[petsc-dev] Web question
Wed Apr 9 12:59:46 CDT 2014
  My response was going to the same as Karl’s.
   1) it is trivial to add a check box next to each test arch
   2) actually using the check box is a different story.
   Barry
On Apr 9, 2014, at 11:05 AM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi,
> > How hard is it to make a checkbox next to each test arch so that someone can
>> indicate whether they have fixed the errors in question? The value does not
>> have to be stored long term, but should be refreshed to nothing with
>> each run.
> This depends on whether we can run scripts (e.g. PHP) on the server. Satish, is this possible?
> If we can't, there is still the option of using a (somewhat shaky) JavaScript approach, where the value of the checkbox is loaded from and stored at another server.
> Best regards,
> Karli
