[petsc-dev] PETSC_VERSION_GE
Mark Adams mfadams at lbl.gov
Wed Apr 16 14:01:03 CDT 2014
On Wed, Apr 16, 2014 at 2:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Apr 16, 2014, at 1:38 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Ed, I fixed some integer -- PetscInt error and put #ifdefs for the new
> interface to KSPSetOperators.  It works for me on Edison.  This is with
> Intel compilers.
> > You seem to be dying in MatCreate...  I'm guessing you are using 64 bit
> indices.  I fixed this in the code.  Give this a try and see if it works.
>    I’m confused. This code works with ONLY one particular branch of PETSc;
> it will not work with any other branch or version!!!!! Why are you putting
> ifdefs for different versions in the code.
Good point.
Ed: you could just put #error in place of the old call.
>    Barry
> > On Wed, Apr 16, 2014 at 2:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Mark,
> >     Please send configure.log and make.log and run with 4 threads and
> send all output.
> >     Now Ed and I have had no problem running this code. But there are
> some issues with running code with each thread creating their own objects.
> That is, I have an another example in C that does not work. There are
> places where we work with MPI attributes and they are not properly
> protected with locks. This may or may not be affecting you. If you have to
> develop code that has different threads create different objects you are
> welcome to work with Jed and I etc in getting the thread stuff working in
> PETSc but this branch is not the starting point. So basically Ed got lucky
> and we won’t have “real” support for this usage of threads for a while
> (months at least).
> > You absolutely should configure with —with-debugging —with-log=0
> >    Barry
> > On Apr 16, 2014, at 10:26 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I could also use your compile line.  I am getting no output.
> > > On Wed, Apr 16, 2014 at 10:41 AM, Ed D'Azevedo <dazevedoef at ornl.gov>
> wrote:
> > > Hi Mark,
> > > I hope this back trace might be helpful.
> > > You may need to build petsc with
> > > ./configure \
> > > --with-x=0 \
> > > --with-debugging=0 \
> > > --with-log=0 \
> > > env003> addr2line --exe=tpetsc_madams 0x4b76e3 0x4aa3d7 0x484888
> 0x475798 0x548aa5 0x5e5df2 0x57a353 0x4a701e  0x44e9be 0x44e1f4
> > > /autofs/na3_home1/adams/petsc/src/sys/memory/mal.c:27
> > > /autofs/na3_home1/adams/petsc/src/sys/utils/str.c:188
> > > /autofs/na3_home1/adams/petsc/src/sys/logging/utils/eventlog.c:317
> > > /autofs/na3_home1/adams/petsc/src/sys/logging/plog.c:747
> > > /autofs/na3_home1/adams/petsc/src/mat/interface/dlregismat.c:145
> > > /autofs/na3_home1/adams/petsc/src/mat/utils/gcreate.c:57
> > > /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3576
> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/ftn-custom/zaijf.c:14
> > > /autofs/na3_home1/efdazedo/test/PETSC/./tpetsc.F90:147
> > > ======= Backtrace: =========
> > > /lib64/libc.so.6(+0x75558)[0x2aaaba5ff558]
> > > /lib64/libc.so.6(cfree+0x6c)[0x2aaaba6044fc]
> > > ./tpetsc_madams[0x4b7759]
> > >   /lib64/libpthread.so.0(+0xf7c0) [0x2aaaaacdb7c0]
> > >   /lib64/libc.so.6(gsignal+0x35) [0x2aaaba5bcb55]
> > >   /lib64/libc.so.6(abort+0x181) [0x2aaaba5be131]
> > >   /lib64/libc.so.6(+0x7576d) [0x2aaaba5ff76d]
> > >   /lib64/libc.so.6(+0x789f0) [0x2aaaba6029f0]
> > >   /lib64/libc.so.6(__libc_malloc+0x77) [0x2aaaba6045e7]
> > >   ./tpetsc_madams() [0x4b76e3]
> > >   ./tpetsc_madams() [0x4aa3d7]
> > >   ./tpetsc_madams() [0x484888]
> > >   ./tpetsc_madams() [0x475798]
> > >   ./tpetsc_madams() [0x548aa5]
> > >   ./tpetsc_madams() [0x5e5df2]
> > >   ./tpetsc_madams() [0x57a353]
> > >   ./tpetsc_madams() [0x4a701e]
> > >   ./tpetsc_madams() [0x44e9be]
> > >   ./tpetsc_madams() [0x44e1f4]
> > >   /lib64/libc.so.6(__libc_start_main+0xe6) [0x2aaaba5a8c36]
> > >   ./tpetsc_madams() [0x44e0e9]
> > > On 04/16/2014 10:33 AM, Mark Adams wrote:
> > >> cc'ing petsc-dev.
