[petsc-dev] PetscFinalize broken with -options_table ?
Václav Hapla vaclav.hapla at vsb.cz
Sun Apr 6 17:12:52 CDT 2014
Thank you Barry, now it works for me. Bill, thanks you helped to fix
this issue reported originally by me. I was not able to follow petsc-dev
nor to provide the stripped code for weeks because of lack of time, I
wanted to progress now, but I'm pleasantly surprised it had been
resolved already.
Vaclav
Dne 19.3.2014 13:59, William Perkins napsal(a):
> OK. That probably explains some other weirdness I was seeing, but
> could not isolate.
> Thanks.
> On 03/18/2014 09:52 PM, Barry Smith wrote:
>>    Bill,
>>      Fixed in maint and soon to be pushed to next and then master
>>       Thanks for providing a working program that exhibits the
>> problem so well. It was a rather convoluted bug. So long as you
>> either avoid the -options_left option or make sure all PETSc objects
>> are destroyed before PetscFinalize() it should not bit you until you
>> get the fix.
>>     Barry
>> On Mar 18, 2014, at 10:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>    False alarm, problem is not as general as I stated.
>>>    I can reproduce the problem in maint with your example code when
>>> -breakme is on
>>>     Problem also happens in master
>>>    Still working on it.
>>>     Barry
>>> On Mar 18, 2014, at 10:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   This looks like a problem unrelated to viewers, options, etc.
>>>>   In maint, 3.4.3 and 3.4.4 PetscFinalize() crashes if any PETSc
>>>> object (like your viewer) is not destroyed before PetscFinalize().
>>>> This does not occur in master and is not suppose to happen.
>>>>    Trying to track it down but could take a while to determine what
>>>> change broke this.
>>>>   Barry
>>>> On Mar 18, 2014, at 6:20 PM, William Perkins
>>>> <william.perkins at pnnl.gov> wrote:
>>>>> All,
>>>>> I also ran into this today.
>>>>> Attached is a minimal program that exhibited the problem for me.
>>>>> Initially, I thought it was because I was using non-default
>>>>> formats (e.g. MATLAB) for VecView and MatView, but I think any
>>>>> Viewer use causes the problem.
>>>>> Thanks.
>>>>> Bill
>>>>> P.S. I'm using 3.4.3 configured as follows:
>>>>> python ./config/configure.py \
>>>>>   PETSC_ARCH=arch-macosx-complex-opt \
>>>>>   --with-prefix="$prefix" \
>>>>>   --with-mpi=1 \
>>>>>   --with-cc=mpicc \
>>>>>   --with-fc=mpif90 \
>>>>>   --with-cxx=mpicxx \
>>>>>   --with-c++-support=1 \
>>>>>   --with-c-support=0 \
>>>>>   --with-fortran=0 \
>>>>>   --with-scalar-type=complex \
>>>>>   --with-fortran-kernels=generic \
>>>>>   --with-valgrind=0 \
>>>>>   --download-superlu_dist \
>>>>>   --download-parmetis \
>>>>>   --download-metis \
>>>>>   --download-f2cblaslapack=1 \
>>>>>   --with-clanguage=c++ \
>>>>>   --with-shared-libraries=0 \
>>>>>   --with-dynamic-loading=0 \
>>>>>   --with-x=0 \
>>>>>   --with-mpirun=mpiexec \
>>>>>   --with-mpiexec=mpiexec \
>>>>>   --with-debugging=0
>>>>> On 03/12/2014 04:30 AM, Matthew Knepley wrote:
>>>>>> On Wed, Mar 12, 2014 at 4:52 AM, Václav Hapla <vaclav.hapla at vsb.cz
>>>>>> <mailto:vaclav.hapla at vsb.cz>> wrote:
>>>>>>   You're right this is not happening with the petsc example. Thus
>>>>>> it's
>>>>>>   probably problem in my code. I'll come back when I know what's the
>>>>>>   true reason.
>>>>>> It could still be our bug. If you can strip down your code and
>>>>>> send it,
>>>>>> I will look at it.
>>>>>> Thanks,
>>>>>>     Matt
>>>>>>   Matt, sorry for replying to your personal address only.
