c0 ***
> >> which is seems to indicate the MPI implementation is messing up by
> freeing the same thing twice (which it should not do if the MPI is thread
> safe)
> >>   but then there seems to be an issue in the PETSc allocation.
> >>> env003> addr2line --exe=tpetsc_madams 0x4b76d3 0x57a915 0x57a48e
> 0x4a700e 0x44e9be  0x44e1f4
> >>> /autofs/na3_home1/adams/petsc/src/sys/memory/mal.c:27
> >>> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3682
> >>> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3578
> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/ftn-custom/zaijf.c:14
> >>    Is there another version of MPI you can build with?
> >>    Barry
> >> On Apr 16, 2014, at 2:38 PM, Ed D'Azevedo <dazevedoef at ornl.gov> wrote:
> >>> Hi Mark,
> >>> I used the modified tpetsc.F90 in your email but I get the following
> error on Titan with 16 threads (works with 1 thread) with your version of
> petsc for titan.
> >>> aprun -n 1 -d 16 ./tpetsc_madams
> >>> Rank 0 [Wed Apr 16 15:30:53 2014] [c4-1c0s0n2] internal ABORT -
> process 0
> >>> Error: abort
> >>>    rax 0000000000000000, rbx 00002aaabd5466c0, rcx ffffffffffffffff
> >>>    rdx 0000000000000006, rsp 00002aaabd546538, rbp 0000000000000001
> >>>    rsi 0000000000004ad9, rdi 0000000000004ad8, r8  00000000ffffffff
> >>>    r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000206
> >>>    r12 00002aaabd546cc0, r13 00000000a4400002, r14 00002aaab9a9eab0
> >>>    r15 0000000000000009
> >>>   /lib64/libpthread.so.0(+0xf7c0) [0x2aaaaacdb7c0]
> >>>   /lib64/libc.so.6(gsignal+0x35) [0x2aaaba5bcb55]
> >>>   /lib64/libc.so.6(abort+0x181) [0x2aaaba5be131]
> >>>   /opt/cray/lib64/libmpich_pgi.so.2(+0xcb75e) [0x2aaab96b175e]
> >>> ======= Backtrace: =========
> >>>  PETSC_VERSION_RELEASE               0
> >>>  PETSC_VERSION_MAJOR                 3
> >>>  PETSC_VERSION_MINOR                 4
> >>>  PETSC_VERSION_SUBMINOR              4
> >>>  PETSC_VERSION_PATCH                 0
> >>>  PETSC_VERSION_DATE      unknown
> >>>  petsc_version_lt(3,3,0) is false
> >>>  nthreads =            16  NCASES =           100
> >>> Application 4896333 exit codes: 127
> >>> Application 4896333 resources: utime ~0s, stime ~0s, Rss ~12544,
> inblocks ~11435, outblocks ~35849
> >>>   /lib64/libc.so.6(+0x7576d) [0x2aaaba5ff76d]
> >>>   /lib64/libc.so.6(__libc_malloc+0xda) [0x2aaaba60464a]
> >>>   ./tpetsc_madams() [0x4b76d3]
> >>>   ./tpetsc_madams() [0x57a915]
> >>>   ./tpetsc_madams() [0x57a48e]
> >>>   ./tpetsc_madams() [0x4a700e]
> >>>   ./tpetsc_madams() [0x44e9be]
> >>>   ./tpetsc_madams() [0x44e1f4]
> >>>   /lib64/libc.so.6(__libc_start_main+0xe6) [0x2aaaba5a8c36]
> >>>   ./tpetsc_madams() [0x44e0e9]
> >>> Application 4896342 exit codes: 127
> >>> Application 4896342 resources: utime ~0s, stime ~0s, Rss ~12544,
> inblocks ~11435, outblocks ~35851
> >>> /autofs/na3_home1/efdazedo/test/PETSC/./tpetsc_madams.F90:143
> >>> ??:0
> >>> On 04/16/2014 02:38 PM, Mark Adams wrote:
> >>>> Ed, I fixed some integer -- PetscInt error and put #ifdefs for the
> new interface to KSPSetOperators.  It works for me on Edison.  This is with
> Intel compilers.
> >>>> You seem to be dying in MatCreate...  I'm guessing you are using 64
> bit indices.  I fixed this in the code.  Give this a try and see if it
> works.
