[petsc-dev] MatSetValues with v=0
Jed Brown jed at jedbrown.org
Wed Apr 16 08:44:02 CDT 2014
Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> writes:
> I was writing (new) code which do the firsts MatSetValues after the
> MatXAIJSetPreallocation.  We have to do this because the "real"
> non-zeros will be added later by a mix of ADD_VALUES and
> INSERT_VALUES... which would prevent us to "lock" the matrix
> (MatSetOption(aMatricePETSc, MAT_NEW_NONZERO_LOCATION_ERR, PETSC_TRUE)
> because this option must be passed after the first MatAssemblyEnd()...
> but all the non-zeros are "triggered" only after this "mixed" assembly...
> In other words, we have to do a "fake" assembly with all "0" to cover
> all non-zeros that will be in fact added later... So we have to create
> many "fake" elementary matrices to pass for assembly... that is why
> Patrick was asking if the feature was supported... It would save us from
> creating the fake matrices...  Or maybe there is a better solution?...
Just create one large-enough buffer containing all zeros.  For example,
  PetscScalar *values;
  PetscCalloc1(1000,&values);
  for (...) {
    MatSetValues(...,values,INSERT_VALUES);
  PetscFree(values);
Is this okay?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/6f7eb179/attachment.sig>
