[petsc-dev] Fwd: MatSetValues with v=0
Wed Apr 16 14:11:04 CDT 2014
  Do we then remove the current functionality? Which is a little weird as currently partly supporting one matrix format and only one of the set values calls
   Barry
Begin forwarded message:
> From: Jed Brown <jed at jedbrown.org>
> Subject: Re: [petsc-dev] MatSetValues with v=0
> Date: April 16, 2014 at 8:44:02 AM CDT
> To: Eric Chamberland <Eric.Chamberland at giref.ulaval.ca>, Barry Smith <bsmith at mcs.anl.gov>, Patrick Lacasse <patrick.m.lacasse at gmail.com>
> Cc: For users of the development version of PETSc <petsc-dev at mcs.anl.gov>
> Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> writes:
>> I was writing (new) code which do the firsts MatSetValues after the
>> MatXAIJSetPreallocation.  We have to do this because the "real"
>> non-zeros will be added later by a mix of ADD_VALUES and
>> INSERT_VALUES... which would prevent us to "lock" the matrix
>> (MatSetOption(aMatricePETSc, MAT_NEW_NONZERO_LOCATION_ERR, PETSC_TRUE)
>> because this option must be passed after the first MatAssemblyEnd()...
>> but all the non-zeros are "triggered" only after this "mixed" assembly...
>> In other words, we have to do a "fake" assembly with all "0" to cover
>> all non-zeros that will be in fact added later... So we have to create
>> many "fake" elementary matrices to pass for assembly... that is why
>> Patrick was asking if the feature was supported... It would save us from
>> creating the fake matrices...  Or maybe there is a better solution?...
> Just create one large-enough buffer containing all zeros.  For example,
>  PetscScalar *values;
>  PetscCalloc1(1000,&values);
>  for (...) {
>    MatSetValues(...,values,INSERT_VALUES);
>  PetscFree(values);
> Is this okay?
