[petsc-dev] Problem with generateetags.py
Fri Apr 4 10:24:48 CDT 2014
The code was was added in a few months back - and there is no reported
issue [by petsc-dev users] or in nightlybuilds since then - so this
issue must be something else.
Is it reproduceable in a clean repo?
git clean -f -d -x
I think we need the *.tex files in 'etags' file [and currently we
process the same files for ctags aswell]
Satish
On Fri, 4 Apr 2014, Barry Smith wrote:
>   Jose,
>     I’m sorry I don’t understand this bug report. I don’t see a *.tex in generateetags.py nor does it crash for me.Is it crashing in a particular directory?
>    Thanks
>     Barry
> On Apr 4, 2014, at 4:17 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> > I am getting an error when generating the tags, see error below. I have tracked the problem down to this offending commit:
> > https://bitbucket.org/petsc/petsc/commits/326299b7
> > It started to appear when the TAO users guide was placed under src.
> > A simple fix is to remove *.tex from generateetags.py
> > Do you want me to change this?
> > Jose
> > $ make alletags
> > Traceback (most recent call last):
> > File "bin/maint/generateetags.py", line 154, in <module>
> >   main(ctags)
> > File "bin/maint/generateetags.py", line 143, in main
> >   os.path.walk(os.getcwd(),processDir,[etagfile,ctagfile])
> > File "/usr/lib/python2.7/posixpath.py", line 246, in walk
> >   walk(name, func, arg)
> > File "/usr/lib/python2.7/posixpath.py", line 238, in walk
> >   func(arg, top, names)
> > File "bin/maint/generateetags.py", line 94, in processDir
> >   if newls: createTags(etagfile,ctagfile,dirname,newls)
> > File "bin/maint/generateetags.py", line 62, in createTags
> >   raise RuntimeError("Error running ctags "+output)
> > RuntimeError: Error running ctags ctags: "/home/jroman/soft/petsc/CTAGS" doesn't look like a tag file; I refuse to overwrite it.
> > make: [alletags] Error 1
