[petsc-dev] 6-node wedge cells in DMPlex
Adrian Croucher a.croucher at auckland.ac.nz
Mon Apr 14 20:44:14 CDT 2014
hi
I just discovered that DMPlexInterpolate() complains if I try to
interpolate a mesh containing 6-node wedge cells in 3-D:
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Cone size 6 not supported for dimension 3
Looking in the code, it appears that DMPlexGetRawFaces_Internal() only
supports cells with 3, 4 or 8 nodes in 3-D.
At first I thought it would be simple enough to add another case in
there for cone size 6. But then I noticed that
DMPlexInterpolateFaces_Internal() will throw an error for any type of
cell with faces that don't all have the same number of nodes - and
there's a comment in there saying "I see no way to do this if we admit
faces of different shapes".
I don't know the routine well enough to understand what the difficulty
is, but are there any plans to generalise DMPlexInterpolate() so that it
can handle commonly-used cell types (like 6-node wedge) that have faces
with different numbers of nodes? We use wedge cells quite a bit, so it
would limit the usefulness of DMPlex if it can't support them. Unless
there is some kind of workaround?
Cheers, Adrian
Dr Adrian Croucher
Department of Engineering Science
University of Auckland
New Zealand
tel 64-9-373-7599 ext 84611