> > >> I will try it.
> > >> On Wed, Apr 16, 2014 at 10:21 AM, Ed D'Azevedo <dazevedoef at ornl.gov>
> wrote:
> > >> Hi Mark,
> > >> I got an error when I tried the simple test code (see attached) on
> Titan.
> > >> Can you try to run the attached test case to see if it will work for
> you?
> > >> I have also sent the simple test code to Barry.
> > >> The code seems to work with 1 thread
> > >> env003> export OMP_NUM_THREADS=1
> > >> env003> aprun -n 1 -d 16 ./tpetsc_madams
> > >>  PETSC_VERSION_RELEASE               0
> > >>  PETSC_VERSION_MAJOR                 3
> > >>  PETSC_VERSION_MINOR                 4
> > >>  PETSC_VERSION_SUBMINOR              4
> > >>  PETSC_VERSION_PATCH                 0
> > >>  PETSC_VERSION_DATE      unknown
> > >>  petsc_version_lt(3,3,0) is false
> > >>  nthreads =             1  NCASES =           100
> > >>  nz =         88804
> > >> Warning: ieee_inexact is signaling
> > >> all done
> > >>  total time is     7.268438
> > >>  maxval(err)    6.9650285539069046E-011
> > >> Application 4895013 resources: utime ~8s, stime ~0s, Rss ~22300,
> inblocks ~11428, outblocks ~35848
> > >> The code seems to have trouble using more threads
> > >> env003> export OMP_NUM_THREADS=16
> > >> *** glibc detected *** ./tpetsc_madams: double free or corruption
> (!prev): 0x00000000015ee0b0 ***
> > >>  nthreads =            16  NCASES =           100
> > >> tpetsc_madams: malloc.c:3091: sYSMALLOc: Assertion `(old_top ==
> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
> (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
> fd_nextsize))+((2 * (sizeof(size_t))) - 1)) & ~((2 * (sizeof(size_t))) -
> 1))) && ((old_top)->size & 0x1) && ((unsigned long)old_end & pagemask) ==
> 0)' failed.
> > >> Error: abort
> > >>    rax 0000000000000000, rbx 0000000000000fff, rcx ffffffffffffffff
> > >>    rdx 0000000000000006, rsp 00002aaac4554f78, rbp 00002aaad0000098
> > >>    rsi 0000000000005200, rdi 00000000000051f1, r8  00000000ffffffff
> > >>    r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000202
> > >>    r12 0000000000000000, r13 00002aaad0008e30, r14 0000000000000020
> > >>    r15 0000000000000000
> > >> Application 4895021 exit codes: 127
> > >> Application 4895021 resources: utime ~0s, stime ~0s, Rss ~12544,
> inblocks ~11429, outblocks ~35849
> > >> On 04/11/2014 04:34 PM, Mark Adams wrote:
> > >>> PETSc dev 'master' now has Barry's thread safe stuff so you should
> be able to use that.  I have build it in:
> > >>> PETSC_DIR=/autofs/na3_home1/adams/petsc
> > >>> PETSC_ARCH=arch-titan-opt
> > >>> So try this version out.  And revert the code to the repo version by
> doing:
> > >>> > git checkout poisson.F90
> > >>> and any other place where #if PETSC_VERSION_GE(3,5,0) is used.  I
> only see poisson.F90.
> > >>> If this works I can install it wherever you like as Ed did.
> > >>> Mark
> > >>> On Thu, Apr 10, 2014 at 11:24 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> Hi Mark,
> > >>> I think it is not a big problem until we use petsc 3.5 other than
> you. Now I disabled #if #endif for other users. Sorry for the
> inconvenience. Could you uncomment it when you are working with 3.5, and
> does not commit to core_dev, please?
> > >>> We need Ed's thread safe petsc for performance issue, so we can find
> some way to resolve it when 3.5 is released and installed on titan.
> > >>> Thanks,
> > >>> Seung-Hoe
> > >>> On Thu, Apr 10, 2014 at 11:38 AM, Mark Adams <mfadams at lbl.gov>
> wrote:
> > >>> We've figured out the problem (again).  It will be fixed in future
> versions.
