[petsc-dev] DMView_Plex crash with sequential DM and numproc>1
Andrés Alessandro León Baldelli a.leon.baldelli at gmail.com
Fri Apr 11 12:11:17 CDT 2014
I am trying to use the new Plex to HDF5 interface. From what I understand, it only works in sequential mode.
I would like to write a sequential DM, created e.g. from an exodusII mesh via DMPlexCreateExodusFromFile.
What puzzles me is that I only can do it if I run on a single processor, since it crashes as soon its  communicator contains more than one proc.
My understanding is that, if numproc>1, the crash is due to the call to ISView in src/dm/impls/plex/plex.c:785 which fails because its two arguments do not share the same communicator.
Could you help me understand a little more what is going on, what I am doing wrong and what could help solving this issue?
I attach the error message, a minimal code to reproduce the crash and a test mesh.
Best,
————— begin output—————
geothermal:dmcomplex kumiori$ mpirun -n 2 ./testHDF5Plex -i data/TwoTri.gen
cubit(/Users/blaise/Development/DMComplex/data/junkTri.gen): 08/31/2013: 19:01:0 in 2 dimensions:
  0-cells: 6 0
  2-cells: 4 0
Labels:
  depth: 2 strata of sizes (6, 4)
  Cell Sets: 1 strata of sizes (4)
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Arguments must have same communicators
[0]PETSC ERROR: Different communicators in the two objects: Argument # 1 and 2 flag 3
[0]PETSC ERROR: See http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-3957-g24a0f54  GIT Date: 2014-04-02 15:35:24 -0500
[0]PETSC ERROR: ./testHDF5Plex on a Darwin-llvm50-g named geothermal.lsu.edu by kumiori Fri Apr 11 12:06:44 2014
[0]PETSC ERROR: Configure options --CFLAGS=-Wno-unused --download-chaco=1 --download-exodusii=1 --download-hdf5=1 --download-metis=1 --download-mpich=1 --download-netcdf=1 --download-parmetis=1 --download-sowing=1 --download-triangle=1 --download-yaml=1 --with-cmake=cmake --with-debugging=1 --with-pic --with-shared-libraries=1 --with-x11=1 PETSC_ARCH=Darwin-llvm50-g
[0]PETSC ERROR: #1 ISView() line 756 in /opt/HPC/petsc/src/vec/is/is/interface/index.c
[0]PETSC ERROR: #2 DMPlexView_HDF5() line 785 in /opt/HPC/petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #3 DMView_Plex() line 812 in /opt/HPC/petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #4 main() line 61 in /Users/kumiori/Code/dmcomplex/testHDF5Plex.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 80) - process 0
[cli_0]: aborting job:
HDF5-DIAG: Error detected in HDF5 (1.8.10-patch1) MPI-process 1:
  #000: H5F.c line 2058 in H5Fclose(): decrementing file ID failed
    major: Object atom
    minor: Unable to close file
  #001: H5I.c line 1479 in H5I_dec_app_ref(): can't decrement ID ref count
    major: Object atom
    minor: Unable to decrement reference count
  #002: H5F.c line 1835 in H5F_close(): can't close file
    major: File accessability
  #003: H5F.c line 1997 in H5F_try_close(): problems closing file
  #004: H5F.c line 1142 in H5F_dest(): low level truncate failed
    minor: Write failed
  #005: H5FD.c line 1897 in H5FD_truncate(): driver truncate request failed
    major: Virtual File Layer
    minor: Can't update object
  #006: H5FDmpio.c line 1984 in H5FD_mpio_truncate(): MPI_File_set_size failed
    major: Internal error (too specific to document in detail)
    minor: Some MPI function failed
  #007: H5FDmpio.c line 1984 in H5FD_mpio_truncate(): Invalid argument, error stack:
MPI_FILE_SET_SIZE(74): Inconsistent arguments to collective routine
    minor: MPI Error String
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscError line 363 /opt/HPC/petsc/src/sys/error/err.c
[0]PETSC ERROR: [0] ISView line 750 /opt/HPC/petsc/src/vec/is/is/interface/index.c
[0]PETSC ERROR: [0] DMPlexView_HDF5 line 656 /opt/HPC/petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: [0] DMView_Plex line 803 /opt/HPC/petsc/src/dm/impls/plex/plex.c
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: #5 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 59
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
————— end output—————
—————begin C source code testHDF5plex.c ———————
/* usage: testHDF5plex -i meshfilename
#include <petscdmplex.h>
#include <petscsf.h>
#include <exodusII.h>
#include <petsc-private/dmimpl.h>     /*I      "petscdm.h"     I*/
#include <petscviewerhdf5.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
	PetscErrorCode      ierr;
	DM                  dm;
	char                ifilename[PETSC_MAX_PATH_LEN];
	PetscBool           flg;
	int                 CPU_word_size = 0,IO_word_size = 0,exoid;
	float               version;
	PetscMPIInt         numproc,rank;
	PetscViewer         hdf5Viewer;
	PetscInt            dim;
	PetscInt            numFields = 2;
	PetscInt            numComp[2] = {1,1};
	PetscInt            numDof[6] = {1, 0, 0,
	                                 0, 0, 1}; /*{Vertex, Edge, Cell} */
	PetscInt            bcFields[1] = {0}, numBC=0;
	IS                  bcPoints[1] = {NULL};
	PetscSection        section;
	MPI_Comm            comm;
	ierr = PetscInitialize(&argc, &argv, (char*)0, help);CHKERRQ(ierr);
	comm = PETSC_COMM_WORLD;
	ierr = PetscOptionsBegin(PETSC_COMM_WORLD,"","testHDF5Plex Test Options","none");CHKERRQ(ierr);
	ierr = PetscOptionsEnd();
	ierr = PetscOptionsGetString(PETSC_NULL,"-i",ifilename,sizeof ifilename,&flg);CHKERRQ(ierr);
	ierr = MPI_Comm_size(PETSC_COMM_WORLD,&numproc);
	ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
	ierr = DMPlexCreateExodusFromFile(PETSC_COMM_WORLD, ifilename, PETSC_FALSE, &dm);CHKERRQ(ierr);
	ierr = DMPlexGetDimension(dm, &dim);CHKERRQ(ierr);
	ierr = DMPlexCreateSection(dm, dim, numFields, numComp, numDof, numBC, bcFields, bcPoints, NULL, &section);CHKERRQ(ierr);
	ierr = DMSetDefaultSection(dm, section);CHKERRQ(ierr);
	ierr = PetscViewerHDF5Open(PetscObjectComm((PetscObject) dm), "out/seqDM.h5", FILE_MODE_WRITE, &hdf5Viewer); CHKERRQ(ierr);
// Crashes if numproc > 1,
	ierr = DMView_Plex(dm, hdf5Viewer); CHKERRQ(ierr);
	PetscViewerDestroy(&hdf5Viewer);
	ierr = DMDestroy(&dm);CHKERRQ(ierr);
	ierr = PetscFinalize();
	return 0;
—————end C source code testHDF5plex.c ———————
————— test mesh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140411/be343815/attachment.obj>
Andrés A. León Baldelli
LSU Center for Computation & Technology
2099 Louisiana Digital Media Center