> >>>> On Wed, Apr 16, 2014 at 2:33 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >>>>    Mark,
> >>>>     Please send configure.log and make.log and run with 4 threads and
> send all output.
> >>>>     Now Ed and I have had no problem running this code. But there are
> some issues with running code with each thread creating their own objects.
> That is, I have an another example in C that does not work. There are
> places where we work with MPI attributes and they are not properly
> protected with locks. This may or may not be affecting you. If you have to
> develop code that has different threads create different objects you are
> welcome to work with Jed and I etc in getting the thread stuff working in
> PETSc but this branch is not the starting point. So basically Ed got lucky
> and we won’t have “real” support for this usage of threads for a while
> (months at least).
> >>>> You absolutely should configure with —with-debugging —with-log=0
> >>>>    Barry
> >>>> On Apr 16, 2014, at 10:26 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>>>> I could also use your compile line.  I am getting no output.
> >>>>> On Wed, Apr 16, 2014 at 10:41 AM, Ed D'Azevedo <dazevedoef at ornl.gov>
> wrote:
> >>>>> Hi Mark,
> >>>>> I hope this back trace might be helpful.
> >>>>> You may need to build petsc with
> >>>>> ./configure \
> >>>>> --with-x=0 \
> >>>>> --with-debugging=0 \
> >>>>> --with-log=0 \
> >>>>> env003> addr2line --exe=tpetsc_madams 0x4b76e3 0x4aa3d7 0x484888
> 0x475798 0x548aa5 0x5e5df2 0x57a353 0x4a701e  0x44e9be 0x44e1f4
> >>>>> /autofs/na3_home1/adams/petsc/src/sys/utils/str.c:188
> >>>>> /autofs/na3_home1/adams/petsc/src/sys/logging/utils/eventlog.c:317
> >>>>> /autofs/na3_home1/adams/petsc/src/sys/logging/plog.c:747
> >>>>> /autofs/na3_home1/adams/petsc/src/mat/interface/dlregismat.c:145
> >>>>> /autofs/na3_home1/adams/petsc/src/mat/utils/gcreate.c:57
> >>>>> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3576
> >>>>> /autofs/na3_home1/efdazedo/test/PETSC/./tpetsc.F90:147
> >>>>> /lib64/libc.so.6(+0x75558)[0x2aaaba5ff558]
> >>>>> /lib64/libc.so.6(cfree+0x6c)[0x2aaaba6044fc]
> >>>>> ./tpetsc_madams[0x4b7759]
> >>>>>   /lib64/libc.so.6(+0x789f0) [0x2aaaba6029f0]
> >>>>>   /lib64/libc.so.6(__libc_malloc+0x77) [0x2aaaba6045e7]
> >>>>>   ./tpetsc_madams() [0x4b76e3]
> >>>>>   ./tpetsc_madams() [0x4aa3d7]
> >>>>>   ./tpetsc_madams() [0x484888]
> >>>>>   ./tpetsc_madams() [0x475798]
> >>>>>   ./tpetsc_madams() [0x548aa5]
> >>>>>   ./tpetsc_madams() [0x5e5df2]
> >>>>>   ./tpetsc_madams() [0x57a353]
> >>>>>   ./tpetsc_madams() [0x4a701e]
> >>>>> On 04/16/2014 10:33 AM, Mark Adams wrote:
> >>>>>> cc'ing petsc-dev.
> >>>>>> I will try it.
> >>>>>> On Wed, Apr 16, 2014 at 10:21 AM, Ed D'Azevedo <dazevedoef at ornl.gov>
> wrote:
> >>>>>> Hi Mark,
> >>>>>> I got an error when I tried the simple test code (see attached) on
> Titan.
> >>>>>> Can you try to run the attached test case to see if it will work
> for you?
> >>>>>> I have also sent the simple test code to Barry.
