[petsc-dev] MatSetValues with v=0
Patrick Lacasse patrick.m.lacasse at gmail.com
Fri Apr 11 12:51:41 CDT 2014
   I see that implementation of MatSetValues handles a special case when
one passes a null pointer v=0.
In this case, it is considered that all values are 0.
But the documentation doesn't seems to talk about it :
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValues.html
Is it a feature that we can use?
Should it be added to the doc?
Patrick Lacasse
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140411/29f93dab/attachment.html>