>>>>>>   Thank you,
>>>>>>   Vaclav
>>>>>>   Dne 11.3.2014 16:04, Matthew Knepley napsal(a):
>>>>>>>   On Tue, Mar 11, 2014 at 9:27 AM, Václav Hapla
>>>>>>>       FWICS PetscFinalize in petsc-current contains the
>>>>>>> following bug.
>>>>>>>       It calls
>>>>>>>          PetscObjectRegisterDestroyAll()
>>>>>>>       and after that, if -options_table is present, it calls
>>>>>>> PetscViewerASCIIGetStdout(PETSC_COMM_WORLD,&viewer);
>>>>>>>          PetscOptionsView(viewer);
>>>>>>>       causing
>>>>>>>          [0]PETSC ERROR: No support for this operation for this
>>>>>>>       object type!
>>>>>>>          [0]PETSC ERROR: Only supports ASCII viewer!
>>>>>>>       because the viewer is destroyed already by
>>>>>>>       PetscObjectRegisterDestroyAll.
>>>>>>>       I haven't tested petsc-dev but I can see in it's the same
>>>>>>>       situation in the pinit.c source.
>>>>>>>   I cannot reproduce this on 'next':
>>>>>>>   next $:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$
>>>>>>> ./ex19
>>>>>>>   -options_table -snes_monitor
>>>>>>>   PETSC_OPTIONS="-cublas 0" ./ex19 -options_table -snes_monitor
>>>>>>>   lid velocity = 0.0625, prandtl # = 1, grashof # = 1
>>>>>>>     0 SNES Function norm 2.391552133017e-01
>>>>>>>     1 SNES Function norm 6.839858507066e-05
>>>>>>>     2 SNES Function norm 8.558777232425e-11
>>>>>>>   Number of SNES iterations = 2
>>>>>>>   #PETSc Option Table entries:
>>>>>>>   -options_table
>>>>>>>   -snes_monitor
>>>>>>>   #End of PETSc Option Table entries
>>>>>>>   Can you reproduce this with a PETSc example?
>>>>>>>     Thanks,
>>>>>>>        Matt
>>>>>>>       Best regards,
>>>>>>>       Vaclav
>>>>>>>       Vaclav Hapla
>>>>>>>       Junior researcher / PhD student
>>>>>>>       IT4Innovations <http://www.it4i.eu/> / Dept. of Applied
>>>>>>>       Mathematics <http://am.vsb.cz/>
>>>>>>>       _office PI 328_
>>>>>>>       tel.: (+420) 597 329 078 <tel:%28%2B420%29%20597%20329%20078>
>>>>>>>       Podnikatelsky inkubator VSB-TUO
>>>>>>>       Studentska 6202/17
>>>>>>>       708 00 Ostrava-Poruba
>>>>>>>       Czech Republic
>>>>>>>       _contact address_
>>>>>>>       IT4Innovations
>>>>>>>       VSB - Technical University of Ostrava
>>>>>>>       17. listopadu 15/2172
>>>>>>>       708 33 Ostrava-Poruba
>>>>>>>       Czech Republic
>>>>>>>   What most experimenters take for granted before they begin their
>>>>>>>   experiments is infinitely more interesting than any results to
>>>>>>>   which their experiments lead.
>>>>>>>   -- Norbert Wiener
>>>>>>   Vaclav Hapla
>>>>>> Mathematics
>>>>>>   <http://am.vsb.cz/>
>>>>>>   _office PI 328_
>>>>>>   Studentska 6202/17
>>>>>>   Czech Republic
>>>>>>   _contact address_
>>>>>>   IT4Innovations
>>>>>>   Czech Republic
>>>>>> experiments is infinitely more interesting than any results to which
>>>>>> -- Norbert Wiener
>>>>> Bill Perkins
>>>>> Research Engineer
>>>>> Hydrology Group
>>>>> Pacific Northwest National Laboratory
>>>>> 902 Battelle Boulevard
>>>>> P.O. Box 999, MSIN K9-36
>>>>> Richland, WA  99352 USA
>>>>> Tel:  509-372-6131
>>>>> Fax: 509-372-6089
>>>>> www.pnnl.gov
>>>>> <viewer.cpp><viewer.out>
Vaclav Hapla
IT4Innovations <http://www.it4i.eu/> / Dept. of Applied Mathematics
<http://am.vsb.cz/>
_office PI 328_
Studentska 6202/17
Czech Republic
_contact address_
IT4Innovations
Czech Republic
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/cb21dc04/attachment.html>