> >>>>>> The code seems to work with 1 thread
> >>>>>> env003> export OMP_NUM_THREADS=1
> >>>>>> env003> aprun -n 1 -d 16 ./tpetsc_madams
> >>>>>>  nthreads =             1  NCASES =           100
> >>>>>>  nz =         88804
> >>>>>> Warning: ieee_inexact is signaling
> >>>>>> all done
> >>>>>>  total time is     7.268438
> >>>>>>  maxval(err)    6.9650285539069046E-011
> >>>>>> Application 4895013 resources: utime ~8s, stime ~0s, Rss ~22300,
> inblocks ~11428, outblocks ~35848
> >>>>>> The code seems to have trouble using more threads
> >>>>>> env003> export OMP_NUM_THREADS=16
> (!prev): 0x00000000015ee0b0 ***
> >>>>>> tpetsc_madams: malloc.c:3091: sYSMALLOc: Assertion `(old_top ==
> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
> (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
> fd_nextsize))+((2 * (sizeof(size_t))) - 1)) & ~((2 * (sizeof(size_t))) -
> 1))) && ((old_top)->size & 0x1) && ((unsigned long)old_end & pagemask) ==
> 0)' failed.
> >>>>>> Error: abort
> >>>>>>    rax 0000000000000000, rbx 0000000000000fff, rcx ffffffffffffffff
> >>>>>>    rdx 0000000000000006, rsp 00002aaac4554f78, rbp 00002aaad0000098
> >>>>>>    rsi 0000000000005200, rdi 00000000000051f1, r8  00000000ffffffff
> >>>>>>    r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000202
> >>>>>>    r12 0000000000000000, r13 00002aaad0008e30, r14 0000000000000020
> >>>>>>    r15 0000000000000000
> >>>>>> Application 4895021 exit codes: 127
> >>>>>> Application 4895021 resources: utime ~0s, stime ~0s, Rss ~12544,
> inblocks ~11429, outblocks ~35849
> >>>>>> On 04/11/2014 04:34 PM, Mark Adams wrote:
> >>>>>>> PETSc dev 'master' now has Barry's thread safe stuff so you should
> be able to use that.  I have build it in:
> >>>>>>> So try this version out.  And revert the code to the repo version
> by doing:
> >>>>>>>> git checkout poisson.F90
> >>>>>>> and any other place where #if PETSC_VERSION_GE(3,5,0) is used.  I
> only see poisson.F90.
> >>>>>>> If this works I can install it wherever you like as Ed did.
> >>>>>>> Mark
> >>>>>>> On Thu, Apr 10, 2014 at 11:24 PM, Seung-Hoe Ku <sku at pppl.gov>
> wrote:
> >>>>>>> Hi Mark,
> >>>>>>> I think it is not a big problem until we use petsc 3.5 other than
> you. Now I disabled #if #endif for other users. Sorry for the
> inconvenience. Could you uncomment it when you are working with 3.5, and
> does not commit to core_dev, please?
> >>>>>>> We need Ed's thread safe petsc for performance issue, so we can
> find some way to resolve it when 3.5 is released and installed on titan.
> >>>>>>> Thanks,
> >>>>>>> Seung-Hoe
> >>>>>>> On Thu, Apr 10, 2014 at 11:38 AM, Mark Adams <mfadams at lbl.gov>
> wrote:
> >>>>>>> We've figured out the problem (again).  It will be fixed in future
> versions.
> >>>>>>> We can fix your installation.  I'm guessing Ed did this
> installation so it might not be worth fixing this code since you are up and
> running.  Let me know what you want to do.
> >>>>>>> The problem is that is a development version of the code, which is
> not as stable as the releases.  This version needs to be updated to get fix
> this problem.  I have to tell you how to do this update so let me know if
> you want to do it.
> >>>>>>> Mark
> >>>>>>> On Thu, Apr 10, 2014 at 8:58 AM, Seung-Hoe Ku <sku at pppl.gov>
> wrote:
> >>>>>>> One question is..
> >>>>>>> If PETSC_VERSION_GE is defined with PETSC_VERSION_GT and
> PETSC_VERSION_GT is defined with something in petsc.h,
> >>>>>>> redefinition of PETSC_VERSION_GT after petsc.h will change
> PETSC_VERSION_GE?
> >>>>>>> On Thu, Apr 10, 2014 at 10:55 AM, Seung-Hoe Ku <sku at pppl.gov>
> wrote:
> >>>>>>> This is the code I tried to compile.