> > >>> We can fix your installation.  I'm guessing Ed did this installation
> so it might not be worth fixing this code since you are up and running.
>  Let me know what you want to do.
> > >>> The problem is that is a development version of the code, which is
> not as stable as the releases.  This version needs to be updated to get fix
> this problem.  I have to tell you how to do this update so let me know if
> you want to do it.
> > >>> Mark
> > >>> On Thu, Apr 10, 2014 at 8:58 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> One question is..
> > >>> If PETSC_VERSION_GE is defined with PETSC_VERSION_GT and
> PETSC_VERSION_GT is defined with something in petsc.h,
> > >>> redefinition of PETSC_VERSION_GT after petsc.h will change
> PETSC_VERSION_GE?
> > >>> On Thu, Apr 10, 2014 at 10:55 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> This is the code I tried to compile.
> > >>> #if PETSC_VERSION_GE(5,5,0)
> > >>>  214   BBBBBBBBBBBBBBBBBBB=0
> > >>>  215   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
> ierr )
> > >>>  216 #else
> > >>>  217   AAAAAAAAAAAA=0
> > >>>  218   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
> SAME_NONZERO_PATT     ERN, ierr )
> > >>>  219 #endif
> > >>> On Thu, Apr 10, 2014 at 10:49 AM, Mark Adams <mfadams at lbl.gov>
> wrote:
> > >>> On Thu, Apr 10, 2014 at 8:25 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> I have the same problem. I used poisson.F90 in
> /lustre/atlas2/env003/scratch/shku/XGC1_3_petsc_problem/
> > >>> It seems that #undef should be after #include<finclude/petsc.h>.
> Otherwise, petsc.h seems to try redefine it.
> > >>> Oh yes.
> > >>> Anyway, I got the same error message:
> > >>> PGF90-S-0038-Symbol, bbbbbbbbbbbbbbbbbbb, has not been explicitly
> declared (poisson.F90)
> > >>>   0 inform,   0 warnings,   1 severes, 0 fatal for init_1field_solver
> > >>> is this in the source file?
> > >>> I tried 5.5.0 for the arguments of PETSC_VERSION_GE, but still have
> the same problem.
> > >>> Or do you mean VERSION_GE and VERSION_LT instead of VERSION_GT and
> VERSION_LE?
> > >>> Thanks,
> > >>> Seung-Hoe
> > >>> On Wed, Apr 9, 2014 at 9:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >>> We might have a fix.  It turns out that some fortran compilers to
> not do the #define quite right. Try this:
> > >>> This will out the original (bad) file back. Then add to poisson.F90
> > >>> #undef PETSC_VERSION_GT
> > >>> #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
> > >>>   (0==PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR))
> > >>> This is the fix that Jed thinks will work.  If it works we can
> propagate it.
> > >>> Sorry about the confusion,
> > >>> Mark
> > >>> On Wed, Apr 9, 2014 at 7:36 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> Great! Thank you.
> > >>> On Wed, Apr 9, 2014 at 9:35 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >>> Good news.  I'm at a meeting and Jed Brown is here and he seems to
> have been able to reproduce the error.  Preprocessors can be a pain.  I'm
> going to wait until Jed has a chance to look at this and come up with a
> solution.
> > >>> On Wed, Apr 9, 2014 at 7:28 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> Now I am using iterative solver which will be replaced to your 2
> field solver later.
> > >>> Sorry. The line number 3003 is wrong. It is  209 or near it.
> > >>> Yes. We can take a look at this when you come. It is not urgent
> problem.
> > >>> Thanks,
> > >>> Seung-Hoe
> > >>> On Wed, Apr 9, 2014 at 9:25 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > >>> I noticed that your makefile was not using the new petsc solver.  Is
> that intensional?
> > >>> The line you gave me 3003 poission.F90 seems to be the last line of
> the file.
> > >>> I am not getting Edison or Titan to build.  We can take a look at
> this next week.
> > >>> Mark
> > >>> On Tue, Apr 8, 2014 at 12:38 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
> > >>> Hi Mark,
> > >>> It seems that PETSC_VERSION_GE is not working line 3003 of
> poisson.F90. Is there any reason of using PETSC_VERSION_GE instead of
> PETSC_VERSION_LE? The previous code worked, I think.
> > >>> Thanks,
> > >>> Seung-Hoe
> > <tpetsc.F90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/80e8974f/attachment.html>