> >>>>>>> #if PETSC_VERSION_GE(5,5,0)
> >>>>>>>  214   BBBBBBBBBBBBBBBBBBB=0
> >>>>>>>  215   call KSPSetOperators(solver%ksp,  solver%Amat,
>  solver%Amat, ierr )
> >>>>>>>  216 #else
> >>>>>>>  217   AAAAAAAAAAAA=0
> >>>>>>>  218   call KSPSetOperators(solver%ksp,  solver%Amat,
>  solver%Amat, SAME_NONZERO_PATT     ERN, ierr )
> >>>>>>>  219 #endif
> >>>>>>> On Thu, Apr 10, 2014 at 10:49 AM, Mark Adams <mfadams at lbl.gov>
> wrote:
> >>>>>>> On Thu, Apr 10, 2014 at 8:25 AM, Seung-Hoe Ku <sku at pppl.gov>
> wrote:
> >>>>>>> I have the same problem. I used poisson.F90 in
> /lustre/atlas2/env003/scratch/shku/XGC1_3_petsc_problem/
> >>>>>>> It seems that #undef should be after #include<finclude/petsc.h>.
> Otherwise, petsc.h seems to try redefine it.
> >>>>>>> Oh yes.
> >>>>>>> Anyway, I got the same error message:
> >>>>>>> PGF90-S-0038-Symbol, bbbbbbbbbbbbbbbbbbb, has not been explicitly
> declared (poisson.F90)
> >>>>>>>   0 inform,   0 warnings,   1 severes, 0 fatal for
> init_1field_solver
> >>>>>>> is this in the source file?
> >>>>>>> I tried 5.5.0 for the arguments of PETSC_VERSION_GE, but still
> >>>>>>> Or do you mean VERSION_GE and VERSION_LT instead of VERSION_GT and
> VERSION_LE?
> >>>>>>> Thanks,
> >>>>>>> Seung-Hoe
> >>>>>>> On Wed, Apr 9, 2014 at 9:54 PM, Mark Adams <mfadams at lbl.gov>
> wrote:
> >>>>>>> We might have a fix.  It turns out that some fortran compilers to
> not do the #define quite right. Try this:
> >>>>>>> This will out the original (bad) file back. Then add to poisson.F90
> >>>>>>> #undef PETSC_VERSION_GT
> >>>>>>> #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
> >>>>>>>   (0==PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR))
> >>>>>>> This is the fix that Jed thinks will work.  If it works we can
> propagate it.
> >>>>>>> Sorry about the confusion,
> >>>>>>> Mark
> >>>>>>> On Wed, Apr 9, 2014 at 7:36 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> >>>>>>> Great! Thank you.
> >>>>>>> On Wed, Apr 9, 2014 at 9:35 PM, Mark Adams <mfadams at lbl.gov>
> wrote:
> >>>>>>> Good news.  I'm at a meeting and Jed Brown is here and he seems to
> have been able to reproduce the error.  Preprocessors can be a pain.  I'm
> going to wait until Jed has a chance to look at this and come up with a
> solution.
> >>>>>>> On Wed, Apr 9, 2014 at 7:28 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> >>>>>>> Now I am using iterative solver which will be replaced to your 2
> field solver later.
> >>>>>>> Sorry. The line number 3003 is wrong. It is  209 or near it.
> >>>>>>> Yes. We can take a look at this when you come. It is not urgent
> problem.
> >>>>>>> Thanks,
> >>>>>>> Seung-Hoe
> >>>>>>> On Wed, Apr 9, 2014 at 9:25 PM, Mark Adams <mfadams at lbl.gov>
> wrote:
> >>>>>>> I noticed that your makefile was not using the new petsc solver.
>  Is that intensional?
> >>>>>>> The line you gave me 3003 poission.F90 seems to be the last line
> of the file.
> >>>>>>> I am not getting Edison or Titan to build.  We can take a look at
> this next week.
> >>>>>>> Mark
> >>>>>>> On Tue, Apr 8, 2014 at 12:38 PM, Seung-Hoe Ku <sku at pppl.gov>
> wrote:
> >>>>>>> Hi Mark,
> >>>>>>> It seems that PETSC_VERSION_GE is not working line 3003 of
> poisson.F90. Is there any reason of using PETSC_VERSION_GE instead of
> PETSC_VERSION_LE? The previous code worked, I think.
> >>>>>>> Thanks,
> >>>>>>> Seung-Hoe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/dbdcbca3/attachment.html>
